OCZ Agility 3 Schlechte SMART-Werte
hlux155
in meinem Linux-Server läuft seit etwa 1 Jahr eine Agility 3 240 GB.
Heute wollte ich die SMART-Werte der SSD auslesen und bin etwas erschrocken:
smartctl 6.0 2012-10-10 r3643 [x86_64-linux-2.6.32-5-xen-amd64] (local build)
Copyright (C) 2002-12, Bruce Allen, Christian Franke, smartmontools
=== START OF INFORMATION SECTION ===
Model Family: SandForce Driven SSDs
Device Model: OCZ-AGILITY3
Serial Number: OCZ-H29(zensiert)
LU WWN Device Id: 5 e(zensiert)
Firmware Version: 2.15
User Capacity: 240,057,409,512 bytes [240 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS, ACS-2 T13/2015-D revision 3
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Mar 3 10:32:37 2013 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x02) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 1) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 2930) seconds.
capabilities: (0x7f) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Abort Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 48) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x0021) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 095 095 050 Pre-fail Always - 0/188674427
5 Retired_Block_Count 0x0033 100 100 003 Pre-fail Always - 0
9 Power_On_Hours_and_Msec 0x0032 090 090 000 Old_age Always - 8841h+53m+25.790s
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 19
171 Program_Fail_Count 0x0032 000 000 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 000 000 000 Old_age Always - 0
174 Unexpect_Power_Loss_Ct 0x0030 000 000 000 Old_age Offline - 8
177 Wear_Range_Delta 0x0000 000 000 000 Old_age Offline - 18
181 Program_Fail_Count 0x0032 000 000 000 Old_age Always - 0
182 Erase_Fail_Count 0x0032 000 000 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 030 030 000 Old_age Always - 30 (Min/Max 30/30)
195 ECC_Uncorr_Error_Count 0x001c 120 120 000 Old_age Offline - 0/188674427
196 Reallocated_Event_Count 0x0033 100 100 003 Pre-fail Always - 0
201 Unc_Soft_Read_Err_Rate 0x001c 120 120 000 Old_age Offline - 0/188674427
204 Soft_ECC_Correct_Rate 0x001c 120 120 000 Old_age Offline - 0/188674427
230 Life_Curve_Status 0x0013 100 100 000 Pre-fail Always - 100
231 SSD_Life_Left 0x0013 088 088 010 Pre-fail Always - 0
233 SandForce_Internal 0x0000 000 000 000 Old_age Offline - 115231
234 SandForce_Internal 0x0032 000 000 000 Old_age Always - 320848
241 Lifetime_Writes_GiB 0x0032 000 000 000 Old_age Always - 320848
242 Lifetime_Reads_GiB 0x0032 000 000 000 Old_age Always - 7371
SMART Error Log not supported
SMART Self-test Log not supported
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Sind diese Werte tatsächlich so schlimm?
Du hast eine veraltete Version der smartmontools benutzt (5.4 von Juli 2010).
Hups, Linux voll übersehen, nimm eine aktuelle Version der smartmontools, 6.0.1 ist aktuell.
Danke, ich habe jetzt neue Ergebnisse hochgeladen (Version 6.0, die 6.0.1 scheint es nur für Windows zu geben). Jetzt sehen die Werte schon realistischer aus... Muss ich mir trotzdem Sorgen um die SSD machen?
Auffällig ist hier nur die hohe Schreibrate gegenüber der geringen Leserate, sind die 320.848 GiB (871 Gib/24 h) realistisch?
Wear Range Delta: 18, ein zu hoher Wert, die Verschleißregulierung arbeitet schlecht.
(18 ist der Durchschnitt zwischen den am meisten und am wenigsten verschlißenen Blöcken, je niedriger dieser Wert desto Besser arbeitet die Verschleißregulierung)
SSD Life left: 88 %, ein durch Herstellervorgaben errechneter theoretischer Wert.
Lifetime Writes: 320.848 GiB, ID-233: Writes after Compression: 115.231 GiB.
Die Vertex3 sollte 900 bis 1200 TiB Schreibleistung vertragen, sofern nicht der Sandforce Controller vorher sein Leben aushaucht, das läßt sich aber natürlich nicht Vorhersagen/Vorhersehen.
Ich gehe davon aus, das es in diesem Umfeld (Speicher Server?) wohl eine vernünftige Redundanz- und Backup-Lösung gibt.
Wo ist das Problem? Das sieht alles normal aus. Die Daten waren sogar sehr gut komprimierbar, die WA liegt nur bei 0,36 und damit sehe ich zum ersten mal reale S.M.A.R.T. Werte, die das Versprechen von Sandforce einhalten, dass die WA unter 0.5 liegen würde. Das scheint eben nur bei Serveranwendungen zu funktionieren, denn auch Desktopnrechnert sehe ich i.d.R. werden um 0.8.
Was hast Du da genau drauf? Eine Oracledatenbank oder nur deren ReDo Log?
