[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
Das sind so viele Dinge die ich ned ganz blicke, mein englisch ist leider schlecht deshalb fang ich mit den meisten Bezeichnugen nur wenig an und auch das Handbuch hilft hier nicht.
Frage: Was zeigt euer Board im laufenden betrieb auf dem Display an?
Bei mir steht immer b1 : Save System context for ACPI
Dazu piepst die Kiste 2 mal kurz beim einschalten.
Passt da was nicht? oder soll das so sein?
Greetz Rocco
Kann jenamd seine OC Einstellungen posten. Hab jetzt das Mainboard erhalten,
und meinen PII 940 X4 schon auf default am laufen.
Normal bin ich je der Tüfftler und es macht auch freunde runzubasteln.
Jedoch habe ich in den nächsten Wochen kaum Zeit :(
Greetz Rocco
Genau wie bei mir auch, allet jut wa ;)
? ich chek das BIOS ganz und gar nicht.
Bei meinem alten DFI LP UT-n4D kenn ich jede Option, aber bei dem
J&W ist alles anders.
Hat jemand screenshots oder eine Anleitung zum OC´s dieses Boards
Sehr schön, das Freut mich zu hören, mein Bios is bis jetzt noch alles auf AUTO, nur die Rams hab ich eingestellt weil die nur als ddr 800 erkannt wurden.
Wenn ich mal Zeit hab werd ich ma schaun was geht.
Temps vom 940 sind traumhaft hingegen meinem 6400+BE.
Immer sowas um die 26-30 Grad im Idle. Last noch keine Ahnung, der musste so gut wie noch nichts arbeiten. (No Time)
Greetz Rocco.
Total easy:
Nimm diese Liste an Hexa-Codes, dann trägst du im "normalen" Bios deine 1,4xx V Spannung ein, und im "checkichnichtbios" deine Hexa.
normal: wo man alles einstellen kann außer den Multi.
checkich net: Das mit den Hexa-Codes.
MfG
@octa danke erstmal
für was steht NB (NB VID, NB FID)
und was sagt der Wert CPU FID 18=20 4000Mhz aus
Hier gibts noch Mainboards KLICK
NB FID dürfte der Multi für die Northbridge sein. NB VID dann halt die Spannung für die Northbridge.
CPU FID sollte sich jetzt von selbst klären.
wieso sind bei mir die ganzen CPU Einstellungen (CPU VID, CPU FID,...)ausgegraut.???
Muss ich einen Jumper umsetzten um die zu aktivieren?
Die Patriot Viper Ram passen uns Haar.
<a href="http://www.bilder-hochladen.net/files/3g78-1p-jpg-nb.html"><img src="http://www.bilder-hochladen.net/files/3g78-1p.jpg" alt="Bilder Upload"></a>
CPU Kühler ist ein Mugen 2, Bilder folgen
Mal den JHDT Jumper übern ersten PCIe Slot umgesteckt?
Hab selbst nurn 3800+ drauf.. also weiß ich net so Recht worans liegt.
@marsman am OS vieleicht? Angeblich voll ab Vista nicht mehr so viel drinn sein
Was hat das Betriebssystem mit den Bios-Optionen zutun?
Oder mit was gehst du da ran :confused:
ne,
das ist es nicht!
Und was du auf ebay gefunden hast, ist nichts anderes als jwele.de!
Und meiner Gruppe beitreten bitte ;)
Sind sie ebenfalls nicht...bloss auf Standard oder eben "noch" nicht erkannt.
von euch hat nicht zufällig jemand die Möglichkeit zu testen ob auf dem Board bei einem X3 720 sich der vierte Kern freischalten lässt?
Die Boards wo es definitv geht gefallen mir nicht so wirklich und ich hätte passende CPU hier schon liegen :)
Greetz
@octa danke erstmal
Ist das denn so schwer?! Steht doch in der Tabelle...
VID ist die Voltage und FID der Multi
Auf der linken Seite sind die Settings in "Bios Sprache" und auf der rechten Seite verständlich...
Wie schon oben steht, FID ist der Multi, im Bios stellst du zb. bei CPU FID18 ein und in Windows unter cpuz zeigt er dir dann einen Multi von x20 an.
Da der Reftakt von einem Deneb940 bei 200 liegt ergibt sich folgendes, CPU FID18/20x200=4000MHz CPU Takt.
Oh backe.... wie wär es mal wenn du mit den Pfeiltasten einfach nach unten gehst?! Das oben graue sind die Aktuellen Settings und unten kannst du dann deine eigenen Eingeben mit +/-
Greetz
Schick her ich guck nach...
@fusi: lies dich nochmal durch den Thread, hier steht schon alles drin was wichtig ist...
so danke erstmal, hab mir die halbe Nacht um die Ohren geschlagen.
Jetzt hab ich es so einigermassen gecheckt.
Jedoch bekomm ich nicht mehr wie 3,6Ghz stable hin.
Na, da geht noch mehr ;)
Was hast du wo im Bios eingestellt?
€: ich hab die neuste Beta Version, die bringt ein paar Erneuerungen mit sich aber ich hab noch keine Ahnung für was das gut sein soll. Bestimmt so eine art ACC
Kann mir einer sagen wo zu das gut ist?
Das es für den Sideportmemory ist, ist klar aber was kann ich mit den Einstellungen festlegen bzw. was genau verändert sich da durch?
Greetz
Schau mal hier
http://www.jwele.com/bbs/viewtopic.php?f=6&t=98&sid=bf5fd7b500d3a379e9caafb45deb8da1
Vielleicht eine Art Emulation? :hmm:
Ja, wenn die selbe CPU auf einem DFI unlockbar ist. Wäre wünschenswert, wenn J&W da BIOS-mäßig noch nachbessert, aber bezweifeln tue ich's.
Hey..
woher bekommt man die?!
Was hast du denen geschrieben, dass du einfach "Post" bekommst?!
@4th Floor: bin genau so schlau wie vorher :d
@octa: ich schreib da nicht hin, sondern bekomme die so zu geschickt. Selbstverständlich auf eigenes Risiko ;)
Nicht mit der neuen Beta :fresse:
Aber das du nicht über 3,47GHz kommst würde ich nicht dem Bios zuschreiben...
Am Prozi sollte es auch nicht liegen ;)
Die miesesten 940er Denebs machen auf jeden Fall zwischen 3,6GHz und 3,8GHz@1,488v.
Er hat doch noch nen Agena....Dafür finde ich 3,47GHz doch recht gut.
Hoffe mein Prozzi (940BE von monteboy) kommt heute, hab evtl. noch die Möglichkeit den mit einem EKL Brocken zu testen, aber im Endeffekt kommt er unter Wasser, ich hoffe mal die Temps sind mit dem kleinen Dual Radi und einer 88GTX im Kreislauf immer noch besser als mit Lukü.
bestimmt gut!
@octa: SORRY mein Fehler, dachte du hast nen Deneb :fresse:
3,47GHz für nen Agena ist wirklich super :bigok:
