[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
den beitrag hab ich schon gelesen nur meine frage war ob bei aktivierten c&q die K10NB spannung herabgesetzt wird oder wird sie nicht von c&q beeinflusst
bei post 515 beziehst du dich ja auf die höhe der spannung nicht ob c&q einfluss auf die K10NB spannung hat
hast du das Board? Oder ein ähnliches GX?
nein leider hab ich das board noch nicht hoffe das ich es nächste woche in händen halten kann
ein anderes gx board hab ich auch nicht hab nur ein 780g board
Ich würd' mich eher auf übernächste Woche einstellen. Nächste Woche soll ein Flieger mit Boards zum Distibutor nach Holland gehen. Ende nächster Woche oder Anfang übernächster Woche wird dann die Lieferung bei jwele.de erwartet. Und der muss die ja dann auch erstmal rausschicken...
Gruß Rippraff
Moin, mir gefällt das Mainboard auch sehr gut!
Kann ich im Bios bei einer BlackEdition auch einfach den Multiplikator abändern? Genug OC Potenzial bietet das Mainboard schließlich.
Worin sind jedoch die Vorteile gegenüber dem:
DFI LANparty DK 790GX-M2RS
Gigabyte GA-MA790GP-UD4H
ASUS M3A78-T
Möchte gerne zwei 4870 verbauen sowie einen Phenom X4 940. Und dann bisschen Ocen in Richtung 3,6 Ghz.
Was meint ihr?
TK
@eXtremeTK
Multi lässt sich einstellen, aber mit dem aktuellen BIOS halt nicht ganz so komfortabel wie bei anderen Boards, da du dafür dein Gehirn einschalten und den Multi in eine Hexadezimalzahl umrechnen musst. 3.6GHz beim 940BE sind wohl ein Witz, das schaffst auch auf den grottigsten nForce und SB600 Boards, möchte ich meinen.
Warum ich mich für das J&W entschieden habe:
- Exotenstatus
- bestes Design
- moderater Preis
beim DFI:
- angebliche RAID Probleme
- angebliche Temperaturprobleme des Chipsatzes
- kein eSata
das Gigabyte:
- grottenhässlich
- viel zu teuer fürn Gigabyte
- kein eSata
das Asus:
- hat irgendwie jeder, abgesehen davon sehr nett
- angebliches Elko-Fiepen bei hoher Last (siehe Geizhals Bewertung)
Ich denke mal von der OC-Ability nehmen sich alle 4 nicht viel.
@Rippraff
Danke für die Information. Warte auch schon seit 2 Wochen.
Was mir beim J&W sorgen macht ist die nicht funktionierende Lüftersteuerung. Wie kann ich dann meine Lüfter regeln lassen? Soll mir beim spielen ja nicht abrauchen!
Von der Kühlung ist das J&W vorne dabei oder? Nicht das wie beim MSI die Spawas mal durchbrennen :(
Unterstützt das Mainboard Crossfire 16x/16x oder nur 16x/8x
J&W ist nicht Jetway :fresse:
Hey ihr Übertakter
Ich habs mittlerweile hinbekommen meinen Speicher auf die vom Hersteller vorgesehenen Timings von 4-4-4-12 DDR2 800 einzustellen. Der Rechner bootet auch ganz normal und CPU-Z erkennt alles. Wenn ich den Rechner aber vom Strom trenne (steckt bei mir in einer Steckerleiste die ich nachts ausschalte) und am nächsten Tag wieder anschalten will, dann laufen die Lüfter an, aber sonst macht der GAR NIX. Soll heißen, der Grafikkartenlüfter, der immer kurz mit Fullspeed anläuft aber dann sofort heruntergeregelt wird (bei einem normalen Start) bleibt im Fullspeed-Modus. Ich habe KEIN bild, ich kann NICHT mal ins Bios. Was ich dann mache ist das BIOS mithilfe der Jumper wieder zurückzusetzen. Dann startet der Rechner wieder normal, mit Bild und allem. Wenn ich dann wieder im BIOS die schärferen Timings einstelle, dann startet der Rechner immer noch normal. Nur wenn ich den PC wieder komplett vom Strom trenne tut sich wieder gar nichts mehr.
Wenn ich die Standardeinstellungen für den Speicher lasse fährt der Rechner auch hoch wenn ich ihn mal vom Strom getrennt habe.
Achja die Spannungen vom Speicher hab ich variiert bis 2.0V, das Problem tritt immer auf.
Wäre froh wenn einer ne Idee hat, worans liegen könnte. Vielleicht sollte ich mal die anderen Ram-Bänke ausprobieren, verwende im Moment die roten.
grüße bl3xX
Den Bug gab es damals beim Abit AW9D MAX auch, wurde irgendwann mit nem BIOS Update behoben.
Auf XS sagt man. das für 790 eine extra SPD her muß um RAM´s vernünftig hoch zu takten/bzw mit niedrigeren timings zu fahren.
Achja, ich messe heute aus! :)
EDIT///Großclockner: Passt meines erachtens nur bedingt, da (wie schon bei meinem (L) 128 x (B) 85 x (H) 165 mm) die Breite einen Ramplatz überlagert, also wird es bei diesem
Probs geben!
Brocken: Gleiches Problem!
Fazit: Am besten bestellen und testen!
MfG OCta
Probs geben!
MfG OCta
octa, du bist echt toll! Danke dir :)
ps: weiss jmd eig wann jwele.de wieder welche auf vorrat hat?
Das ACC haben nicht alle Boards.
Jo die Frage ist noch gut. Haben des alle 790GX Boards? MSI hat doch kein ACC? Oder?
http://geizhals.at/a365735.html
Kein ACC MSI KOD790GX
Ich hatte das auch schon in nem Review gelesen. Aber habe hier gerade nen Fred gefunden, der das Gegenteil bestätigt.
http://www.computerbase.de/forum/showpost.php?p=5175327&postcount=7
Hier ein anderer Bericht...
"Nie wieder MSI KA790GX" (1 Antwort)
Review: http://technik-ostfriese.com/technik-ostfriese/cemsika790gx.php
Ich hatte das Mainboard 3 Monate in Betrieb und von Zeit zu Zeit abstürtze. Es ist kein ACC möglich! Deutscher Support ist schlecht informiert. Viele Besitzer haben ähnliche Probleme. Board wieder umgetauscht.
Aber ob des stimmt, kann ich nicht sagen. Manchmal steht ausdrücklich "kein ACC" und manchmal das Gegenteil.
Lol, hab beim Suchen grad gesehen, dass es ne MSI 790GX -M mit 1 GB DDR3 1333 Sideportmemory gibt.
http://global.msi.com.tw/index.php?func=proddesc&prod_no=1616&maincat_no=1&cat2_no=171&cat3_no=537
das mit dem tripel als quad geht glaub nur mit nem ami bios. was für eins hat das j&w?
Hallo Leute..habe mir das Board grade gekauft..wie lange musstet ihr so darauf warten?..
Was könnt ihr mir so zum OC(24/7) des PhII sagen? was geht da so(wenn es gut läuft?)
Also ich bin zwar nicht der Threadersteller, aber ich hab nen Mugen 2 auf diesem Board! Passt einwandfrei.
Den hat glaub ich der Threadersteller, ja!
Ne, hab nen Nexxos XP drauf :shot:
Ich hab anfang Januar ca. ne Woche drauf gewartet, als 24/7 Setting lass ich den PII auf 3.4Ghz und C&Q laufen, mehr Takt brauche zz. nicht. Mit dem Board geht alles, kommt nur auf die CPU an. Die Spannung bleibt jedenfalls unter last sehr stabil, hab ich so noch bei keinem Board vorher gehabt.
Tja,
ich habe so einen Dreck erwischt :)
Nja,
was brauch ich mehr,
ehrlich gesagt hatte ich NIE vor über 3,1 zu kommen
->Signatur!
