[Sammelthread] Gigabyte (GA-) X79-UD3 / UD5 (Intel X79)
GA - X79 - UD3
GA - X79 - UD5
Inhalt
  1. Features
  2. Bilder
  3. FAQ
  4. Downloads
  5. Links
Features
1. Features
X79-UD3X79-UD5
Form FactorATX Form Factor; 30.5cm x 24.4cmE-ATX Form Factor; 30.5cm x 26.4cm
ProzessorSupport for Intel® Core™ i7 processors in the LGA2011 packageSupport for Intel® Core™ i7 processors in the LGA2011 package
ChipsatzIntel® X79 Express ChipsetIntel® X79 Express Chipset
Arbeitsspeicher
  • 4 x 1.5V DDR3 DIMM sockets
  • supporting up to 32 GB of system memory
  • quad channel memory architecture
  • Support for DDR3 2133/1866/1600/1333/1066 MHz memory modules
  • Support for non-ECC memory modules
  • Support for Extreme Memory Profile (XMP) memory modules
  • 8 x 1.5V DDR3 DIMM sockets
  • supporting up to 64 GB of system memory
Audio
  • Realtek ALC898 codec
  • High Definition Audio
  • 2/4/5.1/7.1-channel
  • Support for Dolby® Home Theater
  • Support for S/PDIF Out
LAN1 x Intel GbE LAN (10/100/1000 Mbit)
  • 1 x Intel GbE LAN (10/100/1000 Mbit)
  • Bluetooth 4.0 und WiFi Karte 150 Mbps Transferraten, unterstützt 802.11n
Erweiterungssteckplätze
  • 2 x PCI Express x16 slots, running at x16 (PCIEX16_1/PCIEX16_2)
  • 2 x PCI Express x16 slot, running at x8 (PCIEX8_1, PCIEX8_2) (All PCI Express x16 slots conform to PCI Express 3.0 standard.)
  • 2 x PCI Express x1 slots (All PCI Express x1 slots conform to PCI Express 2.0 standard)
  • 1 x PCI slot
  • Support for 4-Way/3-Way/2-Way AMD CrossFireX™/NVIDIA SLI technology (The PCIEX16 slots operate at up to x8 mode when 4-Way/3-Way AMD CrossFireX™/NVIDIA SLI is enabled.)
  • 1 x PCI Express x16 slot, running at x8 (PCIEX8) (All PCI Express x16 slots conform to PCI Express 3.0 standard.)
  • 1 x PCI slot
  • Support for 3-Way/2-Way AMD CrossFireX™ / NVIDIA SLI technology (The PCIEX16_1/PCIEX16_2 slots operate at up to x8 mode when 3-Way AMD CrossFireX™/NVIDIA SLI is enabled.)
SATAChipset:
  • 2 x SATA 6Gb/s connectors (SATA3 0/SATA3 1) supporting up to 2 SATA 6Gb/s devices
  • 4 x SATA 3Gb/s connectors (SATA2 2~SATA2 5) supporting up to 4 SATA 3Gb/s devices
  • Support for RAID 0, RAID 1, RAID 5, and RAID 10
3 x Marvell 88SE9172 chips:
  • 4 x SATA 6Gb/s connectors (GSATA3 6~GSATA3 9) supporting up to 4 SATA 6Gb/s devices
  • 2 x eSATA 6Gb/s connectors on the back panel, supporting up to 2 SATA 6Gb/s devices
  • Support for SATA RAID 0 and RAID 1
Chipset:
  • 2 x eSATA 6Gb/s connectors (including 1 eSATA/USB Combo) on the back panel supporting up to 2 SATA 6Gb/s devices
USBChipset:
  • Up to 14 USB 2.0/1.1 ports (8 ports on the back panel, 6 ports available through the internal USB headers)
2 x Fresco FL1009 chips:
  • Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB headers)
Chipset:
  • Up to 14 USB 2.0/1.1 ports (8 ports on the back panel, including 1 eSATA/USB Combo, 6 ports available through the internal USB headers)
IEEE 1394VIA VT6308 chip:
  • Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
Interne I/O Anschlüsse
  • 1 x 24-pin ATX main power connector
  • 1 x 8-pin ATX 12V power connector
  • 6 x SATA 6Gb/s connectors
  • 1 x CPU fan header
  • 4 x system fan headers
  • 1 x front panel header
  • 1 x front panel audio header
  • 1 x S/PDIF Out header
  • 3 x USB 2.0/1.1 headers
  • 1 x USB 3.0/2.0 header
  • 1 x serial port header
  • 1 x Clear CMOS jumper
  • 1 x Trusted Platform Module (TPM) header
  • 1 x IEEE 1394a header
Rear Panel I/O
  • 1 x PS/2 keyboard/mouse port
  • 1 x optical S/PDIF Out connector
  • 1 x coaxial S/PDIF Out connector
  • 8 x USB 2.0/1.1 ports
  • 2 x USB 3.0/2.0 ports
  • 1 x RJ-45 port
  • 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
  • 1 x CPU overclocking button
  • 1 x BIOS switch button
  • 1 x Clear CMOS button
  • 1 x IEEE 1394 port
  • 7 x USB 2.0/1.1 ports
  • 1 x eSATA/USB Combo connector
  • 1 x eSATA 6Gb/s connector
  • 1 x RJ-45 port
  • 5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
Bilder
2. Bilder
FAQ
3. FAQ
  1. Es gab Probleme bei dem Mainboard mit den Spannungswandlern (News), welches dazu führte, dass diese sich in Rauch auflösen. Die BIOS Versionen F7 und höher beheben dieses Problem. Wer ein älteres BIOS hat, sollte dieses umgehend auf eine neue Version flashen.
  2. Wer Probleme mit dem Sound unter Windows 8 hat, der sollte sein BIOS aktualisieren. Es gibt eine Betaversion, die diese Probleme behebt.
  3. Mit einer neuen Grafikkarte fährt unter Umständen der PC nicht mehr hoch. In diesem Fall muss im BIOS bei Slot Configurations die "PCI ROM Priority" auf "Legacy ROM" umgestellt werden.
  4. Das UD5 hat teilweise Probleme mit aktuellen Grafikkarten (Stand 2020). Für diese gibt es das (inoffizielle) BIOS F14e. Eine Anleitung von gogoAustria dazu ist hier zu finden.
Downloads
4. Downloads
UD3:
BIOS
Treiber
UD5:
BIOS
Treiber
Für beide Mainboards können auch aktuelle BIOS-Versionen über JZelectronic bezogen werden.
Links
5. Links
UD3:
Reviews/Tests:
Preview: Gigabyte GA-X79-UD3
Gigabyte Produktseite
Geizhals
UD5:
Reviews/Tests:
Gigabyte GA-X79-UD5 : Das ultimative X79-Board? Fünf LGA-2011-Motherboards im Test
Gigabyte GA-X79-UD5 Intel LGA 2011 Review - Page 1/13 | techPowerUp
Tech-Review.de » Artikel » Reviews » Asus P9X79-Pro und Gigabyte X79-UD5 im Test
Geizhals
so, heute noch mal getestet und schwubs war ich bei Euren Bootzeiten, aber nur einmal. siehe Video.
Danach hatte ich Übertaktet und er brauchte 1,30 Min. und die Einstellungen vom Video konnte ich nicht noch einmal hin bekommen. Ich verstehe es nicht, aber ich arbeite dran und teste noch weiter. Es ist schon richtig, dass die Bootzeit nur Primär eine Rolle spielt, aber ich möchte gerne begreifen, verstehen und lernen.
Bei mir wirds auch immer besser, baue ich eine zusätzliche Renesa USB3-Karte in einen PCIe-Slot: Dann kann ich nicht mehr von USB3 Booten, wird zum Systemstart nicht mehr erkannt/benutzt, erst im Windows wieder :-(
dann sollte mann das hiermit mal JZ melden
hmm das ist schon komisch bei dir wenn du taktest.
Du hast nur den Multi verstellt?
nimm bitte mal ein andere Graka nur zum Test
ja mein dich sorry teste das bitte mal. wenn ich richtig genau stoppe komme ich sogar unter 20 Sekunden.
getaktet habe ich aber nur über den Multi.
so andere GarKa rein und ich konnte auch die Einstellungen wieder reaktivieren, wie auch immer.
Power - bis zum BIOS Info = 15 sec.
weiter bis zum Windowsladeschirm = 21 sec.
auf dem Windows Desktop = 40 sec.
aber alles ohne zu Übertakten
nun teste ich noch mal mit diesen Einstellungen und der Karte und OC
War jetzt genau 21 Sekunden bis zum Windows lade Bild. Sieht doch schon mal gut aus.
Gesendet von meinem HTC Desire HD A9191 mit der Hardwareluxx App
ja, 21 sec. bis zum Windowsladeschirm
Und jetzt noch mit OC alles auf Auto, mit aber nur 4,3GHz, weil er sonst nicht stabil läuft. = 52 sec. bis zum Windowsladeschirm
Edit: und immer für eine Minute Netzteil aus, dann 30 sec. vor dem Start angeschaltet.
Edit 2 mit festen Spannungen sind es bis zum Windowsladeschirm 38 sec.
Ok du hast nur den Multi hoch gesetzt ?
ja, nur den Multi, ich weiß ja das ich mit dem BLCK längere Bootzeit habe.
wieder die GTX 580 drin
20 sec. bis zum BIOS Infos
30 sec. bis zum Windowsladebildschirm
hmm ok ist komisch irgendwas bremst kann die tasta sein oder und die Graka .
Ich weiss nicht mehr weiter, komisch ist es schon.
Aber sei froh, gibt Asus X79 Bretter die Booten 1 Min.
Du kannst nur hoffen das es bald ein BIOS Update richtet oder ein firmeware für den USB 3 Controller.
Ich werde aber auch mal am Ball bleiben mit der Bootzeit.
ich hatte ja nun schon andere GraKa und auch schon andere Tastatur + mouse dran, ohne Änderung, ich bin ja nun mit dem Boot unter 1 min. und das ist schon okay,ich experimentiere weiter...
Ok. Ich werde auch mal testen hatte bis jetzt keine Zeit. Ich denke mal wird noch viel passieren zwecks BIOS. Gibt noch USB Probleme , leider. Die sollen mal hin machen in Taiwan.
Geht sie hinten ?
Denn Treiber hast du drauf ?
Bei mir läuft nur einer der Frontanschlüsse mit USB 3.0 Geschwindigkeit. Allerdings kann ich ein Defekt des Kabels nicht ausschließen.
Mal umstecken am Board
Wo ist denn der zweite USB 3.0 Header auf dem Mainboard?
Keine Ahnung hab kein frontUSB 3.0 sind die nicht beide 3.0
Hinten läuft die externe USB 3, stecke ich sie am Adapter für das Frontpannel geht sie auch nicht, aber USB 2 Geräte gehen sowie am Frontpannel als auch am Adapter. Nun habe ich das Frontpannel mal hinten angeschlossen dann wird die USB 3 Platte auch am Frontpannel erkannt. Also liegt es bei mir am Adapter (intern USB 3.0 zu extern USB 3.0)
ich habe auch den Aktuellen Treiber von hier klick mich, der ist neuer als der von der Gigabyte-Page
das kabel hattest du aber aber auch mal ab beim Booten?
Nicht das das bremst
ich hatte es aber schon ab gemacht, so wie alle Kabel die zu Frontpannel etc. führen, hatte nichts geändert. das hatte ich also auch getestet...
Ich habe jetzt schon den neusten Treiber drauf, aber trotzdem wird mir einer der USB 3.0 Controller mit einem Code 10 Fehler im Gerätemanager angezeigt. Der läuft damit nur im Highspeed-Modus.
Schreib es mal direkt ios gb Forum mit dem USB 3 Problem. Kann es sein das sich zu Zeit nichts tut mit dem BIOS weil z77 raus ist. Die Probleme mit dem Mäusen im BIOS sind immer noch. Das Board ist jetzt schon lange genug draußen. Schade eigentlich von gb
also irgendwie ist di usb geschichte schon merkwürdig
ich wollte heute meinen rechner mal nach über einen monat neustarten, da ich nen prob mit nem lizenzdienst hatte der nicht mehr richtig wollte
alles kein problem soweit
aber beim booten kam ich bis zum loadscreen und nicht weiter, nichmal ins uefi
irgendwie hat der nicht weiter inistialisiert und usb2 war auch tod (an den 2er ports hab ich alles dranhängen)
zum glück hatte ich noch ne ps2 tastatur um erstmal wieder ins windows reinzukommen (mit allen usb geräten abgezogen gings nämlich mitm booten)
erstmal bios von f8 auf f10 gebracht (ich bin halt einer der biosupdates nach "never change a running system" macht), bracht nur bedingt besserung
usb2 wurde richtig initialisiert, aber sobald der win screen für die passwort eingabe kam waren schonwieder alle usb2 ports tod (usb3 hab ich garnicht getestet)
schlussendlich hab ichs dann mit rumprobieren und rechner nen bischen demontieren (2. graka hat die interen usb2 anschlüsse überdeckt, so das ich die nicht rausziehen konnte und die graka ist an ort und stelle leicht verbaut^^)
problem war wohl auf einem meine dvb-s2 usbbox, sobald ich die weglasse funktionierts einwandfrei (da die ne eigene stromversorgung hat vermute ich das es daran liegt, da ich immermal probs hab mit usb geräten mit eigener stromversorgung)
wieso das erst jetzt auftrat und nicht vor nem monat versteh ich zwar nicht, aber versuchen solche fehler zu verstehen hab ich irgendwann bei nem nforce chipsatz aufgegeben^^
Nach dem Neustart gerade läuft jetzt alles richtig :confused:
Aber Du weißt schon das kein Trim an der Samsung ankommt wenn der RST installiert ist?
