hier is echt lustig,ging um das neue Zenith BIOS aber lest einfach mal selbst:
Dear Sir:
This is indeed a confirmed issue, you will need to re-install your OS after using this update.
Yours sincerely,
Chaintech Technical Support
Chaintech Europe
Coenecoop 620
2741 PV WADDINXVEEN
THE NETHERLANDS
( Phone: +31-(0)182-623960
( Fax: +31-(0)182-623969
* E-mail: support@chaintech.nl <mailto:support@chaintech.nl>
: Web: <http://www.chaintech.dk/>
-----Original Message-----
Sent: Saturday, March 08, 2003 6:10 PM
To: support@chaintech.nl
Subject: Technical Support Request Form
Technical Support Request Form Last Name xxxxx
Date 2003/3/9
Location Germany
Telephone No
FAX No
Main Board Model 7njs Zenith
Product Serial Number xxxxxxxxxxxxxxxxx
Distributor / Retailer Avitos GMBH
Problem Description Hi I only wanted to tell you that your latest bios causes problems with the loading of the OS. With the first BIOS i Had no problems but after flashing of the latest nothing worked anymore. My only way to sulute this problem was to flash the old BIOS and to reinstall WIN XP. I plead you to check your testboards. With best regards(in hope you understood my english) xxxxx
BIOS Date 2002/11/18 ->2003/2/24
CD Version
Operating System Win XP
CPU Type
VGA Type
Memory Modules
Other Devices
Dear Sir:
Yours sincerely,
Chaintech Europe
Coenecoop 620
2741 PV WADDINXVEEN
THE NETHERLANDS
Date 2003/3/9
Location Germany
Telephone No
FAX No
CD Version
CPU Type
VGA Type
Memory Modules
Other Devices
