Catalyst 8.1 Final ist draußen.
seb74
Semiprofi
Niederrhein
Hier der Link für XP32:
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
Und die 8.1 Releasenotes:
http://game.amd.com/us-en/content/pdf/Catalyst_81.pdf
Posts zu Benchmarks, Bugs sowie auch gefixten Bugs sind willkommen..
den 8.1 HotFix gibt es auch schon:
http://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=31625
New Features:
MultiView™
Catalyst 8.1 introduces MultiView™ support. This feature provides for hardware accelerated OpenGL rendering across multiple graphics adapters. MultiView™ will provide hardware accelerated 3D rendering in a system containing multiple graphics cards on an extended desktop arrangement. This feature will allow for the rendering performance and additional frame buffer resources to be evenly shared with the second and third graphics adapters. This allows for a 3D applica- tion to have the same performance running on a secondary or third display device as if it were running on the primary display device. This feature will be supported under Windows XP (32 and 64 bit versions), Windows Vista (32 and 64 bit ver- sions), and the Linux operating system.
ATI’s Folding@Home
Folding@Home is a distributed computing project designed by the Stanford Uni- versity. The application performs intensive simulations of protein folding. This simulation will help researchers uncover how certain diseases develop. Fold- ing@Home uses distributed computing to simulate protein folding, the workload is broken up into small work units and distributed across hundreds of thousands of computers over the internet. You can help find the cure to many different diseases!
GUTEN MORGEN! :d
nichts für ungut, aber der ist schon seit gestern in aller munde :drool:
so long
wie ist das eigentlich mit dem Hotfix! Ist das ein selbstständiger Treiber oder muss ich erst das 8.1. Treiberpacket installieren?
Gruss
Silti
Von der grundsätzlichen funktion und dem installationsvorgang her gesehen ist 8.1 um grössenordnungen besser als 7.12. Muss sich nun noch zeigen obs in spielen auch so ist.
Irgendwie aber nicht in diesem Forum, habe keinen anderen Cat8.1 Thread
entdecken können und es geht nicht jeder täglich auf ati.de um zu prüfen, ob vllt ein neuer Cat raus ist. Nehme an, daß so mancher durch diesen Thread auf den 8.1 aufmerksam gemacht wird.
Es gibt den Treiber Thread da ist der Treiber bereits erwähnt!
Also bitte..
Froggi :wink:
