[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
ja wan isn nu das neuste d16 oder p15?
Da ja das Mars kein Dualbios hat, kann bei einem BIOS-Update mit Stromausfall, fehlerhaftem BIOS, fehlerhaftem Datenträger, etc... alles vorbei sein:
Der Foxconn Support empfiehlt die DOS- Methode mit folgenden Parametern:
A:\awdflash 752f1p15.bin /py/sn/cc/cd/cp/wb
Die Kommandos bedeuten:
/py: Programmiere den Flashbaustein
/sn: "Save No" bzw das Abschalten der Aufforderung zum Abpeichern eines Abbilds des alten Bios
/cc: lösche CMOS nach dem Programmieren
/cd: lösche DMI nach dem Programmieren
/cp: lösche PNP (ESCD) nach dem Programmieren
/wb: Mitflashen des Bootblocks
Und genau der Befehl /wb sorgt auch dafür, dass alles schief gehen kann.
Wird der Bootblock beim Flashen jedoch übersprungen, kann nichts passieren. Befindet sich zum Beispiel ein zerschossenes BIOS auf dem Mainboard, kann man mit einem intakten Bootblock sein Diskettenlaufwerk weiterhin booten und den Flashvorgang wiederholen.
Auf er sicheren Seite ist man mit folgender Befehlszeile:
awdflash 752f1p15.bin /sn/sb/py/cc/cd/cp
/wb: (habe ich weggelassen)
/sb: Überspringe Bootblock
Denn Bootblock flashe ich nicht mehr mit! Es sei denn ein Hinweis mit dem neuen BIOS sagt mir, dass er einer Aktualisierung bedarf.
Hier mal eine Anleitung zum sicheren Flashen in DOS (Bsp.: P15, Diskette):
  1. Die BIOS.RAR- Datei auf das Laufwerk (A: ) entpacken. Es müssen 3 Dateien auf der Diskette sein (752F1P15; AWDFLASH; AUTOEXEC)
  2. Die autoexec.bat Datei mit der rechten Maustaste anklicken und auf Bearbeiten gehen. Die Befehlszeile ändern auf: awdflash 752f1p15.bin /sn/sb/py/cc/cd/cp und speichern.
  3. Rechte Maustaste auf A:/ Eigenschaften/ Extras und Fehlerprüfung der Diskette durchführen. Danach die fehlerfreie Diskette aus dem Laufwerk entnehmen.
  4. Eine neue Diskette einlegen und Laufwerk A: (mit rechter Maustaste) anklicken/ Formatieren/ MS-DOS Startdiskette erstellen.
  5. Windows herunterfahren. Im BIOS das Diskettenlaufwerk als erstes Bootlaufwerk festlegen, und die Fail Safe Defaults laden.
  6. Neustart. Rechner fährt auf A:/ hoch. Dann Diskette wechseln und autoexec eingeben.
  7. Nun startet das Programm awdflash und die oben beschriebenen Kommandos werden automatisch durchgeführt. Man darf jetzt nichts weiter tun!
  8. Ist der Flashvorgang beendet, ertönt ein ständiges akustisches Signal (mehrmals kurz, einmal lang). Auf dem Bildschirm steht (in englisch): Die Diskette aus dem Laufwerk entfernen und die Taste F1 drücken.
  9. Beim ersten Hochfahren gleich ins BIOS gehen und die Optimized Defaults laden, noch mal Neustart und im BIOS die alten Einstellungen vornehmen. Fertig!
Notfallplan:
Man nimmt eine Diskette mit dem alten BIOS z.B. 752f1p14, der awdflash- Datei und der autoexec.bat. Die autoexec.bat muss folgende Parameter enthalten:
awdflash 752f1p14.bin /py/sn
Punkt 6-9 wiederholen.
Das Booten kann man ja hören. Ansonsten ist man jetzt auf akustische Signale angewiesen:
Sich ständig wiederholende, lange Beeps oder. mehrmals kurz 1 mal lang: Programmierung abgeschlossen.
Fehlermeldungen:
Zwei kurze Beeps: keine Bootdiskette in Laufwerk A:
Sich ständig wiederholende, kurze Beeps: kein Diskettenlaufwerk vorhanden.
LordIT schöne anleitung :)
da wird das flshen per nios gaanz leicht:d
was is den momentan das neuste bios? der updater meint p14 du mienst p15 ja wasn nu? mache sagen gar d16
Achja ich vergaß ich hab kein floppy mehr^^ geht das auch von usbstick?
Das P15 ist das neuste.
Mit USB Stick muss es auch gehen - hab ich hier im Sammelthread gelesen. Ganz so einfach ist es aber nicht. Bein USB Stick hat man leider nicht die Option "MS-DOS Startstick erstellen", um ihn bootbar zu machen.
In Nero kann man eine Boot-CD erstellen, die bei mir leider nicht funktioniert. Zwar setzt der Bootvorgang ein, aber ein Treiber fehlt, und auf der CD wird endlos danach gesucht.
Dann ist hier noch eine Anleitung, die bei dir passen könnte. Bei meiner SD-Karte hat es aber nicht hingehauen. Mein Datenträger wurde beim Booten als fehlerhaft ausgewiesen.
http://www.flazh.de/bios-boot-usb-stick.htm
Das soll aber nichts heißen. Du hast bestimmt andere Geräte und kommst vielleicht mit den Treibern zurecht.
okay danke schön werd ich auf alle fälle mal probieren.
wo gibts das p15 den? bei quantumforce hab ichs nämlich nicht gefunden. vielleicht auch nicht richtig geschaut
mal ne frage und zwar könnte man nicht einfach nur das bios ändern wie du es gesagt hast und dann trotzdem mit dem tool von foxconn aufspielen?
Mit dieser Anleitung konnte ich mir eine Boot- CD erstellen, auf der dann allerdings nur 1,4MB an Daten drauf sind. Der Rechner fährt dann per CD auf das Laufwerk A: hoch. Es können dann aber nur diese 1,4MB der Boot-CD gelesen werden - aber ein BIOS passt drauf!
http://www.flazh.de/bios-boot-cd.htm
auch per Fox- LiveUpdate kann man den Bootblock unberührt lassen - nicht zu fassen!
Wenn es schon über LiveUpdate sein muss, dann würde ich aber vorher im BIOS die Fail- Safe Defaults laden, Bootreihenfolge einrichten für den Notfall (vorher funktionierendes Bootmedium erstellen!) und in Windows dann alle möglichen Programme wie Virenscanner schließen. Danach dann LiveUdate folgendermaßen einstellen:
Nur ist mir die Funktion "Flash BIOS to Backup BIOS ROM" ein Rätzel. Damit sichert man sein vorhandens BIOS wohl in Form einer Datei auf der Festplatte. Und wie soll man im Notfall diese Datei dann einsetzen? Über LiveUdate geht es wohl kaum.
Hat eigentlich schon jemand seine Speicher mit Command Rate CR1 zum Laufen gebracht?
hehe das board hab ich auch noch daheim und die g.skill die ich habe haben die selben chips drauf
muss ich doch glatt mal test wenn ich zeit habe ob bei einem von den beiden mb's das 1t geht
und wie schauts aus? biste schon zum testen gekommen?
@Tobi:
du verwendest ja 8GB RAM. Kann man diese eigentlich vorteilhaft in der Praxis nutzen? Also ich hab nur 2GB und meine Speicher sind selten über 40% ausgelastet.
Als OS verwendest du ja auch Windows XP mit SP1 und SP3. Hat sich dein Bootvorgang mit dem SP3 auch verlängert?
Kannst du dich mit dem SP1 sicher im Netz bewegen?
SP1 bei Vista
SP3 bei XP
hab früher unter XP schon 4gb genutzt und beim Booten hab ich nichts gemerkt, hab genug tweaks die das sicher weg machen :)
unter vista 64 will ich nicht mehr 8gb miesen
Ähnliche Themen
