[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
Jo, das stimmt wohl. Ich bin ja mal gespannt auf die NVidia-Boards, die noch kommen sollen. SLI zieh ich Crossfire ja doch zu...bloß die Boards taugen da ja oft nicht viel.
Wer von euch hat denn schonmal den MAx FSB ausgetestet?
Ich komm nich wirklich weit über die 520Mhz raus.
NBV: 1,5V
FSB:1,35V
SB:1,6V
Ram und CPU machen den Takt locker mit, also kanns eigentlich nur am Board liegen. Eventuell auch am Teiler von 1:1, denn mit dem hatte ich schonmal meine Probleme. Irgendjemand irgendwelche Erfahrungen?
das kann ich hoffentlich morgen mal testen, aber das mars lief beim vorbesitzer schonmal 560 FSB. werd mit einem E8400 testen, der hoffentlich morgen kommt ;) würde mich aber mal interessieren, ob jemand schonmal die 600 FSB mit dem Board gemacht hat.
haben alle gigabyte ds3p und ds4 die ich hatte gemacht ;) mein mars läuft nach anfangsschwierigkeiten, nur krieg ich grad diesen dummen lüfter nicht auf den chipsatzkühler drauf ^^
Dito. Meins will ich auch nicht mehr her geben.
Super zum undervolten, mit 8 GB keine Probleme, und mit ner 7900 GT und nem e8400 im Idle nur 85 Watt Verbrauch.:bigok:
so bin jetzt dabei mich langsam im FSB hochzuarbeiten - 500x7.5 läuft gerade 32m mit 1.3V...im Orthos wird das Ding zu warm mit Boxed-Kühler (mit nur 2 eingesteckten Pins :p) und hängt sich spontan auf nach ein paar Minuten also werd ich es bei 32m belassen solange wie ich kein Trockeneis hier habe. Das hol ich entweder gleich noch nach der Arbeit oder morgen. Könnte mit Luft zumindest FSB und RAM heut vortesten, dann geh ich morgen ganz entspannt mit DICE ran und weiß schonmal wie das Board sich so verhält (eben bei 500FSB zickte es erst rum, leichte NB-Spannungserhöhung dann ging es).
Hinzugefügter Post:
NBV: 1,5V
FSB:1,35V
SB:1,6V
ich hänge ebenfalls genau dort - gleiche einstellungen, ohne NBV erhöhung kommt man nichtmal über 500MHZ :( alle multis und einstellungen durch, irgendwie bin ich ein wenig enttäuscht. ansonsten macht das board einen stabilen eindruck, aber so wenig FSB reicht einfach nicht.
€: hab jetzt weiter getestet und werde wohl mal warten bis mein guter alter E6850 zurückkommt - hab das gefühl mein neuer E8400 ist kein fsb-monster ^^
€dit: so ich hab jetzt mit DICE getestet und auch hier ist bei 540 FSB schluss...mit 1.65V auf der northbridge wohlgemerkt ^^
@SoF: DAnn können wir das Ganze ja auch hier in Deutsch ausdiskutieren und müssen uns nich im XS rumschlagen, obwohl mir englisch fast leiber is als Deutsch :d
Meld dich, wenn du neue ergebnisse hast...bei mir gehts nich vorwärts -.-
vorhin gingen die 535 auch noch bench-stable, aber mitlerweile bin ich wieder bei 515 ^^ alles andere gibt nur noch abstürze / blue screen egal welche voltage ich der nb gebe. ist schon sehr komisch mit dem board...bis ~515 super stabil, alles bestens, aber ab dort muss man entweder glück haben, oder man kann machen was man will hab ich so das gefühl.
mit ein bisschen glück kommt morgen mein E6850 zurück, dann schnall ich den drauf und schau was passiert. der kann mehr als 600 FSB ohne pll erhöhung und wer der es nicht packt, dann gar nix :P
ich hab auch bisschen das gefühl es liegt am speicher, CL4 geht sehr schlecht(~550 mit diversen teilern), CL5 auch nur mäßig (580 32m 2.45V), dafür, dass das kit >600 MHZ 4-4-4 auf der AOCM gemacht hat o_O subtimings sind stellenweise recht scharf, das ist aber bei foxconn irgendwie üblich, das blackops macht ja auch mächtig zackig was das angeht ;)
Ja, das selbe Gefühl hab ich auch.
ICh hab ja einen E8200 hier, der 600Mhz ohne weiteres mitmacht. Und den Ram hatte ich auch schon auf 620 Mhz, is also auch kein Problem. Aber bei dem Board stirbt der Ram immer wieder.
Ist es bei dir auch beim 1:1er Teiler so aufällig?
bei mir sind alle teiler irgendwie komisch - wirklich gut läuft der ram nicht.
vorgetestet 600 4-4-4 und laufen tut er 550 4-4-4 und 580 5-5-5. Hab hier noch ein Gskill kit was ich evtl. testen werder übers we. für den moment hab ich das sys jetzt nach stundenlangem testen ausgemacht - wurde immer schlechter mit dem fsb ^^
morgen mal neu an die sache rangehen und schauen ob noch irgendwas geht.
Alles klar, wir bleiben aber auf jeden Fall dran. Das Board enttäuscht mich bisher nämlich ein bisschen. Hätte mir mehr erwartet, nach dem, was man so gelesen hat.
Auf den anderen Teilern geht der Ram auf jeden Fall besser als mit 1:1, da bekomm ich ihn auf 600Mhz SPI stable. Aber auch grade so und mit 6er timings. Aber ich hatte 620 schon mit 5er timings stable auf nem anderen Board!
Alles sehr komisch.
E: 612Mhz aufm Ram sind ohne weiteres SPI Stable bei 5-5-5-12!
MEhr hab ich leider noch nicht getestet!
also meine ergebnisse mit dem E6850 zeigen, dass das Board an sich deutlich mehr kann:
550 FSB mit 1.5 vnb
und 565 test ich grad noch 32m mit 1.625V...
scheint sich mal wieder zu bewahrheiten, dass der P35 Chipsatz mit 45nm CPUs einfach nicht so das FSB-Monster ist :( aber ram auch hier 5-5-5 mit 4-4-4 ist irgendwo bei 530 schluss :(
PS: das sys
Auf der foxconnchannel Seite gibts ein neues Bios fürs Mars. Version P14 vom 28.06.08,
changelog: "Fix Foxconn live update sometimes will hang"
Ein bischen o.t. aber trotzdem mal gefragt:
Seit dem ich FF3 installiert habe, kann ich mich zwecks download nicht mehr auf der quantum-force Website einloggen. Hat noch jemand das Problem?
Das Einloggen bei Quantum Force ist kein Problem. Komisch ist aber, dass das P14 dort derzeit noch nicht zum Download zur Verfügung steht.
Naja, die Koordination zwischen den beiden Seiten scheint nicht besonders gut zu funktionieren.
Da P12 war auf der Foxconn Seite eher, das D16 gibts nur auf Quantum-Force obwohl als
"public" gekennzeichnet und jetzt das P14 wieder bei Foxconn eher.
Aber was solls, hauptsache das board ist top.
Also das Board macht mich irgendwann nochmal fertig:
Und bei 1:1er Teiler komm ich die 500Mhz imho nichmal gebootet -.-
Und hat sich schon was verbessert?
Test mom mein Q6600 auf 9x412Mhz 3,7 Gh bei im bios eingestellten 1,45V. läuft min ne std prime small stable.bei mom ca 61°
Geht in Ordnung oder?
Hab ma ne frage und zwar is der Drop normal 1.36V? unter last mit cpu-Z?
Und dann auf welche spannung musss ich achten, auf die die ich im bios einstell, oder die ich mit cpu-z ausless? (bei nem max von 1,5V)
kannst einstellen das es kein droop mehr gibt
temps mit realtemp ausgelesen ?
seit dem das p14 drauf ist bootet der rechner schneller, hat das noch jemand beobachtet ??
temps sin leider noch mal auf 65 hoch ne mit everest.
wo stell ich des ein mit dem drop`?
@TobiasAlt
Was hattest du denn für Probleme mit dem P12
Zu dem droop, wo lässt sich das denn einstellen? habe da auch noch nichts gefunden.
Ähnliche Themen
