[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
ich hab alle windows sowie warntöne aus, werd mal später das bios durchforsten...
hatte ja vorm MB wechsel keine töne ;)
die Töne müssen auch nicht immer von Windows kommen. Nach BIOS- Flash in DOS habe ich z.B. Töne in schneller Folge als Hinweis, dass der Flashvorgang erfolgreich war und die F1 Taste gedrückt werden soll.
Und wenn du die Soundlautstärke in Windows änderst hörst du Pieptöne?
Jop, ist nur beim Soundregler (schieber) und halt wenn man z.B. mehrere Tasten gleichzeitig drückt.
Im BIOS kann man den Boardlautsprecher wohl nicht ausstellen.
Vielleicht ist es aber echt nur ein Treiberproblem. Hast du mal über LiveUdate deine Treiber auf den neusten Stand gebracht?
Hinzugefügter Post:
Wenn ich bei mir mehr als zwei Tasten gleichzeitig drücke, habe ich auch einen kurzen, leisen Onboard- Piepton (wohl ein Warnton).
Wenn es nur der Onboard pieper wär würde es mich nicht stören, den hab ich mit Tesa
ruhiggestellt. Aber das Piepen kommt auch durch die Boxen und das nervt mich schon.
Werde nachher mal alle Treiber updaten (wobei ich bezweifel das es daran liegt).
Moin,
mein Kumpel will sich das Mars kaufen udn fragt ob das Board SLI kann und er eine zweite 8800 GTS 512 einsetzten kann.
Ich habe irgendwie im Kopf der hat Crossfire oder? Fuktionieren dann 2 Nvidia Karten damit?
grüße
Lartens
ok, nutze den onboard sound nicht, daher kommt auch nichts aus den boxen
echtes Crossfire ist es wohl nicht, weil wie bei allen P35 Boards der zweite PCIe Anschluss nur 4x angebunden ist.
Moin,
ich sitzte gerade bei Kumpel und wir wollten seine neue Grafikkarte einbauen bzw haben diese eingebaut. Dabei treten für mich nich nachvollziehbare Probleme auf:
1. Installation Karte ok
bootet sauber XP
2. Treiber 8.5 installiert
3. Neustart
4. kommt bis zum LogonScreen und fährt das System runter??
Nun gut abgesicherter Modus:
- ATI-Treiebr läßt sich nicht deinstallieren
- Karte im Gerätermanager deinstalliert.
Danach fährt das Sytsem wieder normal hoch.
ATI-treiber 8.476 installiert
-> gleiches Problem
Unter Vista gleiches Problem!
Die Graka funktioniert einwandfrei, da ich die Graka bei mir getestet habe.
Nun gut 8800 GTX eingebaut
-> alles einwandfrei
Die 3870 GX2 wieder eingebaut
Treiber installiert
-> Problem bleibt
Woran kann das liegen?
ich werde die Graka gleich mal in den PCIe 4x einstecken
grüße
Lartens
Eventuell das D16 mal antesten. Sonst hätte ich auch keine Idee mehr.
Hinzugefügter Post:
http://forum.foxconnchannel.com/Tit...Name3=Asus+3870x2+4xDVI+gives+me+black+screen
D16 augespielt läuft mit dem Omega durch udn schmiert mit 3DMark06 direkt ab.
ATI 8.5 installiert und bootet bis zum Login und schmiert weg.
grüße
Lartens
Hinzugefügter Post:
Fehler gefunden.
Ich habe die beiden Kabel vom NT zur Graka getauscht und siehe da es lüppt.
eines der beiden Kabel war defekt. Daher hat die Graka im 2D Betrieb funktioniert.
thx @ all
grüße
Lartens
Folgendes Problem
ich habe einen e8400, der auf einem asus P5K pro ohne probleme mit 444x9 auf 4000MHZ gelaufen ist @ 1,295 V beim MARS benötige ich 1,4 V um dieselbe CPU 2 stunden prime stable @ 4000 MHZ laufen zu lassen, was die temps natürlich hoch gehen lässt.
bios habe ich p16 drauf NB/SB ein bisschen erhöht. habe alle spannungen bis 1.4 V stufenweise getestet und erst bei 1.4 V läufts stabil...
denkt ihr es liegt an der bios version? oder warum braucht die CPU eine so viel höhere spannung?
danke für eure antworten
cheerz
Wieso? Hab nen P5Q Deluxe ergattert :d
Brauch einfach mal wieder bissel was neues :d
Chris
Einfach was neues zum Spielen, erhoffen tu ich mir garnichts :p
Ist nunmal nen Hobby und es war bei mir von anfang an klar das das Mars nur als Übergang
zum P45 dient :d
Chris
Also ich sag mal so, wenn ich eins von den neuen Monsterboards von Foxconn ergattern könnte, dann würd ich das glatt gegen das Mars eintauschen, auch wenns null Probleme macht. ;-)
Ich sag nur Foxconn BlackOps....schöner X48! Das ganze ist mir aber etwas zu unerschwinglich..knapp 300€ find ich hart.
Ähnliche Themen
