[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
Das P12 verhält sich in Sachen VCore wie das G30.
Dass FSB 475 mal geht und mal nicht liegt vielleicht an der Strap- Umschaltung der NB (einmal An - Aus). Typisch ist auch, dass bestimmte RAM- Multis gehen und andere wieder nicht.
Alle 6 SATA Anschlüsse sind bei mir im Intel ICH9 SATA AHCI Controller eingebunden. Den Brenner am Anschluss 6 würde ich gern am JMicron betreiben, weil dieser die Acronis Wiederherstllungs-CD booten kann. Kann man eigentlich einen einzelnen Anschluss aus der Matrix Storage ausgrenzen und dafür den JMicron aktivieren?
Die 6 SATA Anschlüsse stellt die Intel Southbridge zur Verfügung.
Der JMicron ist für E-SATA und PATA zuständig.
Wenn du deinen Pioneer am JMicron betreiben willst, dann nur per E-SATA.
@gonzos-revenge
Danke für die schnelle Antwort. Das erspart mir wohl sinnloses Ausprobieren.
@TobiasAlt:
an zu wenig VDIMM wird es wohl nicht liegen, oder?
Mir ist schon einmal aufgefallen, dass im BIOS auf Auto eingestellte RAM- Subtimings nicht immer über Everest mit denselben Werten ausgewiesen werden. Ein Neustart und die Werte können sich in einigen Punkten unterscheiden. Es kann natürlich auch an Everest liegen. Wenn aber alle Timings manuell eingestellt werden, sollte dies nicht mehr vorkommen.
nö hab testweise 1,9v drauf
laufen aber 1100 mit 1,8v bei 8gb
475 1:1 sollte dann also locker gehn
welche spannungen könnte ich denn erhöhen um es gegen zu testen?
also 3,82ghz laufen stable mit 9*425 !
wollte gern 8*475 24/7 fahren
die meisten RAMS haben ja einen offiziellen Bereich von 1,8V-2,1V. Dann würde ich bis 2,1V gehen - testweise auch mal 2,2V.
ok werds versuchen und auch mal mit nur 4gb
wieviel saft sollte ich auch nb/vtt/sb geben bei ab 450 bis 500 ?
Habe meinen Ram mit 2,1V laufen.
Hab teilweise CPU auf 8*500 laufen und dabei brauchst der nb und sb nicht mehr Spannung geben. Auch VTT ist bei mir auf Std. nur der Vcore ist leicht erhöht.
so leute ich hab nun den fehler bei mir gefunden wieso 8*475 nicht geht !!!
wenn ich im bios einen kleineren multi als 9 einstelle macht er automatisch ,5 drauß !!
in meinem beispiel bedeutet das 8,5*475 und das geht sicher nicht mit 1,28v !
und das ist bei jedem multi kleiner 9 !
atm rennt er 515*7,5 1:1 :)
hat jemand das ganze board (NB, SB, Mosfets) unter wasser? Mich würde brennend interessieren, welche SpaWa Kühlre (am liebsten von EK) auf die Mosfets passen.
Any ideas?
Unter dem Multi gibt es eine Option für halbe Multis, die musst du deaktivieren, dann
hast nur volle Multis. Wie diese Option genau heißt müsste ich später mal nachsehen.
Chris
sooo, nu hab ich auch mal ne Frage zum Board! Und zwar hat das dingen sonen dreckigen
onboard Speaker, der nervt mich total (piept beim lauter / leiser machen oder auch wenn
man mehrere Tasten gleichzeitig drückt -> und das nicht gerade leise!). Wie kann ich das
dingen ausschalten?
Chris
kleines Stück oberhalb der Batterie. Der Speaker ansich ist nichtmal so wild, da hab
ich nen stück Tesafilm drüber geklebt und der is leise geworden, größeres Problem
ist das das Piepen auch über die Boxen weitergegeben wird die über die onboard
Soundkarte angeschlossen sind. :kotz:
Ömm also das piepen beim lauter machen, muss aber an irgendner Einstellung liegen. Ich verwende auch den Onboard-Sound und ich hab son Phänomen nicht...
Ähnliche Themen
