[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
na du bist lustig die hab ich nich mehr!^^ sonst würd ich nich fragen
naja da war ich schon aber da find ich nix oder hast du es da schon gefaunden?
ah danke der link führt dirikt zum DL^^ merci
so endlich ist mein MARS angekommen... der einzige scheiss ist jetz, hab keine boxed version gekauft, und habe keinen kühler, da der IFX-14 auf sich warten lässt... naja zum glück scheint die sonne und draussen sein ist grad besser als drinnen zu schrauben... :d
Hallo, habe auch vor, mir dieses Board zu holen, habe damals schon ein Auge drauf geworfen, dann aber einen Umweg über's P5K-E gemacht.
Wie schaut es mit dem Strap bei dem Board aus? Beim Asus konnte ich den im Bios einstellen.
@Chrisch:
...0,9V ist unglaublich niedrig. Liegt es an der CPU, am BIOS oder den Einstellungen, dass diese Spannung läuft? Ist C1E auch noch aktiv?
Liegt wohl an der CPU, die hat eine recht niedrige VID ;)
Die läuft ausserdem noch mit 3.2Ghz @ 1.048v / 4Ghz @ 1.232v :)
Chris
Mal ne Frage zu den RAMs.
1. Welche nutzt Ihr und welche würdet Ihr empfehlen.
Kollege will sich das Foxconn holen und direkt auf 8GB ausbauen. Kosten so um die 120 overall. Kein OCer
Evtl. habt Ihr einen Tip.
grüße
Lartens
@Chrisch
Die Werte sind super!
Welches BIOS hast du drauf?
@earth
Der Strap ist der programmierte Grundtakt der CPU. Der FSB, Multi umd RAM- Multi spielen eine Rolle. Man hat in einem Strap einen Bereich, in dem Einstellungen vorgenommen werden können. Ein Strapwechsel erkennt man durch ein einmaliges An- Aus des Rechners. Ist der gewählte RAM- Multi nicht Strap konform, fährt der Rechner gar nicht hoch.
Dass man den Strap selbst gezielt einstellen kann, ist mir neu. Das würde aber helfen, die optimalen Einstellungen schneller zu finden.
@Lartens
Schau doch mal bei TobiasAlt in die Signatur. Der hat doch neulich erst geschrieben, dass seine 8GB RAMS mit FSB 425 laufen.
sach mal chrisch hat deins eigentlich ne neue Rev?
g.skill hab ich drauf
Ich hatte hier diesen Bericht gefunden, dort schreiben sie von verschiedenen Strap's auf dem Foxconn Mars, daher meine Frage:
http://www.anandtech.com/mb/showdoc.aspx?i=3107&p=6
@Chrisch
Hast du mit deinem Intel C2D E8200 @ 2.66Ghz (0.90v) C1E und EIST aktiviert, und arbeitet es? Wie bist du mit dem Board im Vergleich zum P5K zufrieden?
hat etz zwar nix mit dem theam zu tun, aber kann ich eigentlich jmd einen schnellbericht von everest schicken, ohne das dieser wichtige infos von mir erfährt z.B. serial des OS etc?
Ach wegen der Rev hätt ja sein können, weil des ja anscheinend ne neue Lieferung war/ist.
Aber wieso was verbessern:asthanos:
@Chrisch
...meine E4400 hat laut Intel auch eine VID min. von 0,85V.
Bei 1,0375V @2Ghz kommen die ersten Fehlermeldungen im Windows Betrieb - @1,0V macht der Rechner einen Reset.
Selbst 0,9V im Standardtakt sind für mich sehr schwer vorstellbar.
hats von euch schonmal jemand erlebt das das Mars partu nicht den Multiplikator von der CPU übernehmen will?
Im BIOS lässt sich alles schön einstellen, er zeigts bei bootscreen auch an,
aber im Windows is Multi immernoch auf 9x
Bios hab ich das G30 und das P12 getestet brachte keinen unterschied
jemand ne idee oder kennt jemand ne ähnliche situation?
hast mal bios defaults geladen und alles neu manuell eingestellt? (ohne OC Profil)
Hatte ähnliches gestern mitm E7200
Habe jetzt zwei BIOSe auf minmale VCore hin getestet:
VCore G30: 1,0625V
VCore P07: 1,0500V
Es gibt tatsächlich Unterschiede - auch wenn sie nur gering ausfallen!
sagt mal hat jemand 8gb mit fsb 500 laufen ??
fahre grad meinen e8400 mit 8*475 und einmal gehts es mit dem fsb und einmal nicht
echt komisch
hat jemand ne idee ??
oder liegts wirklich an der vollbestückung ??
Ähnliche Themen
