Pimok
Ich darf zu der Luftleitfolie mal das offizielle Statement von Corsair zitieren:
Diese Sache interessierte mich nämlich auch, da bei meinem Test kaum eine Veränderung der Temperatur zu bemerken war, lediglich ein höherer Geräuschpegel...
"The reason the plastic sheet goes over part of the fan is to direct air to “hot spots” inside the PSU that normally would not get airflow if the fan were not covered in that section.
If the fan baffle is removed, the air blows directly into the PSU and does not channel through the front of the PSU (where the connectors are) without some sort of airflow directing device. The plastic baffle is an easy way to direct airflow towards the front of the PSU and necessary to avoid component failure due to overheating."
