[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
Stimmtes dass mana uch auf INTEL Boards ein SLI System fahren lassen kann. Z. Bsp mit 2 x 9600GT.
Wenn ja hat jemand Erfahrungen damit und kann mir da einige Tipps geben ?
Das wär mir jetzt mehr als neu, also zumindest von offizieller Seite...nVidia und Intel liegen ja momentan ziemlich im Clinch. Beide Seiten verweigern sich gegenseitig die Lizenzen. :-[
SLI mit Intel gibt es mit speziellen Treibern, aber die hab ich schon lang nicht mehr in aktuellen Versionen gesehen...daher denk ich mal das die 2x 9600GT nicht laufen werden.
Und die Performance ist dann wohl auch eher bescheiden.
Danke. Schon Komisch dass INTEL quasi die Konkurenz AMD unterstüzt. Da soll einer noch mitkommen. Aber dass Board geb ich nicht her somit heisst es wartena uf den 8800GTX/ULTRA nachfolger.
Genau, ich werd das Board auch nicht weggeben, da wechsel ich eher ins AMD/ATI Lager. :hmm:
Und mit Quantum-Force mein ich die Seite, wo man die Teile downloaden kann.^^
Hast du dich noch nicht registriert? Mit deiner Seriennummer kannst du dich auf der Seite registrieren, gibt Video-Tutorials für die, die's brauchen *g* und und jede Menge Beta-Biosse.
Naja dann schonmal viel Spaß. ;)
Ma gucken, was du so an Max FSB schaffst, bin ja anscheinend grad der Leader hier. :eek:
Ich stell heut Abend wenn ich zu haus bin auch nochmal nen Screen rein.
Mal ne andere Frage...mich würd ja mal reizen, Crossfire zu testen.
Da der 2. PCIe ja aber nur mit 4x angebunden ist, wird da ja bestimmt ne Menge skaliert...hat einer Erfahrung, wie hoch die Skalierung im Gegensatz zu 2 16x PCIe auf nem X38 zum Beispiel wäre?
das war aber auch ein richtiges Schnäpchen.... Wird bestimmt nicht nochmal so günstig angeboten.
Man muss 60 Tage hier im Forum registriert sein um am Marktplatz aktiv sein zu können, oder?
Ich sehe immer nur "privat".
... bin gerade am Grübeln. Das Foxconn X38A ist dem Mars sehr ähnlich:
DDR2 u. DDR3 Support und 2 echte PCIe 16x wären die Vorteile.
Nur ob es so gut wie das Mars läuft, ist schwer zu sagen. Kombo Boards sollen doch recht zickig sein. In einem Test lief es ohne Spannungserhöhung doch schon bis 450 Mhz.
Der Mehrpreis gegenüber dem Mars sind 35€.
Einfach mal testen, mit Foxconn machts du bestimmt nichts falsch :bigok:
Also DDR2/3 Boards sind glaub ich wirklich nicht so der Bringer...bis ich umsteig, gibts bestimmt schon wieder ne neue Chipgeneration und dann kommt halt auch wieder n neues Board...
Und ich würd mich auch so fürs Mars entscheiden, es ist einfach ne andere Serie, halt für Gamer und OCer. Das einzige interessante wäre wirklich die Crossfire-Möglichkeit, aber das könnte man mit der 3870 x2 ja auch kompensieren. *g*
Hab mal gelesen, dass der zusätzliche DDR3 Support das Board ausbremst. Hier ist auch jemand unglücklich mit dem X38er:
http://geizhals.at/deutschland/?sr=286630,-1
Ich werde mich wohl für das Mars entscheiden. :banana:
Den Quantum-Force Service gibt es für das X38 auch nicht. :confused:
Hat jemand einen Tipp für einen Versandhändler, der das Board günstig und mit gutem RMA Service anbietet?
Weiß jemand, ob derCPU- Kühler Xigmatek HDT-S1283 Red Scorpion passt?
http://geizhals.at/deutschland/a313111.html
Ich hab meins bei amazon gekauft.
ja quatnutm force is eine seite nur für des MARS!^^
Hi Leute,
habe erst mit dem DFI DK P35 Board liebäugelt, aber ehrlich gesagt kann man damit zuviel scheiß einstellen...
Nun bin ich hier gelandet und es klingt sehr geil was ihr hier beschreibt.
Hab nun mal 3 Fragen:
Hat jemand nen Q9450 darauf ausprobiert?
Funktioniert der Ram Corsair XMS2 Dominator DDR2-1066?
Gibts Probleme mit bestimmten Netzteilen? Wollte mir en Corsair 750W holen.
Vielen Dank und hoffe meine Fragen werden hier net so übergangen wie im DFI Post.
Moin moin!
Ich wollt mir auch erst das DFI holen, da ich noch sehr gute Erinnerungen an mein DFI aus Sockel 939 Zeiten habe...im Grunde hab ich auch nur das Mars genommen, da ich sehr günstig drangekommen bin. Aber ich muss sagen ich bereue den Kauf keineswegs, das Bios ist vollkommen ausreichend für alle erdenklichen OCs. Kannst auch alles in verschiedenen Speicherslots wegspeichern und wieder bei Bedarf laden, das Bios lädt von selbst mit bootalbe Einstellungen, wenn man den OC mal übertrieben hat...weiß nicht, was das DFI da besser kann.
Außerdem ist die Kühllösung vom Mars besser.
Und die Quantum-Force Seite ist MOMENTAN nur für das Mars. Auf der Cebit wurden schon weitere Boards angekündigt, eins mit 780i Chipsatz und eins mit 780a Chipsatz.
Also ich glaub da hat Foxconn ne sehr gute Serie geboren, hoffe das geht munter so weiter, dann bleib ich Foxconn auch treu.
Ähnliche Themen
