[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
ach so, der lüfter ist direkt von foxconn. da ist optisch natürlich gar nichts inzuwenden. :)
aber auf wakü verzichten? :heul:
gruß klasse
Naja, wozu ne Wakü wenn die Teile (NB, SB, Spawa) kaum warm werden? Ist alles
nur rausgeworfenes Geld :)
Chris
@ chrisch
wenn dich bei foxconn anmeldest kannst noch paar beta biose runterladen!
MARS BETA BIOS G29
Version: VG29
1) Enhanced 45nm Support 2) Display correct Multiplier for Intel QX9650 at boot-up
Download File
MARS BETA BIOS G28
Version: VG28
(1) Solve Vista 64 memory 4GB issue (2) Solve Vista show 24.33G with QX9650 in N/2 ratio. (3) Modify for 45nm CPU temp. show (4) Added QF logo (5) Modify for "Target CPU Core Speed" item in N/2 ratio (6) Auto Disabled Full Logo if Manual O.C. mode (7) Auto Enabled QF Logo if Manual O.C. mode
Download File
MARS BETA BIOS G26
Version: VG26
MARS BETA BIOS G26 1. Supports Intel QX9650 / Q9550 /Q9450 45nm CPUs 2. Solve space not enough to decompress RAID ROM and LAN boot ROM together 3. Supports DDR2 memory EPP function 4. Add CPU Clock vs Memory speed function 1:3.2 and 1:4e selected value 5. Supports x0.5 Multiplier adjustments with CPUs supporting this function
Download File
MARS BETA BIOS G23
Version: VG23
1.Update QX6950 CPU micro code; 2.Auto enabled "Frequency Unlimit" item if QX???? or X???? CPU detected; 3.Auto adjust "Over Clock Phase Select" item to "Manual O.C." if "DRAM Timing Selectable" item select "Manual" mode, 4.Auto adjust "DRAM Timing Selectabl" item to "By SPD" if "Over Clock Phase Select" item select "O.C. Disabled" mode; 5.Auto enabled "Over Clock Recovery" item and disabled "Spread Spectrum" , "Smart Power LED" items if "Over Clock Phase Select" item not in "O.C. Disabled" mode; 6.Modify BIOS model string from "P35A04 series" to "P35A MARS".
tja, das ist das gleiche wie:
"wozu einen E8500 besorgen und auf 4Ghz takten, wenn beim zocken doch die graka limitiert?"
ist halt nen hobby und ein voll bestücktes board sieht schon klasse aus.
gruß klasse
gruß klasse
Naja, nur wenn man bedenkt das 3 Wasserkühler fast soviel kosten wie das Board
ists halt nen bissel anders. ;)
@ bronti
hab das aktuelle Beta Bios drauf (hab ich schon kurz nachdem ich das Board bekommen
hab geflasht) :)
@Chrisch,
wie kühlst du die CPU?
glaube die neuen cpus wo kommen sind 4 ghz on air kandidaten!
netzteil muss ich nachrüsten meins geht bei 12 volt zu arg in die knie!
Hab das Board seit dem letzten Wochenende auch und bin bis jetzt sehr zufrieden mit dem Board. Hatte vorher eine Gigabyte DQ6. Ein Nachteil gegenüber dem DQ6 ist der höhere Stromverbrauch, auch die Mainboardtemperaturen vom Mars sind höher als vom DQ6.
Interessant ist auch dass EIST sogar bei Undervolting problemlos funktioniert. Hab meinen E6850 auf 1,14 V undervoldet und mit EIST läuft er dann bei 2000 Mhz mit ca. 0,95 V.
Der VCore weicht bei mir aber von dem im Bios eingestellten Wert ab. Bei 1,175 V im Bios, sind es bei Prime dann nur noch 1,14 V.
Wie viel höher sind Temperaturen und Stromverbrauch im Vergleich zum DQ6?
Zu vernachlässigen?
Wäre mir neu das das Mars einen höheren Stromverbrauch sowie Temperaturen als das Gigabyte besitzt, das widerspricht sich auch mit diversen Review-Ergebnissen: klick mich
Oh, nett. :)
Werd's Donnerstag ordern, hab' mich entschieden.
Die "knapp 31 Megabyte pro Sekunde"-Firewire-Performance stören mich nicht. Mehr schaffen externe Platten und Camcorder eh nicht.
Zu vernachlässigen?
Na ja , der Stromverbrauch ist im Idle geringfügig höher als beim DQ6, knappe 5 Watt (mit DQ6 122 Watt, mit Mars 128 Watt). Unter Volllast habe ich noch nicht getestet.
Allerdings ist bei der Mainboardtemperatur der Unterschied schon höher. Beim DQ6 waren es ca. 33 °C, beim Mars sind es knappe 10 °C mehr (43 °C). Sind aber die Temperaturangaben von Everest. Bei dem Test bei Hardware-Mag wurde ja ein Infrarot-Thermometer benutzt.
Um ehrlich zu sein, sind diese Werte eher schlecht als recht. Zumal sie genau das Gegenteil von dem widerspiegeln, was Chrisch an Ergebnissen gepostet hat.
Edit:
Wie läuft denn das mit dem Strap bei Foxconn ab? Ist dieser manuell einstellbar?
@ tehcrs
die haben noch das alte Bios genutzt, im aktuellen kann man das Performance Level
einstellen usw. Strap ist nicht einstellbar, aber Leistung ist i.d.R. immer vorhanden.
Hat schon jemand Erfahrungen mit Scythe-Kühlern auf dem MARS gemacht?
Passt der Mine B?
Dass der Strap nicht manuell einstellbar ist, ist für mich gerade ein großer Minuspunkt :/
Passt der Mine B?
Also der Scythe Mugen passt, wenn man das eine mit Foxconn beschriftete Blättchen von der Heatpipe entfernt. Man kann nur die untere Lüfterklammer nicht einrasten.
Der Mine sollte also passen.
Danke für die Antwort, aber was meinst du damit:
Der Kühlerkörper auf der NB hat ja oben nen Bogen wo auf beiden Seiten "Foxconn"
steht. Die kann man jeweils rausziehen, dann ist der Kühler ein wenig Tiefer und es
gibt keine Probleme mehr mit größeren Luftkühlern (so wie den Scythe-Kühlern) :wink:
Chris
Sag einmal wie seid ihr im grossen und ganzen zufrieden Quallitäts mässig mit dem Bord ich möchte es mir eben vielleicht auch holen als übergang zu einem 780 I SLI der Preis fürs Mars ging jo vor zwei Tagen noch etwas runter. :rolleyes:
Hab es mir jetzt auch gekauft.
Leuts jetzt müsst ihr mir mal kurz helfen bitte ...
Folgendes probs hab ich, wenn ich Win aufgesetzt habe und danach den INTEL Chipsatz Treiber installiert habe und der PC bootet neu, hängt sich meine Maus auf oder hatte es auch schon das auch meine Tastatur ned geht hatte auch alles mal umgesteckt. Das hab ich aber erst wenn er neu gestartet ist wie wenn es beides nicht erkennt, ohne den Treiber geht alles ohne probs unter Win ... hat einer ne Idee. :hmm:
Gibts das Handbuch auch auf Deutsch zum Downloaden ??
Sonst soweit läuft alles wie ne 1.
Leider Nein, läuft bei mir absolut einmalig und problemlos. Kann Dir da leider auch nicht helfen :(
PS: Nicht das ich wüsste. Aber es liegt bei Foxconn in einer neuen Revision 1.1 vor :)
Mal ne Frage ist das zuviel Saft auf der CPU ... QX2.jpg wieviel Volt soll ich der geben ? Rennt wie ne 1 bei mir. :p
Das probs ist gelöst musste die Raptor gegen ne Samsung austauschen.:rolleyes:
Ich glaube, 1.59V sind schon ziemlich heftig.
Ähnliche Themen
