[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
ja bin bisher mehr als zufrieden!
werde kräftig weiter testen
bis fsb 505 gings bisher mit 8er multi
Hmm... bin am überlegen das mal zu bestellen...
Wie schauts mit der VCore aus?
Also eingestellte VCore im Bios = Idle / Load?
Edit: funktioniert EIST / C1E wenn man übertaktet bzw die VCore manuell anhebt?
EIST / C1E haben mir keine probleme bereitet
hier mal screens vom bios und dann im betrieb idle load!
Die Abweichung beträgt bei mir 0,008v (wenn überhaupt) und EIST / C1E funktioniert auch übertaktet bzw. mit manuell eingestellter VCore - siehe hier: klick mich
Wenn man keine zwei Grafikkarten braucht wüsste ich nicht welches Board auch nur ansatzweise mit dem Mars mithalten könnte :d
bin bisher auch hochzufrieden es gibt ja mittlerweile einige neue bios versionen und paar beta´s mal ne neuere version draufspielen!
werde mir nen neuen speicher kaufen dominator 8500er und nen d-tek fuzion dann mal schön weiter testen!
Moin moin,
gibt es im Bios irgendeine Einstellung wegen dem VCore Droop?
Habe das Board seit heute und der VCore Droop von Idle zu Load beträgt 0.024v
und nicht wie bei euch 0.008v :( (und das sogar nur mit nem Dual Core)
Ansonsten läuft das Board soweit, bin aber noch am testen :)
Eigentlich nicht, ich habe das so eingestellt und es läuft perfekt. Vielleicht liegt das an der Kombi Board <-> Netzteil!?
hmmm...
kann ich mir nicht wirklich vorstellen. Hab nen 600W Seasonic und das langweilt
sich mit der HW :d
Und mit anderen Boards hatte ich ja auch keine Probleme :)
Naja, ma gucken ob ich irgendwo nen Droop Mod finde
Chris
Betreiben die Besitzer das Board mit dem zusätzlichen Lüfter für die Heatpipe? Ist das Ding laut? Und überhaupt notwendig?
Nein, ohne Lüfter und komplett passiv. Der sollte nur nötig sein wenn man alle Spannungen aufs Maximum stellt und kaum Luftfluss vorhanden ist :)
Mich würde jetzt mal interessieren ob es wie darmals angekündigt auch halbe Multiplikatoren kann . Habe darmals irgendwo einen Vorserientest gelesen . Das Board an sich scheint sehr gut fürs Ocen zu sein !
Danke.
Bin sehr am Board (für eine zukünftige Q6600-Plattform) interessiert, da ich das DQ6 öde finde und mal was anderes als Asus ausprobieren möchte.
Die 6 Phasen genügen für's Übertakten eines Quads? Scheinbar, die Ergebnisse von bronti sprechen ja dafür.
Vielleicht mit einer Extreme-Edition CPU, für diese gibt es spezielle Reiter und Optionen zum freischalten der Multis.
@Myrken:
Die reichen 100%ig :)
halbe Multis funktionieren problemlos. ;)
Funktioniert aber nur bei CPUs die auch halbe Multis haben! (Yorkfield / Wolfdale)
Gut zu wissen. Klappen diese halben Multis auch auf anderen Boards oder bildet das Mars da eine Ausnahme?
Aufm Maximus Formula funktionieren die auch mitm letzten Bios. Beim P5K-E funktionierten
die noch nicht, wird aber auch wohl mitm nächsten Bios kommen :)
Denke also das demnächst jedes 45nm Board die halben Multis hat...
Nuja, selbst wenn, immerhin bietet das Mars jetzt schon diesbezüglich (funktionierenden) Support. Ich rede es mir mal schön und behaupte einfach: Foxconn scheint ja wirklich eine Menge an diesem Board zu liegen. Ansonsten würden sie wohl nicht so fehlerfrei und Zukunftsorientiert arbeiten bzw. rechtzeitig (finale) Bios-Versionen bringen (ist ja nicht gängig) :d
Auch schön zu sehen, dass das günstige Transcend-4GB-Kit läuft.
Das habe ich nämlich schon. ;)
Läuft zudem noch mit 475MHz bei 1,8v und Standard-Timings. Mal schauen das ich mich die Tage (bzw. am Wochenende) nochmal damit beschäftige, aktuell ist dazu nicht wirklich Lust vorhanden :)
Hmm...
bis auf nen paar kleinigkeiten die mich bissel nerven läufts sehr gut (ab und an
will der nen paar OC Settings nicht booten, wenn man dann den FSB aber noch
höher stellt gehts wieder, dann muss ich nur wieder zurück ins Bios und auf den
gewünschten FSB zurück stellen)
SB PLL Voltage kann ich auch nicht anheben, sobald ich das mache isses nur noch am piepen
und lädt die standard Einstellungen...
Ansonsten nen TOP Board welches sich sehen lassen kann, die SuperPi Performance ist
sogar noch nen Tick besser als beim Asus :)
Hier als kleiner Vergleich (selbe Teiler / Timings)
Foxconn Mars P35 + E8500 @ 4.75Ghz single SuperPi 32M
Foxconn Mars P35 + E8500 @ 4.50Ghz dual SuperPi 32M
Asus P5K-E P35 + E8500 @ 4.75Ghz single SuperPi 32M
Asus P5K-E P35 + E8500 @ 4.50Ghz dual SuperPi 32M
Werd die Tage noch nen bissel testen :)
Holla, die Ergebnisse können sich wirklich sehen lassen. Hätte nicht erwartet das das Mars dann doch so viel schneller ist.
Aber bestätigt mich wieder in meiner Freude mich für diesen 'Aussenseiter' entschieden zu haben. Ich denke das Board wird ne sehr lange Zeit in meinem Rechner werkeln, Abit AN8 SLI like, zumal ich auch nicht mehr wirklich Lust habe in den nächsten Monaten nochmal gross zu basteln / umzubauen. Aber man soll ja niemals nie sagen :haha:
Hmm...
- Undervolting bis welchen Wert möglich? 0,8V ?
- Wieviel wird bei EIST die VCore abgesenkt wenn man z.B. 1,4V lt. CPUZ im großen Multi hat ?
- Ist die Windowssoftware nur als Anzeige gedacht? Kann man dort auch NB und VTT-Spannungen ändern?
bei mir muss das board gedreht eingebaut werden. funktioniert das die heatpipe?
wie sieht es aus mit wasserkühlern. passen vielleicht welche von anderen herstellern?
gruß klasse
- Min VCore im Bios ist 0.825v
- VCore wird abgesenkt (443x9.5 @ 1.33v / 443x6 @ 1.25v)
- Software hab ich noch nicht benutzt, werde ich mir aber mal anschauen
Edit: Die VCore wird je nach dem welchen Takt & Spannung man eingestellt hat
abgesenkt. Habs schon mitm VCore Multi probiert die VCore idle auf 1.00v zu bekommen,
geht aber nicht :( (vll. wird das ja noch mit nem Bios kommen)
gruß klasse
bei mir ist das Board ebenfalls gedreht eingebaut. Habe zusätzlich den NB Lüfter
montiert (welcher lautlos ist), die Heatpipe wird somit nicht sehr warm (beim asus
hat man sich die flossen verbrannt, hier ists recht kühl) :)
Undervolting ist überhaupt kein Thema: CPU, Speicher, North- und Southbridge lassen sich alle unter den Default Wert einstellen:
Wie weit die Spannung jetzt genau bei dem Wert abgesenkt wird kann ich Dir nicht sagen, aber das wissen hier bestimmt auch andere :d
Die Software habe ich nicht getestet (werde ich wohl auch nicht).
so ein lüfter ist optisch bei mir keine option. vielleicht frag ich mal bei mips an, ob sie das board schon in den fingern hatten. irgendwie hab ich das gefühl NB und SB sind kein problem. der spawa-teil ist evtl. von den lochabständen problematisch.
gruß klasse
€: wenn sich jemand die mühe machen will:
hier gibts zeichnungen zum ausdrucken:
http://www.watercool.de/cms/MB_COOLER/HEATKILLER_SW_CAD.pdf
http://www.watercool.de/cms/MB_COOLER/HEATKILLER_NSB_CAD.pdf
die kann man an die hardware ranhalten und sehen, ob vielleicht was vorhandenes passt.
gruß klasse
was stört dich an der optik :confused:
Ähnliche Themen
