[Sammelthread] Offizieller AMD RX 9070 (XT) Overclocking und Modding Thread
Habe eben überhaupt erst realisiert, dass ich den Takt damit weiter anheben kann. Die Karte hält zwar Abstand zur Grenze, aber taktet höher. Eben bei 3420 mhz in Cyberpunk dann aber abgekackt. Vermutlich ist das der Bereich wo man dann +mV nimmt.
Dann muss ich irgendwann aber auch noch mal was am Score machen xD
Wird halt irgendwann instabil, 260-320mhz geht meistens bei mir, Ausnahmsweise ging schon weit mehr.
Hoffe das bringt auch was im Benchmark, bin da noch nicht ganz so gut dabei wie gewünscht.
Hmmm so cooling isn't really the problem with this gen...the max clocks are at the ragged edge for the gpu itself!
Ok eh it wont hurt to try...or will it 😅😅
Only SN so far....this is pretty much the limit for me stock card oc....just custom water loop so far...water temp was around 25c its getting warm here.
+300mhz core
--105mv
2830 mem
+10PL
It won't hurt the GPU, but the drive. After ~5 heavy crashes the drive will be broken and you cannot get stable settings any more.
So lots of driver reinstalls? Or does CRU help at all?
I need a course of action...i will muck around software modded first...then will try the evc...didnt really want to take to the card with shunts straight off the bat 😆...ive only just mastered connecting evcs! Heating pad is definitely the go there!
Looks like im gonna have to brush up on the linux skills....again 😥
Ok! Oh i meant with just resetting the driver...does it help with the broken driver? Or its that broken it needs a reinstall....
Sounds tedious...but eh no pain...no minimal gain? 😆😆😆
Ok! Nice....will keep that in mind when im at the end....gonna muck around with linux today and hook up the chiller...just to keep temps in check.with the weather/humdity here...quite low atm...i can probably get the water down to like 9/10c,a couple of c above dew point...will stuff around like this for a while then probably move the card to the sub zero chill box set up...
Dont want to pull the card apart again just yet...for evc/shunts...that will be something for the future
Im obviously a little concerned about the 12v 2x6 cable but will try and keep things relatively conservative...knowing my tinkering habbits i should have held off for a 3x 8pin pcie card but not much here on the used market ans i picked this card up at a good price...so eh...what can you do! I did notice that alphacool included a thermal pad for the connector on the back plate! I also have a fan set up pointing straight at the connector...i doubt either of these things are gonna help...if the cable decides to let go its gonna let go!
Ging gut +400 mhz vulkan und +300 mhz bei mir mit -135 mv im schön warmen PC-Zimmer. Minimale Verbesserung meines personal best - vielleicht geht mit Balkonmod dann nochmal mehr :)
Die Karte versucht dann halt auch höher zu boosten, wenn du Offset gibst. In Kombination mit EVC will die schnell 3600MHz+ boosten und dann gibt es direkt einen Crash.
Musst dann den Boost-Takt mit dem Offset Slider begrenzen und dich bis unterhalb 3500MHz rantasten.
Muss ich mich mal dran setzen. Bin vorhin bei in SN bei -155mv, 2940mhz VRAM und 0mhz Takt bei 7880 Punkten ausgestiegen. Hat mir dann leider den Treiber zerlegt. TSE ging mit +550mhz Takt mal durch. Ich hoffe auf kältere Temperaturen um die 2980mhz VRAM stabil zu bekommen und dann hoffentlich auf 16500 Punkte zu kommen, für SN wären erstmal 8000 Punkt angepeilt.
Ich gehe davon aus, dass ich zu sehr im Powerlimit bin, TSE ist nämlich schon auf -190mV runter, das könnte wieder bei 0°C weiter runter gehen auf -200mV. Dann muss aber auch wirklich was kommen. Wenn die 16500 damit nicht fallen muss ich mir was überlegen.
Weißt du wo so das Limit liegt bei 374w?
Ok all...what do i need before running this script? Downloads etc
Balls of steel? 😅
Keine Ahnung mehr. Aber soweit ich weiß hat auch ShirKhan noch ohne offenes PT also 374W gebencht und mehr Punkte als ich.
Ich kam gestern ad hoc bei 8644 vulkan raus, obwohl schon teilweise 3500 mhz anlagen...
Also, vorausgesetzt, ich sollte eine Karte mit Samsung VRAM erwischen.
Wie undervolted kann ich denn zB eine 9070 XT laufen lassen?
Also wirklich bissi die Handbremse anziehen für später. Darf ruhig bissi FPS verlieren.
Habt ihr Beispiele für effiziente Configs für 9070 & 9070 XT ?
Ich will der Karte nochmal eine Chance geben! :) und auch den blöden Stecker vermeiden! 😀
Beispiel aus Reddit:
PowerColor Reaper -500 MHz Frequenzoffset -90 mV Spannungoffset -Schnelle Speichertimings -Max. Speicherfrequenz 2700 MHz -30% Powerlimit
Ergebnisse: 200W maximale Leistungsaufnahme, 2-3% Performanceverlust in Spielen. Extrem leise.
OK, auf CB gibt es schon recht gute Tests:
Update: es ist jetzt eine 9070 nonXT geworden für 549€ - bin gespannt welcher VRAM verbaut ist!
Meine Mercury OC (Samsung) läuft bei -30% PL (238w) mit -80 bis - 110mV. VRAM 2850-2920mhz für Gaming. Die verliert keine 5% an Leistung und ist damit immer noch schneller als zum Beispiel eine 9070XT Swift.
Interessant wäre für mich mal eine Swift VBIOS oder gleich ein 9070 VBIOS zu flashen um mal zu schauen wie effizient man eine 9070XT wirklich betreiben kann.
Hat jemand eine Idee warum ich eine luftgekühlte Powercolor Red Devil kaum über 3ghz bekomme im Steel Nomad ?
meine Settings , memory ist Hynix
CPU ist n 5800X3D
Vielen Dank schonmal . Clocks wie eure , 3,1 oder 3,2 ghz sind völlig ausser Reichweite . Was muss man tun ?
Ok best so far...pretty minor adjustments in linux
448w PL
+25mv gpu core
+50mv vram
+25mv vccdi
1.50 multiplier for TDC
I hit the PL easily...so gonna add a bit more to it.
Behaviour i noticed i had to drop the undervolt slider a bit -95 vs -105 or it would crash.kept core offset at +400(no idea what im doing with this yet!)
increase in hotspot temp from 54c to 61c at 448w..so plus 74w/ 7c...gonna see what i can get out of it on the loop before i try the chiller...then probably sub zero
Loop temp was around 25/26c
Also...why two hotspot temps now?
Das ist ja echt cool mit dem PT über Linux. Kann ich leider nicht testen. Aber zum hier und da benchen reicht das ja völlig und man muss nichts löten^^ Hoffentlich geht das bei zukünftigen Gen auch noch :)
Ja schon, aber bei 98fps (100hz moni). Und der Test kommt nicht an die 100fps
Auch wenns vielkleicht egal ist, beim Benchen niemanls ein FPS Limit setzen. Weil die Testlast is ja nicht konstant. Die FPS variieren. Mit einem Limit schneidest du dir ggf. Spitzen ab, welche dir dann im Mittelwert=Score Fehlen. Der Monitor ist da egal.
Es gibt aber auch Karten, meine auch, die einfach über ein bestimmtes Limit nicht weiter hoch kommen.
Es ist eine XFX 9070 Swift aufgetaucht, welche sich nicht mit dem ModFlasher Flashen lassen will.
Die Karte nutzt einen SPI ROM IS25WP016D, scheinbar mag die AMDVBFlash Version von Acer diesen nicht.
slowly creeping up
500w power limit...which im hitting again...
25mv on core only
Temps still manageable...still the loop..not even the chiller yet....gonna give it more juice but i guess the stupid 12v 2x6 cable is gonna be my limit...675 watts?!
Habe eben das 9070 XT Pure Bios auf die 9070 Pulse geflashed^^
7000 Punkte im Steel Nomad.
