qq948371167
Profi
It seems that the 40903DMark Time Spy Extreme score of the forum is not high
Basically, you lower Iout gain for power limit and add offset for more volts..Can I see your evc data?
I still can't successfully use evc because I only reduce the output current gain, but it doesn't give me any higher power consumptionThat one goes to Holzmann i'd say
Guess you know already?
Stimmt nicht ganz ,PL ist nicht ganz frei.Normally if you set Iout gain of loop 1 address 22 to 100 you dont have PL anymore..
"Virtually no PL". Wo liegt das ca. mit 100? Man kann ja sicher auch noch tiefer gehen..Stimmt nicht ganz ,PL ist nicht ganz frei.
Yes it is wrong. You need to add 2856 at Adress 22! for GPUIs my chip added wrong? It reduces the current output gain and still cannot take effect
Here are the correct addresses:What was added to address 24 and address 26?
Sapphire 7900XTX super platinum also common this configuration? Thank you for your helpHere are the correct addresses:
MP2857 —>22 (Core)
MP2857 —>24 (SOC)
MP2856 —>26 (Memory)
As far as I know all 7900XTX have same addresses.Sapphire 7900XTX super platinum also common this configuration? Thank you for your help
If you press scan butten on I2C menu in EVC it will list the addresses.Sapphire 7900XTX super platinum also common this configuration? Thank you for your help
The addresses are right 22, 24, 26. I just don't know how to add those chipsAs far as I know all 7900XTX have same addresses.
You can look which addresses are listed there.
It should usually list 22, 24, 26.
That can't be difficult.The addresses are right 22, 24, 26. I just don't know how to add those chips
No mine is at 43.258k.Ok, thank you. I will study hard
Your 4090 has to be accelerated, my friend is 45,000, I'm almost 43,000
Not every 4090 kann hit 45k.Look forward to your good grades, I can have better data to learn
So that's how he achieved 45k. Through a bug.After my friend's evc connection, the core overclocking Settings cannot take effect, but the video memory overclocking Settings can take effect. If the core frequency is changed, loop1 vid, iout gain, the core frequency changes cannot take effect
My friend who runs 45,000 points said that your scoring data is very powerful, and he ran 45,000 by bug
Result not found
www.3dmark.com
Memory has cold bug so putting water at 6°C the menory performance drops. There I am waiting for VRAM heater to arrive.
I ordered one from Elmor.
Möglichst im Nicht-Powerlimit, also entweder mit ASR-XOC-BIOS oder reduziertem Iout Gain. Oder kräftig undervolted natürlich.Wieviel TS-Grafikpunkte machen 250 MHz VRAM-Takt bei der 7900 XTX etwa aus?
It's your turn!
Aber endlich hast du geschafft dein KF auf 8400 Speicher zu laufen.Sieht schlecht aus für mich, die 43K schaffe ich wohl nicht mehr /:
I scored 33 537 in Time Spy
Intel Core i9 processor 14900KF, NVIDIA GeForce RTX 4090 x 1, 32768 MB, 64-bit Windows 11}www.3dmark.com
Na, auf den Balkon mit dem ganzen KlimbimSieht schlecht aus für mich, die 43K schaffe ich wohl nicht mehr /:
Und hoffen das die VRAM nicht mit cold bug getoffen sind.Na, auf den Balkon mit dem ganzen Klimbim![]()
