Butanding1987
Profi
- Ort
 - Philippines
 - Delidded 7950X3D / 5950x
 - Asrock X670E Taichi / MSI X570s Unify-X Max
 - Custom loop — 2x360mm RAD, Bykski GPU block, Mycro, 3xD5/3x360mm RAD, GPU Eisblock, TechN AM4, 1xD5
 - Patriot 8000@6400 CL28 / G.Skill 3800 CL14
 - Sapphire 7900 XTX Nitro+ / Sapphire RX 6800 XTk Nitro+
 - 3440x1440p / 3440x1440p
 - 2TB Kingston Fury Renegade / 1TB Kingston KC3000
 - Asus GT501 / Asus GT 502
 - Corsair HX1500i / Seasonic Prime Platinum 1300w
 - Windows 11
How long was the PC running with the CPU installed in the socket incorrectly? My first CPU (486 DX266) cracked after it was incorrectly installed. I wonder whether modern CPUs have better protection. I don't understand some things that you wrote, maybe it's the Google translator. You said your XTX BIOS2 has been modified? How?
So the XTX was working on air and the problem started when you installed the water block and put the CPU in the socket the wrong way?
 Das zweite GPU-BIOS – läuft nicht.
