[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Aha…
Also mir hat die Leistung in Dying Light 2, RDR2 und vielen weiteren Games nicht ausgereicht.
Selbst MW2019 mit alles auf Anschlag war nicht mit durchgehend 120 FPS drin, sodass ich paar Sachen auf low stellen musste wie die Reflections.
Die 4090 ist die erste Karte, wo ich mir vorstellen könnte, eine Generation zu überspringen.
Ich habe die 4090 auch nur geholt, weil der Sprung wirklich gewaltig ist. Manche Game laufen nahezu doppelt so schnell wie mit der 3090.
Kommt halt auf das Game und den Settings an. Aber bei RDR2 auf 4K mit Anschlag Settings war Feierabend mit der 3090.
Klar, wer mit Drops auf 30 FPS leben kann, wird hier glücklich :fresse:
Also die low FPS Drops bzw 99% Drops bei TLOU und Dead Space Remake sind bei mir mit dem 5800X3D und RTX 4090 sind echt massiv, teils Drops bis auf 20er Bereich bei DS und um die 40er bei TLOU und dadurch diese nervigen Micro Ruckler...
Das geht dermaßen auf die Nüsse, da man sich sonst eigentlich auf extrem hohen Einstellungen ohne Probleme bei über 100 FPS in 4k nativ oder mit DLSS bewegt. Bei anderen Games wie Forza Horizon 5, Gears 5 oder andere Spiele habe ich sowas nicht... Liegt das nur an den Games oder was ist so deine Erfahrung?
TLOU weiß ich nicht aber Dead Space Remake liegt auf jeden Fall am Game. Wird wahrscheinlich auch nie gefixt werden. Kann dir nur empfehlen das Spiel in 4K nativ mit nem 60fps Cap und Controller zu spielen. Dann Sind die Ruckler nicht ganz so auffällig. Mit Maus bei über 100fps in 4K DLSS Quality war es für mich unspielbar weil es alle paar Meter ruckelt und man das mit der Maus deutlich spürt. Leider eine Krankheit aktueller Games, hauptsächlich AAA.
Ich spiel oft mit Controller am LG CX65. Da dreht man sich in der Regel nicht so schnell, wie mit einer Maus.
Dazu ein FPS Lock… das hilft ungemein.
TLOU spiele ich am 4K TV mit in 5K durch DLDSR 1.78 + Quality.
FPS auf 80 gelockt - ja manchmal kommt es hier und da zu Stuttering. 4K Nativ lief etwas geschmeidiger. Dafür ist die Grafik aber eine Wucht.
Bei Dead Space hatte ich die Frames auf 70 gelockt, das hatte gut harmoniert mit DLDSR 2.25 auf 6K + Quality.
Ob es an den Games liegt oder an der Hardware - ich weiß es nicht.
Witcher 3 in 4K Nativ artet manchmal auch in eine Diashow durch Stuttering aus.
Dann aber mit Quality läuft es nahezu einwandfrei.
5K DLDSR ist dann eine gewaltige Diashow mit vielen und langen Stutters - von 6K fange ich erst gar nicht an :o
5K + Balanced gefiel mir als Kompromiss am Besten.
Das werden wir feststellen, wenn noch schnellere Grafikkarten und CPUs zur Verfügung stehen 🥲
Ok Dankeschön, muss ich mal ausprobieren heute Abend!
TLOU hab ich ebenfalls in allen möglichen Settings getestet und selbst auf DLSS performance gibts immer wieder kleine drops vor allem wenn man in neue Räume kommt, die nach einer Zeit wieder verschwinden. Echt extrem nervig das ganze. Überlege mein System auch komplett auf Windows X Lite umzuschmeißen. Da soll alles etwas runder laufen... Ach ja spiele grundsätzlich solche Games mit Controller 🎮 am LG OLED C1, 65 Zoll von Sofa aus in Halbliegen 😂
Habe gestern mit einem PC Experten telefoniert und der meinte bei dem läuft TLOU auf einem Laptop mit einer 2070 Max Q ruckelfrei... 😮 Das ist unfassbar 😂
Ja wird wohl ewig so gehen... Es ist einfach schon seit einem Monat Ruhe mit Patches... Hoffe sehr, dass sich da noch was tut.
Sieht schlecht aus. Auf Steamdb tut sich bei dem Game absolut nichts mehr. Das ist immer ein ziemlich sicheres Zeichen, dass da niemand mehr aktiv dran arbeitet. Da die Konsolenfassung dasselbe Problem auch hat, wenn auch deutlich schwächer ausgeprägt, scheint es irgendein fundamentales Problem zu sein. Oder EA scheißt einfach drauf und das Entwicklerstudio wird für weitere Arbeiten daran nicht mehr bezahlt. Beides möglich. :fresse:
@SaiBot62
Ich glaub es nicht aber bei Callisto ist auch seit Monaten Stillstand. Was ist da bloß los. Bei games wie Halo Infinite oder sogar Max Payne 3, was 1000x älter ist, werden ab und an immer noch irgendwelche Aktualisierungen Gemacht und bei solchen top modernen AAA Titeln ist jetzt schon Ende Gelände? Ziemlich, ziemlich traurig ist es um die Gaming Branche geworden...
Und die Steam Keys für den Müllhaufen kosten immer 58€ einfach absurd. Hatte das D1 gekauft und sofort refunded, ich probier es nochmal wenn es das mal für 5€ im Sale gibt.
Da hast vollkommen recht... Richtig Müll und ein absurd hoher Preis für so ein abartig schlecht optimiertes Game.
17€ über Argentinien:
Hast du die letzten Monate unter einem Stein verbracht? Na klar liegt es an den Games:
Dann aber mit VPN auf eigenem Steam Account? Darauf hab ich genau null Bock :d Ich hätte ja auch kein Problem damit 58€ zu bezahlen wenn das Spiel technisch nicht so unverschämt wäre.
Meinen Willen habe ich ja artikuliert, fairer Steam Preis auf meinem Steam Account.
Ich weiß, dass die nicht immer die Accounts dafür bannen, aber bei meinem Glück passiert das garantiert beim ersten mal, also ne danke :fresse:
So sieht also deine Wille aus? Nunja kaum bis gar nicht vorhanden würde ich mal sagen. 😂
Ich benutze VPN bei Steam schon seit bestimmt 10 Jahren, habe mir da für jedes Land einen eigenen Account aufgemacht etc.
Was ich da an Geld gespart habe über die vielen Jahre, dafür könnte man sich bestimmt 1-3 4090er kaufen. Globalisierung ist was sehr feines, nicht nur für Unternehmen 🤘
Also hast du mehr als 20 Acc, dafür jeweils ne eigene Email und musst dich dann ständig in nen anderen Account einloggen?
Ok, da hätte ich einfach mal Null Bock drauf. Man muss ja auch nicht jedes Spiel sofort zum Release kaufen, Sales gehen immer und ordentliche Key-Reseller auch und die paar Spiele im Jahr die ich schnell haben muss, die bezahle ich dann halt "normal"
ich hab dafür einen extra zweit-account, der im ausland registriert und via diesem steam family kram in meinen hauptacc eingebunden ist. so wird der hauptacc nicht angegriffen, wenn denn mal was sein sollte.
Vor allen Dingen sind viele Spiele dann auch gereift. Habe Cyberpunk für 9€ bei Steam im Sale gekauft ein Jahr nach Release. Und da funktionierte dann auch schon das meiste.
Habt ihr das neue Pathtracing in CP2077 schon ausprobiert?
Ich würde mal sagen es wäre jetzt Zeit für die 5090.
4K DLSS Qualität +FG läuft dann zwar mit über 60 FPS aber man muss dann halt alle Register ziehen da mit die RTX 4090 das bewerkstelligt.
FG ist hier dann echt mal ein Game Changer.
Ich bin ja mal echt auf die ersten UE5 Spiele gespannt.
Also hast du mehr als 20 Acc, dafür jeweils ne eigene Email und musst dich dann ständig in nen anderen Account einloggen? Ok, da hätte ich einfach mal Null Bock drauf.
Mach daraus doch keine Wissenschaft… ich habe 4 Accounts (Deutschland, Türkei, Argentinien, Ukraine) und logge mich per Steam App und QR Code innerhalb von Sekunden ein. Und ich wechsle ja nicht täglich, eher monatlich.
Aber ja, wenn 1 mal im Monat sich Umloggen als zu nervenaufreibend und kompliziert betrachtet wird, dann ist die Trägheit schon sehr sehr sehr weit ausgeprägt. Denke dann ist Bett machen jeden Morgen schon eine harte Herausforderung 😂
Ich gebe zu, dass Steam auf mehreren Acc´s nicht gerade komfortabel ist. Aber von der Globalisierung sollte Jeder was haben
Ein Game vor 40 Jahren zu laden war deutlich nerviger und langwieriger als heute
Wenn Leute mit dicken High End Gaming PCs bei Games sparen müssen und am besten noch per VPN kaufen, echt traurig. XD
Ich für meinen Teil muss nicht sparen, ich sehe es einfach nicht ein denen 58€ für diesen Müll zu geben. Für gute Spiele gebe ich gerne 60€ aus, überhaupt kein Thema. Ich hab ja auch Interesse dran, dass weiterhin Qualität kommt. Leider waren einige Spiele die in letzter Zeit abgeliefert wurden echt ziemlich enttäuschend und Callisto hatte ich ja Vollpreis zum Release gekauft und dann sofort den refund eingeleitet nachdem es unspielbar war.
später kauft weil die Games eh verbuggt erscheinen, ist auch selber schuld
Das stimmt, ich finde es ja auch eher bemerkenswert, dass die aktuell immer noch so viel verlangen und man nichtmal günstige Keys bekommt, von den VPN Dingern abgesehen.
Ich spare überall, völlig egal wo. Selbst die 4090 Strix habe ich erst gekauft, als es sie günstiger gab.
Bei jeder anderen PC Komponente wurde genauso verfahren, meist über mydealz getrackt oder auch gebraucht gekauft.
Dieses Vorgehen halte ich übrigens konsequent bei jedem von mir gekauften Produkt bei, neuste Errungenschaft?
Der X3800 AVR, natürlich weit weg vom UVP, hatte ich Monatelang unter Beobachtung:
Und das gleiche Verfahren wird bei Allen Sachen bei mir angewendet, vom Kühlschrank bis zur Mikrowelle bis zum kleinsten Gemüsemesser .
Und ausgerechnet bei Games, von denen ich mir ca 2-4 im Monat hole soll ich aufhören sparen zu wollen? Weil? Ergibt für mich keinerlei Sinn…
Ähnliche Themen
Antworten
7K
Aufrufe
587K
