[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also die Benchie Ergebnisse sind out of the Box ok. Boost bei 2795MHz.
Zirpt wie eine Grille. Ich glaube rasseln ist der falsche Ausdruck. Es hört sich so an wie ein kleines RC Car mit Mini Benzinmotor.
Aber die Karte passt wie gesagt nicht richtig ins Mesh 205, daher warte ich noch auf das H7 und werde es dann im geschlossenen Gehäuse beurteilen. Musste den unteren Intake Fan ausbauen. :lol:
Kabel knicken und gut ist.
Meine neue Suprim X hat unterschiedliche Spulenfiep Geräusche wenn ich bei War Thunder das Thermalvisier an oder aus mache. Wenn ich im Thermal bin ist es eher ein fiepen, in der normalen Ansicht ein rasseln. Wie kann das bitte sein 🥹😂
Unterschiedliche FPS/Auslastung/MHz die anliegen.
Ehm, für den Preis kann man genau das erwarten.
Für den Preis einer Strix kann man erwarten, dass selektierte GPU`s verbaut werden, hochwertigere Bauteile verbaut werden und für den extra Aufpreis einer White Strix auch ein weisses PCB verwendet wird.
Also man kann sagen, dass bei der Strix das zirpen im offenen Gehäuse so ab 180W Verbrauch unangenehm wird. Wie ja schon mehrfach festgestellt, liegt es nicht an den FPS. In Menüs bei 400+ FPS hört man nix. Bei the Witcher und ~60FPS volle Lunte.
Allerdings ist ab dieser Grenze kein Muster mehr erkennbar. Die Karte kann bei 290W lauter sein als bei 350W. Das Zirpen ist auch total unregelmäßig. Ich hab mal den Dirt 2 Benchmark laufen lassen, das klang als ob die Karte das Motorgeräusch des Wagens nachmacht. :lol: Braucht man keine Boxen mehr. Auch wechselte es mit der Kameraperspektive.
Undervolten bringt stand jetzt nix, da ich nicht auf die <180W komme, logo.
Der Kühler und die Lüfter sind hingegen der Wahnsinn. Laufen meistens nicht mal an, und wenn dann maximal auf 30% und die Karte wird nicht wärmer als 49°. Dabei sind noch alle Folien drauf. Offenes Gehäuse, aber trotzdem sehr gut. Ich hoffe dass ein geschlossenes Gehäuse oder solche Ideen wie die Backplate etwas lösen was bringen.
Asus Ihr Volldeppen! Ein schwarzer Adapter zu einer weißen Karte? Ihr seid echt die dümmsten... allesfressenden Paarhufer. Man ey... :rolleyes:
Die Farbe erinnert mich mehr an Waschmaschinen und/oder Haushaltsgeräte :(
Für den Preis eines Ferraris can man erwarten, dass die Motoren nicht brennen. ;)
Eben. Wer extra zahlt, der zahlt sicher nicht für Qualität. Das war nie so, auch nicht bei Ferrari.
sind wohl genug da, aber keiner möchte eine :d
Kauft man sowas heute noch offline? Ohne Widerrufsrecht? Ich würde gar nicht auf die Idee kommen dort nach so einer Karte zu suchen. „Ach fahr ich mal nach MediaMarkt und guck mal, ob ich ne 4090 kriege.“ So denkt man nicht - oder liege ich da falsch?
Früher (90er bis 2010) war ich gern dort. Letztens war ich mal dort, um nach einem neuen Fernseher zu schauen. Weder das Angebot noch die Auswahl war irgendwie relevant für den anschließenden Kauf, den ich bei MM online getätigt habe.
Die Frostbite wäre übrigens noch immer erhältlich...
Überlege gerade, ob ich noch ne zweite Karte bestelle, falls die erste fiept/rasselt.
Warten wir es erst mal ab.
Ich habe um 11.36 Uhr eine Bestätigung meiner Bestellung bekommen, mehr aber auch noch nicht.
Der Laden öffnet am Montag um 10 Uhr wieder, da werden dann die Stornos kommen :D
Der Laden öffnet am Montag um 10 Uhr wieder, da werden dann die Stornos kommen :d
Sehe da wenig Risiko. Mehrere Shops haben seit heute die Frostbite mit 3-5 Tagen drin - da hängt sicher derselbe Distri dahinter, daher auch alle mit derselben Info... CU hat schon 10x verkauft.
Danke, das stimmt mich freudig :)
Hab ja lange mit mir gerungen, aber nun dominiert ganz klar die Vorfreude, da wäre es wirklich schade, wenn die storniert werden würde.
Hab mir auch gleich noch einen neuen Durchflusssensor bestellt, meiner hat schon seit einem Jahr den Dienst aufgegeben, und ich hatte keine Lust, Wasser zu lassen :d
Vielleicht noch für den ein oder anderen Interessant:
Welcher Saturn ist denn das? Naja ich kann mir gut vorstellen, dass man hier mehr Probleme mit der Rückgabe / Widerruf bekommt wenn einem die Karte nicht gefällt, da es ja vor Ort gekauft werden muss.
Darüber denke ich auch gerade nach!
Die Frostbite bis jetzt bei Computeruniverse 15x verkauft! 😎
Verrückt, ich hab letzte Woche alles abgesucht auf verfügbare Karten die schon mit nem Wakü kommen, keine einzige war vorhanden. Kaum kauf ich dann eine und bau sie um ist eine verfügbar und auch noch zu nem guten Preis :fresse:
Bin auch noch am überlegen. Habe zwar seit 1 Woche erst die 4090 FE aber warte noch auf den Watercool Kühler für den Eigenumbau.
Der große Vorteil der Frostbite ist die Garantie, der Nachteil ist für mich der Acrylblock. Den finde ich nicht so pralle.
Tja, nun bin ich am grübeln. :d
Ich hätte die auch wegen der Garantie genommen, aber da ich jetzt schon umgebaut habe ist es auch ok. Aussehen ist mir wurscht, das Ding steht eh im Eck rum :fresse:
Ich wein der Sache jetzt auch nicht hinterher aber es ist mal wieder typisch :d
Dito. Hab den WC für die FE vorbestellt und finde die Acryl Version nicht so prickelnd, leise Spulen und Garantie sind aber schon was feines... Ich schaus mir mal an.
Die neuen verkauften bei CU kommen wahrscheinlich von den Krokos...
Würdet ihr die Frostbite empfehlen wenn eh was mit Wasserkühlung sein muss?
Wer mit einem PT von 450Watt leben kann macht mit der Frostbite nichts falsch.
Was bedeutet das denn?
Ohne übertakten bzw. sogar etwas undervolten kann man die beruihgt nehmen oder ist die dann in der Leistung schon beschnitten?
@Lt.Face
Eine FE hat zb. 600watt zum gamen wird das aber voll ausreichen aber Taktrekorde zum benchen wird man mit nicht erreichen.
Dual Bios ist auch nicht vorhanden aber gut es hat hier schon User geben die auf ihre Frostbyte das Galax bios mit 666Watt geflasht haben also mit ein wenig Mut limitiert da nichts.
Das mit dem 100% Powertarget ist echt absurd bei dieser Karte, aber wenn man mit dem 450W zufrieden ist (was bei mir so wäre) dann passt die Karte ja gut, Preis ist in Ordnung.
Rein zum Gamen hat die 4090@Stock mehr als genug Reserven für alles, da geht es wie hier schon gesagt wurde letztendlich eher um bessere Benchmark Ergebnisse.
Also bin mal mit Bildschirmlupe ran, der 12VHPWR ist doch nich richtig drinne oder seh das nur ich falsch? 😵
Also wenn die 450W für 3Ghz Core reichen, ist das sowieso ausreichend, auch zu aufdrehen. Gerade die 4090er glänzt ja eher mit Effizienz im UV Bereich in meinen Augen. Wenn ich 7% weniger Leistung hab und 100W einspare, die mir meine Radi Lüfter selbst bei Vollgas auf silent bringen. Bring it on.
Davon abgesehen können die VRM Stages ja schon mehr ab und Biose gehen ja alle drauf. Muss man sich dann halt überlegen, ob es einem das dann wieder wert ist. Ich wäre ja schon happy, wenns kein Gurkenchip ist und halbwegs ohne fiepen und rasseln geht :shot:
Übertakten will ich nicht. Hab eher vor so wie von vielen berichtet das Powertarget noch etwas zu senken, da man Strom spart, die Karte aber nicht viel langsamer wird. Oder trifft das dan eher auf die mit 600 Watt PT zu?
Überlege nur was mehr Sinn macht. Die fertige Frostbite oder ne Gigabyte Gaming OC oder vergleichbar und Kühler selber umbauen
