[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Denke entweder kommen die zurück oder zu amd oder die gehen pleite .
Ich habe bisher immer nur bei "GPU Power" (obendrüber) geschaut. Das ist auch der Wert, den MSI AB/RTSS abgreift und der im Ingame-Overlay las Verbrauch dargestellt wird.
Das ist auch der richtige Wert. Lass dich nicht verunsichern. Keine Ahnung warum @***** immer noch daran glaubt, der andere Wert sei der reale Stromverbrauch. Es sind irgendwelche spontanen peaks im Millisekundenbereich oder whatever.
Das ist ein alter Hut:
"Note, that the core power might sometimes seem higher, due to instantaneous peaks, which are averaged in the total (chip) power calculation."
Naja du musst bedenken es geht hier um eine Karte mit dem Anschaffungspreis von meist ~50-100% des monatlichen Nettoeinkommens vieler. Da ist die Frage "Was passiert im Falles eines Defektes?" schon angemessen und hat auch nichts mit Hypochonder zu tun.
Auch du solltest deinem Rat folgen und deinen Verstand benutzen. Die meisten Boardpartner schreiben in den Garantiebestimmungen, dass die Karte mit dem Orginalzubehör einzusenden ist. Garantie ist eine freiwillige
Leistung des Herstellers, die Bedingungen darf er völlig frei formulieren (nicht mit Gewährleistung verwechseln).
Wenn ich nun meine verbrannte Karte einschicke und einen unbeschädigten Adapter beilege wird es schon schwierig mit der Garantie (Kulanz mal ignoriert), auch den Adapter mit z.B. einem Heißluftföhn einschmelzen würde nichts bringen. Das blöde bei geschmolzenen Plastik: Man kann sehr eindeutig zuordnen, ob die beiden Teile zum Zeitpunkt des Ereignisses verbunden war. Kurz: Der Hersteller weiß ziemlich genau was im Falle eines geschmolzenen Anschlusses passiert ist.
Andere Frage in eigenem Interesse: Hat hier jemand Erfahrungen mit der PNY XLR8? Ich hatte die mal "günstig" bei Amazon für 2130€ geschossen, VRM ist aber ziemlicher Müll wie ich nachträglich herausgefunden habe (14x50A auf Vcore)... ist der Kühler der Karte gut, man liest unterschiedliche Infos? Oder trash und direkt zu Jeff zurück?
Vorteil bei Jeff: Wenn wirklich mal was mit dem Ding ist, dann gibt es eben bei Amazon die ersten 24 Monate das Geld binnen 48h zurück, no questions asked...
Zielsetzung war eigentlich ja eine 4090 TUF für 1949€, aber das ist wohl aktuell realistisch betrachtet eine Träumerei...
Vielleicht hierauf nochmal Bezug nehmend, als kleines Mini Review der 4090 XLR8:
Ich habe die Karte jetzt mal ausgepackt und eingebaut... ist nen echtes Monster und wiegt auch knapp über 2,1kg... erwartet man bei der Größe gar nicht. Viel des Gewichtes entfällt vermutlich auf den "Stahlträger" welcher die gesamte Karte stabilisiert und mit allen 3 Slots der Slotblende verschraubt ist... die karte ist auch ohne zusätzliche Halterung komplett gerade, das ist schon mal beeidnruckend und sehr wertig. Optisch ist sie real auch deutlich ansprechender als die Renderbilder online, RGB kann für 3 individuelle Zonen eingestellt werden. (XLR8-Logo und jeweils vorderer und hinterer Bereich des X).
Karte also eingebaut und mal geguckt was der Kühler so leistet... kurzum die Lautstärke und die Temperaturen sind der Wahnsinn. Die Lüfter machen keinerlei Nebengeräusche, gefühlt auf dem qualitativen Level eines Gehäuselüfters alá Arctic P14. Auch sehr beeindruckend waren die Temperaturen, nach einer Stunde Superposition im 8K Preset hatte die Karte einen Peak bei 68 Grad auf dem Core und die Lüfter gingen bis max 1200 rpm... bitte beachten Superposition ist worst case und es wurden permanent 450W gezogen. Hotspot lag bei 75 Grad und Speicher bei 73 Grad... Gehäuse ein Fractal Pop Air. Die Lüfter waren eigentlich die ganze zeit über sehr leise, gehört hat man nur die Luft die bewegt wird... und das Spulenfiepen...
Das ist leider die eine wirklich miese Sache.... die Karte schreit wie ein Kind was etwas im Spielzeugladen haben möchte... noch nie gehört sowas.... scheint aber laut Reddit eher genau meine Karte zu treffen als die Masse... viele schrieben ja, dass es bei ihren Karten nach einer Weile besser wurde, darauf werde ich nun wohl auch mal pokern.
Die Karte hat leider nur ein 450W Powerlimit, ich konnte mit stock Voltage allerdings trotzdem den Takt auf 2980 MHz erhöhen und der Speicher konnte mit +1900MHz stabil versehen werden. Alles in allem also eine absolut solide und mittelmäßige Karte, bzw. gar leicht überdurchschnittlich, das 450W Powerlimit war kein wirkliches Problem.
Jetzt kommen wir als letztes zu dem Thema, welches mich auch sehr gewurmt hatte.... der grottige VRM der Karte, speziell auf Ebene des Core.
Wenn man so durch das Internet scrollt und auch das Video von Bullzoid gesehen hat ist man erstmal geschockt, die Gainward und Palit Karten wurden komplett zerrisen für den Einsatz von nur 16 DrMOS-Komponenten und noch dazu nur NCP302150, während andere Hersteller auf eine höhere Anzahl oder bessere Bauteile setzen... manche Karten haben ja sogar Smart PowerStages...
Die PNY 4090 hat sogar noch einen "schlechteren" VRM... hier werden nur 14 NCP302150 verbaut... absurd, oder?...
Um es kurz zu machen.... NEIN!
Ich war auch erst geblendet von der Allwissenheit des Internets, aber praktisch zeigt sich, dass der VRM der PNY mehr als ausreichend für ein 450W Bios (und darüber hinaus) ist.
Von den 450W Boardpower landen lediglich 370-380W bei dem Core selbst. Die 4090 verwendet eine Spannung von 1,05V, es ergibt sich also bei Vollauslastung ein Bedarf von ~362A sustained Current welcher der VRM zur Verfügung zur Verfügung stellen muss. Diese 362A verteilen sich nun auf die 14 NCP302150, es bleibt also bei ~26A die jeder NCP302150 liefern muss. Ein kurzer Blick in das Datenblatt (https://www.onsemi.com/download/data-sheet/pdf/ncp302150-d.pdf) zeigt nun, dass dabei ~2,6W an Verlustleistung je NCP302150 anfällt, also 36,4W über den gesamten VRM. Das ist wahrlich überhaupt kein Problem über die gesamte Fläche und den potenten Kühler, auch ist das Bauteil gerade einmal etwas über 50% ausgelastet... die Karte ist also weit weg davon einen unterdimensionierten VRM zu haben. Ja er ist schlechter als bei der Konkurrenz, aber dafür bekommt ihr einen absolut soliden Kühler :)
Ein 600W Bios würde ich nicht auf die Karte packen, das würde zwar auch funktionieren, allerdings kommt man bei 600W dann doch langsam an die thermische Grenze von dem VRM Design (hier haben wir schon ~70W an thermischen Verlusten). 500W Boardpower sollte für diesen VRM ungefähr das sinnvolle Limit sein, hier haben wir ~50W an Verlusten über den VRM
is alles Referenz Design
Ja, aber es kommt ja auch auf die Bestückung an.
So ist das Ref Design zwar für 24 Phasen ausgelegt, Inno verbaut aber nur 14, was dann wiederrumm auch das PT von 450W erklärt.
Der Hersteller wird es ja auch nicht total gewürfelt ausgelegt haben sondern rein Rechnerisch wird es schon passen. Zu einem früheren sterben eines VRMs kann es dennoch dort eher kommen. Es passiert ja auch öfter mal bei Karten mit deutlich mehr VRM das was stirbt. Die Wahrscheinlichkeit ist halt größer. Problem wird eher der Strom als die Thermik sein. Im Theoretischen Idealfall sind 26A nicht das Problem. Rechnet man aber noch ein paar mehr Praxisnahe Einflüße mit rein ist die Belastung halt schon hoch verglichen zu einer Auslegung mit noch mehr VRM zweigen.
1. Der Strom wird sich nicht 100% Aufteilen auf die jeweiligen VRMs sodas manche mehr als andere abbekommen von der Last
2. Es gibt in der Regelung immer Peaks die auftreten wo einiges höher liegen als der reguläre Strom der Fließt
3. Was sicherlich der Hauptgrund für ein Ableben ist die Einflüße die der Hersteller nicht vorgesehen hat, anderes Bios mit mehr Watt und Undervolting dann kanns schonmal puff machen.
Ich könnte auch 4 nehmen aber mit der 4090 nicht nötig. Wasser liegt 11 Grad über Zimmer und gpu 10 bis 11 grad über Wasser. Das passt.
Paar Phasen weg gelassen und schon bleiben paar Öcken mehr hängen, Smart Power Stages sind auch nicht gerade günstig derzeit.
CP 2077 ist auf jedenfall fordernd für die 4090 und denke auch Watch dogs Legion und dying light 2 alles mit RT . Alles ohne RT ist für die 4090 echt kein Ding mehr in UHD .
Nvidia ist egal welcher Name auf der Rechnung steht. Die wollen die Original Rechnung. Hat bei mir schon funktioniert. Und wie sich NBB verhält finde ich absolut unkulant … trotz der Abzockerei bei schlechter Verfügbarkeit.
Nee das ist richtig so. Auch wenn es nicht wirklich was bringt, aber dieses Scalpen sollte in keinem Fall unterstützt werden.
Heute die 4090FE bekommen, hat wunderbar geklappt!
Mal kurz das erste OC Limit ausgetestet:
Je nach Last zwischen 3.015 MHz und 3.045 MHz Core-Takt. Speicher geht ziemlich genau auf 1.500 MHz, danach wird er instabil.
Das Ding passt locker in das Lian Li O11D XL, nur musste ich einen Lüfter des Seitenradiators entfernen, weil der im Weg war (Ist wirklich ein dicker Klopper). Sobald mein EK Block da ist, kommt der wieder rein und dann wird das System auch mal Grund gesäubert:
Wirklich ein Wahnsinnskühler. Die Lüfter waren zunächst aber wirklich ohrenbetäubend Laut auf 100%. Die mussten sich erst etwas einlaufen. Auch rasselte die FE schlimmer als jede Karte die ich vorher hatte. Auch das ist schon etwas besser geworden, allerdings ist es immer noch deutlich hörber ab 100-150 FPS aufwärts.
Ich habe auch direkt ein natives Cablemod Kabel verwendet und nicht den Adapter. Was beim Cablemod Kabel direkt auffällt, es sind andere Pins:
Ich habe jetzt leider kein Bild vom mitgelieferten Adapter gemacht, er sieht aber genau so aus:
Es fällt auf, dass die Buchsen beim Adapter durchgängig gespalten sind, während Cablemod eine stabilere Variante nutzt, die nur an einer Stelle aufgetrennt ist.
So viel mal zu meinem Ersteindruck ^^
Soo, alles fertig:
(finde es btw sehr schade, dass ausgerechnet das „Geforce GTX“ Logo nicht beleuchtet ist…)
PL 90%, +100/+900:
Erzähl Mal wie ist die Lautstärke im Silent Mode wie ist die Anlaufdrehzahl der Lüfter nach Zerofan bei welcher Temps laufen sie an.
Temps /GPU /RAM Vram /Hotspot /undervolting ohne Takt zu senken bitte ohne Fenster Mod !
So was halt ein schönes 24/7 Setting sein könnte 🙂
Geh ruhig ins Detail.
Vielen Dank !
Freue mich für dich
Grüße
NBB schadet aber auch damit den Leuten die vielleicht von netten Mitmenschen eine zum EK bekommen konnten. Ich finde das es letzten Endes auf dem Rücken des Besitzers/Verbrauchers ausgetragen wird. Die machen es sich da einfach und versuchen es schön darzulegen.
Dasss das ganz kurze Peaks sein müssen, kann man auch dadurch erklären, dass sie den Durchschnittlichen Verbrauch (auch in HWInfo ersichtlich) kaum nach oben treiben. Insofern können sie auf der Zeitachse nicht lange und/oder häufig auftreten. Und wenn das so ist, dürfte das auch kein Problem für die Karte oder den Stecker sein.
Was allerdings dem Zusammenhang interessant ist, ist dass das nicht überall auftritt. Ich habe diese Peaks z.B. nie in 3D Mark gesehen (egal welchen Test ich versucht habe), aber ständig in Cyberpunk. Es wäre schon interessant was das triggert. Ich habe auch schon in Cyberpunk versucht ob diverse Einstellungen diese Peaks abmildern oder ganz verhindern, aber ich kam im Grunde nur dann auf ein Ergebnis, wenn ich die Framerate extrem gebremst habe (z.B. VSync auf 72 Hz).
Immer dran denken: ihr habt idR Garantie. Wenn die Karte wie vom Hersteller vorgesehen betrieben wird und aus irgendeinem Grund im laufenden Betrieb beschädigt wird, kann man darauf zurückkommen. Ist nicht optimal, sollte aber beruhigen.
