[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hallo Zusammen,
da ich neu im Forum bin, kann ich keine PM an memphis@mg schicken. Soweit ich das gelesen habe sammelt er / du (falls du es selbst liest :d) die Seriennummern von den Gainward Phantom Karten.
Zu meiner Phantom GS -> bei 30% Lüfter das schöne Rasseln oder was auch immer der / des defekten Lüfter/s. und wenn sie höher drehen sind Frequenzen dabei, die meinen kompletten Tisch vibrieren lassen.
Habe das Ding bei Alternate gekauft und dort vorhin auch mal den Support angehauen. Mal schauen was die dazu sagen.
Aber auch um was positives zu bereichten - kein Spulenfiepen und aus dem Stand heraus macht sie erst mal 2820 Mhz ohne dass ich da mit Tools was verändert hätte.
mfg Zorn
Welches Games ist denn bei 120FPS in der Lage die CPU auszulasten?
Es gibt ne Menge Spiele in denen mein 12700 mit 3200cl16 keine 118fps erreicht es sind genug. Aber wir driften vom Thema ab
Welches Games ist denn bei 120FPS 4K in der Lage die CPU auszulasten?
Vergiss die cpu auslastung. Die ist wurscht.
Schau einfach hier unter 4k
Ein bissl limitiert er schon, aber deshalb würde ich mir (hab auch 5950X) keinen kompletten Unterbau 12900K/13900K, MB und RAM kaufen
Diese paar fps weniger spürt kein Mensch
Ein cpu bench in 4k mit einer 3090 bringt ihm nichts.
Er muss einfach nur auf seinem System das cpu limit testen
Dauet keine 5minuten pro spiel
Völlig am thema vorbei. Es geht um einen 5950x. Und jetzt nenn mir ein Spiel. Du hast doch gerade so laut gesagt, dass ich falsch liege...
Anno 1800, cities skylines, farcry 6, gta5, zelda botw, warzone, etc...
Beachöftige dich bitte mit der Thematik. Wenn er dir glaubt und er spielt dummerweise anno 1800, dann wird ihm die 4090 nichts bringen aber du hast ihm ja gesagt, kein problem.
Ich will das er selber rausfinder und versteht wie er das selbst ermitteln kann.
schau dir mal das an... das ist bei mir auch so und der hat nen 7950X
nein ist es nicht, denn er versucht zu erklären warum diese aussage pauschal einfach nicht korrekt ist.
eine cpu bringt in jeder auflösung die gleichen fps unabhängig von der gpu.
wenn man das weiß, kann man für seine spiele schauen ob die gewünschten fps, z.b. 120 weil der monitor das kann, bringt oder nicht.
Dann spiel Du mal Cyberpunk in 4K Psychotracing in 120FPS und zeig mir, dass dein Prozessor ausgelastet ist.
Also ich schaffe es in 4587x1920 alles auf Anschlag mit DLSS durchaus auch Mal stellenweise ins CPU Limit in Cyberpunk. Und in Spiderman is das quasi Dauerzustand, in Far Cry 6 auch.
Ahh, da sist aber ärgerlich, diesen Status habe ich noch nie gesehen. Da muss wirklich etwas unvorhergesehenes passiert sein. Und wenn sowas passiert dann befindet man sich häufig außerhalb der normalen Prozesse, was dann individuelle Problemlösungen erfordert, was in Konzernen erfahrungsgemäß dann meist zu weiteren Verzögerungen führt. Ich würde aber vermuten, daß Du diese Woche noch eine Zustellung bekommst, ob heute ist nicht klar. Wenn es doof läuft wurde das Paket beschädigt und muss neu umverpackt werden, was dann durchaus eine Woche dauern kann. Aber ich drücke Dir die Daumen das da bald was kommt. Am besten Du rufst DHL an und fragst nach was genau Sache ist, die haben möglicherweise mehr Daten in ihrem System.
Hab' ich gemacht, die Dame am Telefon erklärte mir das das Paket am Samstag dann im Verteilerzentrum ausgeladen wurde, weil der Zusteller die Ware nicht im Wagen lassen darf und heute im Verteilerzentrum neu bearbeitet würde und morgen geliefert werden müsste. :LOL: Ich bin gespannt...
4k ist auf 120FPS begrenzt. Wegen HDMI 2.1 und DP1.4
Also reicht da der Prozessor.
Alles was darüber geht ist dann komprimiert und das will keiner.
Hz ist nicht gleich FPS. Und HDMI 2.1 geht bis 4k 144hz und mit DSC (kompression) bis über 300hz in 4k...
Schau einfach hier unter 4K
Genau diese Antwort wollte ich hören 👌🏽🤪
Spiele tue ich zur Zeit call of duty black ops Cold War
Lg
Schließe ich mich an. Spider Man Remastered lastet meine 4090 in 4k@120hz nicht aus... die dümpelt so bei 60% rum und liefert auch nur 60-90FPS. Erst DLSS3 und Frame Generation liefert an die 120fps, aber noch immer voll im CPU Limit mit nem 5900X
Stell mal unter Raytracing die Objektreichweite etwas runter. Das zieht ordentlich CPU Leistung.
Würdet ihr die Karte zurückschicken ? Man hört dieses brummen des Lüftermotors durch das geschlossene Case.
Es sind alle 3 Lüfter die so brummen. Im Zotac Reddit Forum sind auch schon andere Leute die das selbe Problem haben.
Im Video muss man die Lautstärke hochdrehen, da es ziemlich schwer ist das brummen aufzunehmen.
Was auch auffällt ist das nicht die Lüfter brummen sondern die Motoren. Merkt man daran, das sobald ich die Lüfter stoppe im AB
das das brummen direkt weg ist, obwohl die Lüfter noch nachlaufen.
hehe dann ist ja gut wenn ihr Lösungen habt. Wir hatten halt hier nur schon seit einiger Zeit die genauen Abmessungen aller Karten im Startpost, daher wär es zumindest möglich gewesen, noch deutlich bevor man den Kaufbutton drückt rauszufinden, was überhaupt passt oder nicht, Daher war ich einfach etwas verwundert :)
Nunja bei einem Gehäuse steht es nicht immer fest. Außerdem weiß ich nicht wie weit ich den Adapter biegen kann, ohne ihn in der Hand zu haben.
Ich habe vom Ende des Slots ca 50-55mm bis zum Panel. Das Ende des Slots sind ca 112mm GPU Höhe, alles was drüber ist + der Adapter müssen in den 50-55mm rein...
Eine FE trägt 25mm auf mit 137mm Höhe und der Winkeladapter wäre 23.2mm...wäre knapp, passt aber. Der Nvidia Adapter selbst ist vermutlich bei 4-5cm... und wäre zu hoch...außer ich mache einen agressiven 90° Knick :d
Ein 5950x wird für eine RTX 4090 nie ein Flaschenhals werden wenn diese 4K 120Hz erreichen soll.
by Cyberpunk ist es die GPU
Bei Dying light 2 die CPU
bei Counter Srrike oder jedes andere Game ohne RT ist es keines von beiden.
Zeigt mir ein konkretes Beispiel.
Alle 3 Karten instant weg... Von wegen großer Verkauf ^^
ich hab dir doch das Video verlinkt... bei ihm ist es ein 7950X und er ist bei Spider Man, Halo und Far Cry 6 im CPU Limit
ist doch wurscht was wir machen würden, wenn es dich stört: zurück damit... ist ja keine 300€ Karte
Naja, die Karte hat kein Spulenfiepen. Wenn ich wüsste das ich nicht 5 Wochen auf eine RMA warten müsste,
würde ich die Karte einschicken.
Wenn ich die Karte so zurückschicke, wars das für mich mit dem Thema 4090 weil es keine gute Lieferbar gibt.
Werd mal bei Zotac anfragen, wie lange eine RMA dauern würde.
Dann gib mir ein Timestamp. Habe jetzt keine Zeit 20 Minuten im video zu suchen was Du mir nicht konkret nennen kannst.
In d
RTX 4090 - 21:9 // Overkill for 3440x1440?​
ist nicht UHD!!!
Spiderman Remastered :). Stell da alles auf Max und der 5950X liefert dir keine 120 fps.
Edit: Sorry, sehe gerade das es oben schon erwähnt wurde.
Edit2: Ich renne da sogar in 5k mit meinem 5900x ins CPU Limit. Ist einfach nicht gut optimiert in dem Bereich, da die CPU zu Teilen die Raytracing Berechnungen übernimmt sowie ich es gelesen habe.
ist das jetzt dein Ernst? Soll ich dich noch an die Hand nehmen und am besten per Teamviewer helfen?!!!
2:55
das Video hat sogar bookmarks für die....
Also meine 4090 hängt in CP2077 häufig im CPU Limit in 4k RT Psycho, gerade mit RT wird die CPU zum Flaschenhals.
Auch mit der 3090 schon, zwar nicht ganz so häufig aber definitiv vorhanden.
Jippie...Bestellung im Asus Webshop scheint durch zu sein, einfach zufällig die Artikel auf der Wunschliste in den Warenkorb gepackt und da war sie drin, gab ja nicht mal eine Verfügbartkeitsbenachrichtigung 🤪
Wollte zwar eigentlich keine Tuf OC, aber immerhin gibt es die dort zur UVP, so hat sich das Thema jetzt erledigt und ich kann in Ruhe weiter Fenster putzen 😁
Mfg
Kiryu
Habe ich gemacht. Meine GPU ist dann bei 99%! Sehe da keinen CPU Flaschenhals.
2:55
ich dachte wir reden von UHD???
ist nicht UHD!!!
Ja wenn ich Zuhause wäre könnte ich dir schnell Nachweise zeigen (in Spiderman, Far Cry 6, BF2042, Warzone und wie sie nicht alle heißen... in 4587x1920 (und jetzt sag nicht "ist nicht UHD" das sind 8,8 Mio Pixel... UHD hat weniger), aber die Diskussion bringt doch jetzt auch nicht wirklich was, und gehört in dem Umfang hier auch nicht mehr rein denke ich :)
