[Sammelthread] Cinebench R23 - Rangliste
Domdtxdissar ST = 2167 points
Windows 10 x64 - AMD Ryzen 7 7950x | 16/32 @ ~6000mhz | ROG CROSSHAIR X670E HERO | 2x16GB DDR5-6200-28-36-36-28 1T
Domdtxdissar MT = 42257 points
Windows 10 x64 - AMD Ryzen 7 7950x | 16/32 @ ~5700/5400mhz | ROG CROSSHAIR X670E HERO | 2x16GB DDR5-6200-28-36-36-28 1T
Large custom watercooling loop. (4 pumps + MO-RA3 420 + NexXxoS Monsta Full Copper 400mm + 10L water among other things)
nevermind the "1.61" vcore, its a readout bug.. Highest voltage used was 1400mv.
Sepultura SC - 1964
Windows 11 - I7 12700K | 12/20 @ Intel Spec (PL1 125W/PL2 190W) - MSI Z690 Edge WiFi (DDR5) - 2 x 16 GB DDR5 6000 @ 6200 36-36-36-76
Sepultura MC - 22767
@pepe.tar.xz Ich möchte erhöhen. Bitte die alten Ergebnisse gegen die neuen austauschen. Danke
Multi Core:
Induktor - 19.668
Windows 11 - Intel i7-12700H - Lenovo Legion 5i Pro - 2x16GB DDR5-4800-34-34-34-76 - Notebook
Single Core:
Induktor - 1.823
@pepe.tar.xz
Holzmann - 2402 Singe Core
Windows 11 x64 - Intel 13900KF | 5.8 AC / 6.1 SC – 2x16GB DDR5 6000 Cl40
Single Core:
<oo> - 2285
Windows 11 x64 - Intel 13600KF | 6P/12 @ 5.84 SC - MSI Z690 Edge WiFi (DDR4) – 16GB DDR4 4000 Cl17
snakeeyes - 2410 Singe Core
Windows 10 x64 - Intel 13900K | 6.1 SC – 2x16GB DDR5 7000 Cl32
snakeeyes - 2450 Singe Core
Windows 10 x64 - Intel 13900K | 6.2 SC – 2x16GB DDR5 7000 Cl32
Wird leider nicht angezeigt, da mein LN2 Score höher ist.
Small update:
Domdtxdissar ST = 2182 points
Domdtxdissar MT = 42719 points
Older benches for fun :)
R20 = 847 ST and 16566 MT
R15 = 347 ST and 7013 MT
R11 = 4.04 ST and 76.19 MT
Holzmann - 43465 Multi Core
Windows 11 x64 - Intel 13900KF | 5.8 AC / 6.1 SC / 4.6 E Cores – 2x16GB DDR5 6000 Cl40
webmi - 2339
Windows 11 - Intel i7 13700K | 5.7 AC / 6.0 SC - Asus Strix Z690 - 2x16GB DDR4-4200C16
webmi - 33014
Sepultura SC - 2005
Windows 11 - I5 13600KF | 14/20 @ Intel Spec (PL1 125W/PL2 181W) - MSI Z690 Edge WiFi (DDR5) - 2 x 16 GB DDR5 6000 @ 6400 36-36-36-76
Sepultura MC - 22942
Ram etwas übertaktet , CPU @ Stock , wobei ich mal wieder manuell einstellen muß da MSI beide limits auf 181 setzt , wodurch ich eine schlechtere Performance als mit dem 12700K habe.Bei Intel Spec steigt die Leistung darüber :-)
WolfJ13
Windows 10 - 7950X - Curve Optimzer -10 - Asus X670E Hero - 4 x 16 GB DDR5 6000 Mhz 30-38-38-38-96 (Stock).
MultiScore: 38.820 Punkte
Sepultura SC - 2164
Windows 11 - I5 13600KF | 14/20 @ Pcore boost 5,5GHz / E-Core Boost 4,3GHz - MSI Z690 Edge WiFi (DDR5) - 2 x 16 GB DDR5 6000 @ 6400 36-36-36-76
Sepultura MC - 23279
Induktor - 15231
Windows 10 - AMD Ryzen-7 5800X3D @ 4450 Mhz – Gigabyte Aorus Master X570 (F36f) - 4x8GB DDR4-3800-16-16-16-30 - NZXT Z63 AIO
Simply1337 - 39843
Windows 11 x64 - Intel 13900K @ Stock - Gigabyte Z790 Aorus Master - 2x16GB DDR5 6000 CL40
40K hat er auch schon gemacht, für alles Stock aber okay 🙆‍♂️
Ist ein unterschied von 0,5%, würd ich mir nicht mal gedanken drum machen.
Fresh Windows wirds wohl sein. Oder kein HWinfo offen.
15658
Ryzen 5700X @ PBO @ Wraith Prism
2*8gb 2666Mhz @ 3100Mhz
In Spielen läuft das kleine Monster mit 4,85ghz :d
Hoschi - 1575
Windows 10 x64 - AMD Ryzen 7 5800x3d | 8/16x4650mhz – ASUS ROG CROSSHAIR VIII DARK HERO - 2x16GB DDR4-3800-15-15-13-30
Hoschi - 16049
Chris1975 - 39418 - Windows 10 - AMD 7950X @ Stock - Gigabyte Aorus Master X670E - 2x16GB DDR5 6600 CL34
13700kf 5,5Ghz P, Rest stock, zieht so ~260W
Holzmann - 43580 Multi Core
Windows 11 x64 - Intel 13900KS | 5.8 AC / 6.0 SC / 4.7 E Cores – 2x16GB DDR5 8200 Cl34
