[Sammelthread] Die HWLuxx 3D Druckerkolonne....
~/klipper/scripts/calibrate_shaper.py /tmp/resonances_y_*.csv -o /tmp/shaper_calibrate_y.png
Fitted shaper 'zv' frequency = 80.4 Hz (vibrations = 32.9%, smoothing ~= 0.030)
To avoid too much smoothing with 'zv', suggested max_accel <= 25200 mm/sec^2
Fitted shaper 'mzv' frequency = 46.8 Hz (vibrations = 6.9%, smoothing ~= 0.093)
To avoid too much smoothing with 'mzv', suggested max_accel <= 6500 mm/sec^2
Fitted shaper 'ei' frequency = 65.0 Hz (vibrations = 11.4%, smoothing ~= 0.076)
To avoid too much smoothing with 'ei', suggested max_accel <= 7900 mm/sec^2
Fitted shaper '2hump_ei' frequency = 58.4 Hz (vibrations = 0.6%, smoothing ~= 0. 158)
To avoid too much smoothing with '2hump_ei', suggested max_accel <= 3800 mm/sec^ 2
Fitted shaper '3hump_ei' frequency = 61.2 Hz (vibrations = 0.0%, smoothing ~= 0. 219)
To avoid too much smoothing with '3hump_ei', suggested max_accel <= 2700 mm/sec^ 2
Recommended shaper is 2hump_ei @ 58.4 Hz
pi@mainsailos:~ $ ~/klipper/scripts/calibrate_shaper.py /tmp/resonances_x_*.csv -o /tmp/shaper_calibrate_x.png
Fitted shaper 'zv' frequency = 85.2 Hz (vibrations = 16.6%, smoothing ~= 0.028)
To avoid too much smoothing with 'zv', suggested max_accel <= 28300 mm/sec^2
Fitted shaper 'mzv' frequency = 55.4 Hz (vibrations = 5.8%, smoothing ~= 0.066)
To avoid too much smoothing with 'mzv', suggested max_accel <= 9000 mm/sec^2
Fitted shaper 'ei' frequency = 81.0 Hz (vibrations = 4.5%, smoothing ~= 0.049)
To avoid too much smoothing with 'ei', suggested max_accel <= 12200 mm/sec^2
Fitted shaper '2hump_ei' frequency = 69.6 Hz (vibrations = 1.5%, smoothing ~= 0.111)
To avoid too much smoothing with '2hump_ei', suggested max_accel <= 5400 mm/sec^2
Fitted shaper '3hump_ei' frequency = 64.0 Hz (vibrations = 0.4%, smoothing ~= 0.200)
To avoid too much smoothing with '3hump_ei', suggested max_accel <= 3000 mm/sec^2
Recommended shaper is ei @ 81.0 Hz
Welchen Shaper würdet ihr da nehmen?
Oben Y und unten X Achse.
Ich hab gelesen dass der mzv eigentlich der beste sein sollte?
Hab die Shaper im Moment so wie sie empfohlen sind aktiv.
Aber ringing hab ich trotzdem.
Vermeiden kannst du ringing nie. Die Empfehlung ist meist schon die beste Lösung.
Argh ich hab ein innen liegendes Gewinde mit Supports gedruckt:cautious:
Bekommt man echt nicht raus...
Da fehlt echt Routine...
Obwohl Sonntags in den Baumarkt, wird sportlich 🤔🤣
Kommt immer darauf an, ob man mit und mit wieviel Semtec H oder C4 man unterwegs ist. :rofl:
Ich erschieße mich mal wieder durchs Knie. Ich versuche eine Stepdatei des Duet3 6HC in eine 3mf Datei zu konvertieren. Freecad? Stürzt jedesmal ab. Also Fusion360 laden. Direkt als 3mf speichern? Da wird jedes Bauteil einzeln generiert. Und das mit (lt. 3D Builder) Fehlern. Speichern als STL und Laden in 3D Builder? Geht prinzipiell. Aber nur mit Fehlern. Ich liebe ja die Geschwindigkeit von 3D Builder auf meinem Rechner. Da kann ich mit schon mal eine Kanne Kaffee machen.
also ich hab alles was R oder C ist wegelöscht,dann geht ganz fix
  • Duet3_MB.zip
Oh ha....
Mein Druckbett sieht ganz schön böse aus :oops:
bei welcher Temperatur ?
Krümel unter der Platte ?
Kleber/Platte gelöst ?
So kam die Buildplate eben aus der Wash and Cure...tolle Reinigung mit dem drecks Baumarkt Ethanol.
Btw die war vorher oben drauf sauber, wollte nur das flüssige Resin abspülen. Und abwischen is nicht, die Flecken sind festgepappt, selbst mit Iso jetzt drüber hat nicht geholfen.
Ich hab gerade drei Drucke mit dem Zeugs gewaschen und hab drei Liter in der Wash and Cure drin. Auch sieht die Flüssigkeit nicht allzu dreckig aus...Naja dann wird halt jetzt Höfer Zeugs bestellt.
OK, bei ner Layerhöhe von 0.1 kratzte dann aber schon was ab,oder ?
In der Theorie nicht. Du nutzt ja dieses Mesh um die Unebenheiten auszugleichen. Sollte daher eigentlich sehr gut klappen
Wtf? Sieht echt übel aus. Also ich wasche ab und an auch mit Ethanol aber so sieht das bei mir nicht aus
mit dem Mesh,also wenns bei Euch so gut funktioniert , bei meinem hab ich so meine Zweifel ,ich lasse zwar vermessen aber irgendwie scheint das nichts zu verändern, hab ich so das Gefühl !
muss ich mich wohl mal auf die Suche machen ...
Dein Mesh ist nur so gut wie die Punkte die du prüfst. Wenn es dazwischen extrem uneben ist hast du Pech. Für extrem unebene Betten gibt es in Marlin unified bed leveling. Da prüfst du einmal 100 Punkte und speicherst diese ab. Dazu ist jeder Punkt bei Bedarf einzeln "levelbar".
Das Mesh wird dann vor dem Druck geladen und via 3 Punkt Messung angepasst (,falls sich was leicht verändert hat).
Alles ist eingerichtet inkl. folgender config in der printer.cfg
Code:
[mcu rpi]
serial: /tmp/klipper_host_mcu
[adxl345]
cs_pin: rpi:None
[resonance_tester]
accel_chip: adxl345
probe_points:
    100, 100, 20  # an example
Ich bekomme dann das hier als Fehlermeldung:
Code:
mcu 'rpi': Unable to connect
Once the underlying issue is corrected, use the
"FIRMWARE_RESTART" command to reset the firmware, reload the
config, and restart the host software.
Error configuring printer
@toscdesign läuft den der Pi als 2. MCU?
Was genau steht im klippy Log? Die Meldung die du gepostet hast ist ja "nur" der Fehler aus der GUI und lässt keinerlei Rückschlüsse auf die eigentliche Ursache zu.
Ich hatte zuletzt einen permission denied Fehler.
sudo usermod -a -G tty pi
half, steht aber auch so in der Doku :)
vor dem 'make menuconfig' kann es teilweise helfen ein 'make clean' zu machen. steht nicht in der anleitung, aber ohne das wollte es bei mir nicht...
Was meint ihr mit "Pi als 2. mcu"?
Steuert der Pi denn nicht schon den Drucker?
Ich meine ohne Pi bekomme ich ja nicht Mal eine Anzeige auf dem Drucker Display
^^ Da liegt der Fehler.
Ja, dein Pi steuert Komponenten auf denen du Klipper Firmware installiert hast, mehr aber auch nicht.
Vereinfacht:
Du hast auf dem Pi Klipper in der "Steuerungsvartiante" installiert. Sprich der Part welcher deinem Drucker die Befehle sendet.
Nun möchtest du mit dieser Steuerungskomponente auf den Pi selbst zugreifen, hast dafür aber nicht die nötige Klipper Komponente installiert da ja nur die Steuerung vorhanden ist.
Schau dir den Link von morpheuz an ;)
Du musst Klipper für den Linux Prozess kompilieren und via make flash installieren, erst dann kann Klipper auch eine Verbindung zur PI MCU herstellen. Und dann klappt das vermutlich auch ;)
Einfach Schritt für Schritt befolgen.
Edit:
Mit "2. MCU" ist dieser Part gemeint:
[mcu rpi]
Du möchtest den Raspberry als zweiten Microcontroller (MCU) neben deinem Mainboard festlegen. Und dafür muss der Pi eben die nötige Software haben um überhaupt die Verbindung zu ermöglichen und die Befehle zu verstehen.
Effektiv sagst du mit dem Teil der Config das es einen Microcontoller namens rpi gibt welcher via der serial Verbindung /tmp.... erreichbar sein sollte. Dein Klipper versucht nun sich damit zu verbinden und stellt fest: Es ist niemand erreichbar. Ursache dürfte die fehlende Software sein ;)
7:42 gehts los
Schau mal nach dieser Anleitung hab ich gemacht.
Wird schön erklärt. Er sagt auch, dass er auch zwischendrin mal noch neustarten musste obwohl es in der Klipper Doku so nicht beschrieben wird.
