[Sammelthread] Mechanische Tastaturen und andere Sonderwünsche
Mal schauen was 120 euro so taugen..
New estimates based on recent information from GMK
- GMK Dolch R5 - End of January (geplant Juli 21)
- GMK Space Cadet II - End of January (geplant August 21)
- GMK Noire - Februar (geplant Q2 21)
- GMK Beta & JS - February (geplant Juni 21)
- GMK Honor - March (geplant September 21)
Not yet confirmed by GMK, but reasonable estimates
- GMK Monokai Material - Estimating March (geplant Juli 21)
- GMK Yuri R2 - Estimating April (geplant Oktober 21)
- GMK 80082 - Estimating April to May (geplant Oktober 21)
- GMK Serika 2 - Estimating April to May (geplant Oktober 21)
Update von Oblotzky.industries:
- OG Spacekeys R2 fixed 3U Spacebars are coming in January,
- Nuclear Data Spacebar kits are shipping in January,
- Space Cadet II, finished production, waiting on banderoles from the print factory. Once received, packing up and off to vendors. Might ship in January still
- Redacted, GMK is being very meticulous about the redacting double pad print. This is taking longer as expected as they are continuing to redo some keys. Currently looking at late January, might spill over into February.
- Beta & JS, end of February
- Dolch R5, end of March
- Monokai Material, can be done in March, but we are still working on refining 3 colors (next batch already on its way).
- Noire, April
- Honor, April
I don't think there will be any more sets that I ran by April, so any set not mentioned would be after all this.
Apropos Oblotzky, der hat Cherry PBT Keycaps auf Lager. Die Cherry Taro gefallen mir sehr gut. Cherry Sand wäre auch eine gute Farbe für das Holz Case von @egal0000
Auf der vorherigen Seite war ein Video zu den Taro verlinkt. Der Druck sieht nicht so toll aus, dafür sind sie mir viel zu teuer.
Sooooo ooo ooo ....
Erster Schreibtest mit 120 Euro Switches. (Zeal Healios V2)
Definitiv lauter als die Bobagum.
Aber angenehmes Tippgefühl und Stärke wie ich finde.
gehen auch wie Butter bis durch, und sind jetzt nicht übermäßig laut.
haben aber soweit ich das hören kann im Moment doch ein Pingen.
Wobei ich mir da Grad nicht zu 100% sicher bin ob das nicht vom Case der tasta kommt.
bisheres Fazit:
sind es gute Switches? ja auf alle Fälle.
Würde ich nochmal 120 dafür Zahlen? nein wohl eher nicht.
Weil auch wenn Sie gut sind, gibt es Siwitches die ähnlich sind und auch ähnlich gut sind, die einfach bedeutend weniger Kosten.
Vergleich Bobagums zu den Healios:
Die Bobagums sind Auch sehr Weich beim Tippen, und absolut lautlos möchte ich behaupten.
Dennoch sind sie etwas Gewöhnungsbedürftig und fühlen sich etwas an wie eine Rubberdometastatur.
Wie hatte ich das mal in dem einen Video gehört, sie fühlen sich an als würde man auf seinem Marshmellow rumdrücken, oder auf einem Warmgewordenen nicht klebrigen Maoam. Daurch fehlt mir zuweilen etwas das feedback beim tippen. Ich denke hier wäre eine Taktile Variante davon wirklich besser.
Das ist wahrlich gewöhnungsbedürftig, aber nicht umbedingt schlecht. Für den Preis und das Absolut nicht vorhandene Geräuschlevel, kann man sich da durchaus dran gewöhnen. Auf einer ganzen Tastatur werden sie aber wohl nicht meine Favoriten
Die Zeal Healios.
Wunderschöner druckpunkt.
kein Stemwobble oder ähnliches, auch wenn mir die Cap aufnahme auf den stems etwas kleiner vorkommt als bei den Bobas zb. Allgemein wirkt der ganze switch etwasa zierlicher, was eventuell an der farbe liegen kann.
Sie besitzen auf jeden fall ein gutes Schreibgefühl, nicht übermäßig laut.
Leider aber nicht so leise wie die Bobas, und vorallem in meinen Augen viel zu teuer.
Somit Kröhne ich den (aktueller Stand) neuen Switch könig in meinem Hause...
Es ist der alte, die Kailh Box dark Yellow.
Selbst wenn ich den Preispunkt außer acht lasse, liegen sie gleich auf mit den Healios. bedenkt man aber nun das man für die Kailh Box nur etwa 1/3 zahlt wie für die Healios.. ist jede diskussion beendet.
meine (Lineare) Switchliste
1. Kailh Box Dark Yellow
2. ZealPC Healios V2
3. Bobagum 68G
4. Boba LT und Cherry MX Black
Platz 4 ist geteilt, da ich mich dort nicht entscheiden kann, sie haben beide ihre vor und Nachteile. Sind aber beides in meinen Augen nichts besonderes. Was ja nicht schlecht sein muss.
Gerade auf meiner alten GMMK TKL zum arbeiten, sind die Cherry MX Black durchaus angenehm.
Jetzt brauch ich nur langsam mal ein Paar behältnisse in denen ich die Switches Lagern kann :d
Die Zippertüten sind für meine Keycaps in Verwendung :-/
120 für die Switches?
Und ja, 120 Euro Switches. also 100 Switches um genau zu sein.
EDIT: Grad noch gesehen weil ichs mal angemacht habe.
Dadurch das Die Healios komplett Klar sind, also durchsichtig,
Hatt man auch die volle Dröhnung RGB :d
nich wie bei den Bobas wo so eine Kleine Lize mal leuchtet, nein.. der ganze Switch sieht aus als Hätt sich da nen Regenbogen drauf entleert :d
bekommt man fast Augenkrebs von...
Vielleicht irgendwann mal für jemanden interessant, ich stell es einfach mal in den Raum: so sieht die Varmilo 108er Platine (110% Keyboard) aus.
Zum öffnen hat man unter den ER und PÜ Tasten je eine Schraube und dann im Rahmen jede Menge (stabile) Plaste Clips. Danach kann man das Unterteil abnehmen und das PCB / Plate Dingens vom Oberteil abschrauben (nochmal 4 Schrauben).
Hatte das Keyboard jetzt nach 2 Wochen zum ersten mal wieder in der Hand und ich muss sagen, im Vergleich zur GMMK fällt definitv das geringe Gewicht auf, da könnte man gut noch 1kg bei unteren Abdeckung drauflegen, die GMMK fühlt sich da wertiger an (ok, ist eh komplett aus Alu statt Plastik).
By The way, jemand ne Ahnung qwo ich aktuell ein Paar Kailh box Blacks kriegen kann? (AUSSER BEI CANDYKEYS!)
die standard sehen nett aus. leider schon zu viel bestellt. muss auch mal gut sein :fresse:
Danke die hatte ich auch gesehen. Aber 50 Euro für nen paar Blacks. Weiß nich da schlägt der Geiz durch :d
Mal noch so ne becheuerte Frage, weil ich grad dabei bin mal alles zusammenzusammeln um doch etwas mehr an meiner GMMK Pro zu machen,
Der Unterschied zwischen Krytox Glp 205 g0 und Krytox GLO 205 g2 ist doch nur die Viskosität oder?
Oder hab ich da auf irgendeiner seite blödsinn gelesen und es gibt kein g2?
Jo, wenn du auch willst die Festigkeit der Masse :d
Ähm das sind 120 Stück. Knapp 42Cent pro Stück ist doch i.O.
An und Pfirsich richtig, aber ich brauch halt keine 120 stück. Bei Candykeys zb bekommt man ebn 100 packs für 12 Euro weniger.
zudem sind warum auch immer die versandkosten bei Caseking echt astronomisch mit ihren ca 9 Euro.
Ich habe gerade auch beim Ali geschaut, aber das zahlst du auch für 100 Stück ca. 40 EUR. Kannst dich ja da umsehen, wenn es nicht eilig ist.
Beim Ali habe ich immer die latente Angst beschissen zu werden und nicht das zu bekommen was ich erwartet habe. Weil ich vermutlich gar nicht erkennen würde ob das der Fall ist.
Über 100 Bestellungen nur 3 mal nicht das bekommen was bestellt war (immer verloren gegangen aufm Weg) 2 mal support erledigt 1 mal paypal.
Ansonsten hilft es oft die Bewertungen zu lesen und die Bilder dort anzusehen.
@qD3m0Np also mit etwas gesundem Menschenverstand sieht man schon wo versucht wird über den Tisch gezogen zu werden.
Aber das ist genauso auffällig wie es bei deutschen Fakeangeboten ist. Preis zb. Etc.
Ich finde Amazon ist mittlerweile weit weniger ersichtlich als Aliexpress
Hier schon mal ein Bild vom GMMK Pro PCB mit der FR4-Plate. Die Plate benötigt keinerlei schrauben. Mal schauen, wie das hält. Mit den Switches an den Ecken hatte ich so meine Probleme. Aber jetzt scheint alles zu halten.
Ach ja, Durock V2 passt ohne Probleme. Die Switches sind Boba U4T RGB.
Frage in die Runde:
Kennt jemand von euch zufällig einen Keyboard Build Service, der entlöten und Switches neu verlöten kann?
Oder bietet hier im Forum jemand so etwas vielleicht sogar an?
Um wieviele switches geht es denn? Komplettes Board?
Ne, sorry, das ist dann doch eine Strafarbeit... Bei nem einzelnen defekten Switch oder so könnte ich sicher helfen, aber nicht soviele :)
Her we go. Einige verbogene Pins später funktioniert alles :)
An das DSS Profil muss ich mich noch gewöhnen.
GMMK Pro White Ice
AVX Works FR4 Plate
Mintlodica DSS First Light Keycaps
Gazzew Boba U4T RGB
Durock V2 Stabs
Oh Gott, die F-Tasten sind ja total falsch ausgerichtet. Da muss ich wohl noch mal ran :d
