@Sylwester. Did the 6900 xt file I gave you work?
Only the LD curve? That can stabilize yes.Good news and mediocre news
I triggered OPP/OCP on my Powersupply by doing stupid misscalculations
BUT , i made progress with my mediocre sample not wanting to hold 2667Mhz TimeSpy
Started to understand the curve menu ~ soo a little request
May you 6800XT guys try this out and report back ?
I've passed it artifact free and made some progress, but couldn't get the score nor the powerdraw out
I think 1.2v SOC & GFX pulled over 520W and triggered OCP on it ~ CPU only uses 120W but still, transient "hardcrash"
Please test how it scales and if you lose clock 🙇♂️
It's all i could "recover"
I was stupid and put ontop of 450W,350A,56A a +11% powerlimit extend
Will continue pushing after 3-4 days when his powersuply & parts arrive
But if this really took +500W instead usual sub 400 near 1.175v
Then i might be at the limit with the 750W unit for the "clients" 5900X build
Hatte den größten unterschiedOnly the LD curve? That can stabilize yes.
Wäre sie, aber ab welcher freqenz sie anliegt und um wie viel es droopt ~ ist der unterschiedich verstehe die LD Kurve als "LLC" welche mir den maximalen spannugs abfall im bezug auf die GHz/V Kurve begrenzt.
Aber nur meine vermutung.
Danke dir !Wenn ich heute Abend Zeit habe teste ich sie mal.
Ist das mit TDV? Greift da die Kurve überhaupt noch?
JaEDIT:
Curves seem only to trigger and fail boot with the Temp_Dependent_VMIN flag
Without, the linear drop doesn't appear to do anything.
Static voltage offset functions too ~ and i'd deliver a "done" result
But this was the best "progress" i can give now ~ till i have a bigger powersuply
EDIT2:
The most crucial part is matching 4 as that is what should match to default boosting - 5 is then peak boost
In my opinion the Linear Drop clock is working with FRC (FPS-Limit)Curves seem only to trigger and fail boot with the Temp_Dependent_VMIN flag
Without, the linear drop doesn't appear to do anything. Static voltage offset functions too
Still Waiting for mod-BiosDo you guys think having more than 2150 mhz memory clock will be possible with xtx cards in the future?
Da beim LC-Bios die Timings anders sind, ... ist evtl. das FT2 ungefähr eher so wie FT1 bei der normalen 6900.Wenn ich sehe, dass Karten wie Holzis @LC-Bios mal eben 2400 FT2 akzeptieren, ohne mit dem Speichercontroller zu zucken, sollte das ganz oben auf unserer Prioritätenliste stehen.
Dein .mpt hat mir gerade den Treiber komplett gekillt ( 1.11.21 ) musste eine reparatur installation machen.Danke dir !
Eigentlich ist das ding noch nicht fertig - aber vlt kannst du es dir anschauen
Bitte nur als "Experimentell/Alpha" ansehen
Glaube alle nutzen das CRUNutzt hier eigentlich noch wer die restart.exe von CRU oder startet ihr ständig nach MPT changes neu?
Grade schon wieder mit wem geschrieben und gemerkt das kaum wer das kennt. Solange man nichts total abschießt kann man sich den reboot damit sparen.
Wo hast du die Timings her ?Ich suche mal die Werte vom ollen Bios, wait a minute.
Wäre interessant wie ne normale XT dann mit 2249@Standard Timing dann so läuft.
(FT1 wird evtl. too much)
Yes, the file is working, although I do not know why it changed the extension to .mp3, but it opens in Notepad, I do not have much time to test in the week, at the weekend I will play, but I initially copied the record from the file to my registry, some programs recognized the card as 6900xt (eg MPT) but in the windows manager the card was marked as an exclamation mark, with the note does not work properly, so probably I will have to change the different branches of the registry, the problem is also probably a different version of window and driver@Sylwester. Did the 6900 xt file I gave you work?
Maybe u have to reinstall the Driver after you mod the Registry.Yes, the file is working, although I do not know why it changed the extension to .mp3, but it opens in Notepad, I do not have much time to test in the week, at the weekend I will play, but I initially copied the record from the file to my registry, some programs recognized the card as 6900xt (eg MPT) but in the windows manager the card was marked as an exclamation mark, with the note does not work properly, so probably I will have to change the different branches of the registry, the problem is also probably a different version of window and driver
Are you trying to make your card look like a 6900 xt to remove the frequency locks? Because afaik the 6800 xt can't be pushed more than 2800 mhzYes, the file is working, although I do not know why it changed the extension to .mp3, but it opens in Notepad, I do not have much time to test in the week, at the weekend I will play, but I initially copied the record from the file to my registry, some programs recognized the card as 6900xt (eg MPT) but in the windows manager the card was marked as an exclamation mark, with the note does not work properly, so probably I will have to change the different branches of the registry, the problem is also probably a different version of window and driver
Give me an unlocked BIOS, a jug of water, a hammer, jumper cables and 10 minutes :PAre you trying to make your card look like a 6900 xt to remove the frequency locks? Afaik the 6800 xt can't be pushed more than 2800 mhz
yepAre you trying to make your card look like a 6900 xt to remove the frequency locks? Because afaik the 6800 xt can't be pushed more than 2800 mhz
hwbot.org
