Sylwester.
Experte
- Desktop System
- 13700KF - Custom Loop(CPU>GPU>D5>rad 1080/45+18x arctic P12@600rpm) - Z790 EDGE - GSkill 4x8GB@4000-16-16-16-36@1.5V - 4x8GB 4000 cl14-15-15-30/1.5V - RTX4090TUF+ek vector2+XOC bios 1000W - Corsair RM 1200x - o11air mini - G8 OLED
Well then there is something wrong with the block, you have an awfully high temperature delta, in my case with too small cooling system (240 + 280) water temperature after several TS runs is 40-42'C and gpu temperature is around 60'C and hot spot 77-80'C (380W draw card max), delta is 20'C max, and in your case it looks like 30+, you have changed paste and pads many times, so I would suspect a defect in the block, if it is not made with precision, water will naturally take the easier way and will go sideways or over the fins where it meets the gpu, I have seen such problems with EK on YT
aber ich kann meine system pushen ohne sorge mit PSU zu haben.
