[Sammelthread] ASUS X570 Strix Series (X570-E Gaming, X570-E Gaming Wifi II, X570-F Gaming, X570-I Gaming)
ROG Strix X570-E Gaming
ROG Strix X570-E Gaming Wifi II
ROG Strix X570-F Gaming
ROG Strix X570-I Gaming
BIOS/UEFI Versionen
Reviews & VRM
Häufig gestellte Fragen
BIOS Mods
ChangelogDownload
Flashing and using on your own risk!
  • Added VDDP Voltage
    Might be helpful for CPU overclocking
  • Added ASPM Support (Should be visible by default since v4802)
    PCIe Energy Saving
  • Added Erp Ready (Strix-E only)
    Energy Saving
  • Unlocked AMD PBS
    Hidden options unlocked
  • Added PCH Temerature
    Shows the PCH Temperature in the Bios
  • Added PCH Fan Control
    Gives you control over the PCH Fan
  • Advanced (Pump) Fan Settings
    Min and Middle Duty Cycle can be changed to 0%
  • Added Advanced Boot Settings
    Might be helpful for faster boot
Strix X570-E Gaming
Download Folder
Download Folder
Strix X570-F Gaming
Download Folder
Strix X570-I Gaming
EOL
CPUAMD AM4 Socket 3rd and 2nd AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
ChipsetX570
Memory3rd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
2nd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
4 x DIMM, Max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
GraphicIntegrated Graphics in the 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI 2.0b with maximum resolution of 4096 x 2160 @ 60 Hz
- Supports DisplayPort 1.2 with max. resolution 4096 x 2160 @ 60 Hz
Multi-GPU Support3rd and 2nd Gen AMD Ryzen™ Processors
Supports NVIDIA® 2-Way SLI® Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX™ Technology
Expansion Slots3rd Gen AMD Ryzen™ Processors
2 x PCIe 4.0 x16 (x16 or dual x8)
2 x PCIe 3.0 x16 (x16 or dual x8)
1 x PCIe 3.0 x16 (x8 mode)
AMD X570 chipset
1 x PCIe 4.0 x16 (max at x4 mode) *1
2 x PCIe 4.0 x1
Storage3rd Gen AMD Ryzen™ Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
8 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
LANIntel® I211-AT, 1 x Gigabit LAN Controller(s)
Realtek® RTL8125-CG 2.5G LAN
Anti-surge LANGuard
ROG GameFirst Technology
WiFi2 x 2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) with MU-MIMO supports dual frequency band 2.4/5GHz
BluetoothBluetooth® 5.0
AudioSupremeFX 8-Channel High Definition Audio CODEC S1220A
- Dual OP Amplifiers
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- SupremeFX Shielding Technology
- Supports up to 32-Bit/192kHz playback *2
Audio Feature :
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB Ports3rd Gen AMD RyzenTM Processors :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, )
2nd Gen AMD RyzenTM/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s)
AMD X570 chipset :
1 x USB 3.2 Gen 2 front panel connector port(s)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, , 3 x Type-A+1 x Type-C)
AMD X570 chipset :
2 x USB 3.2 Gen 1 port(s) (2 at mid-board)
AMD X570 chipset :
4 x USB 2.0 port(s) (4 at mid-board)
Special Features5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
TPU
- Auto Tuning, TurboV, GPU Boost
Gamer's Guardian:
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
- SafeSlot
- ESD Guards on LAN, Audio,and USB ports
ASUS EPU :
- EPU
AURA :
- Aura Lighting Control
- Addressable Gen 2 Header
ASUS Exclusive Features :
- USB BIOS Flashback®
- AI Suite 3
- Ai Charger
- ASUS NODE : hardware control interface
- BIOS Flashback® Button
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports1 x DisplayPort
1 x HDMI
5 x USB 3.1 Gen 1 Type-A
8 x USB 2.0
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Anti-surge 2.5G LAN (RJ45) port
1 x USB BIOS Flashback® Button(s)
1 x ASUS Wi-Fi Module
7 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-C)
Anti-surge LAN (RJ45) port
Internal I/O Ports1 x PCH_FAN
1 x AAFP connector
2 x Aura RGB Strip Header(s)
2 x Addressable Gen 2 header(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x M.2 Socket 3 with M key, type 2242/2260/2280/22110 storage devices support
1 x SPI TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x Thermal sensor connector(s)
1 x Clear CMOS jumper(s)
1 x Node Connector(s)
1 x System panel connector
1 x T_Sensor Connector
1 x M.2 Fan Header
1 x USB 3.2 Gen 2 (up to 10Gbps) connector
1 x USB 3.2 Gen 1 (up to 5Gbps) connector support additional 2 USB ports
AccessoriesUser's manual
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x Supporting DVD
1 x Strix door hanger
1 x ROG Strix stickers
1 x Cable ties pack(s)
1 x Wi-Fi Antenna(s)
1 x Extension Cable for RGB strips (80 cm)
1 x Extension cable for Addressable LED
1 x Thermistor cable(s)
1 x ROG Thank you card
BIOS256 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.2, ACPI 6.2.
Form FactorATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note*1 PCIeX16_3 slot shares bandwidth with PCIeX1_2.
*2 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
Bios Version 0807
AiTweaker
Advanced
Monitor
Boot
Tool
Kompatibilitätsliste
Memory QVL Ryzen 3000/4000/5000
Chipsatz Modding
Alternativer Chipsatz Kühler von KCX
ROG Strix X570-E Gaming WIFI II
Produktseite | Handbuch (EN) | Support-Downloads | Preisvergleich
CPUAMD Ryzen™ 5000 Series/ 5000 G-Series/ 4000 G-Series/ 3000 Series/ 3000 G-Series/ 2000 Series/ 2000 G-Series Desktop Processors
ChipsetX570
MemoryAMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
4 x DIMM, Max. 128GB, DDR4 4600(O.C.)/4400(O.C.)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200/3000/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 5000 and 4000 G-Series Processors
4 x DIMM, Max. 128GB, DDR4 5100(O.C)/4800(O.C.)/4600(O.C)/4466(O.C.)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3200/3000/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 and 3000 G-Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
ECC Memory (ECC mode) support varies by CPU
Graphic1 x HDMI 2.0
1 x DisplayPort
Expansion SlotsAMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
2 x PCIe 4.0 x16 (x16 or dual x8)*
AMD Ryzen™ 5000 G Series/4000 G-Series/ 2000 Series Processor
2 x PCIe 3.0 x16 (x16 or dual x8)*
AMD Ryzen™ 2000 G-Series/ 3000 G-Series Processor
1 x PCIe 3.0 x16 (x8 mode)*
AMD X570 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
2 x PCIe 4.0 x1
*PCIeX16_3 slot shares bandwidth with PCIeX1_2.
StorageSupports 2 x M.2 slots and 8 x SATA 6Gb/s ports
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors:
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
AMD Ryzen™ 5000 G-Series/4000 G-Series/ 3000 G-Series/ 2000 G-Series/2000 Series Processor
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 3.0 x4 & SATA modes)
AMD X570 Chipset
M.2_2 slot (Key M), type2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
LAN1 x Realtek 2.5Gb Ethernet
1 x Intel® I211-AT 1Gb Ethernet
Anti-surge LANGuard
1 x Intel® 1Gb Ethernet
WiFiWi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
BluetoothBluetooth® v5.2
AudioRealtek S1220A 7.1 Surround Sound High Definition Audio CODEC*
- Internal audio Amplifier to enhance the highest quality sound for headphone and speakers
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input (Line-in)
- Supports up to 32-Bit/192 kHz playback*
Audio Features
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
USB PortsAMD RyzenTM 5000, 5000 G-Series, 4000 G-Series, and 3000 Series Desktop Processors
- 4 x USB 3.2 Gen2 ports (4 ports at back panel, Type-A)
AMD RyzenTM 3000 G-Series, 2000, and 2000 G-Series Desktop Processors
- 4 x USB 3.2 Gen 1 ports (4 ports at back panel, Type-A)
AMD X570 chipset
- 1 x USB 3.2 Gen2 front panel connector
- 4 x USB3.2 Gen2 (at back panel, 3x Type-A, 1x Type-C)
- 2 x USB3.2 Gen1 ports (at front panel)
- 4 x USB 2.0 ports (at front panel)
Special FeaturesExtreme Engine Digi+
- 5K Black Metallic Capacitors
ASUS Q-Design
- M.2 Q-Latch
- Q-Code
- Q-DIMM
- Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
- Q-Slot
ASUS Thermal Solution
- M.2 heatsink
ASUS EZ DIY
- BIOS FlashBack™ button
- BIOS FlashBack™ LED
- ProCool II
- Pre-mounted I/O shield
- SafeSlot
AURA Sync
- AURA RGB headers
- Addressable Gen 2 headers
Back I/O Ports8 x USB 3.2 Gen 2 ports (7 x Type-A + 1 x USB Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® I211-AT 1Gb Ethernet port
1 x Realtek 2.5Gb Ethernet port
5 x Gold-plated audio jacks
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
Internal I/O PortsFan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
2 x 4-pin Chassis Fan headers
1 x 4-pin M.2 Fan header
1 x W_PUMP+ header
Power related
1 x 24-pin Main Power connector
1 x 8-pin +12V Power connector
1 x 4-pin +12V Power connector
Storage related
2 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Miscellaneous
2 x Addressable Gen 2 headers
2 x AURA RGB headers
1 x Clear CMOS header
1 x Front Panel Audio header (AAFP)
1 x SPI TPM header (14-1pin)
1 x Speaker header
1 x 10-1 pin System Panel header
1 x Thermal Sensor header
AccessoriesCables
4 x SATA 6Gb/s cables
1 x Thermistor cable pack
Miscellaneous
1 x ASUS Wi-Fi moving antennas
1 x Cable ties pack
1 x M.2 Rubber Package
1 x M.2 Q-Latch package
1 x ROG key chain
1 x ROG Strix thank you card
Installation Media
1 x Support DVD
Documentation
1 x User manual
Full Specs:
ChipsetX570
AMD X570 chipset
2 x PCIe 4.0 x1
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
Anti-surge LANGuard
Audio Feature :
- Sonic Radar III
USB Ports3rd and 2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s) (4 at back panel, )
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
TPU
Gamer's Guardian:
- DIGI+ VRM
- SafeSlot
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
1 x HDMI
8 x USB 2.0
5 x Audio jack(s)
4 x USB 3.2 Gen 1 (up to 5Gbps) ports
3 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x AAFP connector
1 x SPI TPM header
1 x M.2 Fan Header
1 x Supporting DVD
Chipsatz Modding
Wasserkühler von Neo111430
ChipsetX570
2 x DIMM, Max. 64GB, DDR4 4800(O.C.)/4600(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3800(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory
- Support DisplayPort 1.4 with max. resolution 8 K 7680 × 4320 @60 Hz
1 x PCIe 4.0 x16 (x16 mode)
1 x PCIe 3.0 x16 (x16 mode)
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2_2 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
4 x SATA 6Gb/s port(s),
LANIntel® I211-AT
Anti-surge LANGuard
WiFiSupports channel bandwidth: HT20/HT40/HT80/HT160
Intel® Wi-Fi 6 AX200
Up to 2.4Gbps transfer speed
Audio Feature :
- DTS® Sound Unbound
- LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
- Sonic Radar III
- Sonic Studio III + Sonic Studio Virtual Mixer
4 x USB 3.2 Gen 1 port(s) (4 at back panel, blue)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (3 x Type-A+1 x Type-C)
AMD X570 chipset :
AMD X570 chipset :
2 x USB 2.0 port(s)
TPU
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
1 x HDMI
3 x LED-illuminated audio jacks
4 x USB 3.2 Gen 1 (blue)
Internal I/O Ports1 x HS_FAN
1 x PCH_FAN
1 x AAFP connector
1 x Aura RGB Strip Header(s)
1 x Addressable Gen 2 header(s)
1 x USB 3.2 Gen 1(up to 5Gbps) connector(s) support(s) additional 2 USB 3.2 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
2 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
4 x SATA 6Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Speaker connector
I/O Shield
2 x M.2 Screw Package
1 x Supporting DVD
1 x M.2 bracket
1 x AAFP Extension Cable
1 x Panel cable
Form FactorMini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm )
Note*1 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
*2 Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
  • Sound setzt aus oder knistert
    Immer wieder USB Disconnects
    Meistens tritt dieses Problem auf, wenn man einen hohen RAM Takt verwendet. In diesem Fall kann man versuchen die SOC Spannung auf 1.125V zu erhöhen. Sollte das nicht ausreichen, zusätzlich noch die VDDG CCD Spannung auf 1.00V (oder niedriger), sowie VDDG IOD Spannung auf 0.925V stellen.
  • USB Disconnects
    Mit bestimmten UEFI/Agesa Versionen (v2 1.1.0.0/ 1.1.8.0) können sporadische USB Disconnects auftreten. Um dies zu umgehen bitte folgende Einstellung im Bios deaktivieren:
    UEFI -> Advanced -> AMD CBS -> Global C-States deaktivieren
    Der Verbrauch steigt dadurch um ca. 5Watt an aber ansonsten hat man keine weiteren Nachteile
  • USB Flashback funktioniert nicht
    Bitte folgende Punkte ausprobieren:
    - Datei richtig umbenannt? Vorzugsweise mit dem im BIOS Download enthaltenen Renamer
    - Vor dem Flashen das BIOS auf Werkseinstellungen zurück setzen!
    - Einen anderen USB Stick ausprobieren. Vorzugsweise ein USB 2.0 Stick
  • BIOS/UEFI Downgrade
    Ein UEFI Downgrade ist ohne Probleme mit USB Flashback möglich, soweit vorhanden.
  • Ist der Chipsatz Lüfter regelbar?
    Nein, dieser wird automatisch, je nach vorhandener Temperatur, geregelt. Bis zu einer Temperatur von 55 Grad ist der Lüfter deaktiviert. Bei höheren Temperaturen wird er stufenweise schneller bis er letztendlich bei 93 Grad seine Höchstgeschwindigkeit erreicht. Über selbst erstellte Bios Mods kann man jedoch den Lüfter auch nach seinen Wünschen einstellen.
  • Chipsatz Temperatur zu hoch?
    Wem das Optische nicht so wichtig ist, kann die Lüfterabdeckung vom Chipsatz beim X570-E oder x570-F entfernen. Dadurch staut sich die warme Luft nicht an, sondern kann direkt entweichen.
    Des weiteren kann man im Bios unter "Onboard Devices Configuration" die vorhandenen Steckplätze (PCIe X16, X1, M.2, SB Link) manuell auf PCIe 3.0 umstellen, sofern man keine PCIe 4.0 Karte verwendet. Bei Auto Einstellung wird automatisch PCIe 4.0 angelegt, was zu einer höheren Last führt.
  • Kann ich ein altes Bios Profil mit einer neuen Bios Version nutzen?
    Nein, es ist zu empfehlen kein altes Profil mit einer neuen oder älteren Bios Version zu nutzen. Dies endet meist mit einem Blackscreen. Nach jedem Bios Flash bitte die Einstellungen neu vornehmen. Selbst wenn sich ein Profil laden lässt, kann es trotzdem zu Instabilität führen.
  • Rechner bootet nicht, wenn eine Soundkarte verbaut ist
    Dieses Problem kann mit dem Bios 1404 oder höher (Agesa 1004b) auftreten. In dem Fall bitte in dem AMD CBS Menü die Option "PCIe Ten Bit Tag Support" auf Disabled stellen. Sollte das nicht ausreichen, dann zusätzlich noch unter dem Menü Advanced -> Onboard Devices Configuration -> die Option PCIEXxxx (den Slot auswählen, in der die Soundkarte steckt) von Auto auf Gen3 ändern.
Mich die ganze zeit gewundert wieso er nicht den Flashvorgang per USB Flashback von 2816X auf 4002X bzw. 3604X gemacht hatte. Nach einen zwischen update auf 3405 gings dann doch😁 Habe keine Problem mit meinen Einstellung durch das Update, außer das jetzt endlich der USB Anschluss durchgehend funktioniert :drool:
Hallo an alle!
Hat jemand schon Erfahrungen mit dem neuen BIOS-Update 4002?
Ich habe das E-Gaming und seit gestern upgedatet. Das System läuft prima und bis jetzt sind meinerseits keinerlei Probleme feststellbar, bis auf die Eigenartigkeit, dass ich unter Advanced die ERP-Settings nicht auffinden kann. Beim Herunterfahren des Systems bleibt das Mainboard und mein Kopfhörerverstärker beleuchtet, der via USB am Frontpanel angeschlossen ist. Tastatur- und Mausbeleuchtung schalten sich jedoch aus. Hat jemand eine Lösung für das Problem?
MfG
untoxic
Von der erste Seite das Mod Bios installieren. Da kann alles eingestellt werden.
Das gute alte 1405. Kann dich ein wenig verstehen, da ich damit sehr gute CPU OC Ergebnisse hatte. Ich habe fast jede Version mitgemacht und mein 3733CL16 lief immer ohne Probleme oder Fehler. Timings und Spannungen einfach immer stumpf übernommen. Natürlich neu eingetragen und nicht per Profil. Aktuell mit dem neusten 3801 unterwegs. Ich kann gar nicht anders als immer den Update Knopf zu drücken
Jetzt komm ich vermutlich nicht mehr rum upzugraden, da demnächst eine 6800XT Einzug hält und ich SAM natürlich schon gern nutzen würde.
Auf 3733 CL16 laufen meine E-Dies auch, IF 1900 will er irgendwie nicht. Ich vermute, da verhalten sich die neuen Versionen auch nicht anders und das liegt direkt an der CPU?
Paar Fragen hab ich noch:
1. Es heißt ja Bios Flashback, kann man also auch wieder zur alten Version zurück, wenn irgendwas nicht klappt? Ist Cmos Reset zwingend nötig nach dem Upgrade?
2. Wie ist denn die beste Vorgehensweise, wenn man das mit Grakatausch verbindet? Erst mal neue Graka rein, gucken ob die normal läuft, ggf. Treiber frisch, danach Bios Upgrade, Sam aktivieren und Chipsatz Treiber frisch, und als letztes die Einstellungen wieder manuell reinhämmern?
Seh ich irgendwo, was ich alles im Bios verändert habe?
Bin da echt nervös, weil ich normalerweise Hardware eher selten wechsle und daher, solange alles läuft, bis auf Sicherheitsupdates bei allem anderen auf der "don't touch running systems" Schiene bin.
Mit 2 Riegeln konnte ich bei mir 3800CL16 und einen IF Takt von 1900 laufen lassen. Das ging mit den direkten Vorgänger Bios Versionen nicht. Kann also durchaus sein, dass du auch mit 4002 dann 1900 erreichst.
Jetzt mit 4 Riegeln läuft bei mir aktuell 3600CL16 IF1800. Muss aber zugeben, dass ich nicht mal versucht habe den RAM für 3800 mit 4 Riegeln zu tunen. Werde ich aber sicherlich irgendwann, wenn ich Zeit habe, mal nachholen :d
Mit der uralt Bios Version 3001 ging bei mir ein IF Takt von 2000 eh die CPU ausgestiegen ist. Asus oder AMD haben da aber scheinbar irgendwas nachgeschärft (oder kaputt gemacht) wodurch bei neueren Versionen bei mir schon bei 1800 Schluss war und erst mit 4002 wieder 1900 gingen.
Vollbestückung ist auch mehr Stress für den IC. Vor einigen Bios Versionen ging bei mir auch der 2000 IF, danach kann ich es zwar einstellen, aber er setzt es auf 1900 IF immer.
Aber egal...
Ich brauch mal euer Schwarm-Wissen, vielleicht hat @Reous auch Zeit (oder gleich ein Lösung? :d )
Was stellt ihr im allgemeinen im UEFI so ein?
Von "default" aus gesehen bei mit :
Lüftungssteuerung,
Dienste die ich nicht brauche, schalte ich ab (BT, den 2. Lan , SATA usw)
(Fast) Boot auf 1 Sekunde und die Asus Werbung weg...
Speicher idR so ca nach 1Usmus Kalkulator bis Proc ODT und Power/Gear down.
Den Rest lasse ich auf "auto" bzw testweise PBO (5800X) - keine richtige Übertaktung.
Selbst PCI 4.0 auf "auto"
Temperaturen 1a (~94 C° bei 6900XT Max und ~74C° interne beim 5900X mit 360er AiO) egal womit ich belaste zB 30min AIDA all on bis auf HDD,
20 Durchläufe 3D Mark , Timespy oder FireStrike Ultra.....
und jetzt folgende Situation:
Scheinbar war auf "auto" PBO off, weil ~ 8100Pt im CB20 , konnte die B-Die (3200er 14-14-14-14) auf cl 14-14-14-14 3800/1900/1,55Volt V-Ramm (aktiv gekühlt) rauf und runter benchen.
RDR2, Far Cry 5 stundenlang.....ich happy:banana:
Ich hatte vorher Testweise GraKas getauscht und konnte auf einmal recht weit den Speicher tunen.
Verschiedene Profile abgespeichert, auch unter anderem das 3800 cl 14 Profil. PBO (nur PBO) mal on gestellt....
Hatte dann Testweise mal probiert, ob ich das Ding vielleicht auf 2000 IF bekomm (soll es ja geben) , ging nicht, nicht weiter schlimm.
Nach Absturz und F1 Boot konnte ich das Adrenalin Radeon Menü nicht aufrufen, Stundenlang Treiber deinstalliert und wieder neu inkl. Chipsatz.
Als das geschafft war, bekam ich nix mehr stabil hin. selbst mit den hinterlegten 3200 cl 14 nicht.
2 Tage rumgebastelt und ganzen Tag Mem Test X86 mit verschiedenen Settings (Fehlerfrei).....nix
1X Benchmark ja, 20 mal Reboot, Soundblaster rausgeworfen, auch nix.
RDR2 und FC5 zwischen 2 und 15 Minuten Reboot.
Hab dann anderen Speicher UND C-Mos Clear gemacht, daraufhin nach 1 Stunde Reboot.
Nochmal C-Mos, nochmal alle Treiber, Spieldaten validiert (Daten waren OK)
Ich habe jetzt beim Wechsel zurück auf die 3200 cl14 (auf 3600 cl 16 aus 1Usmus Kalkulator ) was hinbekommen,.
Alle Benchmarks laufen wieder im 20x Loop, RDR2 ging wieder über >1 Stunde hinaus und ~ 40 Minuten AIDA Burn in.
Jetzt traue ich mich kaum, noch was zu ändern, weil ich nicht weiß, welche Option (Oder RAM Training?) mir da so böse mitgespielt hat?
Was hat mich da so gezankt?
Welche blöde Option die vielleicht auf Auto steht, wechselt da was und ruiniert einem den Tag?
Sry, viel Text....
3800/1900 wollte bei mir auch nicht. Ob es mittlerweile möglich ist habe ich nicht mehr probiert.
Vor dem Flash im Bios die Standard Settings laden. Profile nicht übernehmen bzw. löschen. Alles muss neu eingestellt werden.
Ein extra CMos nach dem Flash ist nicht nötig bzw. wird sowieso alles zurückgesetzt.
Die Reihenfolge ist mMn egal. Persönlich würde ich schon alles vorher machen und dann die GPU einbauen.
Hallo. Besitze das X570-F Gaming, wo stelle ich im UEFI mit einem 5800X die CPU auf 65W / Eco-Mode?
Im Advanced Mode
- Erweitert
- AMD CBS
- NBIO
- System Configuration
Oder mit dem AMD Tool "Ryzen Master"
Screenshot 2021-07-15 at 12-02-02 AMD Ryzen Master 2 1 Reference Guide - Feb 2020 - ryzen-mast...png
Ich habe seit ein paar Tagen gerne mal einen BSOD mit "video memory management internal", wenn die Netflix-App eine Wiedergabe starten will, auch bei einem Wechsel von Folge zu Folge.
Seit ein paar Tagen vermutlich, weil ich die App schon länger nicht genutzt habe.
x570-f, BIOS 4002, 3080 mit Rebar an und NVidia 471.11 (aktueller Game ready)
Pja ...
Seit ich Windows 11 drauf habe, gibt es keine Bootprobleme mehr. Kann das jemand bestätigen?
Mein Windows 11 Versuch hat zu einem nicht behebbaren grauen Bildschirm geführt, den ich nur grade so über Tastenkombinationen und Shift-Restart retten konnte durch einen Windows 10 Downgrade :d
War bei mir also ein verbuggter Scheißhaufen. Komischerweise lief das aber am Anfang ohne Probleme. Habe am ersten Tag Windows 11 komplett ohne große Probleme nutzen können, den PC ganz normal runtergefahren und dann am nächsten Tag nach Neustart ging garnichts mehr. Warum auch immer...
Mein Zweit-PC (SX570EG) mit Win 11 verursacht z. Zt. keine Probleme, weder beim booten oder im Betrieb.
Win 11 läuft schon jetzt erstaunlich stabil, vllt liegts an den Treibern die Win 11 mitinstalliert (Dev-Insiderversion).
Der Stealth Mode hat bei mir nicht gereicht, nach flashen des Mod-Bios 4002X und ErP-Aktivierung ist jetzt alles aus.
Guten Tag,
Habe mit meinen Asus x570 E probleme, evtl kann mir einer einen tip geben. ich weiss nicht mehr weiter.
Und zwar gibt es in jedem spiel mikroruckler. egal welches mal mehr mal weniger.
Hatte vorher eine RTX 2070S da ruckelte es.
jetzt eine RX 6700XT ruckelt.
Win 10 Schon mehrmals neu aufgestezt.
Aktuellste treiber.
Mit dem Bios 4002 ist es richtig schlimm.
Habe den latencyMon ausgeführt und ein paar benchmarks gemacht (userbenchmark).
Sobald er auf der MS SSD 4k60Write schreibt dann sagt latencymon das mein pc nicht mehr Realtime ist.
Mal ist es der TCp/IP die ausschlägt, beim nächsten test ist es die NDIS.sys. dann wieder die DXKRNL. Dann HDaudio.sys.
Also sobald er auf M2 ssd schreibt rastet der latencymon aus.
Keine ahnug ob das so sein soll oder nicht. die schreib werte sind okay.
Anbindung der beiden SSD sind PCIE3.0 x4.
habe zweimal die selbe M2 ssd verbaut.
Habe jetzt das alte bios 3602 geflasht und dies läuft auf jedenfall besser.
Creative Sound Blaster Z schon ausgebaut.... selbe fehler..
mit den neuen bios habe ich auch WHEA 18 fehler bekommen. waren zwar nur 4 mal aber das reichte mir.
Habe alles auf standard bis auf den ram der auf 3200MHZ eingestellt ist. Wlan deaktiviert und onboard sound im bios deaktiviert.
mein system:
Asus Strix X570 E
Amd Ryzen 9 5900X
Gskill Flare x 3200MHZ 32GB(4x8GB)
Bequiet 750Watt netzteil
2x Samsung 970 Pro M2 SSD
Amd RX 6700 XT Referenzdesign
Elgatoo Live GAmer HD 4k60 pro MK2 (auf die neuste version geflasht Firmware)
Ich weiss nicht mehr weiter.
Habe AMD kontaktiert ob evtl der CPU eine weg hat.
Habe die cpu im Februar 2021 geakauft.
Ich hoffe das ich ein paar heisse tips bekomme.
Ram habe ich auf auf standard 2400MHZ laufen gehabt ohne erfolg.
Danke schonmal für jeden TIp
p.s.
Ganz vergessen.
Wenn ich den Aktuellsten AMD chipsatz treiber instaliiere. dann wird am ende der installation allle USB geräte getrennt und das wars dann.
Programm sagt starte neu aber ohne maus Tastatur geht nix. Auch anschluss einer anderen maus hilft nicht.
War vorher nicht so.
Habe ich leider nur mit 4002 bios getestet.
Guten Tag,
Aktuellste treiber.
mein system:
Asus Strix X570 E
Amd Ryzen 9 5900X
p.s.
Ganz vergessen.
Mal den anderen M.2 slot Probiert ob die fehler dort auch auftretten?
Ja habe ich. Mal ja mal nein.
Mehrere benchmarks gemacht.
HAbe nochmals einen test mit Crystalbenchmark gemacht siehe bild.
Bei beiden M2 SSDS das selbe fehler bild. aber nur beim Q32T16 test
Alle anderen laufwerke (Sata SSD) ohne probleme laut Latencymon. alles im grünen bereich. Nur die Beiden M2 SSD´s
anzumerken ist das es 2 Samsung 970 pro m2 ssd NVME 1.3 1Tb sind. habe sogar den Samsung NVME treiber installiert. Ob mit oder ohne treiber kommt der selbe Fehler
Passiert es auch wenn nur eine verbaut ist?
ja auch wenn nur eine verbaut ist.
habe es sowohl im oberen als auch unteren slot ausprobiert.
immer das selbe fehlerbild.
nur mit der bios 3602 ist immer die storport.sys die ausser rand und band ist betroffen.
Was für ein CPU lüfter ist Montiert? Vllt mal mit bissel weniger anpressdruck versucht?
Aio wasserkühler (Deepcool Gammax 240)
der anpressdruck ist normal, hängt auch kein grosses und schweres gewicht dran
Du hattest ja geschrieben mit dem neusten Chipset treiber läuft nichts mehr. Passiert das auch mit Älteren Treibern?
@johny1984 hatte ähnliche Probleme damals bei mir war es der CPU allerdings ein 3900X
Habe es gerade mal getestet. Mit den älteren bios läuft auch die chipsatz installation durch ohne usb disconnects.
Habe den cpu auch im verdacht.
Mainboard lief mit 3800x ohne probleme.
Riecht für mich auch stark nach einer defekten CPU. Du könntest höchstens noch mal versuchen die CPU neu zu setzen. Bevor du die bei AMD einschicken kannst bitten die dich eh darum das zu machen. Glaube persönlich zwar nicht das es was bringt aber Versuch macht klug.
so cpu aus und wieder eingebaut.
Der fehler mit crystaldisk ist erstmal weg.
wenn ich aber das userbenchmark laufen lasse. kommt jetzt die hohe latenz auf DXGkrnl.sys 474520,405679 µs
soll ich jetzt neuste bios aufspielen??
Würde ich machen testweise.
So keine verbesserung bzw das problem verlagert sich nur.
Das allerbeste ist ja das AMD Support sich eben gemeldet hat und ein foto vom eingebauten cpu und der lesbaren seriennummer haben will. hätte ich das eben gewusst dann hätte ich bei der ersten demontage ein foto gemacht
Demontage geht ja zum glück schnell. :d
