[Sammelthread] ASUS X570 Strix Series (X570-E Gaming, X570-E Gaming Wifi II, X570-F Gaming, X570-I Gaming)
ROG Strix X570-E Gaming
ROG Strix X570-E Gaming Wifi II
ROG Strix X570-F Gaming
ROG Strix X570-I Gaming
BIOS/UEFI Versionen
Reviews & VRM
Häufig gestellte Fragen
BIOS Mods
ChangelogDownload
Flashing and using on your own risk!
  • Added VDDP Voltage
    Might be helpful for CPU overclocking
  • Added ASPM Support (Should be visible by default since v4802)
    PCIe Energy Saving
  • Added Erp Ready (Strix-E only)
    Energy Saving
  • Unlocked AMD PBS
    Hidden options unlocked
  • Added PCH Temerature
    Shows the PCH Temperature in the Bios
  • Added PCH Fan Control
    Gives you control over the PCH Fan
  • Advanced (Pump) Fan Settings
    Min and Middle Duty Cycle can be changed to 0%
  • Added Advanced Boot Settings
    Might be helpful for faster boot
Strix X570-E Gaming
Download Folder
Download Folder
Strix X570-F Gaming
Download Folder
Strix X570-I Gaming
EOL
CPUAMD AM4 Socket 3rd and 2nd AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
ChipsetX570
Memory3rd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
2nd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
4 x DIMM, Max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
GraphicIntegrated Graphics in the 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI 2.0b with maximum resolution of 4096 x 2160 @ 60 Hz
- Supports DisplayPort 1.2 with max. resolution 4096 x 2160 @ 60 Hz
Multi-GPU Support3rd and 2nd Gen AMD Ryzen™ Processors
Supports NVIDIA® 2-Way SLI® Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX™ Technology
Expansion Slots3rd Gen AMD Ryzen™ Processors
2 x PCIe 4.0 x16 (x16 or dual x8)
2 x PCIe 3.0 x16 (x16 or dual x8)
1 x PCIe 3.0 x16 (x8 mode)
AMD X570 chipset
1 x PCIe 4.0 x16 (max at x4 mode) *1
2 x PCIe 4.0 x1
Storage3rd Gen AMD Ryzen™ Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
8 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
LANIntel® I211-AT, 1 x Gigabit LAN Controller(s)
Realtek® RTL8125-CG 2.5G LAN
Anti-surge LANGuard
ROG GameFirst Technology
WiFi2 x 2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) with MU-MIMO supports dual frequency band 2.4/5GHz
BluetoothBluetooth® 5.0
AudioSupremeFX 8-Channel High Definition Audio CODEC S1220A
- Dual OP Amplifiers
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- SupremeFX Shielding Technology
- Supports up to 32-Bit/192kHz playback *2
Audio Feature :
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB Ports3rd Gen AMD RyzenTM Processors :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, )
2nd Gen AMD RyzenTM/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s)
AMD X570 chipset :
1 x USB 3.2 Gen 2 front panel connector port(s)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, , 3 x Type-A+1 x Type-C)
AMD X570 chipset :
2 x USB 3.2 Gen 1 port(s) (2 at mid-board)
AMD X570 chipset :
4 x USB 2.0 port(s) (4 at mid-board)
Special Features5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
TPU
- Auto Tuning, TurboV, GPU Boost
Gamer's Guardian:
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
- SafeSlot
- ESD Guards on LAN, Audio,and USB ports
ASUS EPU :
- EPU
AURA :
- Aura Lighting Control
- Addressable Gen 2 Header
ASUS Exclusive Features :
- USB BIOS Flashback®
- AI Suite 3
- Ai Charger
- ASUS NODE : hardware control interface
- BIOS Flashback® Button
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports1 x DisplayPort
1 x HDMI
5 x USB 3.1 Gen 1 Type-A
8 x USB 2.0
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Anti-surge 2.5G LAN (RJ45) port
1 x USB BIOS Flashback® Button(s)
1 x ASUS Wi-Fi Module
7 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-C)
Anti-surge LAN (RJ45) port
Internal I/O Ports1 x PCH_FAN
1 x AAFP connector
2 x Aura RGB Strip Header(s)
2 x Addressable Gen 2 header(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x M.2 Socket 3 with M key, type 2242/2260/2280/22110 storage devices support
1 x SPI TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x Thermal sensor connector(s)
1 x Clear CMOS jumper(s)
1 x Node Connector(s)
1 x System panel connector
1 x T_Sensor Connector
1 x M.2 Fan Header
1 x USB 3.2 Gen 2 (up to 10Gbps) connector
1 x USB 3.2 Gen 1 (up to 5Gbps) connector support additional 2 USB ports
AccessoriesUser's manual
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x Supporting DVD
1 x Strix door hanger
1 x ROG Strix stickers
1 x Cable ties pack(s)
1 x Wi-Fi Antenna(s)
1 x Extension Cable for RGB strips (80 cm)
1 x Extension cable for Addressable LED
1 x Thermistor cable(s)
1 x ROG Thank you card
BIOS256 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.2, ACPI 6.2.
Form FactorATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note*1 PCIeX16_3 slot shares bandwidth with PCIeX1_2.
*2 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
Bios Version 0807
AiTweaker
Advanced
Monitor
Boot
Tool
Kompatibilitätsliste
Memory QVL Ryzen 3000/4000/5000
Chipsatz Modding
Alternativer Chipsatz Kühler von KCX
ROG Strix X570-E Gaming WIFI II
Produktseite | Handbuch (EN) | Support-Downloads | Preisvergleich
CPUAMD Ryzen™ 5000 Series/ 5000 G-Series/ 4000 G-Series/ 3000 Series/ 3000 G-Series/ 2000 Series/ 2000 G-Series Desktop Processors
ChipsetX570
MemoryAMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
4 x DIMM, Max. 128GB, DDR4 4600(O.C.)/4400(O.C.)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200/3000/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 5000 and 4000 G-Series Processors
4 x DIMM, Max. 128GB, DDR4 5100(O.C)/4800(O.C.)/4600(O.C)/4466(O.C.)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3200/3000/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 and 3000 G-Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
ECC Memory (ECC mode) support varies by CPU
Graphic1 x HDMI 2.0
1 x DisplayPort
Expansion SlotsAMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
2 x PCIe 4.0 x16 (x16 or dual x8)*
AMD Ryzen™ 5000 G Series/4000 G-Series/ 2000 Series Processor
2 x PCIe 3.0 x16 (x16 or dual x8)*
AMD Ryzen™ 2000 G-Series/ 3000 G-Series Processor
1 x PCIe 3.0 x16 (x8 mode)*
AMD X570 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
2 x PCIe 4.0 x1
*PCIeX16_3 slot shares bandwidth with PCIeX1_2.
StorageSupports 2 x M.2 slots and 8 x SATA 6Gb/s ports
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors:
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
AMD Ryzen™ 5000 G-Series/4000 G-Series/ 3000 G-Series/ 2000 G-Series/2000 Series Processor
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 3.0 x4 & SATA modes)
AMD X570 Chipset
M.2_2 slot (Key M), type2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
LAN1 x Realtek 2.5Gb Ethernet
1 x Intel® I211-AT 1Gb Ethernet
Anti-surge LANGuard
1 x Intel® 1Gb Ethernet
WiFiWi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
BluetoothBluetooth® v5.2
AudioRealtek S1220A 7.1 Surround Sound High Definition Audio CODEC*
- Internal audio Amplifier to enhance the highest quality sound for headphone and speakers
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input (Line-in)
- Supports up to 32-Bit/192 kHz playback*
Audio Features
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
USB PortsAMD RyzenTM 5000, 5000 G-Series, 4000 G-Series, and 3000 Series Desktop Processors
- 4 x USB 3.2 Gen2 ports (4 ports at back panel, Type-A)
AMD RyzenTM 3000 G-Series, 2000, and 2000 G-Series Desktop Processors
- 4 x USB 3.2 Gen 1 ports (4 ports at back panel, Type-A)
AMD X570 chipset
- 1 x USB 3.2 Gen2 front panel connector
- 4 x USB3.2 Gen2 (at back panel, 3x Type-A, 1x Type-C)
- 2 x USB3.2 Gen1 ports (at front panel)
- 4 x USB 2.0 ports (at front panel)
Special FeaturesExtreme Engine Digi+
- 5K Black Metallic Capacitors
ASUS Q-Design
- M.2 Q-Latch
- Q-Code
- Q-DIMM
- Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
- Q-Slot
ASUS Thermal Solution
- M.2 heatsink
ASUS EZ DIY
- BIOS FlashBack™ button
- BIOS FlashBack™ LED
- ProCool II
- Pre-mounted I/O shield
- SafeSlot
AURA Sync
- AURA RGB headers
- Addressable Gen 2 headers
Back I/O Ports8 x USB 3.2 Gen 2 ports (7 x Type-A + 1 x USB Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® I211-AT 1Gb Ethernet port
1 x Realtek 2.5Gb Ethernet port
5 x Gold-plated audio jacks
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
Internal I/O PortsFan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
2 x 4-pin Chassis Fan headers
1 x 4-pin M.2 Fan header
1 x W_PUMP+ header
Power related
1 x 24-pin Main Power connector
1 x 8-pin +12V Power connector
1 x 4-pin +12V Power connector
Storage related
2 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Miscellaneous
2 x Addressable Gen 2 headers
2 x AURA RGB headers
1 x Clear CMOS header
1 x Front Panel Audio header (AAFP)
1 x SPI TPM header (14-1pin)
1 x Speaker header
1 x 10-1 pin System Panel header
1 x Thermal Sensor header
AccessoriesCables
4 x SATA 6Gb/s cables
1 x Thermistor cable pack
Miscellaneous
1 x ASUS Wi-Fi moving antennas
1 x Cable ties pack
1 x M.2 Rubber Package
1 x M.2 Q-Latch package
1 x ROG key chain
1 x ROG Strix thank you card
Installation Media
1 x Support DVD
Documentation
1 x User manual
Full Specs:
ChipsetX570
AMD X570 chipset
2 x PCIe 4.0 x1
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
Anti-surge LANGuard
Audio Feature :
- Sonic Radar III
USB Ports3rd and 2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s) (4 at back panel, )
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
TPU
Gamer's Guardian:
- DIGI+ VRM
- SafeSlot
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
1 x HDMI
8 x USB 2.0
5 x Audio jack(s)
4 x USB 3.2 Gen 1 (up to 5Gbps) ports
3 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x AAFP connector
1 x SPI TPM header
1 x M.2 Fan Header
1 x Supporting DVD
Chipsatz Modding
Wasserkühler von Neo111430
ChipsetX570
2 x DIMM, Max. 64GB, DDR4 4800(O.C.)/4600(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3800(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory
- Support DisplayPort 1.4 with max. resolution 8 K 7680 × 4320 @60 Hz
1 x PCIe 4.0 x16 (x16 mode)
1 x PCIe 3.0 x16 (x16 mode)
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2_2 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
4 x SATA 6Gb/s port(s),
LANIntel® I211-AT
Anti-surge LANGuard
WiFiSupports channel bandwidth: HT20/HT40/HT80/HT160
Intel® Wi-Fi 6 AX200
Up to 2.4Gbps transfer speed
Audio Feature :
- DTS® Sound Unbound
- LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
- Sonic Radar III
- Sonic Studio III + Sonic Studio Virtual Mixer
4 x USB 3.2 Gen 1 port(s) (4 at back panel, blue)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (3 x Type-A+1 x Type-C)
AMD X570 chipset :
AMD X570 chipset :
2 x USB 2.0 port(s)
TPU
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
1 x HDMI
3 x LED-illuminated audio jacks
4 x USB 3.2 Gen 1 (blue)
Internal I/O Ports1 x HS_FAN
1 x PCH_FAN
1 x AAFP connector
1 x Aura RGB Strip Header(s)
1 x Addressable Gen 2 header(s)
1 x USB 3.2 Gen 1(up to 5Gbps) connector(s) support(s) additional 2 USB 3.2 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
2 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
4 x SATA 6Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Speaker connector
I/O Shield
2 x M.2 Screw Package
1 x Supporting DVD
1 x M.2 bracket
1 x AAFP Extension Cable
1 x Panel cable
Form FactorMini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm )
Note*1 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
*2 Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
  • Sound setzt aus oder knistert
    Immer wieder USB Disconnects
    Meistens tritt dieses Problem auf, wenn man einen hohen RAM Takt verwendet. In diesem Fall kann man versuchen die SOC Spannung auf 1.125V zu erhöhen. Sollte das nicht ausreichen, zusätzlich noch die VDDG CCD Spannung auf 1.00V (oder niedriger), sowie VDDG IOD Spannung auf 0.925V stellen.
  • USB Disconnects
    Mit bestimmten UEFI/Agesa Versionen (v2 1.1.0.0/ 1.1.8.0) können sporadische USB Disconnects auftreten. Um dies zu umgehen bitte folgende Einstellung im Bios deaktivieren:
    UEFI -> Advanced -> AMD CBS -> Global C-States deaktivieren
    Der Verbrauch steigt dadurch um ca. 5Watt an aber ansonsten hat man keine weiteren Nachteile
  • USB Flashback funktioniert nicht
    Bitte folgende Punkte ausprobieren:
    - Datei richtig umbenannt? Vorzugsweise mit dem im BIOS Download enthaltenen Renamer
    - Vor dem Flashen das BIOS auf Werkseinstellungen zurück setzen!
    - Einen anderen USB Stick ausprobieren. Vorzugsweise ein USB 2.0 Stick
  • BIOS/UEFI Downgrade
    Ein UEFI Downgrade ist ohne Probleme mit USB Flashback möglich, soweit vorhanden.
  • Ist der Chipsatz Lüfter regelbar?
    Nein, dieser wird automatisch, je nach vorhandener Temperatur, geregelt. Bis zu einer Temperatur von 55 Grad ist der Lüfter deaktiviert. Bei höheren Temperaturen wird er stufenweise schneller bis er letztendlich bei 93 Grad seine Höchstgeschwindigkeit erreicht. Über selbst erstellte Bios Mods kann man jedoch den Lüfter auch nach seinen Wünschen einstellen.
  • Chipsatz Temperatur zu hoch?
    Wem das Optische nicht so wichtig ist, kann die Lüfterabdeckung vom Chipsatz beim X570-E oder x570-F entfernen. Dadurch staut sich die warme Luft nicht an, sondern kann direkt entweichen.
    Des weiteren kann man im Bios unter "Onboard Devices Configuration" die vorhandenen Steckplätze (PCIe X16, X1, M.2, SB Link) manuell auf PCIe 3.0 umstellen, sofern man keine PCIe 4.0 Karte verwendet. Bei Auto Einstellung wird automatisch PCIe 4.0 angelegt, was zu einer höheren Last führt.
  • Kann ich ein altes Bios Profil mit einer neuen Bios Version nutzen?
    Nein, es ist zu empfehlen kein altes Profil mit einer neuen oder älteren Bios Version zu nutzen. Dies endet meist mit einem Blackscreen. Nach jedem Bios Flash bitte die Einstellungen neu vornehmen. Selbst wenn sich ein Profil laden lässt, kann es trotzdem zu Instabilität führen.
  • Rechner bootet nicht, wenn eine Soundkarte verbaut ist
    Dieses Problem kann mit dem Bios 1404 oder höher (Agesa 1004b) auftreten. In dem Fall bitte in dem AMD CBS Menü die Option "PCIe Ten Bit Tag Support" auf Disabled stellen. Sollte das nicht ausreichen, dann zusätzlich noch unter dem Menü Advanced -> Onboard Devices Configuration -> die Option PCIEXxxx (den Slot auswählen, in der die Soundkarte steckt) von Auto auf Gen3 ändern.
Mein Mainbord hat sich was neues ausgedacht, der Rechner läuft unter Windows 10 einwandfrei. aber er geht nicht in Bios, wenn ich während des starten F2 oder Del drücke, hängt sich der Rechner mit A9 im Display auf. Geht auch nicht weiter. Drücke ich dann Ctrl Alt Del, startet der Rechner neu und funktioniert anschließend einwandfrei in Windows. Hat jemand eine Idee, wie ich das lösen kann?
Drückst du zufällig oft und schnell hintereinander die Del Taste? Das führt gerne zu dem von dir geschilderten Hänger. Erst drücken oder kurz davor drücken wenn das Asus Bild kommt.
Ein Bekannter hatte mir den Tipp geben, den Rechner herunterzufahren und auch hinten am Netzschalter auszumachen und dann 10 Min. zu warten.
Das hat dann funktioniert.
hast du fast boot an- ultrfastboot oder wie auch immer das heißt?
schalt es ab-
dann geht das mit entf ins bios
Hier, dies habe ich rausbekommen:
Ich habe als Monitor einen 4k Samsung TV über HDMI angeschlossen.
Wenn der Bildschirm einige Minuten an ist, erkennt das BIOS Setup anscheinend den Bildschirm nicht. Dann bleibt der bei A9 hängen. Oben die LED (BOOT) auf dem Motherboard leuchtet grün und geht auch nicht aus. Auch der erweiterte Start kommt nicht ins BIOS.
Auch kommt nach einem Restart die Meldung F2 oder Del drücken um ins Setup zu gelangen nicht. Aber wenn ich keine Taste drücke startet Windows 10 einwandfrei und der Rechner selbst läuft perfekt.
Schalte ich aber vorher den Bildschirm aus und wieder ein, dann kommt die Meldung F2 oder Del drücken um ins Setup zu gelangen. Dann komme ich auch problemlos ins BIOS Setup.
Mir ist gestern der Rechner rebootet, weil ich Instant Game Respose am LG OLED aktiviert habe (wodruch der Rechner auf GSynch gehen sollte).
Mit Grafikkarten kann das Motherboard nicht so gut ... ich habe auch 4 Anschlüsse belegt.
Verhalten ist seltsam.
Habe jetzt seit ein paar Tagen auch PBO und Fmax aus.
Noch eine Frage zum OC vom RAM, ich habe diesen Speicher verbaut Corsair CMH32GX4M2Z3600C18
Auf eine OC Seite habe ich dieses empfohlene Timing für genau diesen Speicher gefunden , links (1) ; rechts (2) ist das Timing was ich zur Zeit eigestellt habe.
Meine Einstellung läuft stabil.
Meine Fragen, was hat Uncore Frequency mit dem RAM zu tun? Ist es sinnvoll da so hoch zu gehen? Wo wird das eingestellt?
Was ist mit FSB :RAM ? Ist die Einstellung Sinnvoll? Hat jemand noch andere Ideen?
Uncore Frequency = Takt des Speichercontrollers (UCLK)
Siehe auch ca in der Mitte: Übertaktung des Speichers und der Infinity Fabric
Wenn der Speicher nicht im 1:1 Modus läuft, dann verschenkst du eine Menge Leistung. Anders gesagt, deine DDR4-4000 Einstellungen bringt aktuell die Leistung eines DDR4-3466/3600er Kits.
Hab im Moment das Problem das BCLK Spread Spectrum auf Disabled wirkungslos bleibt, also BCLK dümpelt bei 98-99 Mhz rum.
Wenn ich den Bustakt manuell auf 101MHz anhebe startet der Rechner nicht mehr.
Gibts da einen Lösungsweg?
Weil hier einige Probleme mit Ihrer Grafikarte haben andere haben das auch und es gibt keine Erklärung noch Lösung dazu, ob es an BIOS UEFI liegt keine Ahnung
Klasse, das Reous hier immer noch seine Mod Bios bereitstellt und supportet :hail:
Ich nutze eines seiner frühen (1405X2) und fand die Diskussion hier vor 2 Seitzen ganz interessant, ob man davon oder generell von alten Bios upgraden sollte. Ich scheu mich da irgendwie, hab aber jetzt erstmals ein Problem mit dem USB Hub des Dell Monitors. Sobald ich den an eine der hinteren USB Anschlüsse am Asus anschließe, bekomme ich bei diesen USB Hub Einträgen Fehlermeldungen, dass sie nicht migriert werden konnten, s. hier:
Das sind die Eigenschaften des generischen USB Hubs 2. Interessant dabei, die Fehlermeldung darunter wird getriggert, wenn ich an dem Front USB 2.0, an dem die Maus war, bevor sie an den Dell Hub gewandert ist, ein USB Stick angeschlossen wird, worauf Windows im Ereignisbereich mit "das letzte usb gerät das an diesen computer angeschlossen wurde hat nicht ordnungsgemäß funktioniert" reagiert.
Ob sich da mit einem Bios Update was ändern lässt? Ich sehe in den Beschreibungen keine Behebung von USB Problemen angegeben. Ich trau mich halt nicht so recht, da mein Ram OC soweit stabil läuft, und da ich sowas nicht jeden Tag mache, sicher wieder Stunden brauche, das einzurichten, denn ich kann ja vermutlich nach Bios Update mein Profil nicht einfach wieder laden? Und ggf. funktionieren ja auch die Werte nicht mehr.
Vielleicht hat jemand für das Problem auch eine andere Lösung parat, sonst bin ich irgendwie unsicher, dafür ein Biosupdate zu machen, denn der USB Hub ist zwar nice to have, aber auch nicht essentiell. Sobald ich den trenne, sind die Einträge weg und auch der Front USB, der damit eigentlich gar nichts zu tun hat, gibt dann nicht mehr diese Meldungen.
Auf mitlere Frist, sollte ich irgendwann mal eine neue Grafikkarte ergattern, will ich aber vielleicht rBar, alles schwierig...
Hatte das auch gesehen und dachte an das ein oder andere Problem, das ich auch habe mit dem Multimonitor-Setup.
ich habe ja ein TUF X570, aber sollten sich ja nicht so unentscheiden. leider wenn ich den neuen 5900X auf manuell Vcore 1.2V setze, taktet er bei Aida nicht mehr runter. Irgendwie bin ich noch nicht durchgestiegen. Was muss man einstellen, das es trotzdem runtertaktet. Oder mit Offset arbeiten?
Vielleicht hat ja jemand hier den Hinweis für mich, drehe mich etwas im Kreis. Der 5900X auf Stock ist leider eher so -5% zu den Benchmarks die ich bisher sah. Nun 4400MHz Allcore und 1,2V liefen gut durch mit guten Temperaturen um die 72°C, nur möchte ich halt gerne auch die C-States nutzen. :)
Vielen Dank!
Jo sowas hab ich auch noch nicht erlebt. Aber es scheint ja an der Monitorkombi zu liegen und nicht am Bios. Er hat ja sogar das komplette Setup getauscht. Hätte mir nicht vorstellen können, dass eine Monitor/GPU Kombi einen Error Code aufm Board erzeugen kann. Wirklich crazy
Das gute alte 1405. Kann dich ein wenig verstehen, da ich damit sehr gute CPU OC Ergebnisse hatte. Ich habe fast jede Version mitgemacht und mein 3733CL16 lief immer ohne Probleme oder Fehler. Timings und Spannungen einfach immer stumpf übernommen. Natürlich neu eingetragen und nicht per Profil. Aktuell mit dem neusten 3801 unterwegs. Ich kann gar nicht anders als immer den Update Knopf zu drücken 😅
zum F nicht, zum E aber dann doch schon
TUF
VRM6 reale Phasen (4+2), PWM-Controller: ASP1106 (RT3667BE, max. 6 Phasen)
MOSFETs CPU12x 50A SiC639
MOSFETs SoC2x 50A SiC639
STRIX-E
VRM8 reale Phasen (6+2), PWM-Controller: ASP1405I (max. 8 Phasen, IR35201)
MOSFETs CPU12x 60A IR3555
MOSFETs SoC4x 40A IR3553
STRIX-F
und wenn ich mich nicht irre, spielt die Versorgung beim Thema Spannung keine unbedeutende Rolle
zum 5900X kann ich aber leider nix sagen...
Leider nicht. Jetzt direkt nach dem Start Ereinise eingeschaltet und
Anhang anzeigen 632976Anhang anzeigen 632977
Was ich auch nicht so richtig verstehe warum ich jetzt auf einmal so viele Dynamische Datenträger habe.
Das Windows Dynamische hat ist normal aber das auch eine M2 und eine normal SSD Dynamisch ist verstehe ich nicht. Nu ist die frage ob ich alle Dynamisch oder als Basis machen soll oder nicht :) . Keine ahnung ob es auch was zu sagen hat. Ich instaliere gleich die Bios Version 3604. Mal schauen was es wird.
Edit 1. 3604 ist drauf. Die Meldungen sind noch immer da. Ich werde erst alle Platten bis auf "System" als Basis machen und schauen ob es geholfen hat.
Also PBO off bzw. den Rest auf Auto bis auf RAM (3666MHz) funktioniert bislang wunderbar. Kein Absturz. Maximale Frequenz ist nicht mehr so weit oben wie vorher, aber bei AC merke ich bspw. keinen Unterschied.
Ist zu vernachlässigen, wie ich oft gelesen habe das PBO. Klar gibt es in Benchmarks weniger Punkte wie bspw. Cinebench (und zwar deutliche 500 Punkte weniger), aber es läuft.
Für kleine Tweaks bin ich offen um ggf. etwas mehr Performance raus zu holen, aber dennoch stabil zu bleiben.
LG
Luke
Ich meine das UEFI Bios der Grafikarte nicht vom Bord selber. Beim Boot laufen Grafikarten ja selber eine Prozedere durch und fragen beim Monitor auch Daten ab was der halt so kann oder auch nicht und noch paar Selbs Tests. Könnte sein das er da selber hängen bleibt. Scheint mir bei Nvidia aber häufiger zu sein ich selber hatte noch keine Probleme mit meiner RX6800 XT.
berichten, ich bin mit 5900x asus rog striz x570 mit dem bios 3603, PBO auf, xmp aktiviert in 3200Mhz und seit 27/03/2021 hatte ich keine WHEA 18 mehr, das interessanteste und dass der Basistakt dies in 3,6 GHze 4,9 GHz erreicht, wenn ich Modern Warfare spiele. dieses neue "bios" 3603 stabilisierte den Computer.
sorry , übersetzt über deepl.com
reporting, I am with 5900x asus rog striz x570 with bios 3603, PBO on, xmp enabled in 3200Mhz and since 27/03/2021 I had no more WHEA 18, the most interesting and that the base clock this in 3.6 GHze reaches 4.9 GHz when I'm playing Modern Warfare. this new "bios" 3603 stabilized the computer.
sorry , translated via deepl.com
LG
Luke
Zu früh gefreut. Heute war es wieder soweit. Viele Browser-Fenster mit vielen Tabs, viele Worddokumente, dann noch einige Adobe Programme, daraus ein Druckauftrag, der zum Glück fertig gestellt wurde und dann kam der Absturz wieder mit der ID 41 (Kernel-Power), trotz Stock-CPU-Settings.
Treiber sind alle aktuell, Bios ebenfalls.
Habe hier sogar einen detaillierten Bericht der Dump-Date, aber falls der hier unpassend ist, würde ich mich freuen, wenn ich einen Tipp erhalten kann wo ich damit besser aufgehoben bin um herauszufinden was die Ursache ist:
Code:
*                        Bugcheck Analysis                                    *
PFN_LIST_CORRUPT (4e)
Typically caused by drivers passing bad memory descriptor lists (ie: calling
MmUnlockPages twice with the same list, etc).  If a kernel debugger is
available get the stack trace.
Arguments:
Arg1: 0000000000000099, A PTE or PFN is corrupt
Arg2: 0000000000194f3f, page frame number
Arg3: 0000000000000002, current page state
Arg4: 0600019000194f3e, 0
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 3124
    Key  : Analysis.DebugAnalysisManager
    Value: Create
    Key  : Analysis.Elapsed.mSec
    Value: 23503
    Key  : Analysis.Init.CPU.mSec
    Value: 1280
    Key  : Analysis.Init.Elapsed.mSec
    Value: 143018
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 87
    Key  : WER.OS.Branch
    Value: vb_release
    Key  : WER.OS.Timestamp
    Value: 2019-12-06T14:06:00Z
    Key  : WER.OS.Version
    Value: 10.0.19041.1
BUGCHECK_CODE:  4e
BUGCHECK_P1: 99
BUGCHECK_P2: 194f3f
BUGCHECK_P3: 2
BUGCHECK_P4: 600019000194f3e
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  bdservicehost.exe
STACK_TEXT:
ffff8108`96ba9bc8 fffff807`2afed97f     : 00000000`0000004e 00000000`00000099 00000000`00194f3f 00000000`00000002 : nt!KeBugCheckEx
ffff8108`96ba9bd0 fffff807`2ae9a598     : 8a00000c`00000002 00000000`00000004 0588776a`00000000 00000000`00000000 : nt!MiBadShareCount+0x5b
ffff8108`96ba9c10 fffff807`2ae9ad6e     : 00000000`00000000 ffff8108`96baa320 ffff9401`02f54000 ffff8108`96baa270 : nt!MiDeletePteRun+0x1798
ffff8108`96ba9e20 fffff807`2ae0bedd     : 00000000`00000000 ffffb10e`e9802740 ffff8108`96baa270 ffff9401`02f53ff8 : nt!MiDeleteVaTail+0x6e
ffff8108`96ba9e50 fffff807`2ae0bafb     : ffff944a`00000000 ffffb10e`e9802740 ffff8108`00000000 ffff8108`96baa2c0 : nt!MiWalkPageTablesRecursively+0xc6d
ffff8108`96ba9ef0 fffff807`2ae0bafb     : ffff944a`250040b8 ffffb10e`e9802740 ffff8108`00000001 ffff8108`96baa2d0 : nt!MiWalkPageTablesRecursively+0x88b
ffff8108`96ba9f90 fffff807`2ae0bafb     : ffff944a`25004000 ffffb10e`e9802740 ffff8108`00000002 ffff8108`96baa2e0 : nt!MiWalkPageTablesRecursively+0x88b
ffff8108`96baa030 fffff807`2ae5de6b     : ffff8108`96baa148 ffffb10e`e9802740 ffff8108`00000003 ffff8108`96baa2f0 : nt!MiWalkPageTablesRecursively+0x88b
ffff8108`96baa0d0 fffff807`2ae9b991     : ffff8108`96baa270 ffffb10e`00000000 ffffffff`00000002 00000000`00000000 : nt!MiWalkPageTables+0x36b
ffff8108`96baa1d0 fffff807`2ae6baf0     : 00000000`00000001 ffff8108`00000000 ffffb10e`e9802590 ffffb10e`e9fed080 : nt!MiDeletePagablePteRange+0x4f1
ffff8108`96baa4e0 fffff807`2b236189     : ffffb10e`e6f388d0 00000000`00000000 ffffb10e`00000000 ffffb10e`00000000 : nt!MiDeleteVad+0x360
ffff8108`96baa5f0 fffff807`2b235820     : ffffb10e`e6f388d0 ffffb10e`e9797d60 ffffb10e`e9fed080 00000000`00000000 : nt!MiUnmapVad+0x49
ffff8108`96baa620 fffff807`2b233aef     : ffffb10e`ece45c60 ffffb10e`ece45c60 ffffb10e`e6f388d0 ffffb10e`e98020c0 : nt!MiCleanVad+0x30
ffff8108`96baa650 fffff807`2b25dbd4     : ffffffff`00000000 ffffffff`ffffffff 00000000`00000001 ffffb10e`e98020c0 : nt!MmCleanProcessAddressSpace+0x137
ffff8108`96baa6d0 fffff807`2b306a96     : ffffb10e`e98020c0 ffff9788`a6260060 ffff8108`96baa920 00000000`00000000 : nt!PspRundownSingleProcess+0x20c
ffff8108`96baa760 fffff807`2b2d2918     : 00000000`000003e9 00000000`00000001 ffffb10e`ed57c130 000000eb`e34fc000 : nt!PspExitThread+0x5f6
ffff8108`96baa860 fffff807`2ae67fb7     : 00000000`00000101 00000000`00000000 ffffb10e`e95cc050 00000000`00000000 : nt!KiSchedulerApcTerminate+0x38
ffff8108`96baa8a0 fffff807`2affa3e0     : 00000205`c8d6f1c0 ffff8108`96baa950 000000eb`e7affae8 ffffb10e`00000000 : nt!KiDeliverApc+0x487
ffff8108`96baa950 fffff807`2b00785f     : 00000000`00002d38 00000000`00000000 00000000`77566d4d ffff8108`96baaae8 : nt!KiInitiateUserApc+0x70
ffff8108`96baaa90 00007ffc`44bb0774     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x9f
000000eb`e7affa98 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffc`44bb0774
SYMBOL_NAME:  nt!MiBadShareCount+5b
MODULE_NAME: nt
IMAGE_VERSION:  10.0.19041.928
STACK_COMMAND:  .thread ; .cxr ; kb
IMAGE_NAME:  ntkrnlmp.exe
BUCKET_ID_FUNC_OFFSET:  5b
FAILURE_BUCKET_ID:  0x4E_99_nt!MiBadShareCount
OS_VERSION:  10.0.19041.1
BUILDLAB_STR:  vb_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {60e553e9-e4c5-ed08-9be6-c353e0011003}
Followup:     MachineOwner
Da steht was von https://www.file.net/prozess/bdservicehost.exe.html, also Bitdefender. Habe ich sogar letztens neu installiert. Verursacht BitDefender den Absturz?
Hier steht auch was von C-State (ja habe ich aktiviert): https://de.drivereasy.com/wissen/bluescreen-fehler-ntkrnlmp-exe-unter-windows-10/
Danke im Voraus und LG
Luke
Ah, da haben wir uns missverstanden. Benutze da eher Begriffe wie VGA Bios, oder vBios 😁
Jo sieht nach einem Problem bei "Handshake" aus. Hab ich aber noch nie gesehen oder gehört. Weder bei Nvidia noch bei AMD(ATI). Roman hat ja auch nur ein ? überm Kopf. Normal ist das nicht.
Das passende TPM Modul gibt es übrigens hier:
14,55€ incl. Versand
Habe ich verbaut
Macht vermutlich nicht viel Unterschied, aber ich kann mit 6900 XT kein PCIx 4.0 laufen lassen.
Ewiger Bootloop. Auf 3.0 bootet flott und habe keine Probleme mit Stabilität/Last. (CSM on/off kein Unterschied letztes BIOS geflasht, SAM on/off)
Hab schon alle sinnigen und unsinnigen Optionen geändert- ohne Erfolg.
Finde ich bisschen doof: Mit AMD Board und AMD GraKa das 4.0 Feature nicht laufen lassen kann.
Direkt angeschlossen oder über Riserkabel. Mann liest immer wieder das die PCIex 4 Karten mit PCIx 3 Riser ärger machen.
Direkt angeschlossen. Mehrmals ein und ausgesteckt....daran liegt es auch nicht.
CPU: 3900X, 2X16GB B-Die (def auch Probiert, ob es damit zutun haben könnte), 6900XT an 1050 Watt Corsair, USB Sound, 2X NVMe
BIOS 3801 - und auch alles Auto mal versucht. Spätestens wenn sich 4.0 einrichtet, habe ich den Bootloop.
Batterie habe ich mal herausgenommen, nachdem ich aus Schleife nicht mehr raus kam. (Statt C-Mos)
Die Nvidia Reste hatte ich mit DDU entfernt- Chipsatz+AMD neu installiert. und danach neustes BIOS....
Das war so die Bastelei.
Nicht falsch verstehen, das ist Jammern auf hohem Niveau . Und Die Games performen 1a und alle interessanten Features (Free Sync+ FPS Range usw) funktionieren prima,
aber es wurmt^^
@Neo111430
Läuft deine 6800XT im Strix F bei dir 4.0 ?
Wenn du im BIOS alles auf Auto lässt (Factory Default), dann bootet der normal und hast im GPU-Z PCIe 4.0?
Wer weiß, ob das ausgerechnet nur beim "E" ist?
Der Witz ist, ich hatte mal irgendwo davon gelesen und beim Basteln, bzw Bootloop dann eingefallen.
Ja ich habe alles auf Auto. Nur XMP an "3200". SAM an oder aus macht keinen unterschied. Bootet in paar Sekunden und GPU-Z zeigt
