[Sammelthread] AMD K7 - Sockel A (462)
Das Bios vom -E läuft nur auf dem -E ;) Normales A7N8X v2.0 oder Deluxe v2.0 sollte gehen. Ich tippe das Bios vom Deluxe läuft, so wie bei meinem 4MBO auch. Falls du den Chip vom OEM flashst, mach vorher unbedingt ein Backup. Die OEM Biose sind nahezu unauffindbar...
I found the second sis board as well. This is a Asrock K7S41GX (SIS 741GX).
Edit: I wonder how many people have it boxed...
Nice. I didn`t find much informations about it. It seems like this board was build for OEM (Acer T120E). As far as I see, this is a SIS741 (not 166MHz 741GX) version. FSB 200MHz should be possible.
edit:
driver page
edit2:
I am not sure if you're interested in, but here is the BIOS +mod BIOS for this board. I unlocked quickly hidden options like Vdimm+Vcore+CPUtemp. BIOS is AWARD.
BIOS Chip is soldered to board, so it is more risky to flash this BIOS.
I was just wondering, I see these R01-B1.42 and R01-BM.BIN in the zip file. Is R01-BM.BIN the modded BIOS?
Because I saw this statement in the flash.bat file: awdflash R01-B1.42 /sn /py /cd /cp /R
That would be the wrong one.
R01-BM. Bin is the modded file. The other one is the stock Bios.
I also own one of these ASRock SIS 741GX boards. Not my favourite board. Memory performance is crippled. I hope to find the performance Bios for this board.
YAY, Erfolg! Mein ASUS (A7N8X-E #3) hat sich über die 3500C2 Riegel gefreut :d.
Für 260MHz brauchen die Riegel so wie es aussieht auf dem ASUS ~3,55V. VTT Spannung habe ich hier um ca. -100mV abgesenkt. Ich könnte mir vorstellen, dass die Riegel auf dem NF4 erst richtig los legen. Limit dürfte hier eher das board sein. Vdd=1,69V
passt das?
Top Leistung. Und dazu fast so schnell! (y)
(260-MHz vs. 260.59-MHz, daran lag es bestimmt)
Zum Monster NF7:
:lol:
I decided to test the Acer motherboard with the SIS chipset. No Post at all.
All parts I could replace (including a psu with -5v) I swapped, it doesn't even give a 00 code.
So too bad.
So, this board is dead before flashing new Bios?
Spricht etwas gegen ein abit nf7-s2 als Sockel a Basis? Oder gibt es Gründe die gegen das s2 sprechen und eher für das normale? Ähnliches Thema beim k7n2 Delta. Vielleicht kann mich ja mal jemand aufklären. ;)
NF7-S2 oder NF7 v2.0? Solange du nicht übertakten willst sollte das (fast) egal sein.
Beim Delta1 dürfte vermutlich das BIOS besser sein, Beim Delta2 die Hardware. Das Delta1 dürfte zum modden und OC besser geeignet sein(keine Ahnung, ob es dafür schon Anleitungen gibt) . Das Delta2 BIOS ist etwas buggy, aber wenn man sich damit befasst, bekommt man das auch halbwegs hin. Wenn man nicht übertakten möchte, sind beide Boards okay.
Edit.
Der größte Unterschied zwischen NF7 v2 / Nf7 S2 und Delta1 / Delta2 ist die SB.
Achtung! Das NF7 S2 ist von den OC Funktionen abgespeckt worden.
Maybe just the BIOS Chip is dead? Did you try to reflash the BIOS with your flasher?
Ein Bild der North- und Southbridge im Detail, versteht sich doch von selbst. Und bitte nicht mit dem Blitz so draufhalten ;)
Dazu Revisions-Nr. und Seriennummer und du kommst mit in die Liste.
In welche Liste und welche Seriennummer bitte ? Danke
Sowohl vom BIOS her, als auch von der Hardware her, denn das S2 hat nur eine 2-Phasen Spannungsversorgung. Mit dem NF7(-S) 2.0 hat das Board eigentlich nur Teile des Namens und die Farbgebung gemeinsam, ansonsten sind die beiden Bretter weit voneinander entfernt.
Aber gerade dieser Kartoffel haben sie einen SB-Kühler spendiert...
Hab mir schonmal überlegt eines zu holen und den Kühler dann auf das "ausgewachsene" Board zu zimmern.
Ich habe hier drei Abit NF7 vor mir liegen. Welches sollte davon am ehesten FSB 250 MHz erreichen können, ggf. auch mit Vdd- und Rail-Mod?
VersionPCBSBFarbeCPU-Sockel VerschlussRam SlotsBesonderheit
NF7-S0.510306A3RotPlastikSchwarz-
NF70.510315A4RotMetallSchwarzTeilweise ReCap
NF70.530432A4OrangePlastikBlau-
Vielleicht jedes davon, vielleicht aber auch gar keines. Mod Bios von digitalbath oder Infra drauf und probieren, wie hoch sich die Boards mit 1.7V bis in Win booten lassen und setz dann dort mit dem Tweaker an. Den 3.3V RAM-Mod brauchst du ohnehin nur ab 250-MHz BH-5 (für 24x-MHz würde ich nicht rumlöten)
Infras gute Boards sind alle v0.53
Meines war ein v0.52
Ich habe/hatte bisher ein 51, ein 52 und ein 53. das älteste ging am schlechtesten, das 52er macht 250mhz und das 53er macht 240mhz.
Wenn du alle da hast, Modbios drauf, RAM rein der wenig Spannung braucht (zb Hynix) und dann fsb rauf. wird sich schon zeigen welches taugt und welches nicht ;)
Man könnte auch unter Windows 1M testen und mit Clockgen immer etwas höher gehen. Windows zerlegt es aber auch mit dieser Methode gerne ;)
Ich habe darum schon lange ein Image von meiner Installation.
Der Kühler auf der NB sitzt ziemlich fest, das lasse ich mal so, weil erst wenn ich da zu Elko Tauschen anfange.....
Das ist doch schonmal ein Einfang. Der Kühler der Northbrdige sitzt so fest, weil das Kunstsoffkleber als Wärmeleitmittelverwendet wurde. Da brauchst du dir keine Sorgen machen: den hebels du leicht ab, der kommt von alleine und dann setzt du den hinterher einfach wieder drauf, da der rosane Kleber noch dran ist. Passiert nichts.
Jetzt fehlt noch die genaue Board-Bezeichnung und die Seriennummer für die Liste.
Es geht übrigens um folgende Liste: https://www.hardwareluxx.de/communi...thlon-xp-xp-m-mp.584473/page-29#post-27073135
Ich verstehe
Mit Nichten geht der leicht ab - und es steht eh schon ein Board drinnen
Das ruht jetzt auch einmal, da ich auch beim Elko Tauschen wieder einmal gescheitert bin. Da muss ich in die Werkstatt in den Garten um weiter zu machen. Und in der Wohnung am Küchentisch ... und meine Frau....:cry:(n)
My best board (266MHz at 1.6v) was v0.51. Before it died that is...
Yes, the good ones can boot or even bench at a very low NB voltage. Maybe it is not depending on the MB version at all. Results do vary a lot. On HWLUXX Poweraderrainer claimed that the orange ones with the metal lever/black slots and imprint on the cpu mosfets is the best version with almost all of them beeing able to OC to 250-MHz+ on stock bios.
Source
USB stuff will also fail later on the better ones. Could 3D bench mine at 265-MHz with only 1.7V and my mouse worked up to 268-MHz. Higher VDD is needed to stabilize it in 3D benches.
Something interesting I found relating to the overheating SB problem:
"Finger test disaprove this point : I put 2.5V to Vdd, there is not more heat on SB than at 1.7V
tests :
1.7V / 240Mhz 2-2-2-11 : SB heats a lot
2.5V / 220Mhz 2-2-2-11 : SB does not heat (like normal FSB at voltage 1.7V) "
Source
So it seems like a high FSB at even low NB voltage will cause excessive heating to the SB and might could even kill it (idiot me forgot to cool the damn thing properly because it was getting only lukewarm with BH-5 then at 1.5V NB...) Don't know if things are getting even worse when using 2x512MB instead of 2x256MB. Anyway, it is too late.
Die Version, die man haben wollte war auch die älteste und ist zu erkennen an:
- Schwarzen Ramslots
- volle Mosfetbestückung, Mosfets an der CPU Spannungsversorgung haben Aufdruck
- PCB eher orange, nicht sehr rötlich
- Alter NB Kühler
- Metallhebel am Sockel
Hier waren oft 250MHz FSB drin, sogar ohne MODs etc. - OC-Krüppel gibts nicht
Interesting theory, I didn’t think about it. That did not kill mine but still...
(mine was killed due to short circuit)
