Stagefire
Legende
Öhm ... aus dem Hardforum :
"Ok - i just got my LG48CX connected to my 2080TI and here are the options to run the display. But there are limitations.... "
1 - 4:2:0 - 8 bit 3840 x 2160 @ 60hz max / with Gsync / with HDR
2 - 4:4:4/RGB - 8 bit 3840 x 2160 @ 60hz max / with Gsync / with HDR
3 - 4:2:0 - 8 bit 3840 x 2160 @ 120hz max / without Gsync / without HDR
4 - 4:2:0 - 8 bit 2560 x 1440 @ 120hz max / with Gsync / with HDR
I've also tried custom resolutions at 3840x1600 or 3840x1440. Test works fine (stretching but guessing thats a tv setting issue), but enabling it doesn't work.
Am i missing something? I'd like to run 3 but with GSync and HDR... the difference between 60hz and 120hz on the desktop is VERY noticable."
Kein Plan ob das ein spass von dem User ist ... hat sich auch Heute erst dort angemeldet und dies ist sein erster Post.
Denke also das ist eher verarsche.
LG 48CX
Even if the 3000 series doesn't support 10 bit over HDMI and all the other stupid issues people are complaining about with this TV it will still the best PC gaming display you can get by far. Your only alternative is a 55" C9. Downhyping it and pretending like you aren't going to get it is...
hardforum.com
