[Sammelthread] ASUS X570 Strix Series (X570-E Gaming, X570-E Gaming Wifi II, X570-F Gaming, X570-I Gaming)
ROG Strix X570-E Gaming
ROG Strix X570-E Gaming Wifi II
ROG Strix X570-F Gaming
ROG Strix X570-I Gaming
BIOS/UEFI Versionen
Reviews & VRM
Häufig gestellte Fragen
BIOS Mods
ChangelogDownload
Flashing and using on your own risk!
  • Added VDDP Voltage
    Might be helpful for CPU overclocking
  • Added ASPM Support (Should be visible by default since v4802)
    PCIe Energy Saving
  • Added Erp Ready (Strix-E only)
    Energy Saving
  • Unlocked AMD PBS
    Hidden options unlocked
  • Added PCH Temerature
    Shows the PCH Temperature in the Bios
  • Added PCH Fan Control
    Gives you control over the PCH Fan
  • Advanced (Pump) Fan Settings
    Min and Middle Duty Cycle can be changed to 0%
  • Added Advanced Boot Settings
    Might be helpful for faster boot
Strix X570-E Gaming
Download Folder
Download Folder
Strix X570-F Gaming
Download Folder
Strix X570-I Gaming
EOL
CPUAMD AM4 Socket 3rd and 2nd AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
ChipsetX570
Memory3rd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
2nd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
4 x DIMM, Max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
GraphicIntegrated Graphics in the 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI 2.0b with maximum resolution of 4096 x 2160 @ 60 Hz
- Supports DisplayPort 1.2 with max. resolution 4096 x 2160 @ 60 Hz
Multi-GPU Support3rd and 2nd Gen AMD Ryzen™ Processors
Supports NVIDIA® 2-Way SLI® Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX™ Technology
Expansion Slots3rd Gen AMD Ryzen™ Processors
2 x PCIe 4.0 x16 (x16 or dual x8)
2 x PCIe 3.0 x16 (x16 or dual x8)
1 x PCIe 3.0 x16 (x8 mode)
AMD X570 chipset
1 x PCIe 4.0 x16 (max at x4 mode) *1
2 x PCIe 4.0 x1
Storage3rd Gen AMD Ryzen™ Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
8 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
LANIntel® I211-AT, 1 x Gigabit LAN Controller(s)
Realtek® RTL8125-CG 2.5G LAN
Anti-surge LANGuard
ROG GameFirst Technology
WiFi2 x 2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) with MU-MIMO supports dual frequency band 2.4/5GHz
BluetoothBluetooth® 5.0
AudioSupremeFX 8-Channel High Definition Audio CODEC S1220A
- Dual OP Amplifiers
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- SupremeFX Shielding Technology
- Supports up to 32-Bit/192kHz playback *2
Audio Feature :
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB Ports3rd Gen AMD RyzenTM Processors :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, )
2nd Gen AMD RyzenTM/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s)
AMD X570 chipset :
1 x USB 3.2 Gen 2 front panel connector port(s)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, , 3 x Type-A+1 x Type-C)
AMD X570 chipset :
2 x USB 3.2 Gen 1 port(s) (2 at mid-board)
AMD X570 chipset :
4 x USB 2.0 port(s) (4 at mid-board)
Special Features5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
TPU
- Auto Tuning, TurboV, GPU Boost
Gamer's Guardian:
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
- SafeSlot
- ESD Guards on LAN, Audio,and USB ports
ASUS EPU :
- EPU
AURA :
- Aura Lighting Control
- Addressable Gen 2 Header
ASUS Exclusive Features :
- USB BIOS Flashback®
- AI Suite 3
- Ai Charger
- ASUS NODE : hardware control interface
- BIOS Flashback® Button
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports1 x DisplayPort
1 x HDMI
5 x USB 3.1 Gen 1 Type-A
8 x USB 2.0
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Anti-surge 2.5G LAN (RJ45) port
1 x USB BIOS Flashback® Button(s)
1 x ASUS Wi-Fi Module
7 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-C)
Anti-surge LAN (RJ45) port
Internal I/O Ports1 x PCH_FAN
1 x AAFP connector
2 x Aura RGB Strip Header(s)
2 x Addressable Gen 2 header(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x M.2 Socket 3 with M key, type 2242/2260/2280/22110 storage devices support
1 x SPI TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x Thermal sensor connector(s)
1 x Clear CMOS jumper(s)
1 x Node Connector(s)
1 x System panel connector
1 x T_Sensor Connector
1 x M.2 Fan Header
1 x USB 3.2 Gen 2 (up to 10Gbps) connector
1 x USB 3.2 Gen 1 (up to 5Gbps) connector support additional 2 USB ports
AccessoriesUser's manual
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x Supporting DVD
1 x Strix door hanger
1 x ROG Strix stickers
1 x Cable ties pack(s)
1 x Wi-Fi Antenna(s)
1 x Extension Cable for RGB strips (80 cm)
1 x Extension cable for Addressable LED
1 x Thermistor cable(s)
1 x ROG Thank you card
BIOS256 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.2, ACPI 6.2.
Form FactorATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note*1 PCIeX16_3 slot shares bandwidth with PCIeX1_2.
*2 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
Bios Version 0807
AiTweaker
Advanced
Monitor
Boot
Tool
Kompatibilitätsliste
Memory QVL Ryzen 3000/4000/5000
Chipsatz Modding
Alternativer Chipsatz Kühler von KCX
ROG Strix X570-E Gaming WIFI II
Produktseite | Handbuch (EN) | Support-Downloads | Preisvergleich
CPUAMD Ryzen™ 5000 Series/ 5000 G-Series/ 4000 G-Series/ 3000 Series/ 3000 G-Series/ 2000 Series/ 2000 G-Series Desktop Processors
ChipsetX570
MemoryAMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
4 x DIMM, Max. 128GB, DDR4 4600(O.C.)/4400(O.C.)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200/3000/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 5000 and 4000 G-Series Processors
4 x DIMM, Max. 128GB, DDR4 5100(O.C)/4800(O.C.)/4600(O.C)/4466(O.C.)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3200/3000/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 and 3000 G-Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
ECC Memory (ECC mode) support varies by CPU
Graphic1 x HDMI 2.0
1 x DisplayPort
Expansion SlotsAMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
2 x PCIe 4.0 x16 (x16 or dual x8)*
AMD Ryzen™ 5000 G Series/4000 G-Series/ 2000 Series Processor
2 x PCIe 3.0 x16 (x16 or dual x8)*
AMD Ryzen™ 2000 G-Series/ 3000 G-Series Processor
1 x PCIe 3.0 x16 (x8 mode)*
AMD X570 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
2 x PCIe 4.0 x1
*PCIeX16_3 slot shares bandwidth with PCIeX1_2.
StorageSupports 2 x M.2 slots and 8 x SATA 6Gb/s ports
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors:
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
AMD Ryzen™ 5000 G-Series/4000 G-Series/ 3000 G-Series/ 2000 G-Series/2000 Series Processor
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 3.0 x4 & SATA modes)
AMD X570 Chipset
M.2_2 slot (Key M), type2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
LAN1 x Realtek 2.5Gb Ethernet
1 x Intel® I211-AT 1Gb Ethernet
Anti-surge LANGuard
1 x Intel® 1Gb Ethernet
WiFiWi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
BluetoothBluetooth® v5.2
AudioRealtek S1220A 7.1 Surround Sound High Definition Audio CODEC*
- Internal audio Amplifier to enhance the highest quality sound for headphone and speakers
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input (Line-in)
- Supports up to 32-Bit/192 kHz playback*
Audio Features
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
USB PortsAMD RyzenTM 5000, 5000 G-Series, 4000 G-Series, and 3000 Series Desktop Processors
- 4 x USB 3.2 Gen2 ports (4 ports at back panel, Type-A)
AMD RyzenTM 3000 G-Series, 2000, and 2000 G-Series Desktop Processors
- 4 x USB 3.2 Gen 1 ports (4 ports at back panel, Type-A)
AMD X570 chipset
- 1 x USB 3.2 Gen2 front panel connector
- 4 x USB3.2 Gen2 (at back panel, 3x Type-A, 1x Type-C)
- 2 x USB3.2 Gen1 ports (at front panel)
- 4 x USB 2.0 ports (at front panel)
Special FeaturesExtreme Engine Digi+
- 5K Black Metallic Capacitors
ASUS Q-Design
- M.2 Q-Latch
- Q-Code
- Q-DIMM
- Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
- Q-Slot
ASUS Thermal Solution
- M.2 heatsink
ASUS EZ DIY
- BIOS FlashBack™ button
- BIOS FlashBack™ LED
- ProCool II
- Pre-mounted I/O shield
- SafeSlot
AURA Sync
- AURA RGB headers
- Addressable Gen 2 headers
Back I/O Ports8 x USB 3.2 Gen 2 ports (7 x Type-A + 1 x USB Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® I211-AT 1Gb Ethernet port
1 x Realtek 2.5Gb Ethernet port
5 x Gold-plated audio jacks
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
Internal I/O PortsFan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
2 x 4-pin Chassis Fan headers
1 x 4-pin M.2 Fan header
1 x W_PUMP+ header
Power related
1 x 24-pin Main Power connector
1 x 8-pin +12V Power connector
1 x 4-pin +12V Power connector
Storage related
2 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Miscellaneous
2 x Addressable Gen 2 headers
2 x AURA RGB headers
1 x Clear CMOS header
1 x Front Panel Audio header (AAFP)
1 x SPI TPM header (14-1pin)
1 x Speaker header
1 x 10-1 pin System Panel header
1 x Thermal Sensor header
AccessoriesCables
4 x SATA 6Gb/s cables
1 x Thermistor cable pack
Miscellaneous
1 x ASUS Wi-Fi moving antennas
1 x Cable ties pack
1 x M.2 Rubber Package
1 x M.2 Q-Latch package
1 x ROG key chain
1 x ROG Strix thank you card
Installation Media
1 x Support DVD
Documentation
1 x User manual
Full Specs:
ChipsetX570
AMD X570 chipset
2 x PCIe 4.0 x1
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
Anti-surge LANGuard
Audio Feature :
- Sonic Radar III
USB Ports3rd and 2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s) (4 at back panel, )
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
TPU
Gamer's Guardian:
- DIGI+ VRM
- SafeSlot
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
1 x HDMI
8 x USB 2.0
5 x Audio jack(s)
4 x USB 3.2 Gen 1 (up to 5Gbps) ports
3 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x AAFP connector
1 x SPI TPM header
1 x M.2 Fan Header
1 x Supporting DVD
Chipsatz Modding
Wasserkühler von Neo111430
ChipsetX570
2 x DIMM, Max. 64GB, DDR4 4800(O.C.)/4600(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3800(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory
- Support DisplayPort 1.4 with max. resolution 8 K 7680 × 4320 @60 Hz
1 x PCIe 4.0 x16 (x16 mode)
1 x PCIe 3.0 x16 (x16 mode)
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2_2 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
4 x SATA 6Gb/s port(s),
LANIntel® I211-AT
Anti-surge LANGuard
WiFiSupports channel bandwidth: HT20/HT40/HT80/HT160
Intel® Wi-Fi 6 AX200
Up to 2.4Gbps transfer speed
Audio Feature :
- DTS® Sound Unbound
- LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
- Sonic Radar III
- Sonic Studio III + Sonic Studio Virtual Mixer
4 x USB 3.2 Gen 1 port(s) (4 at back panel, blue)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (3 x Type-A+1 x Type-C)
AMD X570 chipset :
AMD X570 chipset :
2 x USB 2.0 port(s)
TPU
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
1 x HDMI
3 x LED-illuminated audio jacks
4 x USB 3.2 Gen 1 (blue)
Internal I/O Ports1 x HS_FAN
1 x PCH_FAN
1 x AAFP connector
1 x Aura RGB Strip Header(s)
1 x Addressable Gen 2 header(s)
1 x USB 3.2 Gen 1(up to 5Gbps) connector(s) support(s) additional 2 USB 3.2 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
2 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
4 x SATA 6Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Speaker connector
I/O Shield
2 x M.2 Screw Package
1 x Supporting DVD
1 x M.2 bracket
1 x AAFP Extension Cable
1 x Panel cable
Form FactorMini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm )
Note*1 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
*2 Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
  • Sound setzt aus oder knistert
    Immer wieder USB Disconnects
    Meistens tritt dieses Problem auf, wenn man einen hohen RAM Takt verwendet. In diesem Fall kann man versuchen die SOC Spannung auf 1.125V zu erhöhen. Sollte das nicht ausreichen, zusätzlich noch die VDDG CCD Spannung auf 1.00V (oder niedriger), sowie VDDG IOD Spannung auf 0.925V stellen.
  • USB Disconnects
    Mit bestimmten UEFI/Agesa Versionen (v2 1.1.0.0/ 1.1.8.0) können sporadische USB Disconnects auftreten. Um dies zu umgehen bitte folgende Einstellung im Bios deaktivieren:
    UEFI -> Advanced -> AMD CBS -> Global C-States deaktivieren
    Der Verbrauch steigt dadurch um ca. 5Watt an aber ansonsten hat man keine weiteren Nachteile
  • USB Flashback funktioniert nicht
    Bitte folgende Punkte ausprobieren:
    - Datei richtig umbenannt? Vorzugsweise mit dem im BIOS Download enthaltenen Renamer
    - Vor dem Flashen das BIOS auf Werkseinstellungen zurück setzen!
    - Einen anderen USB Stick ausprobieren. Vorzugsweise ein USB 2.0 Stick
  • BIOS/UEFI Downgrade
    Ein UEFI Downgrade ist ohne Probleme mit USB Flashback möglich, soweit vorhanden.
  • Ist der Chipsatz Lüfter regelbar?
    Nein, dieser wird automatisch, je nach vorhandener Temperatur, geregelt. Bis zu einer Temperatur von 55 Grad ist der Lüfter deaktiviert. Bei höheren Temperaturen wird er stufenweise schneller bis er letztendlich bei 93 Grad seine Höchstgeschwindigkeit erreicht. Über selbst erstellte Bios Mods kann man jedoch den Lüfter auch nach seinen Wünschen einstellen.
  • Chipsatz Temperatur zu hoch?
    Wem das Optische nicht so wichtig ist, kann die Lüfterabdeckung vom Chipsatz beim X570-E oder x570-F entfernen. Dadurch staut sich die warme Luft nicht an, sondern kann direkt entweichen.
    Des weiteren kann man im Bios unter "Onboard Devices Configuration" die vorhandenen Steckplätze (PCIe X16, X1, M.2, SB Link) manuell auf PCIe 3.0 umstellen, sofern man keine PCIe 4.0 Karte verwendet. Bei Auto Einstellung wird automatisch PCIe 4.0 angelegt, was zu einer höheren Last führt.
  • Kann ich ein altes Bios Profil mit einer neuen Bios Version nutzen?
    Nein, es ist zu empfehlen kein altes Profil mit einer neuen oder älteren Bios Version zu nutzen. Dies endet meist mit einem Blackscreen. Nach jedem Bios Flash bitte die Einstellungen neu vornehmen. Selbst wenn sich ein Profil laden lässt, kann es trotzdem zu Instabilität führen.
  • Rechner bootet nicht, wenn eine Soundkarte verbaut ist
    Dieses Problem kann mit dem Bios 1404 oder höher (Agesa 1004b) auftreten. In dem Fall bitte in dem AMD CBS Menü die Option "PCIe Ten Bit Tag Support" auf Disabled stellen. Sollte das nicht ausreichen, dann zusätzlich noch unter dem Menü Advanced -> Onboard Devices Configuration -> die Option PCIEXxxx (den Slot auswählen, in der die Soundkarte steckt) von Auto auf Gen3 ändern.
Ein 5.1 System nutze ich nicht. Nur headset mit virtuelle Surround.
Und das funzt ohne Probleme.
Eine Frage: Die weiße Analyse-LED meines X570-E leuchtet seit Kurzem im Betrieb dauerhaft.
Für Anhaltspunkte, was zu tun ist, und gegebenenfalls Tipps, wie ich das beheben kann, bin ich dankbar.
Was heisst im Betrieb? PC bootet normal durch, aber die weisse LED bleibt an?
Normal bleibt die doch nur an wenn es nicht weiter geht wegen eines Problems (orange - RAM, rot - CPU, weiss - GPU, grün - ab die Post - aus)
Hab jetzt von 1404 auf 1407 geupdated. Performance merk ich nicht sonderlich, aber endlich das blöde Spread Spectrum ausgeschaltet (ja, das gabs mit Modbios schon...).
Sieht jetzt endlich manierlich aus!
@ Reous: Hallo, ich würde gerne wissen, ob es in deinem Mod Bios zum E-Gaming folgendes Setting gibt: Advanced\AMD CBS\NBIO Common Options\SMU Common Options\EfficiencyModeEn
oder gibt es das nur für die teuren Heroes? Bei PCGH hat der User FleischmannTV herausgefunden, dass beim aktivieren dieser Einstellung der Ryzen nicht mehr bei jeder kleinsten Belastung gleich auf 4 GHz springt, sondern nur noch bei echter Last. https://extreme.pcgameshardware.de/prozessoren/470191-sammelthread-amd-ryzen-post10271346.html Und: jemand mit einem Asus Board bestätigt das Das wollte ich gerne mal ausprobieren.
Was versprichst Du Dir davon?
Der Boost wurde genau so entwickelt, damit er bei geringsten Lastwechseln im Millisekundenbereich mehr Takt und somit mehr Leistung zur Verfügung stellen kann.
Wenn die CPU sich da mal irren sollte, also bei wenig Last maximal boostet - was solls.
Meiner Erfahrung nach braucht die CPU beim lastlosen hochboosten auch keinen bis kaum mehr Strom.
War bei Ryzen 1 gut nachvollziehbar als die ersten verbugten BIOS Versionen unterwegs waren und Windows mit Ryzen wenig anfangen konnte.
Da lief mein 1700x mit P-State OC permanent (also auch im Idle) mit 3.8 GHz, brauchte aber den selben Strom als wenn er Stock im Idle mit 1.2 GHz lief.
Ist also eher ein kosmetisches oder Kopfproblem dem ich Anfangs auch aufgesessen bin.
Zum Energiesparen gibt es ander Schalter, die deutlich mehr Potenzial bieten.
Könnte auch darum gehen, dass die Lüfter nicht mehr unnötig hoch drehen.
@Tomcat66 Da das eine Datei von AMD ist, ist die Option auch vorhanden. Entweder du spielst das Mod Bios 1405X2 auf oder du probierst vorab das Profil im Anhang. Durch das Laden wird die Option automatisch aktiviert. Danach kannst du beliebige andere Settings verstellen. Bei einem cmos Reset oder Fail Boot wird die Option aber wieder zurück gesetzt.
  • EffiMode.zip
Danke Reous! Ja es geht auch um das hochdrehen der Lüfter. Und um Effizienz. Beim hochtakten wird ja auch immer eine hohe v-core von weit über 1,4 V angelegt, was ich halt ineffizient finde. Die CPU muss nicht jedesmal gleich auf über 4 GHz springen nur weil ich ein Fenster verschiebe oder nur die Maus hin und her bewege.
Lass mich wissen ob es bei dir dann auch den gewünschten Erfolg gebracht hat :)
Mir erschließt sich noch nicht warum die PCIe 4.0 Geräte permanent Broadcast abfragen schicken sollen so wie Broadcast Storm, gibt es Routing Probleme? Der Rest erschließt sich mir. 5.1 nutz ich nicht deswegen war es mir auch mit einer 5700XT nicht untergekommen. Ich finde den Soundcore 3D von Creative eh nicht besonders.
Da bin ich leider auch überfragt wieso es exakt passiert. Wisst ihr eventuell wie man den PCI-E Bus abhören kann? Sollte ja zumindest ein OS Tool geben welches dies ermöglicht.
Ich denke es kommt darauf an wo der virtuelle Surround Effekt berechnet wird. Nutzt das Headset den virtuellen Surround der Soundkarte oder handelt es sich um ein USB Headset, das ein eigenes Soundinterface hat? Falls ja, hat das Headset nichts mit der Soundkarte zu tun - egal ob die Soundkarte im Rechner ist oder nicht, das Headset macht genau das selbe.
Mit Creative Soundkarte und PCIE4 Grafikkarte? Nur dann tritt der Bug auf.
Ich habe von Leuten aus anderen Foren gelesen sie hätten das selbe Problem mit einer Nvidia Graka (die sind ja noch nicht GEN4). Somit liegt da das Problem doch eher bei der GEN4 Implementation.
ne- natürlich nutze ich die soundkarte fürs headset. sonst brächte ich ja die soundkarte ned.
Also hast du das Headset über die Klinke am PC angeschlossen? Virtual Surround über die Windows Einstellung als Effekt (Windows Sonic für Kopfhörer)?
Falls alles Zutrifft, was hast du denn für weitere PCI-E Geräte in deiner Kiste? Alles im BIOS aus Auto? Oder was auf manuell auf GEN3 geändert? Fragen über Fragen^^
Wieso habt ihr euch eig. für so "teure" Boards entschieden und nicht B450 z.B. ?
Hmm, ich baue alle 5-6 Jahre den besten PC den man sich holen kann, ohne dabei ganz zu übertreiben^^ Ist eher ein Bastelprojekt, und dieses Jahr war halt eine Custom Wasserkühlung mit Hard Tubing an der Reihe. Wäre ja Schade, wenn man sich dann ein Board mit einem "alten" Chipsatz holt.
Ich hab nun auch eine Gen4 SSD im Rechner, ist doch ziemlich flott das Teil :)
Wenn ich mir aber nun wieder ein X570 Board aussuchen müsste, dann würde ich eher zu MSI greifen. Der Grund wäre die bessere BIOS Update Kommunikation und der Support - aber da hat glaube ich, jeder unterschiedliche Erfahrungen gemacht^^
Mit meinem MSI Eclipse SLI (i7 920 CPU) hatte ich nie Probleme. Läuft bis heute bei meinem Bruder - und das seit 12 Jahren!
Mein Asus X99 Deluxe (i7 5820k CPU) war auch ganz anständig. Da hatte ich nur das Problem, dass es einen BIOS Bug gab, der mit einer Logitech G15 Tastatur (alte Version mit Display) nicht umgehen konnte. Somit passierte ca. einmal pro Monat, dass meine Tastatur aus heiterem Himmel nicht mehr erkannt wurde^^ Nur der Neustart half :) Ich hatte das Board 2014 gekauft und staunte nicht schlecht als auf einmal 2017! das hier auf der ASUS Support Page stand:
Version 3802
2017/09/22 8.05 MBytes
X99-DELUXE BIOS 3802
1.Improved DRAM compatibility
2.Fixed Intel I211 LAN issue
3.Fixed Logitech device issue
Entweder war der Bug Ultra Low Prio oder das Ganze war so komplex, dass man ihn nicht nachstellen konnte. Wie auch immer, nach 3 Jahren gefixt - da dachte ich mir: "doch es wird wieder ein ASUS Board, die fixen alle meine Probleme mit der Zeit:LOL:".
Nun stehe ich also mit dem Creative Sound Blaster Bug da^^ mal schauen, vielleicht gibt es 2023 ein BIOS Update :d
War ein voller Erfolg! Habe dein Profil ins Bios geladen, meine Einstellungen (DOCP etc.) wieder hinzugefügt und am Ende das Ganze dann nochmal als mein Profil gespeichert. Das die Einstellung dann auch aktiv war hat man sofort gesehen. Das Beste zuerst: CPU Temperatur vorher zwischen 48 und 65° immer rauf und runter. Nachher um die 39 bis 45°. Browser öffnen und Youtube gucken geht er kurz mal auf 55 bis 60 aber dann gleich wieder runter. Takt geht jetzt ohne grosse Last, also Spiele und Benchmarks nicht mehr über 3.85 GHz. CB20 macht er mit 4,1 und Spiele wie gewohnt 4,1 bis 4,4 GHz. Leistungsverlust in Spielen und dem 3DMark gleich 0! Lediglich im CB 20 verliere ich 34 Punkte im Single- und 200 im Multithread.
Man gewinnt also sehr viel Effizienz und verliert kaum bis gar keine Leistung.
P.S. Die maximalen Taktraten von 5 bis 5,25 GHz, die ich sonst auf einigen Kernen sah werden nun nicht mehr erreicht. Aber das war eh' blos Augenwischerei! Denn wer hat diesen maximaltakt jemals während einer laufenden Anwendung unter Last gesehen?? Ich jedenfalls nicht. Jetzt boostet er nur noch bis 4.45 GHz etwa. Müsste ich noch länger testen...
Moin, gibt's einen Adapter von PCI 6 oder 8 Pin auf CPU 4 Pin? Möchte gerne beide CPU Stecker auf dem Board Anschliessen, allerdings hat mein rm1000i nur einen 8 Pin Stecker für die CPU und keinen 4 Pin. Mfg
Ja die habe ich auch schon gesehen, auch gesleeved . Ich schreib Mal Corsair an, ob sie einen Adapter oder Strang haben. Mfg
Exakt. Der Boot läuft normal durch, die weiße LED leuchtet aber weiterhin. Ich glaube, ich bin aktuell auf 1405, eventuell hilft ja ein BIOS-Update. Aber so ist es definitiv erst seit Kurzem.
Bei Netzwerken ja aber beim PCIe BUS wüsste ich zumindest nicht wie man die Traffic sniffen kann. Meine Vermutung kommt eher auch aus dem Bereich Netzwerk, deswegen von mir die Gegenfrage.
Dann muß es tatsächlich mit dem Sondcore 3D zusammenhängen, ich habe die Probleme weder mit einer 1080TI noch mit einer 5700XT, nur Direct Sound wie beschrieben. Weder auf einem ASRock B450 pro 4 noch auf dem StriX-E egal welche Grafikkarte ich in die Systeme einbaue.
Du kannst einfach den 8 Pin (EPS-12V!! Nicht PCI-E) in den 4 Pin (auch EPS) stecken. Wahrscheindlich hast du ja 2x8Pin EPS. Die sind Pin kompatibel. Aber da es sich um ein Corsair Netzteil handelt, kannst du einfach den 8 Pin EPS Stecker in der Mitte auseinander ziehen, dann hast du 2x4Pin EPS :) Ist ein bisschen versteckt, geht aber bei fast allen Corsair Netzteilen.
Man sieht die leichte Kerbe in der Mitte :)
Keine gute Idee. Außerdem auch völlig unnötig.
Weil das Board den zusätzlichen EPS Anschluss gar nicht braucht, bootet ja auch ohne :) Die sind nämlich parallel geroutet, geht also nur darum, dass die Kabel bei Volllast sich nicht erwärmen. Das könnte ja passieren wenn man irgend einen Molex zu EPS-Adapter inkl China Netzteil in Kombo mit einem 3950X verwendet ^^
Bei deinem NT, also nicht nötig :)
Wireshark for PCI-E ;) Ja, habe ich mir schon gedacht. Leider kann ich dir darauf keine Antwort geben - sollte mal bei totaler Langeweile den PCI-E Standard lesen :)
Ja, vielleicht wissen wir ja in Zukunft mehr ;)
X570-E Gaming mit 3950x
Bios update von 1407 auf 1408 startet mein Rechner nicht mehr.
0d wird immer angezeigt und komme auch nicht ins Bios.
Musste wieder ein Bios Flashback machen.
Kann mich auf den Kopf stellen.
Kann das jemand bestätigen?
Von denen, welche 1408 benutzen, hat bisher niemand von solchen Problemen berichtet. Vielleicht ist das auch CPU spezifisch? Probeweise mal die Soundkarte entfernt?
Ja ohne Soundkarte und nur mal mit einem RAM getestet. Zurück aufs 1407 oder drunter, kein Problem.
Ich seh in deiner Sig 3x8GB Ram, betreibst du das System denn auch so? Ryzen kann ja keinen Tripple / Quad Channel.
Clear Cmos gemacht nach dem 1408 update? Sollte ja automatisch passieren, aber man weiss ja nie.
Richtigen RAM Bank gewählt beim Betrieb mit einem RAM Modul? Weiss jetzt leider nicht auswendig ob A1, oder B1 gewählt werden muss.
3x 8GB? Bei mir sind zum testen gerade 2x 8GB verbaut. Cmos reset auch gemacht.
(Bestimmt ewig kein so billiges Board mehr gesehen, wo kein cmos reset button da war)
Ja A2 getestet und auch mit 2 RAM in A2 und B2.
Aber auch Latte, nächtest Bios wird es schon richten.
Hattest du denn Probleme mit der 1405 oder 1407 oder willst das 1408 einfach nur um Up to Date zu sein?
