[Sammelthread] Fallout 76
Der Herr ist mit seinem Video ein wenig spät dran, hm? Wurde hier im Thread übrigens auch schon angesprochen, siehe Beitrag #437 und #438.
Fallout 76 - January 10 Patch Notes : fo76
General
  • Power Armor: The Power Armor light has been made brighter.
  • Performance: Several improvements have been made to in-game performance.
  • Stability: The Fallout 76 game client and servers have received additional stability improvements.
Balance
  • Charging Barrels mod: Increased the Gatling Laser’s damage bonus from the Charging Barrels mod.
  • Glowing Ones: Glowing Ones will no longer grant erroneous large amounts of XP. DevNote: Glowing Ones were granting Large Boss XP rewards, making them highly exploitable when combined with Nuke Zones.
  • Crafting: Lowered chance of Power Generators of spawning fusion cores.
  • Crafting: Set minimum component cost of workshop buildings requiring steel, wood or plastic to 2.
  • Bobby Pins: Reduced the weight value of Bobby Pins from 0.1 to 0.001.
Social
  • Teams: Players now receive a notification that “Players cannot form teams from within Vault 76” if an Invite is sent to a friend still in Vault 76.
Systems
  • PvP: Opening Player-owned, locked containers will now be considered a PVP action as expected.
Bug Fixes
Stability and Performance
  • [Xbox One] Performance: Blowing up the mainframe core stations will no longer cause a performance drop.
  • [PC] Infinite Load: Fixed an infinite load screen that could occur when attempting to join a server on PC.
  • Crash: Fixed a crash that can occur when opening the Pip-Boy.
  • Performance: Improved client performance when viewing a nuke explode.
  • Performance: Fixed an issue where reading a note would cause the background to freeze.
  • Performance: Increased performance in areas with a lot of scorched statues.
General
  • Systems: Fixed an issue where items could be duplicated.
  • [PC] Controls: Resetting controls to default no longer causes most Activate prompts to become unusable.
  • [PC] Controls: Fixed an issue when controls in the Settings menu aren't updated when connecting/disconnecting a gamepad controller.
  • Systems: Fixed an issue that allowed armor mods to reduce carry weight past intended values.
  • Systems: Rads will no longer completely be removed when by dying repeatedly.
  • Systems: Address an issue where players could load into geometry after fast travel.
  • Systems: Fixed an issue where bashing an enemy with the Railway Rifle or Crossbow would add the projectile to the enemy's inventory.
Art and Graphics
  • Animations: Lever-Action rifle now only reloads the correct number of ammo.
  • Effects: Consumed Berry Mentats now correctly show purple glowing auras around players and creatures.
C.A.M.P., Workshops, and Crafting
  • Crafting: Level 25 armor and above now requires ballistic fiber to craft.
  • Repairing: Component quantities required to repair mid to high level armor and weapons have been reduced up to 20%. DevNote: Repair costs scale with level, and there's room to reduce costs at higher levels.
  • Crafting: Ballistic Fiber becomes required for armor at level 25 instead of previously at level 20.
  • Crafting: Updated Bulk Acid crafting recipe to require 15 Acid.
  • Crafting: Fixed an issue that prevented players with the correctly equipped perk cards from being able to craft Antibiotics and Disease Cure (Savage Divide).
  • Crafting: “Hardened Mass” will no longer be scrapped when “Scrap All Junk” is selected.
  • Repairing: Overall repair costs have been lowered for both weapons and armor.
  • Crafting: Ballistic Fiber also is now required for repairing armor at level 25 and above instead of previously at level 20
  • Workshops: Fixed issues where enemies at some Workshop locations would spawn underground, making the Workshops unclaimable. Locations include: Charleston Landfill, Lakeside Cabins, and Sunshine Meadows.
  • Workshops: Fixed an issue where objects in Workshops would sometimes float in the air when the Workshop menu was closed.
  • Workshops: Destroying the hay feeder along with the fertilizer collector will no longer prevent them from being repaired.
  • C.A.M.P./Workshops: Placing Power Armor workbenches on foundation will no longer cause them to place on the floor/ceiling above.
  • C.A.M.P./Workshops: Fixed an issue that would cause a “not supported” error when attempting to place a tall or short post under a roof.
  • Blueprints: Fixed an issue with the cost of wires not being factored in when storing blueprints.
  • Crafting: Fixed an issue where certain objects aren't able to be scrapped through the stored tab
  • Workshops: Fixed an issue where certain stored items obtained from claiming a Public Workshop can't be placed again
  • Crafting: Fixed a visual issue with scrapping items in Crafting Menus.
  • Crafting: Fixed an issue where mods cost less steel than what's displayed in Crafting Menus
  • Crafting: Fixed a display issue where incorrect number of Junk items can appear in Crafting Menus
Challenges
  • Daily Challenges: Fixed several daily challenges that were not being offered on some days. Dev Note: These include “Pick Wild Flowers”, “Harvest Mutfruit Plants”, and “Harvest Wild Plants and Fungi”.
  • Daily Challenge: Fixed an issue that prevented some wild flowers from incrementing in the “Pick Wild Flowers” Daily Challenge.
  • Weekly Challenge: Fixed an issue that caused the weekly challenge "Complete Quests and Events in a Group while at Night" to work during the day and only recognize events. It will now look for quests and events that are completed at night.
  • Weekly Challenge: Edited the description of a Weekly Challenge to correctly reflect the direction.
  • Sub-Challenge: Fixed an issue that prevented certain photomode challenges from completing as expected.
  • Sub-Challenge: Fixed an issue that prevented certain Bobblehead challenges from completing as expected.
  • Sub-Challenge: Fixed an issue that caused a challenge to be marked as complete incorrectly.
  • Lifetime Challenges: Fixed an issue where some lifetime challenges would revert progress after logging out
Enemies
  • Robots: Fixed an issue that would cause robots to respawn too frequently in Whitesprings.
  • Scorched: Fixed an issue where Wasteland Whisperer could affect Scorched. Dev Note: Wasteland Whisperer can no longer be used to pacify Scorched.
  • Scorched: Shooting a Scorched in the leg will no longer break their weapon causing them to not attack the player.
  • Scorched: Fixed an issue where Scorched may be using invisible weapons or not appearing to fire their weapon correctly.
  • Scorched: Fixed an issue that caused floating debris and disassembled guns to appear in Scorched hands when killed.
Items
  • Weapons: Fixed an issue that would sometimes cause plasma weapons, flamers and flamer mods, and weapons with explosive bullet mods to not do damage to other players and creatures.
  • Armor: Fixed an issue that would cause players exiting power armor to sometimes appear stretched and unable to reenter power armor.
  • Armor: Addressed several issues that would prevent players from exiting power armor and at times cause the Pip-Boy to become unavailable.
  • Weapons: Fixed an issue that prevented the Gauss Rifle from being identified as a rifle. Now rifle-related perks can be applied to the Gauss Rifle.
  • Ammo Vending Machines: Fixed an issue where some Ammo Vending Machines were only selling repair components.
  • Weapons: Legendary Hunting Rifles will now drop as loot.
  • Weapons: Fixed an issue where the Walking Cane provided as many resources when scrapped as it costs to craft.
  • Armor: Fixed an issue where some Pocketed Chest Pieces were resetting players back to their base carry weight upon logging back into the game.
  • Armor: Fixed an issue where players can leave behind an unusable chassis after exiting Power Armor.
  • Magazine: Consuming Scouts’ Life 6 magazine now correctly depletes food and water stats at a slower rate.
  • Weapons: M79 Grenade Launcher is now considered an explosive weapon in perks instead of being incorrectly considered a shotgun.
  • Fusion Cores: Fixed an issue where Fusion Core generators were producing cores at a slower rate than intended. They are now back to 8 cores/hr.
  • Magazine: Fixed the Backwoodsman 2 magazine to appropriately boost Tomahawk damage.
  • Mirelurk Eggs: Harvesting Mirelurk Eggs will not result in two separate eggs.
  • Weapons: Fixed an issue where several combat rifle automatic receiver mods were prevented from receiving automatic rifle perk bonuses.
  • Weapons: Fixed an issue where multiple weapons were able to be equipped at the same time.
  • Weapons: The Vampire weapon mod effect now works only when hitting living targets as intended.
  • Armor: Fixed an issue where Power Armor parts would display on top of previously equipped parts.
  • Weapons: Fixed an issue where bashing an enemy with certain weapons would add the projectile to the enemy's inventory.
  • Armor: Fusion Cores will no longer replenish to full charge upon joining another world.
Quests and Events
  • “Get the Supply Drop”: “Get the Supply Drop” Event now will remove holotape once used with supply crate belonging to the player that requested the Supply Drop.
  • Quest: Daily Missile Silo quest rewards are now correctly obtainable only once per day.
  • “Line in the Sand”: Fixed an issue with the quest, Line in the Sand where the Sonic Generator already being repaired prevented the player from completing the quest. The event will now progress to the next stage if the Sonic Generator is already repaired when the Event begins.
  • “Recruitment Blues”: Fixed an issue with the objective, “find Junk Mail” that prevented players who switched worlds from completing the quest.
  • “Second Helpings”: The following location map markers are now available after finishing “Second Helpings”: Slocums Joe, Gauley Mine, Morgantown Trainyard, and Morgantown Airport.
Perks
  • All Night Long: All Night Long now decreases hunger and thirst growth at night.
  • Overdrive: Fixed an issue where Overdrive was not increasing critical chance % properly.
  • Quack Surgeon: Quack Surgeon no longer allows for reviving hostile players.
  • Strange in Numbers: Strange in Numbers effects now scale properly with multiple teammates (with and without mutations).
  • Refractor: Fixed an error where each rank of Refactor is doubling energy resistance instead of adding +20 as indicated on the Perk card description.
  • Fireproof: Fireproof now reduces explosion and flame attack damage by 15% per rank.
  • Happy Camper: Happy Camper now functions correctly whether the player is inside or outside of their C.A.M.P. when the perk conditions are refreshed.
  • Butcher’s Bounty: Fixed an issue that allowed for the Butcher’s Bounty perk to trigger again on an already-searched creature.
  • Homebody: The Homebody perk now works as intended when at a claimed Public Workshop.
  • Party Boy/Girl: Party Boy/Girl now effects active alcohol effects on the player.
PVP
  • Teams: Teamed players can no longer unfairly block an attacking player when that player attempts to overtake a workshop. Your teammate will enter PVP with the attacking player.
  • Turrets: Turrets at Workshops will now attack players the Workshop owner is engaged in PvP with.
Social
  • Systems: Blocking a player now also mutes their proximity chat.
  • Trade: Fixed an issue where players could view another player’s inventory before they can respond to a trade invite.
  • Trade: We no longer let trades occur before the requested player has consented to trade.
  • Trade: Fixed an issue where the Stash transfer menu would appear empty after previously trading with another player.
  • Trade: Stimpaks with a price value set to zero will no longer prompt “use” in the Trade Menu instead of “accept”.
  • Trade: Changed caps limit for player-to-player trades from 5000 to 25000.
Sound
  • Chat: Fixed an issue where voice chat would not always function properly upon exiting the Atomic Shop.
  • Atomic Shop: Fixed an issue where some Atomic Shop content was missing sound effects.
  • Atomic Shop: “Waving Santa” sound effect will now only play when in “on” state.
User Interface
  • General: Players no longer will receive a pop-up for the Atomic Shop when Respawning for the first time.
  • [PC] Resolution: Perk Pack opening screen now extends to the edge on 21:9 monitors.
  • Atomic Shop: Players in the Atomic Shop when the Atomic Shop is taken offline will now be notified and taken back to the Main Menu.
  • [PC] FOV: Fixed an issue with scoped weapons zooming incorrectly when the default Field of View setting has been changed.
  • PvP: Fixed an issue where the PVP prompt would appear repeatedly while the same players engaged in combat with each other.
Habs mir heute auch mal für unter 10€ gekauft und bisher nach 2 Stunden macht es echt Spaß. Die Grafik ist besser als bei Fallout 4, bin nur ein mal vom Server geflogen und die Welt ist schöner. Endlich ist mal nicht alles grau.
Für unter nen 10er würde ich auch mal reingucken....
Bethesda Faces More Ridicule as Players Access Forbidden Dev Room with Every Item in Fallout 76 - YouTube
Tja, was soll man dazu noch sagen? Hoffentlich lernen sie daraus. :shot:
Ja, inzwischen erscheinen mir da selbst 10 Euro schon zu viel dafür. Mal sehn, ob se draus lernen.
Wir haben gestern nochmal nach dem neuen Patch ein paar Stunden gespielt. Macht nach wie vor Spaß, aber leider ist es immer noch so, dass der zumindest für uns nervigste Bug weiterhin besteht. Nach einiger Zeit wird ein Mitspieler schlicht unsichtbar. Inzwischen wird nicht einmal mehr der Name angezeigt. Das kann doch nicht so schwer zu beheben sein?
EDIT: Wurde inzwischen in die FAQ bei Bethesda aufgenommen.
Man darf Gebäude erst betreten/verlassen wenn jeweils beim anderen Spieler der Ladescreen durch ist....oh Mann.
Ich würde das Spiel so gerne mögen, es macht es mir aber ziemlich schwer :/
Traurig, aber ich stimme dir zu.
Ob sie daraus lernen... mir scheint da offensichtlich viel zu viel im argen zu liegen, dass man da auf einen Lernprozess hoffen könnte. Das Spiel ist so lieblos und primitiv auf den Markt geworfen worden und wird noch halbherziger jetzt betreut als alles zuvor - da scheinen Entscheidungen getroffen worden zu sein von Leuten, die es entweder nicht besser wussten oder eben genau so wollten.
Naja, traurig ist es schon, dennoch hatte ich mehr als genug Spaß mit dem Spiel, als Fehlkauf würde ich es daher nicht bezeichnen, aber als perfektes Spiel nun wahrlich auch nicht. Aber ich hab auch schon schlimmeres gespielt bei dem wesentliche grundlegende Kernelemente erst gar nicht richtig aufgingen, das kann man ja bei Fallout 76 nun auch nicht behaupten, im Kern funktioniert es eigentlich, primär ist es die Technik, die es runter zieht.
Von daher... über die Technik herziehen finde ich völlig ok, über das Spiel an sich abseits der Technik finde ich dann aber teils schon unfair, weil man mit dem Spiel definitiv seinen Spaß haben kann. Wäre das Spiel völliger Schrott würde man es viel schneller abhaken, so ist es bei vielen doch mehr schon einen Art von Hass Liebe, weil eben nicht alles schlecht ist.
Ein Kumpel von mir, der selbst größerer Fan der Reihe ist als ich (und im Gegensatz zu mir den 4er gespielt hat), hatte jedenfalls auch seinen Spaß damit, auch wenn auch er sich immer wieder mal über manche Dinge aufregte, aber er gehört eh zu der Sorte Spieler, die sich leicht erregen lassen. ;)
Ich habe mir letzte Woche FO76 für 18€ gekauft und mittlerweile bin ich bei ca. 50h ingame Zeit und ich habe gerade mal 1/3 der Map erkundet.
Das Spiel hat seine technischen Probleme aber overall habe ich mein Geld jetzt schon raus und es macht wirklich ne Menge Spaß.
Für mich war es ein sehr guter Kauf!
Mir machts nach den paar Tagen auch immer noch viel Spaß. Gibt viele Terminals mit lustigen Geschichten und Audio Logs.
Wenn ich Sachen ins Camp lege, können das andere klauen? Sehen andere mein Camp (nur dieser kleine Kasten)?
Es sind die kleinen Details: Der Teddybär am Schlagzeug mit der Zigarette im Mundwinkel :d (derlei Anordnungen findet man überall verstreut)
Spass macht es den FalloutHardcorefan schon. Es sind die vielen kleinen Dinge und die vielen Bug´s die ein in den Wahnsinn treiben. Freu mich wie sau endlich eine Gausskanone gefunden zu haben. Habe sie im Inventar natürlich als Favorit markiert. Beim Verkaufen von Loot beim Händler - Boom mit weg - Text zu lang - Serverlag beim verkaufen - keine abfrage nix - kein Rückkauf möglich. Oder Kämpfst mit 7-8 leutz gegen die Queen - boing F76 return to Desktop in 7 von 10 Fällen. Die Welt ist groß und mit liebe zum Detail aufgebaut. Selbest Atoms bekommest im Spiele ohne Probleme nur durchs zocken. Habe an die ~4000 verdient mit lvl 90ig. Kaufen muss mann da nix mit Echtgeld für bissel Cosmeticstuff.
Naja, aktuell erlaubt die Technik ja Betrügern, dir den Spaß zu vermiesen und sowieso, dass du das Spiel gar nicht beenden kannst, bzw. zur Nuke kommst.
Aber hin wie her, wer damit Spaß hat, soll den haben. Nur weil ich ihn (und offensichtlich viele andere) verloren habe, gönne ich dennoch jedem anderen Spieler seine Freude. :)
Kann das Spiel inzwischen eigentlich 21:9?
@MrWahoo
Nein, es ist nach wie vor nur die ini-Änderung ohne Anpassung der UI.
PC: 1.0.3.10
Fallout 76 Patch Notes – December 11, 2018
21:9 Resolution Support: On PC, you can catch an even wider view from those gorgeous Appalachian vistas, because Fallout 76 now supports monitors that use 21:9 aspect ratio
PC: 1.0.4.13
FOV Slider ist auch drin.
PC: 1.0.3.10
PC: 1.0.4.13
Sieht aber trotzdem etwas komisch aus
Das Spiel ist ja mittlerweile bei 10€ für den Key angekommen (gabs das schon mal 8 Wochen nach Realease bei nem 60€ AAA Titel?:fresse:)und es gibt jetzt Hinweise das es bald F2P werden könnte. Glückwunsch an alle die Vollpreis gezahlt haben :shot:
Nunja, Free2Play würde für mich bedeuten, dass ich es nicht mehr anrühren würde, ich kann Free2Play Spiele bzw. dessen Spieler nicht leiden. Mein Spaß hatte ich an dem Spiel jedenfalls, von daher juckt würde es mich jetzt nicht derart jucken.
Was ein Quatsch an Schlussfolgerungen....Es wird in Chargen geliefert, wenn diese verkauft sind, werden neue nachgeliefert.
das Game ist echt zu verbuggt.......ich werde es noch etwas "reifen" lassen.
Schade, ein neues Fallout ohne den Online Quatsch hätte mir besser gefallen.
Guinnes
Ich denke wir sind uns alle einig, dass die Probleme des Spiels nicht mit dem Online-Modus zusammenhängen. ;)
Bist du dir da sicher? Wer weiß schon wie viel Entwicklung die in ihre Engine stecken mussten, damit es überhaupt läuft wie es läuft.
gibt es eine möglichkeit ein event, welches man nicht geschaftt hat, zu wiederholen ???
das game spielt sich irgendwie komplett träge als hätte man ne schlechte online verbindung.....schade.
guinnes
Einfach wieder mitspielen.
Events finden in gewissen Zeitabständen immer wieder automatisch statt, aber keine Ahnung ob es da einen festen Wert gibt oder die Random sind. Kannst aber so oft mit machen wie du willst.
