[Sammelthread] ASUS ROG Maximus IX Apex - The New Hardcore (Z270)
--- Produktseite | PDF-Handbuch | Preisvergleich ---
388055d1484583484-intel-union-point-mainboards-ft-200-series-chipset-news-reviews-specs-bilder-1561949-1.jpg
Spezifikationen
CPUIntel® for 7th/6th Generation Core i7 / i5 / i3 / Pentium / Celeron Processors
Supports Intel 14 nm CPU
* The Intel Turbo Boost Technology 2.0 support depends on the CPU types.
ChipsetIntel Z270
Memory2x DDR4, Non-ECC, Un-buffered DIMM, max. 32GB**
DDR4 4266/4133/4000/3866/3800/3733/3600/3500/3466/3400/3333/3300/3200/3000/2800/2666/2400(O.C.)/2133 MHz
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
** Anm. d. Verf.: bzw 64GB, sobald 16Gbit DDR4 ICs verfügbar sind
GraphicIntegrated Graphics Processor HD Graphics support
Multi-Monitor support : HDMI/DisplayPort ports
- HDMI 1.4b (up to 4096 x 2160 @ 24 Hz)
- DisplayPort 1.2 (up to 4096 x 2304 @ 60 Hz)
Maximum shared memory of 1024 MB
Multi-GPU Support (2-Way SLI, Quad-GPU SLI, 2-Way & 4-Way CrossfireX)
Expansion Slots2 x PCIe 3.0/2.0 x16 (x16 or dual x8)
1 x PCIe 3.0/2.0 x16 (max at x4 mode)
2 x PCIe 3.0/2.0 x1
StorageIntel® Z270 Chipset :
Supports Intel Smart Response, Rapid Start , Smart Connect
Support Raid 0, 1, 5, 10
Intel Optane Memory Ready
LANIntel® I219V, 1 x Gigabit LAN Controller(s)
ASUS LAN Guard
Dual interconnect between the integrated Media Access Controller (MAC) and physical layer (PHY)
AudioROG SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- ESS ES9023P
- SupremeFX Shielding Technology
- Optical S/PDIF out port(s) at back panel
USB PortsIntel Z270 Chipset :
8 x USB 3.0 port(s)
6 x USB 2.0 port(s)
ASMedia USB 3.1 controller :
2 x USB 3.1 port(s) (2 at back panel, Type-A + Type-C)
ROG Exclusive FeaturesROG RAMCache II
ROG CPU-Z
ROG CloneDrive
MemOK! Button
Slow Mode
CMOS button
Overwolf
ReTry Button
Safe Boot Button
Start Button
Reset Button
LN2 Mode
ROG Aura
- Aura Lighting Control
- Aura RGB Strip Headers
Extreme Engine Digi+ :
- MicroFine Alloy Chokes
- NexFET Power Block MOSFET
- 10K Black Metallic Capacitors
Mem TweakIt
UEFI BIOS features :
Special Features
5-Way Optimization by Dual Intelligent Processors 5
SafeDIMM slot
AURA :
- Aura Lighting Effects Synchronization with compatible ASUS ROG devices
ASUS Exclusive Features- MemOK!
- AI Suite 3
- Anti-Surge
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
- ASUS USB BIOS Flashback
- ASUS UEFI BIOS EZ Mode
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-Connector
Gaming Aesthetics :
- 3D printing friendly
- AURA-RGB Lighting
Performance Optimization :
- Fan Xpert 4 featuring Fan Auto Tuning function and multiple thermistors selection for optimized system cooling control
Back I/O Ports1 x PS/2 keyboard (purple)
1x PS/2 mouse (green)
1x DisplayPort
1x HDMI
1x LAN (RJ45) port(s)
2x USB 3.1 (Type-A + Type-C)
6x USB 3.0
1x Optical S/PDIF out
1x Clear CMOS button(s)
1x USB BIOS Flashback Button(s)
5x Gold-plated audio jacks
Internal I/O Ports1x AAFP
2x RGB Header(s)
1x USB 3.0
3x USB 2.0
4x SATA 6Gb/s
1x CPU Fan
1x CPU OPT Fan
3x Chassis Fan
1x W_PUMP+
1x AIO_PUMP
1x W_Pump+ Header
1x AIO PUMP Header
1x W_IN header
1x W_OUT header
1x W_FLOW header
2x Thermal sensor connector
1x 24-pin EATX Power
2x 8-pin ATX 12V Power
1x EZ Plug connector(s) (4-pin Molex)
1x LN2 Mode switch(es)
1x LN2 Mode jumper(s)
1x Slow Mode switch(es)
1x Slow Mode jumper(s)
1x Reset button(s)
1x BIOS Switch button(s)
1x Safe Boot button
1x ReTry button
1x Start button
1x 14-1 pin TPM
1x 3D Mount screw port(s)
AccessoriesUser's manual
I/O Shield
2 x SATA 6Gb/s cable(s)
1 x SLI HB BRIDGE(2-WAY-L)
1 x Q-Connector
1 x DIMM.2 extension card with 2 x M key (2242/2260/2280/22110, SATA & PCIE 3.0 x 4 mode)
1 x ROG coasters
Operating SystemWindows 10 64-bit
Windows 8.1 64-bit
Windows 7 32-bit
Windows 7 64-bit
Form FactorExtended ATX Form Factor
12 inch x 10.7 inch ( 30.5 cm x 27.2 cm )
Special Features
ASUS Dimm.2 - Dual M.2 Mount Add-On Card
The DIMM.2 module has an exclusive design that accepts two M.2 drives vertically-mounted on a DDR4 interface. This allows a DRAM fan cooler to direct air towards the M.2 drives to prevent throttling.
BIOS
Bilder
Inoffizielle BIOS Versionen u.a. für Extrem-OC (Achtung: Nutzung auf eigene Gefahr!)
  • 0009 (for IGPU benching, higher voltage limits without LN2 Mode)
  • 0023 (0801 with USB over-current detection disabled)
  • 0026 (very early release)
  • 0088 (might fix CBB issues with CPU RSVD switch, BIOS behaves differently during POST with B-die + high voltage)
  • 0091 (0088 + updated Microcode for Core i3-7350K)
  • 0701 (recommended for general use)
News & Reviews
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
ASUS Memory QVL (PDF).​
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tipps (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
4) FAQ - Frequently Asked Questions
  • --> Deine Frage hier!
  • Q: Wie sind die Lüfter und Pumpenanschlüsse konfiguriert? Was ist die maximale Belastbarkeit pro Anschluss?
  • A: Die regulären Lüfteranschlüsse lassen manuell als PWM oder per Spannung geregelt konfigurieren. Die Belastbarkeiten im Überblick:
  • Q: Wie sind die PCI Express Slots angebunden?
  • A:
  • Q: Wo finde ich auf dem Board XYZ?
  • A: (zum vergrößern auf die Grafik klicken)
  • Q: Aus welchen Komponenten besteht und wie leistungsfähig ist das VRM des Apex?
  • A: Es handelt sich um eine 8+2 [2*4(CPU) + 2(iGFX)] & [+ 1(SA) + 1(IO)] Implementierung, mit einem digitalen IR IR35201/3 PWM Controller und zehn TI NexFET PowerBlocks vom Typ 87350D mit einem Rating von bis zu 40A pro Phase für CPU und iGFX.
    (Mosfets für SA/IO sind OnSemi NTMFS4C06B)
  • Q: Wie kann ich den Startvorgang des System beschleunigen?
  • A: Ich habe den Startvorgang bis zum Desktop mit dem M8G mit folgenden Einstellungen auf unter 10s reduzieren können. Diese scheinen analog auch für das Apex wirksam zu sein.
    Code:
    MRC Fast Boost [Enabled] [color=red]Vorher unbedingt die Speichereinstellungen auf Stabilität testen, da das Speicherretraining damit deaktiviert wird![/Color]
    MCH Full Check [Disabled]
    PCH Storage configuration Smart self test [Disabled]
    CSM [Disabled] [color=red]Nur wenn ihr euer OS im UEFI Modus installiert habt.[/Color]
    Option ROM Messages [Disabled]
    Fast Boot [Enabled]
    POST delay time [0]
    Boot Logo [AUTO] oder [Full Screen]
  • Q: Kann man auf dem Maximus IX Apex Coffee Lake Prozessoren verwenden?
  • A: Offiziell ist dies von Intel nicht vorgesehen, es gibt aber einen relativ simplen Hardware+BIOS Mod, der dies ermöglicht. Dies wurde so auch schon von einigen Seiten wie hier Intel Core I9-9900K & Z270! @ overclockers.ru getestet. The_patchelor hat dazu eine Anleitung erstellt:
    APEX IX Coffeelake Mod
    Ohne zusätzliche Modifikationen an der CPU (weder SKT_OCC noch 2 Punkte isolieren) ;) nur Mainboard Mod notwendig.
    So hab ich es gemacht, Bilder sind von mir:
    die 2 Mods
    1x CPU Paqd Mod (SKT_OCC brücken)
    1x Bios brücken (löten, Silberleitlack, Bleistift oder einfach nur kurzschließen) damit wohl das "fremde" Bios drauf kann
    hier der Link zur Quelle
    jAlex@ro hat ein IX Bios aufgebohrt (XP geht damit)
    0084v2 (wohl ohne HT)
    jjxaker hat das Board quasi in ein X verwandelt (XP geht nicht)
    1602 mit HT
    Bios UPDATE
    Base: Asus Maximus X Apex for Maximus IX Apex@BIOS MOD 1602
    Support CPU: Skylake/Kaby Lake/Coffee Lake
    Latest Bios Microcode:
    Intel CPU SKL 0xC6, KBL 0x8E, CFL 8 Core 0x96 / 6 Core 0x96 / 4 Core 0x8E.
    Intel EFI RST 16.5.0.3492
    Intel VBIOS 1059/GOP 9.0.1080
    Intel Lan UNDI 0.0.19/Lan OROM 0.1.13/Lan GBE 0.5
    Intel ME Firmware 11.7.0.1129
    All Region DESC/ME/BIOS Unlock.
    All components of the board are working. including RGB Light, on-board graphics card, HT, PCI-e.
    To MOD flash through the ISP programmer or HW MOD USB Bios Flashback.
    Habe das 1602 einfach per USB Bios Flashback drauf gepackt. Beim ersten Start dreht das Bios 2 Runden und aktualisiert sich, dann habe ich noch den nicht vorhandenen 5G LAN Anschluss deaktiviert. Um das gemoddete 1602 downloaden zu können, müsst ihr im HWBOT Forum eingelogged sein.
    Hinweis zum Bios Flashback: Das Bios überschreibt euch die MAC, UUID und MB Serial.
    Lösung:
    -mit altem Bios zuvor oder mit Bios2 booten (SL oder KL CPU erforderlich...)
    -Universal Bios Backup Toolkit 2.0 suchen und downloaden (als Admin ausführen, Viruswarnung ignorieren... am besten mit einem temp. Windows arbeiten..)
    -Bios auslesen und abspeichern
    -FD44Editor verwenden um die MAC, UUID und Motherboard S/N auszulesen (vom backupBios)
    -1602 creative.rom auch mit FD44Editor öffnen und die Werte eintragen und abspeichern
    hier werden die Werte aus dem alten ins neue eingetragen...
    wieder als creative.rom speichern und auf einen USB Stick packen. BIOS wieder auf 1 umstellen und das korrigierte "persönliche" BIOS per USB Flashback laden
5) ASUS ROG Wallpaper
6) Wasserkühler (Mainboard)
WORK IN PROGRESS :angel:
Was haben die ganzen Meckerer eigentlich mit ihren Boards gemacht, trotzdem behalten oder zurückgegeben?
Im MP sind sie ja offenbar nicht gelandet :fresse:
Kurztest 7700K L644G993 ungeköpft aufm OCFM und APEX
1.248V 1.312V
Das ist die größte Differenz, die ich bisher gesehen habe - auch international. Sind die Einstellungen auf dem Apex wirklich optimal?
sind ca 64mV differenz, scheint ja standard zu sein beim Vergleich OCFM - APEX.
Beim OCFM war die VCore leicht am schwanken (1.248-1.264v). Hab aber bei beiden nicht mitm Multimeter gemessen.
Liege jetzt geköpft und mit Prime Custom bei 1.296v aufm APEX. Merkwürdigerweise brauche ich +50-60mV damit LinX läuft, so groß war aufm OCFM nie die Differenz zwischen Prime & LinX.
Edit: was mich mittlerweile tierisch nervt ist dass das 2te APEX nun auch sonen Aus-An-Aus-An Bug hat... mal läufts ohne Probleme und dann wieder garnicht.... :(
Jemand eine Idee woran der Rotz liegen kann? Aufm OCF(M) nicht einmal gehabt sonen Scheiss :motz:
Ich habe leider krasse Performance Einbußen mit den 2x Corsair Force MP500 im RAID 0 Verbund auf dem Expansion Board. Von anfänglichen 2300MB/s Schreibgeschwindigkeit bleiben nach Installieren von Steam mit Arma 3 und meiner Joysticks / TrackIR5 nur noch lasche 300MB/s übrig.
Jemand ne Ahnung was da los ist?
Danke und Gruß
Hast du den NVME-Treiber installiert?
Das war es nämlich bei mir. Dann Schreibrate > 1.800 MB
@ aero
alles schön und gut das es bei dir läuft, hoffe für dich das die kagge nicht bei dir genauso anfängt ;)
Mir wäre es trotzdem recht wenn jemand nen Tip hätte bzgl des Aus-An-Aus-An Bugs....
Gesendet von meinem LG G5 mit Tapatalk
Hab auch ein Prob. und zwar will meine Kabelgebundene Logitech Tastatur nicht im Bios Load, sprich Leuchtet, aber komme nicht ins Bios,Win läuft alles.
Der Clou, mit einer Kabellosen BT gehts wunderbar. Muss etwas mit Treiber laden zu tun haben :confused:
Ich verstehe die Offset-Funktion nicht wirklich:
Habe die CPU auf 50er Multi eingestellt, gehe auf offset und stelle ein "+" ein, dazu dann den Wert 0,080.
PC bootet auch soweit, alles ok. Aber im Idle liegt meine VCore jetzt bei 1,24V. unter Last bin ich um die 1,328V.
Geht Kaby-Lake mit der VCore im Idle nicht weiter runter oder muss ich offset adaptive einstellen?
Habe auch ein Apex hier und schnalle das nächste Woche direkt mal auf den Benchtable. :)
Welches Bios hat sich denn nun am taktfreudigsten erweisen - gerade auch in Hinblick auf eine möglichst niedrige VCore?
Aus genau dem Grund arbeite ich am Apex mit ner uralten Cherry ps2 Tastatur ;)
Rebooten mit dem Ding ist ein richtiger Krampf, Licht an, Licht aus, Licht an, Licht aus............................:hmm:...........................Licht an, ah, es hat doch noch Lust zu starten :haha:
Merkwürdig das hier ein paar Reboot Probleme haben. Bisher hat hier jeder Reboot im ersten Anlauf funktioniert.
@-Nik-
Meine Kabel-Logitech tut hier problemlos.
Hast dir mal die USB Funktionen im Bios angesehen? Da kannst doch bisken fuddeln.
Dann eben erst mal mit 1,280v.
Hatte noch nie eine CPU die so nah zu nächsten Vcorestufe ( 1,264v. ) liegt .
Hab schon so viel ausprobiert ... Core PLL / Switch Frequency ...und und und .
2x schon ist sie mir bei einem Custom Run mit 1,264v. abgeschmiert .
( Einzeln mal 18K lief schon durch )
Offset bringt auch nicht wirklich was .
Aber ich bleibe dran an den 1,264v.:mad:
Vielleich kommt bald mal ein Bios womit ich es durch bekomme
Hm, also bei den Corsair Force MP500 M.2 SSD´s war kein Treiber dabei, und bei Corsair hab ich nichts gefunden.
Alle Asus Chipsatz sowie Motherboard Treiber habe ich ja installiert, sowie alle Intel Treiber der Asus Seite.
Problem ist ja, das ich anfänglich ca 2300MB/s habe,
aber dann
nach der Installation weiterer Programme und Geräte, die 2300 runter auf nur noch 300 MB/s gehen.
Du hast sicherlich Samsung SSD´s, dafür gibts ja nen NVMe Treiber...
Und um beim Topic zu bleiben:
auf meinem Apex passte leider der Noctua NH-D15 CPU Lüfter NICHT drauf, da man die GraKa dann in den 3. Slot stecken müßte, der DIMM.2 Slot wäre gänzlich unbrauchbar, und meine RGB LED G.SKILL 4133 DDR4 Rams kann man nicht in seiner Farbenpracht bewundern.
Hab diesen gegen eine AiO von Corsair getauscht. Corsair H100i v2. Mit der Corsair Link Software gibts aber leider ebenfalls Inkompatibilitäten mit der Asus FanXpert 4 Lüfter Steuerung, sodaß ich nun mal den NZXT Kraken X62 testen werde!
Ebenfalls bekommt man in Corsair Link keine Motherboard Infos angezeigt, habe dazu bei Corsair mal ein Ticket eröffnet
Sieht gut aus, wie siehts mit LinX aus? Kannst mal testen? :)
Mal so am Rande, passt das Board NUR in E-ATX Gehäuse oder auch in viele/bestimmte "normale" Gehäuse? Sollte was sehr kompaktes sein und die H115i muss auch rein ;) 3,5" und 5,25" brauch ich nicht unbedingt.
E-ATX ist auf der gegenüberliegenden Seite der ATX Blende länger, als ein ATX Board. Wieviel hängt vom Design ab, ist nicht immer gleich. Bei Gehäusen wie dem Define R5 z.b kann es je nach Board vorkommen das das PCB am Gehäuse anliegt. Nicht wirklich schlimm aber auch nicht immer schön.
Hat jemand nen Plan, wie man ein Phanteks Enthoo Luxe Tempered Glass ans Board anschließt?
Brauch man da zwingend das RGB LED Adapter Kabel von PT?
Oder geht das auch anders?
Guten Morgen zusammen,
gehe ich Recht in der Annahme das ein Noctua NH-D15 die Belegung des ersten PCI Espress Slots behindert aufgrund der aus Seite 1 angeführten Bemaßung?
Zitat : Abstand Sockelmitte bis an den Slot: 7,5 cm
Sockelmitte bis ersten RAM Slot: 5 cm
und der Abstand zum ersten RAM Slot ebenfalls eine Inkompatibilität des NH-D15 aufweist?
oder irre ich mich und hat jemand diese Kombination erfolgreich installiert?
Danke für etwaige Aufklärung.
Frage, muss E-ATX2 und EZ-Mode zwingend mit Strom verbunden sein? und gibt's Adpater für E-ATX oder muss ich mir für mein Corsair RM650i extra noch ein zusätzliches Kabel versorgen (am Netzteil hab ich noch einmal frei, verbaue eh keine zweite Grafikkarte)
Wie hab ihr das gelöst?
Board kommt morgen...
