Spezifikationen
| CPU | Intel® for 7th/6th Generation Core i7 / i5 / i3 / Pentium / Celeron Processors Supports Intel 14 nm CPU * The Intel Turbo Boost Technology 2.0 support depends on the CPU types. |
| Chipset | Intel Z270 |
| Memory | 2x DDR4, Non-ECC, Un-buffered DIMM, max. 32GB** DDR4 4266/4133/4000/3866/3800/3733/3600/3500/3466/3400/3333/3300/3200/3000/2800/2666/2400(O.C.)/2133 MHz * Hyper DIMM support is subject to the physical characteristics of individual CPUs. ** Anm. d. Verf.: bzw 64GB, sobald 16Gbit DDR4 ICs verfügbar sind |
| Graphic | Integrated Graphics Processor HD Graphics support Multi-Monitor support : HDMI/DisplayPort ports - HDMI 1.4b (up to 4096 x 2160 @ 24 Hz) - DisplayPort 1.2 (up to 4096 x 2304 @ 60 Hz) Maximum shared memory of 1024 MB Multi-GPU Support (2-Way SLI, Quad-GPU SLI, 2-Way & 4-Way CrossfireX) |
| Expansion Slots | 2 x PCIe 3.0/2.0 x16 (x16 or dual x8) 1 x PCIe 3.0/2.0 x16 (max at x4 mode) 2 x PCIe 3.0/2.0 x1 |
| Storage | Intel® Z270 Chipset : Supports Intel Smart Response, Rapid Start , Smart Connect Support Raid 0, 1, 5, 10 Intel Optane Memory Ready |
| LAN | Intel® I219V, 1 x Gigabit LAN Controller(s) ASUS LAN Guard Dual interconnect between the integrated Media Access Controller (MAC) and physical layer (PHY) |
| Audio | ROG SupremeFX 8-Channel High Definition Audio CODEC S1220A - Impedance sense for front and rear headphone outputs - Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking - ESS ES9023P - SupremeFX Shielding Technology - Optical S/PDIF out port(s) at back panel |
| USB Ports | Intel Z270 Chipset : 8 x USB 3.0 port(s) Intel Z270 Chipset : 6 x USB 2.0 port(s) ASMedia USB 3.1 controller : 2 x USB 3.1 port(s) (2 at back panel, Type-A + Type-C) |
| ROG Exclusive Features | ROG RAMCache II ROG CPU-Z ROG CloneDrive MemOK! Button Slow Mode CMOS button Overwolf ReTry Button Safe Boot Button Start Button Reset Button LN2 Mode ROG Aura - Aura Lighting Control - Aura RGB Strip Headers Extreme Engine Digi+ : - MicroFine Alloy Chokes - NexFET Power Block MOSFET - 10K Black Metallic Capacitors Mem TweakIt UEFI BIOS features : Special Features 5-Way Optimization by Dual Intelligent Processors 5 SafeDIMM slot AURA : - Aura Lighting Control - Aura RGB Strip Headers - Aura Lighting Effects Synchronization with compatible ASUS ROG devices |
| ASUS Exclusive Features | - MemOK! - AI Suite 3 - Anti-Surge ASUS EZ DIY : - ASUS CrashFree BIOS 3 - ASUS EZ Flash 3 - ASUS USB BIOS Flashback - ASUS UEFI BIOS EZ Mode ASUS Q-Design : - ASUS Q-Shield - ASUS Q-Code - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED) - ASUS Q-Slot - ASUS Q-Connector Gaming Aesthetics : - 3D printing friendly - AURA-RGB Lighting Performance Optimization : - Fan Xpert 4 featuring Fan Auto Tuning function and multiple thermistors selection for optimized system cooling control |
| Back I/O Ports | 1 x PS/2 keyboard (purple) 1x PS/2 mouse (green) 1x DisplayPort 1x HDMI 1x LAN (RJ45) port(s) 2x USB 3.1 (Type-A + Type-C) 6x USB 3.0 1x Optical S/PDIF out 1x Clear CMOS button(s) 1x USB BIOS Flashback Button(s) 5x Gold-plated audio jacks |
| Internal I/O Ports | 1x AAFP 2x RGB Header(s) 1x USB 3.0 3x USB 2.0 4x SATA 6Gb/s 1x CPU Fan 1x CPU OPT Fan 3x Chassis Fan 1x W_PUMP+ 1x AIO_PUMP 1x W_Pump+ Header 1x AIO PUMP Header 1x W_IN header 1x W_OUT header 1x W_FLOW header 2x Thermal sensor connector 1x 24-pin EATX Power 2x 8-pin ATX 12V Power 1x EZ Plug connector(s) (4-pin Molex) 1x LN2 Mode switch(es) 1x LN2 Mode jumper(s) 1x Slow Mode switch(es) 1x Slow Mode jumper(s) 1x Reset button(s) 1x BIOS Switch button(s) 1x Clear CMOS button(s) 1x Safe Boot button 1x ReTry button 1x Start button 1x 14-1 pin TPM 1x 3D Mount screw port(s) |
| Accessories | User's manual I/O Shield 2 x SATA 6Gb/s cable(s) 1 x SLI HB BRIDGE(2-WAY-L) 1 x Q-Connector 1 x DIMM.2 extension card with 2 x M key (2242/2260/2280/22110, SATA & PCIE 3.0 x 4 mode) 1 x ROG coasters |
| Operating System | Windows 10 64-bit Windows 8.1 64-bit Windows 7 32-bit Windows 7 64-bit |
| Form Factor | Extended ATX Form Factor 12 inch x 10.7 inch ( 30.5 cm x 27.2 cm ) |
Special Features
ASUS Dimm.2 - Dual M.2 Mount Add-On Card
The DIMM.2 module has an exclusive design that accepts two M.2 drives vertically-mounted on a DDR4 interface. This allows a DRAM fan cooler to direct air towards the M.2 drives to prevent throttling.
BIOS
Bilder
Inoffizielle BIOS Versionen u.a. für Extrem-OC (Achtung: Nutzung auf eigene Gefahr!)
- 0009 (for IGPU benching, higher voltage limits without LN2 Mode)
- 0023 (0801 with USB over-current detection disabled)
- 0026 (very early release)
- 0088 (might fix CBB issues with CPU RSVD switch, BIOS behaves differently during POST with B-die + high voltage)
- 0091 (0088 + updated Microcode for Core i3-7350K)
- 0701 (recommended for general use)
News & Reviews
- [Press Release] ASUS ROG Maximus IX & Z270 Strix Series @ ASUS ROG
- [Video] ASUS ROG Maximus IX Apex - Review & Overclocking Guide @ der8auer (Part II)
- [Video] [Review] ASUS ROG Maximus IX Apex @ OC3D TV
- [Video] [Review] ASUS ROG Maximus IX Apex @ Actually Hardware Overclocking
- [Review] ASUS ROG Maximus IX Apex @ Overclock3d
- [Review] ASUS ROG Maximus IX Apex @ Tweaktown
- [Review] ASUS ROG Maximus IX Apex @ GreenTechReviews (rus)
- [Review] ASUS ROG Maximus IX Apex @ Hardware Asylum
- [Review] ASUS ROG Maximus IX Apex @ KitGuru
- [Review] ASUS ROG Maximus IX Apex @ Play3r
- [Review] ASUS ROG Maximus IX Apex - A overclocking marvel @ ReviewStudio.net
- [User Review] ASUS ROG Maximus IX Apex by Flank3r @ ASUS ROG
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
- Hersteller Modell @ Preisvergleich | Quelle | kompatibel | Einschränkungen / Anmerkungen
- Hersteller Modell @ Preisvergleich | Quelle | inkompatibel | Grund/Foto(s)
- Arctic Liquid Freezer 360 (ACFRE00022A) | DamirRS4 | kompatibel
- Koolance CPU-370 | Otto Riegel | kompatibel | ca 5mm bis zum ersten RAM-Slot
- EK Water Blocks EK-Supremacy EVO | CloudStrife81 | kompatibel | 2,3mm zum ersten RAM-Slot [1]
- Noctua NH-D15 | feiercrack, ralle_h | inkompatibel | blockiert den ersten PEG, die Speicherbänke und ggf. auch den Dimm.2 [1] [2]
- Watercool HEATKILLER IV PRO (18000) | webwilli, Chrisch | kompatibel | kann nur vertikal montiert werden, siehe [1]
- --> Bitte helft mit sammeln!
EK is releasing a new monoblock for the ASUS® ROG MAXIMUS IX APEX & EK-FB ASUS M9A Monoblock - Nickel @ EK Webshop
2) RAM
- Hersteller Modell @ Preisvergleich | Anzahl Module x Größe | Quelle | kompatibel | Einschränkungen / Anmerkungen
- Hersteller Modell @ Preisvergleich | Anzahl Module x Größe | Quelle | inkompatibel | Grund/Screen
- Corsair Dominator Platinum SE CMD32GX4M4C3200C14M | 2x8GB | aerotracks | kompatibel | natürlich nur 2 Module aus dem Quad Kit, [1]
- G.Skill Ripjaws V Z F4-3200C14D-16GVK | 2x8GB | DamirRS4 | kompatibel
- G.Skill Ripjaws V Z F4-3200C14D-32GVK | 2x16GB | emissary42 | kompatibel
- G.Skill Trident Z F4-3600C15D-16GTZ | 2x8GB | webwilli | kompatibel
- G.Skill Trident Z F4-3600C16D-16GTZ | 2x8GB | emissary42 | kompatibel
- G.Skill Trident Z F4-3600C17D-16GTZ | 2x8GB | aerotracks | kompatibel | OC @ DDR4-4133 CL16
- G.Skill Trident Z F4-4266C19D-16GTZA | 2x8GB | HazelPott | kompatibel
- G.Skill Trident Z RGB F4-4000C18D-16GTZR | 2x8GB | Ali G | kompatibel
Zu den Speichern :
G.SKILL Trident Z F4-3600C15D-16GTZ
G.SKILL Trident Z F4-3600C16D-16GTZ
G.SKILL Trident Z F4-3600C17D-16GTZ
G.SKILL Trident Z F4-3733C17D-16GTZ
G.SKILL Trident Z F4-4000C19D-16GTZ
G.SKILL Trident Z F4-4133C19D-16GTZ
G.SKILL Trident Z F4-4266C19D-16GTZ
Galax HOF DDR4-4000 16G (HOF4CXL1BS4000M19SF162C, HOF4CXLBS4000M19SF162C)
Alle mit xmp getestet, rennen astrein! - --> Bitte helft mit sammeln!
ASUS Memory QVL (PDF).
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.
Nützliche Links & Tipps (im Forum & im WWW)
1) Hardwareluxx
- [Sammelthread] [Sammelthread] -= OC Prozessoren Intel Sockel 1151 (Skylake) Laberthread =-
- [Sammelthread] -= OC Prozessoren Intel Sockel 1151 (Kaby-Lake) Laberthread =-
- [Sammelthread] Intel Kaby Lake (Sockel 1151) OC-Ergebnis-Thread! KEIN Quatschthread!
- [Sammelthread] Intel Skylake (Sockel 1151) OC-Ergebnis-Thread! KEIN Quatschthread!
- [Übersicht] Intel Union Point Mainboards ft. 200 Series Chipset - News, Reviews, Specs, Bilder
- Delid-Die-Mate 2 köpft Prozessoren einfacher und günstiger - Hardwareluxx
- Der offizielle ASUS Support direkt hier im Forum: ASUS
- Direktlink zum ASUS eSupport: per E-Mail & per Telefon
2) WWW (international)
- Dancops ASUS ROG Maximus IX APEX LN2 guide for all scenarios @ HWBOT forum
- ASUS ROG Maximus IX Apex OC Guide v1.1 (Mediafire Download
- ASUS ROG Maximus IX Apex Overclocking Thread @ HWBOT forum
- ASUS ROG Kaby Lake Overclocking Guide by Raja
- [GUIDE] Skylake Memory Timings on Asus Motherboards @ ASUS ROG (geschrieben für die Maximus VIII Modelle, vieles davon gilt auch für das Apex)
- Ultimate B-Die Tweaking Guide for ASUS ROG Maximus VIII Series @ hwbot (vieles davon gilt auch für das Apex)
3) Tips & Tricks
- Software Basics
elmor schrieb: - Windows 7 Setup Guide (PDF)
4) FAQ - Frequently Asked Questions
- --> Deine Frage hier!
- Q: Wie sind die Lüfter und Pumpenanschlüsse konfiguriert? Was ist die maximale Belastbarkeit pro Anschluss?
- A: Die regulären Lüfteranschlüsse lassen manuell als PWM oder per Spannung geregelt konfigurieren. Die Belastbarkeiten im Überblick:
- Q: Wie sind die PCI Express Slots angebunden?
- A:
- Q: Wo finde ich auf dem Board XYZ?
- A: (zum vergrößern auf die Grafik klicken)
- Q: Wie viel Vcore braucht das Apex im Vergleich zum ASRock Z170M OC Formula?
- A: Laut ersten Ergebnissen nur etwa 15 bis 32mV mehr.
Apex ist eingebaut und brauch ca. bissle mehr wie das Z170M OC Formula.
Z170M OC Formula 4500Mhz@ 1.088v LinX stabil.
Asus Apex 4500Mhz@ 1.104v LinX stabil
- Q: Wie groß sind die Abstände vom Sockel zum ersten PEG bzw zur ersten Speicherbank?
- A:
Abstand Sockelmitte bis an den Slot: 7,5 cm
Sockelmitte bis ersten RAM Slot: 5 cm
- Q: Aus welchen Komponenten besteht und wie leistungsfähig ist das VRM des Apex?
- A: Es handelt sich um eine 8+2 [2*4(CPU) + 2(iGFX)] & [+ 1(SA) + 1(IO)] Implementierung, mit einem digitalen IR IR35201/3 PWM Controller und zehn TI NexFET PowerBlocks vom Typ 87350D mit einem Rating von bis zu 40A pro Phase für CPU und iGFX.
(Mosfets für SA/IO sind OnSemi NTMFS4C06B)
- Q: Wie kann ich den Startvorgang des System beschleunigen?
- A: Ich habe den Startvorgang bis zum Desktop mit dem M8G mit folgenden Einstellungen auf unter 10s reduzieren können. Diese scheinen analog auch für das Apex wirksam zu sein.
Code:MRC Fast Boost [Enabled] [color=red]Vorher unbedingt die Speichereinstellungen auf Stabilität testen, da das Speicherretraining damit deaktiviert wird![/Color] MCH Full Check [Disabled] PCH Storage configuration Smart self test [Disabled] CSM [Disabled] [color=red]Nur wenn ihr euer OS im UEFI Modus installiert habt.[/Color] Option ROM Messages [Disabled] Fast Boot [Enabled] POST delay time [0] Boot Logo [AUTO] oder [Full Screen]
- Q: Kann man auf dem Maximus IX Apex Coffee Lake Prozessoren verwenden?
- A: Offiziell ist dies von Intel nicht vorgesehen, es gibt aber einen relativ simplen Hardware+BIOS Mod, der dies ermöglicht. Dies wurde so auch schon von einigen Seiten wie hier Intel Core I9-9900K & Z270! @ overclockers.ru getestet. The_patchelor hat dazu eine Anleitung erstellt:
APEX IX Coffeelake Mod
Ohne zusätzliche Modifikationen an der CPU (weder SKT_OCC noch 2 Punkte isolieren)
nur Mainboard Mod notwendig.
So hab ich es gemacht, Bilder sind von mir:
die 2 Mods
1x CPU Paqd Mod (SKT_OCC brücken)
1x Bios brücken (löten, Silberleitlack, Bleistift oder einfach nur kurzschließen) damit wohl das "fremde" Bios drauf kann
hier der Link zur Quelle
jAlex@ro hat ein IX Bios aufgebohrt (XP geht damit)
0084v2 (wohl ohne HT)
jjxaker hat das Board quasi in ein X verwandelt (XP geht nicht)
1602 mit HT
Bios UPDATE
Base: Asus Maximus X Apex for Maximus IX Apex@BIOS MOD 1602
Support CPU: Skylake/Kaby Lake/Coffee Lake
Latest Bios Microcode:
Intel CPU SKL 0xC6, KBL 0x8E, CFL 8 Core 0x96 / 6 Core 0x96 / 4 Core 0x8E.
Intel EFI RST 16.5.0.3492
Intel VBIOS 1059/GOP 9.0.1080
Intel Lan UNDI 0.0.19/Lan OROM 0.1.13/Lan GBE 0.5
Intel ME Firmware 11.7.0.1129
All Region DESC/ME/BIOS Unlock.
All components of the board are working. including RGB Light, on-board graphics card, HT, PCI-e.
To MOD flash through the ISP programmer or HW MOD USB Bios Flashback.
Habe das 1602 einfach per USB Bios Flashback drauf gepackt. Beim ersten Start dreht das Bios 2 Runden und aktualisiert sich, dann habe ich noch den nicht vorhandenen 5G LAN Anschluss deaktiviert. Um das gemoddete 1602 downloaden zu können, müsst ihr im HWBOT Forum eingelogged sein.
Hinweis zum Bios Flashback: Das Bios überschreibt euch die MAC, UUID und MB Serial.
Lösung:
-mit altem Bios zuvor oder mit Bios2 booten (SL oder KL CPU erforderlich...)
-Universal Bios Backup Toolkit 2.0 suchen und downloaden (als Admin ausführen, Viruswarnung ignorieren... am besten mit einem temp. Windows arbeiten..)
-Bios auslesen und abspeichern
-FD44Editor verwenden um die MAC, UUID und Motherboard S/N auszulesen (vom backupBios)
-1602 creative.rom auch mit FD44Editor öffnen und die Werte eintragen und abspeichern
hier werden die Werte aus dem alten ins neue eingetragen...
wieder als creative.rom speichern und auf einen USB Stick packen. BIOS wieder auf 1 umstellen und das korrigierte "persönliche" BIOS per USB Flashback laden
5) ASUS ROG Wallpaper
6) Wasserkühler (Mainboard)
WORK IN PROGRESS
und nicht genau genug für solche Messungen
...ist bestimmt schon einen halben Liter verflogen
