[Sammelthread] Assetto Corsa
musst wahrscheinlich von Steam neu installieren lassen:
when v1.1 and dlc are released there are many changes to ac engine code so this will more than likely break any mods you have installed,
(wait for modders to update them)
also may break other in game functions too.
so what should you do?
simple
DO A CLEAN INSTALL
delete assetto corsa from steam,go to your install folder narmaly located here c/programmefilesx86/steam/steamapps/common/assetto corsa
after that back up your setups folder in your assetto corsa my documents folder then delete the assetto corsa folder.
after that simply download the latest version of ac and all should go well with no hickups
remember to drop your setups folder back into ac after you boot up the game and let it create a new folder.
i know most of you know this but for them that dont this will prevent many problems
if your internet is slow you should just remove all mods and then verify your game cache
like so...
1.Load Steam.
2.From the Library section, right-click on the game and select Properties from the menu.
3.Select the Local files tab and click the Verify integrity of game cache... button.
4.Steam will verify the game's files - this process may take several minutes.
CLEAN INSTALL IS BEST THOUGH
As johny below advises its also a good idea to back up your mods
some tracks may still work cars most likely will not as there is a new physics update too
once backed up
add them one at a time to test them
Geh gerade im full retard mode mit Tastatur und manuellem Schalten auf die Strecke um wenigstens den Sound zu testen. Der Nissan hört sich nicht gut an mMn. Ganz gut ist der McLaren F1 GTR.
m235i und p1 hören sich auch brutal an meiner meinung nach.
Super alle mods im arsch das ist der grund warum ich solche spiele eigentlich nicht mag...sollnses endlich mal fertig machen damit man nicht ständig rumeiern muss mit den mods.
Hab auch ne Clean Install gemacht... läuft 1a!
Find den Sound vom Nismo nicht so übel... der alte eckige Alfa klingt kacke mMn
Läuft prima, besonders die Performance :)
Nur beenden geht bei mir nur über den Taskmanager
bei mir bleibts auch stehen bei Populating car list :(
Dieser Moment wenn man gleichzeitig mit einem Sauber C9 aus dem Parkplatz von der Touristen-Anbindung rausfährt und der dann beschleunigt :love:
Jemand im TS?
bin ich der einzigste bei dem es nicht starten will ?? da war doch über meinen post noch eine wo es nicht wollte?!! hat der jenige es zum laufen gebracht ? wenn ja wie :(
hab da nie was dran rumgemoddet :/
kann man nur noch zwischen 2 Sprachen wählen?
ah, im Menü kann man dann wieder mehrere Sprachen wählen.
In 1h 2mal gecrashed... und mein CSS is hinüber :fresse:
Bei mir liefs nachdem ich einige mods gelöscht hab. In deinem fall von steam spieldatem checken lassen ansonsten neu installieren, leider.
Mann der 155er Alfa klingt klasse.
mhh files checken lassen hab ich schon 3 daten waren da fail!! naja :(
also wenn ich die Grafiksettings auf Anschlag schraub, das bringt meine 980 schon gut zum arbeiten :d
Der P1 ist aber wirklich leider geil ;)
Also @4K und Max Settings läufts auf meiner 290X ohne große Mühe.
Welche Einstellungen muss ich ändern das mein Lenkrad bei geringen grad zahlen sich nicht so schwammig anfühlt? Hab nen DFGT ..Hab nen Screen von meinen Einstellungen gemacht
der C9 hat wirklich einen geilen Außensound. Aber ich komm mit der Karre überhaupt nicht klar :d
Der Nissan GT-R OO ... fap fap fap!!! Geile Karre, hat mich sofort angefixt. So'n richtiges Gewaltauto xD ... genau mein Ding!
wie kannst du damit bitte lenken?! ist das FFB nicht VIEL zu stark??? Ich fahre fast genau mit den Settings jedoch die Stärke ingame auf 50...
Edit: Wie ist denn die TS IP? ts.talkluxx.de bin hier drauf aber da ist weder ein Channel, noch jemand von euch :d
Hm, bisher nur nen paar der neuen Wannen gefahren...
- GTR - als erstes Auto erstmal wieder an die Steuerung gewöhnen (nach 2 Wochen Pcars)... gefiel mir nicht so, nochmal versuchen
- C9 - schönes Ding das, schade das es scheinbar keinen vernünftigen Metallic-Lack in AC gibt ;)
- 155 - geiler Sound und erstaunlich gut zu fahren
- C7 - geil. einfach nur geil.
- P1 - dito, vielleicht sogar noch geiler, wobei der Corvette Sound besser ist.
Meine persönlichen Favs C7 und P1 und natürlich die 25km Schleife :drool:
Und ich muss am arbeiten. Mist muss ich das jetzt bezahlen also ist das ein dlc?
