emissary42
Kapitän zur See
- Ort
- Nehr'esham
- Desktop System
- Endlos-Baustelle
- AMD & Intel
- alle Hersteller
- Luft
- G.SKILL, Corsair & Co
- 8K, 5K, 4K
- 80plus Platinum
Corsair Dominator Platinum DDR4 Series
Press Releases
1) HARDWARELUXX News Corsair bereitet sich ebenfalls auf den Start von DDR4 vor
2) Corsair Corsair Ushers in Next-gen PC Platforms with Vengeance LPX and Dominator Platinum DDR4 Memory
3) Corsair Corsair and ASUS Join Forces to Create World’s Fastest Production DDR4 Memory Kit for Intel Core i7 Extreme Edition Processors
4) HARDWARELUXX News Corsair bietet Dominator Platinum Series DDR4 mit 3400 MHz an
Die Modelle
| Model name | Speed | Bandwidth | Size | Latency | Voltage | Fan | Preis (alle) |
| CMD16GX4M4B3400C16 | DDR4-3400 | PC4-27200 | 16GB (4GB x 4) | CL16-18-18-40 | 1.35V | - | Preisvergleich |
| CMD16GX4M4B3333C16 | DDR4-3333 | PC4-26600 | 16GB (4GB x 4) | CL16-18-18-36 | 1.35V | - | Preisvergleich |
| CMD16GX4M4B3300C16 | DDR4-3300 | PC4-26400 | 16GB (4GB x 4) | CL16-18-18-36 | 1.35V | - | Preisvergleich |
| CMD16GX4M4B3200C15 | DDR4-3200 | PC4-25600 | 16GB (4GB x 4) | CL15-17-17-35 | 1.35V | - | Preisvergleich |
| CMD16GX4M4B3200C16 | DDR4-3200 | PC4-25600 | 16GB (4GB x 4) | CL16-18-18-36 | 1.35V | - | Preisvergleich |
| CMD16GX4M4B3100C16 | DDR4-3100 | PC4-24800 | 16GB (4GB x 4) | CL16-18-18-36 | 1.35V | - | Preisvergleich |
| CMD32GX4M4B3000C15 | DDR4-3000 | PC4-24000 | 32GB (8GB x 4) | CL15-17-17-35 | 1.35V | - | Preisvergleich |
| CMD16GX4M4B3000C15 | DDR4-3000 | PC4-24000 | 16GB (4GB x 4) | CL15-17-17-35 | 1.35V | - | Preisvergleich |
| CMD16GX4M4B2933C15 | DDR4-2933 | PC4-23466 | 16GB (4GB x 4) | CL15-17-17-35 | 1.35V | - | Preisvergleich |
| CMD64GX4M4A2800C16 | DDR4-2800 | PC4-22400 | 64GB (8GB x 8) | CL16-18-18-36 | 1.20V | - | Preisvergleich |
| CMD32GX4M4A2800C15 | DDR4-2800 | PC4-22400 | 32GB (8GB x 4) | CL15-17-17-36 | 1.20V | - | Preisvergleich |
| CMD32GX4M4A2800C16 | DDR4-2800 | PC4-22400 | 32GB (8GB x 4) | CL16-18-18-36 | 1.20V | - | Preisvergleich |
| CMD16GX4M4A2800C16 | DDR4-2800 | PC4-22400 | 16GB (4GB x 4) | CL16-18-18-36 | 1.20V | - | Preisvergleich |
| CMD128GX4M8A2666C15 | DDR4-2666 | PC4-21300 | 128GB (16GB x 8) | CL15-17-17-35 | 1.20V | - | Preisvergleich |
| CMD64GX4M8A2666C15 | DDR4-2666 | PC4-21300 | 64GB (8GB x 8) | CL15-17-17-35 | 1.20V | - | Preisvergleich |
| CMD32GX4M4A2666C15 | DDR4-2666 | PC4-21300 | 32GB (8GB x 4) | CL15-17-17-35 | 1.20V | - | Preisvergleich |
| CMD32GX4M4A2666C16 | DDR4-2666 | PC4-21300 | 32GB (8GB x 4) | CL16-18-18-35 | 1.20V | - | Preisvergleich |
| CMD16GX4M4A2666C15 | DDR4-2666 | PC4-21300 | 16GB (4GB x 4) | CL15-17-17-35 | 1.20V | - | Preisvergleich |
| CMD16GX4M4A2666C16 | DDR4-2666 | PC4-21300 | 16GB (4GB x 4) | CL16-18-18-35 | 1.20V | - | Preisvergleich |
| CMD128GX4M8A2400C14 | DDR4-2400 | PC4-19200 | 128GB (16GB x 8) | CL14-16-16-31 | 1.20V | - | Preisvergleich |
| CMD64GX4M4A2400C14 | DDR4-2400 | PC4-19200 | 64GB (8GB x 8) | CL14-16-16-31 | 1.20V | - | Preisvergleich |
| CMD32GX4M4A2400C14 | DDR4-2400 | PC4-19200 | 32GB (8GB x 4) | CL14-16-16-31 | 1.20V | - | Preisvergleich |
| CMD16GX4M4A2133C10 | DDR4-2133 | PC4-17000 | 16GB (4GB x 4) | CL10-12-12-31 | 1.35V | - | Preisvergleich |
Spezifikationen (allgemein)
| Speichertyp | DDR4 |
| Package Memory Pin | 288 |
| Package Memory Format | DIMM |
| Speicherkonfiguration | Dual, Quad Kits |
| Speichergröße | 64GB, 32GB, 16GB Kits, je 4GB oder 8GB Module |
| Performance Profile | XMP, Version 2.0 |
| Lüfter inbegriffen | variiert, Corsair Dominator Airflow Platinum LED Fan (Preisvergleich) |
| Heat Spreader | Platinum, Customizable Lightbar and DHX Cooling Technology |
| geprüfte Betriebsspannung | abhängig vom Kit entweder 1.20V oder 1.35V |
| Geschwindigkeit | PC4-26400 (3300MHz) PC4-25600 (3200MHz) PC4-24800 (3100MHz) PC4-24000 (3000MHz) PC4-23466 (2933MHz) PC4-22400 (2800MHz) PC4-21300 (2666MHz) PC4-19200 (2400MHz) PC4-17066 (2133MHz) |
| SPD Betriebsspannung | 1.2V |
| SPD Geschwindigkeit | 2133MHz |
| SPD Latenz | 15-15-15-36 |
| Garantie | Lebenslang |
[tr]
The world’s most advanced DDR4 memory modules
Dominator Platinum high-performance DDR4 memory is designed for world-class Intel X99 system builds. It's built with hand-screened ICs and incorporates patented DHX cooling for reliable performance in demanding environments. And, extracting maximum performance is easy -- built-in XMP 2.0 support gives you trouble-free, automatic overclocking. Dominator Platinum modules work with the Corsair Link system for temperature monitoring, and you can even enhance the subtle white LED lighting by adding a light bar kit to match or contrast it with your system.
Designed for Intel X99 systems
Dominator Platinum DDR4 modules are designed to take advantage of the improved clock speeds, bandwidth, and capacity of the DDR4 platform. Our modules are tested across multiple X99 Series motherboards for reliably fast performance.
XMP 2.0 support for trouble-free, automatic overclocking
Dominator Platinum is fully compatible with the XMP 2.0 standard supported by Intel X99-based motherboards. Turn it on, and it will automatically adjust to the fastest safe speed for your Dominator Platinum kit. You’ll get amazing, reliable performance while maintaining full data integrity.
Get more performance and Corsair Link control with a Dominator Airflow Platinum LED fan
Dominator Platinum DDR4 modules already have generous overclocking headroom, but to push them to extreme performance levels, you need active cooling. The Dominator Airflow Platinum (available separately) is designed for quiet operation and optimal cooling efficiency, and it works with Corsair Link for customization and control.
With Corsair Link, you can control PWM fan speed directly from your Windows desktop, and change the built-in LEDs from their default red to any of 16.8 million colors to indicate fan speed, ambient system temperature, or GPU temperature. Or, just set the LED lighting color to match your system or your style.
Compatibility tested across X99 Series motherboards for reliably fast performance
Part of our exhaustive testing process includes performance and compatibility testing on most every X99 Series motherboard on the market – and a few that aren’t.
Designed for Enthusiasts. Backed by Corsair.
World-famous reliability and performance
There's a reason why world-champion overclockers, extreme gaming enthusiasts and high-end system builders all trust Corsair for high-performance memory that they can install with confidence and pride. Whether you're breaking your own records or you're simply building a dream gaming rig, you can count on Corsair memory.
Lifetime limited warranty
Your performance investment is protected. All of our memory products are backed by a limited lifetime warranty.
The Corsair Advantage
With a long history of building enthusiast-grade memory and components, we've earned a reputation for quality, compatibility, and performance. Need help? We're available by phone call, email or web forum.
Reviews
- Corsair Dominator Platinum 16GB DDR4-3200 (CMD16GX4M4B3200C16) @ Tweaktown
- Corsair Dominator Platinum 16GB DDR4-3200 (CMD16GX4M4B3200C16) @ Legit Reviews
- Corsair Dominator Platinum 16GB DDR4-3300 (CMD16GX4M4B3300C16) @ Legit Reviews
- Corsair Dominator Platinum 16GB DDR4-3400 (CMD16GX4M4B3400C16) @ PC Perspective
- Corsair Dominator Platinum 16GB DDR4-3400 (CMD16GX4M4B3400C16) @ Hardware Canucks
Bilder
HARDWARELUXX OC Ergebnisse
| Takt | Rating | Timings | Spannung | Menge | Model | Version | Plattform | Test | User | Screen |
| 2000 MHz | DDR4-4000 | 17-25-25-36 1T | 1.50V | 2x4GB | CMD16GX4M4A3300C16 | V5.29 | X99 | 32M | websmile | Beispiel-Screen |
Noch keine Einträge.
Bitte macht im Screenshot vier CPUz Tabs (CPU, Mainboard, Memory, SPD) sichtbar und blendet die Vdimm mit einem Monitoring Tool ein.
Ob Prime, SuperPI, Linx, OCCT oder ein anderes Tool für den Stabilitätstest verwendet wird, ist euch selbst überlassen.
Nützliche Links
- [Sammelthread] http://www.hardwareluxx.de/communit...views-overclocking-ic-oc-liste-n-1024406.html
- [Sammelthread] http://www.hardwareluxx.de/communit...corsair-link-ddr3-1600-bis-2800-a-895769.html
- [Übersicht] http://www.hardwareluxx.de/communit...ds-news-reviews-specs-bilder-x99-1023557.html
- [Artikel] http://www.hardwareluxx.de/communit...ysterium-der-ddr4-taktfrequenzen-1036463.html
- Corsair DDR4 F.A.Q.: Corsair DDR4 FAQ and Whitepaper
- Corsair DDR4 Whitepaper (PDF-Download)
