Minutourus
Sehe ich auch so, wer sich mit dem Thema ernsthaft auseinandersetzt für den sollten die paar Stunden kein Problem darstellen....
Kompletter Run bis 1344k!
07-10-2013, 08:59 AM
HMB n00bie, 3.1 Years
Status: HMB is offline
If you want to run it properly on a 4 core cpu with HT enabled then change the contents of "runme_xeon64.bat" to the following:
Code:
@echo off
SETLOCAL
rem Setting up affinity for better threading performance
set KMP_AFFINITY=nowarnings,compact,granularity=fine
rem Setting path to OpenMP library
set PATH=..\..\..\redist\intel64\compiler;%PATH%
echo Running linpack_xeon64.exe. Output can be found in win_xeon64.txt.
start /b /affinity 55 linpack_xeon64.exe lininput_xeon64 > win_xeon64.txt
echo.
echo When this window closes the calculation is done.
ENDLOCAL
The important piece was adding "start /b /affinity 55", the rest is mostly cosmetical.
Edit: I might aswell paste the numbers i got running it, i7-4770K (HT on) @ 4200MHz, ram at 1600MHz, only touched the multiplier on the CPU. Running fixed Vcore at 1.215V, Noctua DH14, max temp: 93 degrees Celsius.
Code:
Intel(R) Optimized LINPACK Benchmark data
Current date/time: Wed Jul 10 16:04:37 2013
CPU frequency: 4.194 GHz
Number of CPUs: -1
Number of cores: 1
Number of threads: 4
Parameters are set to:
Number of tests: 12
Number of equations to solve (problem size) : 1000 2000 3000 4000 5000 10000 15000 20000 25000 30000 35000 40000
Leading dimension of array : 1000 2000 3000 4000 5000 10000 15000 20000 25000 30000 35000 40000
Number of trials to run : 4 4 4 4 4 2 2 2 2 1 1 1
Data alignment value (in Kbytes) : 4 4 4 4 4 4 4 4 4 4 4 4
Maximum memory requested that can be used=4210869504, at the size=40000
=================== Timing linear equation system solver ===================
Size LDA Align. Time(s) GFlops Residual Residual(norm) Check
1000 1000 4 0.006 113.2085 1.194739e-012 4.074366e-002 pass
1000 1000 4 0.006 112.8564 1.194739e-012 4.074366e-002 pass
1000 1000 4 0.006 117.0292 1.194739e-012 4.074366e-002 pass
1000 1000 4 0.005 129.1411 1.194739e-012 4.074366e-002 pass
2000 2000 4 0.044 121.9598 4.536926e-012 3.946570e-002 pass
2000 2000 4 0.042 128.0727 4.536926e-012 3.946570e-002 pass
2000 2000 4 0.042 128.5855 4.536926e-012 3.946570e-002 pass
2000 2000 4 0.042 128.6219 4.536926e-012 3.946570e-002 pass
3000 3000 4 0.129 139.9257 8.334888e-012 3.209566e-002 pass
3000 3000 4 0.126 143.0048 8.334888e-012 3.209566e-002 pass
3000 3000 4 0.131 137.8053 8.334888e-012 3.209566e-002 pass
3000 3000 4 0.132 136.6785 8.334888e-012 3.209566e-002 pass
4000 4000 4 0.279 152.9169 1.519912e-011 3.312792e-002 pass
4000 4000 4 0.275 155.5023 1.519912e-011 3.312792e-002 pass
4000 4000 4 0.275 155.4596 1.519912e-011 3.312792e-002 pass
4000 4000 4 0.274 155.7175 1.519912e-011 3.312792e-002 pass
5000 5000 4 0.531 156.9110 2.471656e-011 3.446525e-002 pass
5000 5000 4 0.512 162.8201 2.471656e-011 3.446525e-002 pass
5000 5000 4 0.509 163.9433 2.471656e-011 3.446525e-002 pass
5000 5000 4 0.514 162.2297 2.471656e-011 3.446525e-002 pass
10000 10000 4 3.541 188.3203 9.436774e-011 3.327502e-002 pass
10000 10000 4 3.553 187.6777 9.436774e-011 3.327502e-002 pass
15000 15000 4 11.374 197.8607 2.169435e-010 3.416896e-002 pass
15000 15000 4 11.378 197.7890 2.169435e-010 3.416896e-002 pass
20000 20000 4 26.093 204.4265 3.504283e-010 3.102058e-002 pass
20000 20000 4 26.077 204.5550 3.504283e-010 3.102058e-002 pass
25000 25000 4 51.053 204.0617 5.194889e-010 2.954147e-002 pass
25000 25000 4 50.811 205.0333 5.194889e-010 2.954147e-002 pass
30000 30000 4 86.056 209.1864 7.133177e-010 2.811906e-002 pass
35000 35000 4 135.915 210.3207 1.085449e-009 3.150893e-002 pass
40000 40000 4 202.414 210.8051 1.338275e-009 2.976370e-002 pass
Performance Summary (GFlops)
Size LDA Align. Average Maximal
1000 1000 4 118.0588 129.1411
2000 2000 4 126.8100 128.6219
3000 3000 4 139.3536 143.0048
4000 4000 4 154.8991 155.7175
5000 5000 4 161.4760 163.9433
10000 10000 4 187.9990 188.3203
15000 15000 4 197.8248 197.8607
20000 20000 4 204.4907 204.5550
25000 25000 4 204.5475 205.0333
30000 30000 4 209.1864 209.1864
35000 35000 4 210.3207 210.3207
40000 40000 4 210.8051 210.8051
Residual checks PASSED
End of tests
...ich mache jeden Tag OC-Sets und keins wäre so zu vertreiben... es ist ja so, dass sich die User an was klammern und was im I-Net lesen, was in der Realität so nicht funktioniert... ich telefoniere viel oder bekomme eMails deswegen... entweder stabil in allen lebenslagen oder nur halb... ich kauf mir doch kein Auto, aber darf den 5. Gang nicht verwenden, weil evt. das Auto zu heiß wird *Hallo*Das hast du bisher nicht einmal näher ausgeführt....
Wenn es dich beruhigt dann post halt Deine Ergebnisse mit 22h prime custom rum. Ich denke dir wird keiner deswegen böse sein.
...jeder macht für sich das was er braucht, nur diese listen sind augenwischerei und sagen nichts aus ...die meisten schauen eh nicht mehr drauf bzw. vergleichen sich damit :-/
ist nur meine meinung und nicht böse gemeint !!!
nochmal meine Meinung: es geht doch bei einer OC-LISTE nicht um Stabiliät! Es gibt Rahmenbedingungen, die jeder einhalten muss, egal welcher Test und wie lange. Nicht mehr und nicht weniger. Mit Alltagsstabilität hat das rein garnichts nichts zu tun... Das wäre ja so, dass die RAM-Bencher auch noch einen Prime-Screen (statt nur SuperPi) abliefern müssten, was in den meisten Fällen unmöglich ist.
Dann können wir uns auch gleich auf SuperPi einigen? So einfach ist es dann doch nicht.
