mru
Genauso wie nuts es geschrieben hat.
Wo ist der Danke button?
Und jetzt legen wir uns alle wieder hin.
Bis zum nächsten mal.
Ah, da ist doch was, bin also nicht der einzige
DH77EB + HD 4000 and 23.976Hz
Intel DH77EB - Problem with KNC TV-Station DVB-S2 Twin Card & 23.976 hz
BIOS Version 0101 - EBH7710H.86A.0101.2013.0516.1649 About This Release: Date: May 20, 2013
New Fixes/Features: • Fixed issue where videos with 23.976 Hz format will show as 24.001 Hz.
Das klingt wieder nach einem Wind-Eiviel besser hin bekommen hat
Aber vielen Dank für den Hinweis. Versuchs mal mit dem Google Cache, da kann mans noch sehen, zumindest den Text... Intel has historically struggled to deliver competitive refresh rate accuracy with its GPUs and chipsets. This is no longer the case with 4th generation Intel Core HD graphics, with refresh rate precision for 24p, 29.97 & 59.94 content that is consistent with, or better than, what other vendors provide out of the box. Also worth noting, is that unlike previous generation Core HD graphics where there was occasional drift in the refresh rate, Haswell GPUs exhibiting much less variation once playback begins.
Talking of display refresh rate support, Intel has finally fixed the 23.976 Hz bug which has been plaguing Intel-based HTPCs since 2008. This is going to make HTPC enthusiasts really happy. The fact that Intel manages the best match for the required refresh rate compared to AMD and NVIDIA cards is just icing on the cake
The good news is that the display refresh rate accuracy is excellent.
Even better news is that the set of display refresh rates obtained with the Haswell system is more accurate than anything I had obtained before with AMD or NVIDIA cards. The gallery below presents some of the other refresh rates that we tested out. madVR reports frame drops / repeats only once every 6 hours or more in the quiescent state.
Och menno, Quicksync ist dafür schlechter. Naja, irgendwas ist ja immer.AnandTech | Intel's Haswell - An HTPC Perspective: Media Playback, 4K and QuickSync Evaluated
Der Hoffnung kann ich mich nur anschließen ...However, it makes its appearance under the advanced display settings. Input range (Full / Limited for 0 - 255 / 16 - 235) is under advanced video settings, but the YCbCr / RGB setting is under the Display settings. It would make sense to have both settings under one category as users usually modify both when trying to calibrate and ensure that their setup is working optimally
As I found out when trying to calibrate using Spears & Munsil's HD Benchmark, the mixture of settings in the control panel makes it very difficult to calibrate the correct output color space (amongst other things). For example, there is no way to choose YCbCr 4:2:2 / YCbCr 4:4:4 / Limited RGB / Full RGB. This is just one of the missing features in the configuration utility. I hope Intel's engineers try to calibrate a few displays by driving them using an Intel GPU and using the HD Benchmark 2nd Edition calibration disk (just to understand how badly the layout of the control panel is designed)
So wie beim 24p Bug?Der negative Punkt scheint ja per Software leicht behebbar zu sein. Denke das fixt Intel auch irgendwann, sofern sich genug Leute beschweren.
*SCNR*1 drop alle 15 min passt zwar wohl besser, bei perfektem Timing geht das auf Tage. Die 6 Stunden ist bei mir eher ein anderer Wert. Dass sie anscheinend die angezeigten 23,97605 Hz meinen klingt mal wieder nach nicht verstandenem Problem. Die Zahl ist relativ zum CPU-Timer. Darum geht es bei dem Problem aber gar nicht.Hier noch der Link zum Anandtech Test: AnandTech | Intel's Haswell - An HTPC Perspective: Media Playback, 4K and QuickSync Evaluated
24p Wiedergabe scheint diesmal wirklich (s. Screenshot) zu funktionieren.![]()
Bei den 3 Radeon Karten mit denen ich das getestet habe war es bislang immer perfekt mit HDMI-Ausgabe und ist es bei entsprechender Umsetzung dann auch bei jeder Karte.Even better news is that the set of display refresh rates obtained with the Haswell system is more accurate than anything I had obtained before with AMD or NVIDIA cards.
Die Anantech Ergebnisse sind zwar ganz schön anzuschauen, aber ich glaubs erst, wenn ich hier selbst die 23,976 gesehen hab. Aber so wie es aussieht, war meine Vermutung über den neuen Taktgeber bei Intel richtig und das 24p-Bug-Problem hat sich in Luft aufgelöst.klingt mal wieder nach nicht verstandenem Problem
