[Sammelthread] CyanogenMod
PT-BR: Add missing translation (android_packages_apps_Settings)
PT-BR: Add missing translations (android_packages_apps_Email)
PT-BR: Add missing translations (android_packages_apps_CMParts)
Added Czech translation. (android_packages_apps_ADWLauncher)
Added Czech translation. (android_packages_apps_AndroidTerm)
Czech translation - added missing strings and corrected exists string to be consistent. (android_packages_apps_Camera)
qsd8k:final fix for kernel panic (android_external_v8)
Traditional Chinese: Update translations for account color (android_packages_apps_Email)
res: strings: Set default account color translatable=false (android_packages_apps_Email)
Traditional Chinese: Update translations for application storage (android_packages_apps_CMParts)
Update Russian translation. Email - Account color (android_packages_apps_Email)
extend translation (cmparts/de) (android_packages_apps_CMParts)
Update Russian translation. CMParts (android_packages_apps_CMParts)
bashrc: set alias ls="busybox ls --color=auto" (android_external_bash)
Log Wifi NativeCommand exceptions (android_frameworks_base)
Fix: Do not change music volume if screen off and no music playing (android_frameworks_base)
extend translation (settings/de) (android_packages_apps_Settings)
extend translation (camera/de) (android_packages_apps_Camera)
Added Czech translation. (android_packages_apps_CMStats)
Add 'Mark All Read' Option to the Menu in Messaging App (android_packages_apps_Mms)
settings: Updated Italian translations (android_packages_apps_Settings)
camera: Updated Italian translations (android_packages_apps_Camera)
Fix exception in legacy USB support (android_frameworks_base)
Allow lower end devices to enable animated GIF support (android_external_webkit)
SystemUI: Show mic-less headphone icon in status bar (2/2) (android_vendor_cyanogen)
SystemUI: Show mic-less headphone icon in status bar (1/2) (android_frameworks_base)
Updated Ukrainian translation (android_packages_apps_Camera)
Updated Ukrainian translation (android_packages_apps_Settings)
Fix build error in init when building with bootchart (android_system_core)
Update Russian translation. Matrix metering (android_packages_apps_Camera)
Notification PowerWidget: Additional SoundMode: Vibrate/Silent (android_frameworks_base)
Traditional Chinese: Update translations (android_packages_apps_Camera)
Allow editing of contact birthdays also for Exchange contacts. (android_packages_apps_Contacts)
Update Russian translation. Settings - Additional storage (android_packages_apps_Settings)
Revert "Change Finnish time format to use ':' instead of '.'" (android_frameworks_base)
Camera Timer (android_packages_apps_Camera)
Update Russian translation. Contacts (android_packages_apps_Contacts)
Updated Dutch translations (android_packages_apps_Settings)
Don't inherit FM app, as it doesn't work properly with the Defy audio stack. (android_vendor_cyanogen)
libaudio-qdsp5v2: use new gb method for verify call state (android_hardware_msm7k)
libaudio-qsd8k: use new gb method for verify call state (android_hardware_msm7k)
allow TARGET_SKIA_USE_MORE_MEMORY set to false to override vfp condition (android_external_skia)
Restore pre-openvpn results of needKeyStoreToSave for L2TP_IPSEC_PSK and L2TP (android_packages_apps_Settings)
PT-BR: Add missing translations (android_packages_apps_DSPManager)
Updated Swedish translations (android_packages_apps_Camera)
ide: eclipse: Add theme classes to classpath (android_development)
Set translatable=false (android_packages_apps_DeskClock)
Updated Swedish translations (android_packages_apps_CMParts)
Music: Bluetooth AVRCP 1.3 feature changes (android_packages_apps_Music)
frameworks/base: bluetooth: AVRCP 1.3 feature changes (android_frameworks_base)
Bluez: Changing AVRCP connect timeout to four seconds. (android_external_bluetooth_bluez)
Bluetooth: Ignore the Genre attribute length for AVRCP 1.3 Metadata request (android_external_bluetooth_bluez)
Bluetooth: AVRCP 1.3 feature changes (android_external_bluetooth_bluez)
LGEStarRIL: Modify p999 exclusion logic (android_frameworks_base)
LGEStarRIL: Ignore SCREEN_ON/SCREEN_OFF events on star (android_frameworks_base)
libaudio-msm7x30: CAF Compatibility (android_hardware_msm7k)
libaudio-msm7x30: aic3254: slight performance improvment (android_hardware_msm7k)
libaudio-msm7x30: use the correct acdb for known bt devices (android_hardware_msm7k)
libauido-msm7x30: AIC3254: Updated dsp profile switch (android_hardware_msm7k)
libaudio-msm7x30: fix wrong LPA ifdef (android_hardware_msm7k)
libaudio-msm7x30: Add Desire HD and Inspire 4G DSP Profile support (android_hardware_msm7k)
libaudio-msm7x30: fix for notification with no mic headset (android_hardware_msm7k)
libaudio-msm7x30: code cleanup (android_hardware_msm7k)
Set to properly update the calendar app when display name or account color is changed in Email (Exchange) (android_packages_apps_Email)
Add customizable account 'color' chip - (credit to copolii) (android_packages_apps_Email)
add droid2we (droid2 global) support (1/2) (android_vendor_cyanogen)
Mal wieder ein ordentliches Changelog :)
In der Build #117
Aufm LG 2x zumindest isn bug drin in der GUI. Mobiles Netzwerk wird nurnoch als G oder H dargestellt.
Mir fallen keine Änderungen auf, außer SMS make all Read.
Ansonsten mit dem Klingelmodus wechseln in der Benachrichtigungszeile, kann ich nicht sagen ob das vorher schon war.
Kernel ist auch noch gleiche Version.
ich habe ein HTC HD 2 mit Froxo 2.2 drauf und würde vielleicht auch gerne mal dieses rom testen.
Wer hat eine genaue Anleitung wie ich jetzt das cyanogen rom in der neusten version auf mein handy bekommen, in deutsch wäre noch gut.
Ist das echt merkbar schneller wie das froyo auf dem htc hd 2?
gleich auch mal den fred hier abonniert :)hab die nightly 117 vom 23.08 auf meinen LG Optimus Speed laufen.
Mhhn bin noch schwer am überlegen ob ichs auf mein lg p990 Otpimus speed packe... weil eig. bin ich bis jetzt schon recht zufrieden was das ganze angeht mit geschwindigkeit, aber halt android 2.2.2 nur drauf :(
Ich habe ein paar Fragen:
1. Wann wird das Samsung Galaxy S Plus und Galaxy S2 unterstützt?
2. Funktionieren alle Apps mit dem Mod?
3. Kann man die Android-Version von Samsung wiederherstellen?
als erstes alles löschen mit task29 (handy einschalten mit power und volumen down gedrückt halten --> bootmanager)
--> radio rom flashen (2.15 empfohlen)
--> magldr 1.13 installieren
--> cwm 3.0.2.5 150/5 installieren
--> via cwm cyanogenmod installieren
der erste bootvorgang dauert ca.5-10minuten
detailierte infos hier -->
Weitere fragen:
1. Zum Galaxy S Plus kannst du noch nichts sagen?
2. Cyanogenmod sieht bzw. bedient sich wie Android oder ist es komplett anders?
1. Ich weiß nicht mal was das ist.
2. Es ist Android mit anderem Luncher und vielen Optimierungen/Zusatzoptionen
Würde das Nexus aber deutlich beiden vorziehen.
So habe mal ein paar Bilder in den Startpost geschmissen.
ich hab momentan auf meinem HD2 ne CM Version von seadersn laufen, würde aber wohl gerne mal das Originale CM testen
wo find ich infos zum installieren mit clk?
Soviel ich weiss gibts kein "Originales" CM für das HD2. (Wird hier nicht aufgeführt: CyanogenMod Mirror Network - Powered by TDRevolution)
Allerdings gibt es diverse Leute, die es selbst kompilieren. Im XDA gibt es diverse Versionen.
Diese Version scheint immer aktuell zu sein, weil sie von den Desire nightlies geportet wird: [23.AUG.11][MAG/cLK] TyphooN CyanogenMod 7 Nightly v3.6.0 [2.3.5][A2SD][tytung r11] - xda-developers
Diese Version scheint auch aktuell zu sein und wird vom Sourcecode kompiliert: [Daily] MAGLDR / cLK Cyanogen Nightlies 2.3.5 [kernel: charnsingh_online latest] - xda-developers
Welche Version besser ist oder ob es noch bessere gibt kann ich dir leider nicht sagen. ;)
Wer hat hier denn schon Erfahrungen mit Cyanogen?
Würde das gern mal ausprobieren, weil mein Galaxy S auch manchmal hakt oder sich aufhängt.
Nur scheinen die Nightlys ja auch weit weg von Fehlerfrei zu sein, ist ja dann auch irgendwie jacke wie hose....oder nicht?!
Also bei mir laufen die Nightlys ohne Probleme.
Habe ja ein sehr ähnliches Gerät.
Was nicht funktioniert ist Videotelefonie, sonst gibt es nichts was mir bekannt ist.
Hab ein HTC Sensation. Hin und wieder habe ich diese Bekannten Microrukler.
Gibts für das Sensation was?
Wenn ich auf den CM7 flashe, sind meine Daten weg, oder?
Dann müsste ich alle Apps wieder installieren, sprich MyTracks etc.
Läuft das ganze dann schneller als mit dem normalen 2.3.3?
Stabilität ist kein Problem, läuft seit 6 Wochen mit nur 2 Abstürzen.
Letzte Frage noch... ich weis das ist hier einiges.
Wenn ich den CM7 mal testen wollte, kann ich dann ein Backup machen und dann einfach ne andere Speicherkarte einbauen und testen und im Notfall das Backup wieder laden?
Grüße, xXRadioaktivXX
Aus erfahrung mit dem HTC Desire/HD kann ich sagen, dass CM einiges schneller ist als ein standard Sense ROM. Beim Sensation wird das wohl gleich sein.
CyanogenMod scheint noch nicht fertig zu sein für das Sensation. Es ist noch in Entwicklung. Allerdings kann ich schon mal sagen, dass du alle Daten (Apps und Einstellungen) verlieren wirst beim flashen. Mit den Daten von einem Sense ROM kann CM nicht viel anfangen ;)
Deshalb kannst du dich schon mal erkundigen von wegen Backup machen. Damit du ein komplettes Backup machen kannst brauchst du root und Clockworkmod: [Guide] to Installing S-off, ClockWork, Root, SuperCID & S-on [03/AUG/11](noobproof) - xda-developers
Schneller, das Sensation wird mehr als schneller sein.
Mein Handy ist Stock fast so schnell wie das Sensation, nun ist meins fast doppelt so schnell.
Und ansonsten nichts sichern, CM7 sauber installieren und gut.
Ich denke mal in ca. 2 Wochen wird da was für das Sensation da sein.
Grad mal kurz die Testversion von CM7 fürs Xperia arc geflasht. Nette Sache, kann ich mich definitiv mit anfreunden. Die Jungs müssen es aber noch schaffen, dass GSM und 3G laufen und müssen die Kamera zum laufen kriegen. Wenn das geschafft ist, steig ich auf CM7 um. Bis dahin muss ich mich wohl noch mit dem Stock-ROM begnügen. Das bisher geschaffte überzeugt mich aber, nur als Daily-ROM ists halt noch nicht zu gebrauchen. Das wird noch. :)
http://www.hardwareluxx.de/community/f62/cyanogenmod-7-a-826046.html
Mhh, dachte eingentlich ich hätte mit meinem smartmobil für 10€ jetzt ein Schnäppchen gemacht und hätte erstmal Ruhe....
Das die großen Konzerne nicht einfach direkt atraktive Preise anbieten können, nein, dass muss alles üb sub-tochter-gesellschaften laufen :rolleyes:
Gibt es eine gute DAU Anleitung fürs Flashen von Cyanogen? Hab so viele gefunden und frag mich mit welcher man am besten fährt.
Jopp :)
Hab ich ne möglichkeit meine Kontakte mit allen darin enthaltenen Informationen ohne google Synchronisation mitzunehmen?
Ja genau, hab die 2.3.3, da muss man ja vorher noch rooten oder so ähnlich :confused:
Aber danke schonmal,
ne SD Karte brauch ich auch oder? 2GB sollten ja reichen.
Die Jungs müssen es aber noch schaffen, dass GSM und 3G laufen und müssen die Kamera zum laufen kriegen. Wenn das geschafft ist, steig ich auf CM7 um. :)
Was klappt denn daran nicht?
Schreib doch mal deine genaue Versionsnummer hin: Menutaste auf Homescreen -> Einstellungen -> Über das Telefon -> Build-Nummer
SD brauchst du eigentlich nicht, da der interne Speicher genutzt werden kann.
Naja per GSM hat man zwar Empfang, aber das Netz wird nicht erkannt. Sprich: Nur Notrufe. 3G funktioniert dementsprechend auch nicht. Die Kamera musste von Grund auf entwickelt werden, was Zeit kostet, da der Sensor brandneu ist. Die Kamera ist in Arbeit aber bis jetzt eben nicht funktionstüchtig. Bin zuversichtlich, dass das noch wird. Das Xperia arc bzw. die ganze neue Xperia Reihe brauchen leider noch etwas Zeit, da SE sehr spezielle Treiber für viele Dinge hat. Bisher siehts aber gut aus und ich denke wir werden in einigen Wochen ein volles CM7, auch mit Nightly Builds, auf dem Xperia arc und dem Xperia neo sehen. :)
