[Sammelthread] Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) (Intel Z68)
Asus P8Z68-V(/GEN3) / P8Z68-V Pro(/GEN3) / P8Z68 Deluxe(/GEN3) - Sammelthread
xxxInhaltsverzeichnis:
Ein Hinweis vorweg: Die Mainboard-Modelle mit PCI-Express der 3. Generation (GEN3) sind mit den Vorgängermodellen zu 100% identisch, was die Ausstattung angeht. Lediglich die PCI-Express 3.0 Kompatibilität wurde jeweils für die ersten beiden PCI-Express x16 Slots ergänzt.
xxxP8Z68-V(/GEN3)
Spezifikationen:
CPU:
Intel® Socket 1155 The 2nd Generation Core™ i7/Core™ i5/Core™ i3 Processors
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
Chipset:
Intel® Z68
Memory:
4 x DIMM, Max. 32GB, DDR3 2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 Hz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUSTeK Computer Inc. or user manual for the Memory QVL (Qualified Vendors Lists).
* Due to CPU behavior, DDR3 2200/2000/1800 MHz memory module will run at DDR3 2133/1866/1600 MHz frequency as default.
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
Maximum shared memory of 1748 MB
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD® Quad-GPU CrossFireX™ Technology
Expansion Slots:
2 x PCIe 2.0 x16 (x16 or dual x8)
(beim GEN3-Modell sind es 2x PCIe 3.0 x16 Slots, x16 or dual x8)
1 x PCIe 2.0 x16 (x4 mode, black) *1
2 x PCIe x1
2 x PCI
Storage:
Intel® Z68 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Support Intel® Smart Response Technology
JMicron® JMB362 controller : *2
1 x eSATA 3G port(s), red
LAN:
Intel® 82579, 1 x Gigabit LAN Controller
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
12 x USB 2.0 port(s) (6 at back panel, black+red, 6 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 2 with DIGI+ VRM :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- ASUS DIGI+ VRM Utility
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
ASUS BT Turbo Remote :
- Exclusive Smartphone Interface supporting iPhone, Android, Windows Mobile, and Symbian systems
ASUS Exclusive Features :
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU/DRAM/VGA/Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x Bluetooth module(s)
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
2 x USB 3.0
6 x USB 2.0
1 x Optical S/PDIF out
6 x Audio Jack(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
2 x Chassis Fan connector(s) (1 x 4 -pin, 1 x 3 -pin)
2 x Power Fan connector(s) (3 -pin)
1 x S/PDIF out Header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
2 x Serial ATA 3.0Gb/s cable(s)
2 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: The PCIe x16_3 slot shares bandwidth with PCIe x1_1 slot, PCIe x1_2 slot, USB3_34 and eSATA. The PCIe x16_3 default setting is in x1 mode.
*2: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS-Updates, Treiber und Co.
- CPU-Support List
- Qualified Vendor List
- Geizhals-Link
xxxP8Z68-V Pro(/GEN3)
Spezifikationen:
CPU:
Chipset:
Intel® Z68
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe x1
2 x PCI
Storage:
Marvell® PCIe SATA 6Gb/s controller : *2
2 x SATA 6Gb/s port(s), navy blue
LAN:
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Surround Sensation UltraPC
IEEE 1394:
VIA® 6308P controller
2 x IEEE 1394a port(s)
(2 at mid-board)
USB Ports:
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger+
- Anti-Surge
- Disk Unlocker
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI
1 x D-Sub
1 x HDMI
1 x eSATA 3Gb/s
2 x USB 3.0
6 x USB 2.0
6 x Audio Jack(s)
Internal I/O Ports:
4 x SATA 6Gb/s connector(s)
2 x IEEE 1394a connector(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
1 x ASUS USB 3.0 Bracket(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
UEFI-Screens:
Reviews:
Test: ASUS P8Z68-V Pro - was kann Intels neuer Chipsatz? - Hardwareluxx
ASUS P8Z68-V Pro (Intel Z68) Motherboard Review :: TweakTown USA Edition
ASUS P8Z68-V PRO Review: Our First Z68 Motherboard - Anandtech
ASUS P8Z68-V PRO and Intel Z68 chipset review - Hexus
Wichtige Links:
- Herstellerseite
- CPU-Support List
- Geizhals-Link
xxxP8Z68 Deluxe(/GEN3)
Spezifikationen:
CPU:
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z68
Memory:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1
2 x PCI
Storage:
Marvell® PCIe 9128 controller :
1 x Power eSATA 3Gb/s port(s), green
LAN:
Realtek® 8111E , 1 x Gigabit LAN Controller
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Bluetooth:
Bluetooth V2.1+EDR
ASUS BT GO! Utility
Audio:
Realtek® ALC 889 8-Channel High Definition Audio CODEC
Audio Feature :
- Coaxial and Optical S/PDIF out ports at back panel
IEEE 1394:
VIA® 6315N controller
(1 at mid-board, 1 at back panel)
USB Ports:
NEC® USB 3.0 controller :
12 x USB 2.0 port(s) (8 at back panel, , 4 at mid-board)
Special Features:
ASUS TPU :
- Auto Tuning
- TurboV
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS BT GO! :
- Folder Sync
- BT Transfer
- Shot & Send
- BT to Net
- Music Player
- Personal Manager
- MemOK!
- AI Suite II
- AI Charger
- Anti-Surge
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
2 x LAN (RJ45) port(s)
2 x USB 3.0
8 x USB 2.0
1 x Coaxial S/PDIF out
6 x Audio Jack(s)
1 x Clear CMOS button(s)
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, blue)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
2 x Power Fan connector(s) (2 x 3 -pin)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Power-on switch(es)
1 x Reset switch(es)
Accessories:
User's manual
ASUS Q-Shield
4 x Serial ATA 6.0Gb/s cable(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
*1: Compatible with PCIe x1 and x4 devices.
*2: These SATA ports are for data hard drives only. ATAPI devices are not supported.
UEFI-Screens:
folgt
Reviews:
folgt
Wichtige Links:
- Herstellerseite
- UEFI/BIOS- Updates, Treiber und Co.
- CPU-Support List
- Geizhals-Link
xxxKompatibilität - Arbeitsspeicher
In der Regel gibt es da selten Fälle, wo der Arbeitsspeicher rumzickt. Dennoch sollte man die RAM-Kits, die Art der RAM-Konfiguration und das jeweilige Board-Modell in einer Liste sammeln:
2*2 GB:
G.Skill ECO DIMM Kit 4GB PC3-12800U CL7-8-7-24 (DDR3-1600) (F3-12800CL7D-4GBECO) (P8Z68-V Pro)
1*4 GB:
2*4 GB:
G.Skill RipJaws DIMM Kit 8GB PC3-12800U CL7-8-7-24-2T (DDR3-1600) (F3-12800CL7D-8GBRH) (P8Z68-V Pro)
TeamGroup Elite DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (TED38192M1333HC9DC) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-8GBXH) (P8Z68-V Pro)
G.Skill ECO DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (F3-12800CL8D-8GBECO) (P8Z68-V Pro)
Corsair Vengeance DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600) (CMZ8GX3M2A1600C8) (P8Z68-V, P8Z68-V Pro)
Kingston HyperX blu. DIMM Kit 8GB PC3-10667U CL9-9-9 (DDR3-1333) (KHX1333C9D3B1K2/8G) (P8Z68 Deluxe)
Corsair Vengeance DIMM Kit 8GB PC3-14900U CL9-10-9-27 (DDR3-1866) (CMZ8GX3M2A1866C9) (P8Z68 Deluxe)
Corsair Vengeance blau DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMZ8GX3M2A1600C9B) (P8Z68-V)
Corsair XMS3 DIMM Kit 8GB PC3-10667U CL9-9-9-24 (DDR3-1333) (CMX8GX3M2A1333C9) (P8Z68-V Pro)
Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) (P8Z68-V Pro)
Kingston HyperX DIMM Kit 8GB PC3-10667U CL7-7-7-20 (DDR3-1333) (KHX1333C7AD3K2/8G) (P8Z68-V Pro)
exceleram Sandy Bridge Rippler DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (ERS303A) (P8Z68-V Pro)
G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL) (P8Z68 Deluxe)
Hynix DIMM 4GB PC3-10667U CL9 (DDR3-1333) (P8Z68 Deluxe)
xxxKompatibilität - CPU-Kühler
Hier befindet sich die Liste der kompatiblen CPU-Kühler. Sollten unten stehende Bemerkungen fehlerhaft sein, bitte bescheid geben.
- Scythe Mugen 2 Rev. B Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
- Noctua NH-D14 Achtung! Der oberste PCIe x1 Slot ist nicht mehr verwendbar! RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Scythe Shuriken Rev.B RAM-Module mit höheren Heatspreadern sollten vermieden werden.
- Thermalright Archon Es sind keine Probleme bekannt.
- Prolimatech Armageddon Es sind keine Probleme bekannt.
- Coolink Corator DS Der 1. RAM-Slot wird verdeckt. RAM-Module mit höhere Heatspreader sind nicht verwendbar!
- Thermalright Silver Arrow Es sind keine Probleme bekannt.
- Prolimatech Genesis Es sind keine Probleme bekannt.
- Corsair Hydro Series H70 Es sind keine sonderbaren Probleme bekannt.
- Thermalright Venomous X-Black Es sind keine Probleme bekannt.
- Thermalright Ultra-120 In Verbindung mit Sockel 1156-Halterungen gibt es keine Probleme.
- EKL Alpenföhn Brocken Es sind keine Probleme bekannt.
- Scythe Mugen 3 Solange keine Module mit erhöhten Heatspreadern eingesetzt werden (z.B. diese RipJaws), gibt es keine Probleme.
xxxWeitere Infos
- Lucid Logix Virtu ist nur mit dem P8Z68-V und der Pro-Variante effektiv nutzbar. Das P8Z68 Deluxe bietet keinerlei Grafik-Ausgänge.
- Die USB3.0-Box als Front Panel, was normalerweise nur beim P8Z68 Deluxe dabei ist, gibt es separat nachzukaufen und ist somit bei den kleineren Boards ebenfalls nutzbar: Hardwareluxx - Preisvergleich
Hier sind noch ein paar Links zu anderen, passenden Themen:
http://www.hardwareluxx.de/community/f11/intel-sandy-bridge-lga1155-faq-infos-auf-seite-1-part-5-a-775738.html
http://www.hardwareluxx.de/community/f139/sammelthread-oc-prozessoren-intel-sockel-1155-sandy-bridge-laberthread-3-a-780949.html
http://www.hardwareluxx.de/community/f11/der-sockel-lga1155-quatschthread-part-5-a-789828.html
Sonstige Downloads:
- Lucid Virtu Treiber:
lucidlogix_downloads
Wie aktiviere ich das SSD-Caching Feature? (Intel Smart Response Technology)
Au-Ja! - Intels Smart Response Technology mit dem Z68-Chipsatz - 2/4
Wie richte ich mein System mit Virtu ein?
Klick
Bekannte Probleme und deren Lösungen:
DIE ANWENDUNG DER HIER BESCHRIEBENEN LÖSUNGEN ERFOLGT AUF EIGENE GEFAHR!
Einige Probleme und Lösungen, die bereits im Forum besprochen wurden.
Probleme
1. Der Rechner bootet gelegentlich nicht
2. Doppel-Boot nach Overclocking
3. Standby-Bug (S3), Monitor bleibt schwarz
4. CPU-Fan-Bug
5. Instabiles System wegen falscher RAM-Einstellungen
6. Kompatibilitätsprobleme mit der Tastatur
7. Die CPU-Temperaturen sind nach dem BIOS-Update um ca. 15 C° niedriger
8. Zeigergeschwindigkeit der Maus verlangsamt sich
9. No Physical Disk (beim Bootvorgang)
10. Microsoft .Net3.5 Framework lässt sich unter Windows 7 nicht installieren
11. Über eSata angeschlossene Geräte werden nicht erkannt
12. Lüfter lassen sich nicht leiser stellen
13. Blue Screen - F4 Error wegen korrupter SSD
14. In unregelmäßigen Abständen kommt es zu kurzen (manchmal auch längeren) Freezes
15. Sudden Death of SSD - Die SSD wird im BIOS nicht mehr erkannt
16. Ziel führender Einsatz von Lucid Virtu und Intel Quick Sync
17. CPU-Kühler lassen sich nicht montieren oder verdecken auf Grund ihrer Größe diverse Slots
18. ASUS AI Suite II lässt sich nicht installieren (auch nicht mit Hilfe des AI Suite II Patchers)
19. Die USB 3.0-Anschlüsse (3. + 4. Port vorne am Gehäuse) funktionieren nicht
20. Power On by PS/2 Keyboard funktioniert nicht
21. Instabiles System nach BIOS-Update
Lösungen
1. Nach RESET die Lüfter-Grenzwerte im BIOS unter Advanced-Mode herabsetzen (Nichtsdestotrotz muss stets auf eine angemessene Kühlung des Systems geachtet werden!)
2. BIOS 0706* - oder - BCLK-Wert im BIOS auf 100,0 MHz stellen
3. BIOS 0706* - oder - Internal PLL Overvoltage im BIOS deaktivieren (Bei OC über 4,7 GHz aktivieren)
4. BIOS 0706* - oder - BIOS 0606
5. BIOS 0706* - oder - Aktivierung des X.M.P.-Modes im BIOS-Setup (nicht alle RAM-Typen sind für den X.M.P.-Modus geeignet)
6. BIOS 0706* - oder - die USB-Tastatur einfach an einen USB 3.0 Port anschließen
7. Kein Fehler! Die CPU-Temperaturen sind dieselben wie vor dem BIOS-Update, aber ASUS hat die Art der Temperaturmessung mit den BIOS-Versionen 0603/0606 geändert. Die Temperaturen basieren nach dem Update nicht mehr auf tj.max-Temps (CPU-Kern), sondern auf tcase-Temps (CPU-Umgebung). Der Unterschied zwischen tcase-Temps und tj.max-Temps beträgt ca. 15 C°.
8. Möglicherweise Konflikte mit anderen Ports. Ursache ungeklärt!
9. Marvell Speicher-OPROM im BIOS deaktivieren
10. Kein Bug! Microsoft .Net3.5 Framework ist Teil von Windows 7
11. Hot-Plug im Bios aktivieren (Geräte können dann auch sicher entfernt werden)
12. Regulierung der Lüfter über Fan Xpert oder über eine zusätzlich montierte Lüfter-Steuerung
13. Keine Lösung!
14. LPM-Fix für den Intel SATA III-Port ausführen
15. Keine Lösung! - RMA anfordern
16. Einige positive Testergebnisse gab es bei der En-/Decodierung von Videos, allerdings nur bei gewissen Ausgangsformaten.
Vorteile bringt die Technologie beim Einsatz von zwei oder mehreren Monitoren, sofern iGPU-Anschlüsse vorhanden sind.
Warum die Deluxe-Version ohne Onboard-Grafikanschlüsse ausgestattet wurde, bleibt uns ein Rätsel.
17. Kühler-Empfehlungen auf Seite 1 dieses Threads beachten
18. Keine Lösung!
19. Im BIOS unter Onboard Devices Configuration muss der PCI Express X16_3 Slot auf AUTO gestellt sein. Die Modi X4 oder X1 deaktivieren die erwähnten USB3.0-Anschlüsse. (Dieses Problem betrifft nicht die Deluxe-Version.)
20. Keine Lösung!
21. ASUS empfiehlt dringend auf folgende Kombinationen zu achten:
BIOS 0501 mit IRST-Treiber 10.5
BIOS 0606 (0603 für Deluxe) mit IRST-Treiber 10.6
*Derzeit nur für P8Z68 Deluxe verfügbar
- Über die Software lassen sich nur PWM-Lüfter regeln. 3 Pin Lüfter kann man nur über das BIOS etwas bremsen/einstellen.
Per Nanoxia PWMX kann man 3 Pin Lüfter zu 4 Pin PWMs aufrüsten, wird leider nicht mehr produziert.
- Die ganzen Anzeigen sind nicht wirklich immer richtig.
Teilweise werden 0V oder 23V auf 12V und 5V Schiene oder -30° und mehr Mainbordtemperatur angezeigt ohne dass was ist. Nehmt lieber Aida oder HW-Monitor.
- Thermalright HR-02 Macho - Montage:
dann passt es:
http://www.bieberbach.org/bilder/macho_p8z68v0.jpg
Danke mauorrizze
Es gibt aber bald vom Hersteller auch neue Halter wer nicht basteln will.
Das sollte für den Anfang reichen. Natürlich muss hier und da noch ausgebaut werden. Hierbei hoffe ich zusätzlich auf eure Unterstützung. Änderungen/Verbesserungen sehe ich selbstverständlich gern entgegen (auch per PN).:)
Euer FM4E
@citrus77
Treiber, Bios etc. alles auf dem neuesten Stand. Die selbe Hardware lief zuvor auf einem Asrock P67 einwandfrei im Standby. Es klappt ja auch immer genau 1x, danach ist Ende Gelände. Beide Bildschirme werden dunkel, der Rechner selber bleibt aber an. Beim nächsten Neustart dann wieder auf´s neue, s. o.
Ich habe die Vermutung, dass es irgendetwas mit den USB´s sein könnte, weiss aber leider nicht mehr was ich noch versuchen sollte. Auf jeden Fall ist das Asus das zickigste Board was ich in den letzten Jahren hatte (und das waren einige!)
Welchen "Hänger" meinst du?!?
Ohjee, du Armer.
Ich hatte die Force GT auch genau 4 Tage lang.
Dann ging sie zurück zum Händler.
Diese (und viele andere) SF22xx SSDs haben Probleme mit den Energiesparmodi und enden meist in einem BSOD.
Mal nach 2 Stunden, mal nach 2 Tagen.
Allerdings längst nicht in allen Rechnern, sondern nur bei bestimmten Konstellationen (die aber noch nicht verstanden sind).
Google mal nach LPM oder lies hier nach:
http://www.hardwareluxx.de/communit...2000-client-industrial-enterprise-793969.html
oder hier:
http://www.hardwareluxx.de/communit...-link-power-management-beseitigen-793649.html
oder hier:
http://www.hardwareluxx.de/communit...d-unbedingt-den-ersten-post-lesen-786503.html
Meine Force Gt 120 hatte bisher NULL HÄNGER, egal was ich eingestellt habe , sogar auf Energiesparmodus... nichts
zu ner Corsair SSD :asthanos:passen halt nur Corsair 1866er RAM
@ Lötbert
Hmm, einen kleinen Tipp hätte ich noch, aber daran wirst du selbst schon gedacht haben.
Stell bei den Energieoptionen von W7 alles auf Standard: Ausbalanciert usw.
Wenn das nichts bringt, dann deaktiviere mal genau bei diesen Einstellungen den hybriden Standby-Modus. Wenn das die Lösung sein sollte, so gibt es bei dir das Problem, dass S3 und S4 sich gegenseitig ins Gehege kommen.
Siehste!
Ich habe das gleiche Mainboard wie du und hatte ebenfalls die Force GT 120. Und auch 8 GB Corsair Vengeance, allerdings 1600er.
Keine Chance.
BSOD alle paar Stunden, noch deutlich schlimmer als mit der Vertex3.
Nun erklär das mal bitte. :confused:
Danke für die Info mit den Hängern!
ich hab mich jetzt ein wenig eingelesen und möchte das Risiko nicht eingehen.
Ich hab mir jetzt ne Crucial M4 bestellt.
Vielleicht ist die nicht sooo schnell wie die ForceGT, ich will aber nicht ständig Ärger/Hänger und dann ausbauen/umtauschen...
Eine weise Entscheidung beim derzeitigen Zustand mit den SF22xx Controllern.
Würde ich momentan ebenso machen, wenn ich jetzt eine neue SSD kaufen müsste.
Ich hätte mich allerdings für eine Intel 510 SSD entschieden.
Du Glücklicher. Bei mir war es bis jetzt 3x der Fall, habe diese SSD seit einem Monat. Dabei gab es nur einmal eine BSOD (ntfs.sys als Ursache, ein wenig anders als sonst die BSODs durch SSDs hier), die anderen Male hängt es sich auf, die Maus lebt noch, aber sonst tut sich dann nix mehr. Sie verabschiedete sich dann auch komplett aus dem System, also bei Reset (Warmstart) wird sie im BIOS nicht mehr erkannt. Erst Strom wegnehmen für eine gewisse Zeit bringt sie dann wieder zurück.
Ist durchschnittlich also bis jetzt alle 10 Tage, Firmware 1.3 habe ich allerdings nicht installiert, Corsair bietet sowas bis jetzt ohne jegliches Changelog an - unfassbar.
Intel510 läuft bei mir absolut problemlos - nie auch nur ein Anzeichen von Schwierigkeiten - Intel hat nunmal die geringsten Kompatibilitäts-Probleme.
Die Crucial M4 soll aber auch nicht so schlecht sein (ist ja auch ein Marvell-Contoller). Ausserdem ist die Crucial ca. 70€ günstiger und hat sogar noch etwas mehr Speicherkapazität (119 GB statt 112 GB unter Windows).
hab da noch ein paar fragen, hast du im EFI die option "iGPU Multi-Monitor" aktiviert? und den intel vga treiber installiert (wenn ja welche version) oder brauchtest du das nicht?
Hi wenn ich meinen Display an an meinen MoBo drann hab dann wird mir angezeigt das ich den Intel Treiber drauf hab.
Anscheinend über Win Update oder über mitgeliefeter DVD installiert worden kann ich dir nicht sagen. Ich hab im Bios überhaupt nichts verändert bis auf den Haupt Monitor Asugang den "muss" man auf "on board" umstellen wenn man den MoBo Anschluss nützt. Wenn Graka dann PCI (ist schon default)
Ich würde dir empfehlen die ASUS CD einmal zu installieren Also "Treiber"
Ich hatte das Programm Virtu auch auf der CD ich habs mir aber online geladen da wes eine alte Version war!
Ich persönlich nütze aber den Graka Anschluss da die Video dekodierung mit Virtu (Quick Sync) auch so funktioniert und ich hab keine kompatiilitätsprobleme mit Spielen. Man hat zwar kompatibilitätsprobleme mit den Video Tools (zur zeit gibts nur 2 Unterstütze von Virtu) aber ich hab ja eins das unterstützt wird ;)
Das ist ja so wenn Display an Graka hängt wird in Virtu angezeigt welche Video Programme unterstützt werden von Virtu ( nur 2 das ist "Media Espresso" und "Media Converter 7")
und
wenn man den Monitor am MoBo anschließt werden die Spiele angezeigt die unterstützt werden von Virtu (ziemlich viele ;) )
@citrus77
So und nun mach ich ich mal ans konverten ;)
Das ist echt zum verzweifeln, gibts denn hier noch jemanden bei dem das überhaupt funktioniert? also display an grafikkarte und mediaespresso mit intelquicksync nutzen? oder liegts evtl daran das ich eine ati/amd grafikkarte habe?
So - nun ist auch bei mir BIOS 0706 drauf.
Bei identischen Einstellungen wie beim BIOS 0603 kann ich leider NICHT bestätigen,
dass die Temperaranzeigen niedriger ausfallen.
Werte unter Prime sind nach wie vor hoch (2600K @4,2 GHZ, 1,26V --> 68 - 72 °C).
Irgendwie ist der Wärmeübergang vom Prozessor zum Kühler extrem mies
- ich werde mal versuchen den Prozessor planzuschleifen, vielleicht bringt das ja was.
(Bei 'nem Pentium 100 hat's mal 5 °C reduziert).
Internal PPL Voltage läßt sich nun aktivieren ohne Probleme.
ich lass jetzt den CPUID Hardware Monitor im Hintergrund laufen und immer wieder springt die Tempeartur bei der CPUTIN und AUXTIN auf 127°C, die 4 Kerne haben 35-36°C.
Wer von euch nutzt noch CPUID ?
Und täglich schockt die AI-Suite mit ihren Pop-up Warnungen :stupid:
Ich hatte schon 20V auf der 12V Schiene, 0V auf der 5V, heute CPU-Fan Warnung Umdrehungen 0 ( dank PC Fenster aber gesehn dass sich noch alles dreht)...
Ne Stunde später im idle kam plötzlich ne angebliche CPU-Temp von 128°C. Coretemp und mein Finger haben weiterhin realische 42° gemessen.
Und wieder später plötzlich ne Mainbordtemperatur von -1° da haben die kleinen Asuszwerge wohl schnell LN2 drüberlaufen lassen... :fresse:
Und das System läuft noch ^^
Liegt wohl am Pogramm, springt auch bei mir ständig rum.
Aida64 dagegen bleibt bei ca 40°C.
Ja, ich hab das auch (Version 1.18.0 - Driver version 135) bietet einen guten Überblick übers System.
Mir ist das aber auch schon passiert - da war auf einmal die Systemtemperatur bei - XX °C, aber die Coretemps noch völlig in Ordnung.
Ich hatte allerdings die gleiche, bescheuerte Anzeige bei SpeedFan, also gehe ich davon aus,
dass es nicht am Programm liegt, sondern der Sensor rumspinnt.
Nach erneutem Booten war dann auch gleich wieder alles o.k.
Keine Angst - Deine Systemtemperatur springt garantiert nicht auf 127°C - da wäre Dein Prozessor schon längst verglüht ;)
Ich weiß nicht, ob dir das weiterhilft, aber in diesem Thread diskutieren einige über deine Thematik.
Virtu vs CUDA
Test von gestern ergab
wmv zu iPhone4 --> nVidia ist doppelt so schnell
m2ts zu iPhone4 --> iGPU (Quick Sync) ist 90% so schnell
EDIT mit einer größeren Datei nur noch 90%
Test von heute
Display hängt an GraKa
Alle Videos werden mit Media Espresso 9,5 in das iPhone4 Format MP4 konvertiert!
mp7 wird nicht unterstütz von Media Espresso
f4v wird nicht unterstütz von Media Espresso
mp4
Virtu an
mp4 927MB mit HW Beschleuigung und mit Virtu (mit intel Bild)= 3,52min
mp4 927MB ohne HW Beschleuigung und mit Virtu (kein Bild) = 8,19 min
Virtu aus
mp4 927MB mit HW Beschleuigung und ohne Virtu (mit nVidia CUDA Bild)= 4,31min
mp4 927MB ohne HW Beschleuigung und ohne Virtu (kein Bild) = hat keinen sinn
Direkter Vergleich mp4
"Virtu Quick Sync" ist bei mp4 um ca 19% schneller als "nVidia CUDA"
avi
Virtu an
avi 341MB mit HW Beschleuigung und mit Virtu (mit intel Bild)= 2,27min
Virtu aus
avi 341MB mit HW Beschleuigung und ohne Virtu (mit nVidia CUDA Bild)= 2,12min
"nVidia CUDA" ist bei avi um ca 6% schneller als "Virtu Quick Sync"
mkv
Virtu an
mkv 1,24GB mit HW Beschleuigung und mit Virtu (mit intel Bild)= 5,11min
Virtu aus
mkv 1,24GB mit HW Beschleuigung und ohne Virtu (mit nVidia CUDA Bild)= 11,11 min
Direkter Vergleich mkv
"Virtu Quick Sync" ist bei mkv um ca 110% schneller als "nVidia CUDA"
Überblick:
"Virtu Quick Sync ist bei avi um ca 6% langsammer als "nVidia CUDA"
"Virtu Quick Sync" ist bei wmv um ca 100% langsammerals "nVidia CUDA"
"Virtu Quick Sync" ist bei m2ts um ca 90% schneller als "nVidia CUDA"
Mein Fazit: Ich hab es bewust weg gelassen weil ich hin und her gerissen bin.
Ursprünglich wollte ich meinen Display an das Motherboard hängen und die Spiele anhand "Virtu! von meiner PCI Graka durch reichen lassen. Anhand der doch etwas zu umstänlichen "White List" derer Spiele die über Virtu von der Graka übertragen werden können habe ich mich entschieden meinen Display an die Graka selber zu hängen und somit habe ich das Kopapilitätsproblem mit einigen Spielen gelöst!
Jetzt hatte ich natürlich das Problem, dass ich ein Video Konverter kaufen musste der Virtu unterstütz. Hab mich für Media Espresso entschieden.
Fazit die 40 Euro für das Programm war es nicht wert da nur bei "m2ts" Konvertierung ein deutlicher Performance Gewinn zu bemerken war. Bei allen anderen war es zwischen 10 und 110 % ein hin und her. Mal war CUDA schneller mal war Quick Sync schneller. Im großen und ganzen habe ich mir viel mehr versprochen von Quick Sync da ich ja auch mehrere Tests gelesen habe und überall war Quick Sync bis zu 6x schneller. Nur in der Realität eben nicht!! LEIDER
Ich hätte mir lieber ein Board gekauft das keinen Viedoasgang hat und dafür einen SATA oder USB3 Anschluss mehr.
@ JoergH
... nur ein kleiner Hinweis
Anscheinend sind die SATA 6Gb/s port(s) von Intel besser als die von Marvell. Leider kann ich dir das nicht beweisen, ich habe das auch nur in verschiedenen Foren so mitbekommen.
Ich habe aus diesem Grund meine SSD an den Intel-Port geklemmt.
Mal ne Frage macht das Windows 7 einfach somit ?
Wenn da die Bootplatte dran hängt ?
@ Mrsonei6
VIELEN DANK!!! Dein Test ist äußerst aufschlussreich.
---------- Beitrag hinzugefügt um 21:08 ---------- Vorheriger Beitrag war um 21:07 ----------
Bei mir läuft das jedenfalls perfekt so. Warum hast du da Bedenken?
Hab grad eine etwas größere m2ts datei konvertiert, leider verringert sich jetzt die Geschwindigkeit von 600% auf 90% schneller mit Quick Sync über Virtu
Nur zur Info.
Die kleine Datei war 24 mb und die Große 600mb
auch vielen Dank @ Mrsonei6 für den Test. Werde vorläufig noch auf virtu verzichten, ausser ich kodier mal was.
zu den Sata2/Sata3 Anschlüssen:
Meine Vertex3 (sata3) lief am marvell stabiler (damals noch mit firmware 2.06)
aber langsamer (nur max 320 MB/s)
mit Vertex firmware 2.11 hab ich sie dann an den intel gehängt. Bisher keine BSOD's aber 2 hänger - aber auch deutlich schneller - kommt jetzt über 500 MB/s.
interessant war folgendes: Ich hab ne 2TB WD Green Sata3 als leisen Massenspeicher.
Hatte die zuerst am intel Sata2 port, wo sie schlechte Benchmarkwerte hatte.
Am Intel Sata3 port liefert sie jetzt was man von ihr erwarten kann. Der Sata3 controller der WD Green mag wohl lieber SATA3 Anschlüsse. - dachte eigentlich dass das egal sein sollte, da die Platte Sata2 eh nicht ausreizt, aber beim Cache der Festplatte könnts natürlich schon ne rolle spielen ob am sata2 oder 3.
Am Kabel lags nicht - hab sowohl das sata3 als auch das sata2 kabel
am sata2 anschluss probiert.
Also auch von mir der Rat: SSD an den Intel (falls sie da stabil läuft)
die restlichen Sata3 platten auf jeden fall auch an sata3 anschlüsse.
- kannst ja mal spasseshalber einen deiner sata 3 spinner auch am sata2 und sata3 mal benchen und berichten.
Kurze Frage:
Welches ist das aktuellste Bios für das P8Z68-V? (keine Pro Version)
Ah habs jetzt auch gefunden.
Kann mir jemand noch das 0603 für das P8Z68-V hochladen?
