ASRock > Produkte > Fatal1ty P67 Professional
*] Preise und Verfügbarkeit
ASRock Fatal1ty P67 Professional, P67 (B3) (dual PC3-10667U DDR3) | Geizhals.at Deutschland
ASRock Fatal1ty P67 Professional Sockel 1155 Mainboard: Mainboard Preisvergleich - Preise bei idealo.de
- Spezifikationen
Sockel
1155 Sandy Bridge
Prozessor
Intel® Core™ i7-2600K/2600Intel® Core™ i5-2300-2500/2500KIntel® Core™i3-2100-2120
Chipsatz
Intel® P67 Express
Steckplätze
2x PCI 32 Bit Steckplätze
32 Bit 5 Volt 33 Mhz
2x PCIe 2.0 x1
3x PCIe 2.0 x16 /1x16 oder 2 x8/x8 ; PCIE5: x4
BIOS
64Mb AMI UEFI Legal BIOS with GUI support
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- DRAM, PCH, CPU PLL, VTT, VCCSA Voltage Multi-adjustment
Arbeitsspeicher
Dual Channel DDR3 memory technology
4 x DDR3 DIMM slots Max. 32GB
Supports DDR3 2133(OC)/1866(OC)/1600/1333/1066 non-ECC, un-buffered memorySupports Intel® Extreme Memory Profile (XMP)
Audio
7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
- Premium Blu-ray audio support
- Supports THX TruStudio PRO™
LAN
- PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111E
- Supports Wake-On-LAN
- Supports LAN Cable Detection
- Supports Energy Efficient Ethernet 802.3az
- Supports Dual LAN with Teaming function
SATA3
2 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and "Hot Plug" functions
- 4 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions (SATA3_M4 connector is shared with eSATA3 port)
USB 3.0
- 4 x Rear USB 3.0 ports by Etron EJ168A, support USB 1.0/2.0/3.0 up to 5Gb/s
- 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by Etron EJ168A, supports USB 1.0/2.0/3.0 up to 5Gb/s
- 4 x SATA2 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and Hot Plug functions
Anschlüsse Board
- 6 x SATA3 6.0 Gb/s connectors
- 1 x ATA133 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x COM port header
- 1 x HDMI_SPDIF header
- 1 x IEEE 1394 header
- 1 x Power LED header
- CPU/Chassis/Power FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- CD in header
- Front panel audio connector
- 4 x USB 2.0 headers (support 8 USB 2.0 ports)
- 1 x USB 3.0 header (supports 2 USB 3.0 ports)
- 1 x Dr. Debug with LED
Anschlüsse ATX-Blende
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Coaxial SPDIF Out Port
- 1 x Optical SPDIF Out Port
- 3 x Ready-to-Use USB 2.0 Ports
- 1 x Fatal1ty Mouse Port (USB 2.0)
- 1 x eSATA3 Connector
- 4 x Ready-to-Use USB 3.0 Ports
- 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
- 1 x IEEE 1394 Port
- 1 x Clear CMOS Switch with LED
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Mitgeliefertes Zubehör
1 x SLI_Bridge
1 x Drivers and Utilities CD
1 x Front USB 3.0 Panel mit Aufnahme für 1.SSD !!
1 x Rear USB 3.0 Bracket , einfach nur umschrauben !
1 x Floppy/ATA 133 Kabel
6 x SATA Data Kabel
2 x SATA 1 to 1 Powerkabel
- Bilder uneingebaut und eingebaut
- Bilder Bios Übersicht
- Bilder Bios OC Tweaker und Advanced
- RAM Liste
ASRock > Produkte > Fatal1ty P67 Professional > Speicher Support Liste
- Getesteter Ram
Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) | Geizhals.at Deutschland
G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL)
Corsair XMS3 DIMM Kit 8GB PC3-16000U CL9-10-9-27 (DDR3-2000) (CMX8GX3M2A2000C9)
Corsair XMS3 Dominator GT DIMM Kit 4GB PC3-16000U CL8-9-8-24 (DDR3-2000) (CMT4GX3M2A2000C8)
G.Skill ECO DIMM Kit 4GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-4GBECO)
- Download BIOS + Treiber
ASRock > Produkte > Fatal1ty P67 Professional > Download
Rest kommt nocht
MfG
und ja das brett hat auch einen IDE anschluß, also kannst dein altes IDE-Laufwerk weiterverwenden
Beim Ram einfach die Timings, vdim und den Ram-Teiler manuell im UEFI einstellen und glücklich werden
