[Sammelthread] ASUS Maximus IV Gene-Z (Intel Z68) ROG
Willkommen im Sammelthread zum ...
ASUS MAXIMUS IV GENE-Z
Layout:
weitere Bilder:
Spezifikationen:
Backpanel:
1 x PS/2 keyboard/mouse combo port(s)
1 x HDMI
2 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
2 x USB 3.0
8 x USB 2.0 (white port can be switched to ROG Connect)
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x Clear CMOS button(s)
OnBoard-Anschlüsse:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
6 x ProbeIt Measurement Points
1 x Power-on button(s)
1 x Reset button(s)
1 x ROG Connect switch(es)
1 x Go Button(s)
1 x Clear CMOS jumper(s)
Lieferumfang:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
1 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ROG Connect cable(s)
1 x Cable ties pack(s)
1 x ROG theme label(s)
1 x 12 in 1 ROG Cable Label(s)
UEFI SCREENS:
Links:
Preisvergleich
Produktseite / Info beim Hersteller
Downloads: Bios, Treiber, Handbuch,...
Downloads: Bios, Treiber, Handbuch... Direktlinks
+ Maximus IV GENE-Z Deutsches Handbuch Version G6731
+ Maximus IV GENE-Z BIOS 3305
For proper operation, please ensure to update Intel Rapid Storage Technology driver to version 10.8.0.1003 and BIOS to version 3305 before enabling Intel Smart Response Technology.
Update procedure for users needing Intel Smart Response Technology:
(1) Enter OS, and ensure Intel Smart Response Technology has been turned off under Intel Rapid Storage Technology interface.
(2) Install version Intel Rapid Storage Technology driver to version 10.8.0.1003.
(3) Reboot the system, and update BIOS to version 3305, then reboot.
(4) Enter the BIOS setup screen, press F5 to load BIOS default, then change the Intel SATA Port to RAID mode.
(5) Boot into OS, and re-enable Intel Smart Response Technology under Intel Rapid Storage Technology.
+ Maximus IV GENE-Z 0902 Offizielles Beta Bios Datum 19.09.2011
+ Maximus IV GENE-Z 0706 Offizielles Beta Bios Datum 16.08.2011
+ Maximus IV GENE-Z 0403 Final Bios mit IRST 10601002
+ Maximus IV GENE-Z 0208 First release Bios
+ Maximus IV GENE-Z 0650 Beta Bios
+ Maximus IV GENE-Z 0604 Beta Bios
+ Maximus IV GENE-Z 0603 Beta Bios
+ Treiber Chipsatz: Intel Chipset Software Installation Utility V9.2.0.1030 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V7.1.14.1107 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V7.1.20.1119 XpVistaWin7
+ Treiber SATA: Intel® Rapid Storage Technology Version: 10.6.0.1022 Datum: 08.06.2011
+ Treiber SATA: Intel® Rapid Storage Technology Version: 10.8.0.1003 Datum: 11.11.2011
+ Treiber SATA: JMicron JMB36X(JMB362) Controller Driver V1.17.62.0 WHQL XpVistaWin7
+ Treiber SATA: JMicron JMB36X(JMB362) Controller Driver V1.17.63.0 WHQL XpVistaWin7
+ Treiber SATA: JMicron JMB36X(JMB362) Controller Driver V1.17.63.0 WHQL eSata XpVistaWin7
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.1.0.0 WHQL XpVistaWin7
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.7.0.0 WHQL Win7 32-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.7.0.0 WHQL Win7 64-Bit
+ Treiber USB 3.0: ASM USB 3.0 Driver V1.10.0.0 XpVistaWin7
+ Treiber USB 3.0: ASM USB 3.0 Driver V1.14.1.0 XpVistaWin7
+ Treiber USB 3.0: ASM USB 3.0 Driver V1.14.2.0 XpVistaWin7
+ Treiber Video: Intel(R) Graphics Accelerator Driver V8.15.10.2372 WHQL VistaWin7
+ Treiber Video: Intel® HD Graphics Driver 8.15.10.2462 VistaWin7 32-Bit
+ Treiber Video: Intel® HD Graphics Driver 8.15.10.2462 VistaWin7 64-Bit
+ Treiber Video: Intel® Graphics Media Accelerator Driver 15.22.50.64.2509 VistaWin7 64-Bit
+ Treiber Video: Intel® Graphics Media Accelerator Driver 15.22.50.32.2509 VistaWin7 32-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.106 09.08.2011 Win7 32-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.106 09.08.2011 Win7 64-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.108 Win7
+ Treiber Audio: Realtek Audio Driver Version 5.10.0.6363 & 6.0.1.63 WHQL XpVistaWin7
+ Utility Audio: Sound Blaster X-Fi 2 Utility Package V1.0 (R11) Windows Vista & Windows 7
+ ASUS AI Suite II V1.01.30 Install Program XpVistaWin7
+ ASUS AI Suite II V1.01.40 Install Program XpVistaWin7
+ ASUS AI Suite II V1.02.11 Install Program XpVistaWin7
+ ROG CPU-Z V1.58 Setup
+ ROG CPU-Z V1.58.4 Setup
Besonderheiten:
Reviews:
ASUS Maximus IV Gene-Z LGA1155 Review | techPowerUp
ASUS Intel Z68 ROG Maximus IV Motherboard Reviews | legitreviews.com
ASUS Maximus IV Gene-Z Motherboard Review | tbreak.com
Asus Maximus IV Gene-Z Motherboard Review | ninjalane.com
ASUS Maximus IV Gene-Z - Artikel | Hartware.net
Asus Maximus IV Gene-Z Motherboard review (mATX) | KitGuru.net
ASUS Maximus IV Gene-Z Review - Mainboards - Reviews | ocaholic.ch
ASUS Maximus IV Gene-Z Review | Overclock3D.net
ASUS RoG Maximus IV Gene-Z Motherboard Review | hardwareheaven.com
ASUS Maximus IV Gene-Z review | hardwareheaven.com
ASUS Maximus IV Gene-Z (Intel Z68) mATX Motherboard Review | TweakTown.com
Asus Maximus IV Gene-Z Review | bit-tech.net
Asus Maximus IV Gene-Z Intel Z68 and Asus Matrix GTX 580 Platinum Review | whatswithjeff.com
Weitere Infos und nützliche Links:
- Welcome to Republic Of Gamers! - Maximus IV GENE-Z
- TEST || ASUS MAXIMUS IV GENE Z
- Vorstellung im ROG Community Forum
- ROG Community Blog: Weapon Drop Inbound
- Official ASUS Maximus IV Gene-Z Motherboard Unboxing
- Video COMPUTEX 2011: ASUS ROG Maximus IV GENE-Z Z68 Motherboard
- Maximus IV GENE-Z BIOS Guide - Overclocking
Kompatibilität Arbeitsspeicher:
QVL - QUALIFIED VENDOR LIST - DOWNLOAD
User Berichte:
Corsair Vengeance Rot 8GB DDR3-1600 CL9-9-9-24 (CMZ8GX3M2A1600C9R) @ 1333 7-7-7-19
G.Skill RipJaws-X 8GB DDR3-1333 CL7-7-7-21 (F3-10666CL7D-8GBXH) @ 2133 11-11-11-30|1866 9-10-9-28|1600 8-8-8-24|1333 7-7-7-21
G.Skill RipJaws-X 8GB DDR3-1600 CL9-9-9-24 (F3-12800CL9D-8GBXL) @ 1600 9-9-9-24
G.Skill RipJaws-X 16GB DDR3-2133 CL11-11-11-30 (F3-17000CL11Q-16GBXL) @ 2133 10-11-10-27 1T
Mushkin Enhanced Blackline Frostbyte DDR3-2133 CL10-11-10-28 (994015) @ 2133 10-11-10-27 1T | 1866 9-10-9-27 1T
1067 MHz | 8-8-8-24-1T | 1.563V | 2x2GB SuperTalent Chrome 2000 C8 | Elpida Hyper | P67 | websmile | Screen
1067 MHz | 8-8-8-24-1T | 1.575V | 2x2GB Corsair Dominator GT 1866 C7 | Elpida Hyper MGH-E| P67 | websmile | Screen
1130 MHz | 7-9-7-21-1T | 1.613V | 2x2GB G.Skill RipjawX 2133 C8 | Elpida BBSE | P67 | websmile | Screen
Kompatibilität CPU Kühler:
+ Corsair H60 (Hersteller-Link)(Foto von Emiras)
+ Corsair H70 (Hersteller-Link)
+ be quiet! Dark Rock Advanced C1 (Hersteller-Link)
+ be quiet! Dark Rock Pro C1 (Hersteller-Link) (Foto)
+ EKL Alpenföhn Brocken (Hersteller-Link) (Foto von Emiras)
+ Noctua NH-U9B SE2 (Hersteller-Link)
+ Noctua NH-D14 (Hersteller-Link)
+ Noctua NH-U12P SE (Hersteller-Link)
+ Noctua NH-C12P SE14 (Hersteller-Link)
+ Noctua NH-C14 (Hersteller-Link)
+ Prolimatech Megahalems (Hersteller Link)
+ Prolimatech Super Mega (Hersteller-Link)
+ Scythe Mugen 2 Rev. B (Hersteller-Link) (FOTO) mit SCURK-3000 oder Backplate-Mod
+ Scythe Ninja 3 (Hersteller-Link)
+ Thermalright Venomous-x (Hersteller-Link)
+ Thermalright HR-02 (Hersteller-Link) (Foto von Stullen Andi)
+ Thermalright HR-02 Macho (Hersteller-Link) mit Thermalright Macho Asus Bolt-Thru Kit
Swiftech Apogee XT (Preisvergleich)
Overclocking Ergebnis:
CPU-Z Validator 3.1
ASUS Maximus IV Gene-Z + 2500K
Der Soundchip ist auch nur ein Realtek der guten Sorte mit aufgesetzter Creative Software. Sicher nicht schlecht. Aber mit ner dedizierten Soundkarte gibts besseren Sound.
Das kostet auch extra - eine X-Fi die vergleichbares bietet wie das Board mit der Software ca. 35€ und ein Steckplatz geht dann auch flöten.
Das Board scheint beim ersten Zwischenhändler eingetroffen zu sein. Computer Univers hat es mit eine Lieferzeit von 2-3 Tagen. Müsste also beim Zwischenhändler vorrätig sein.
Juhu...
in wie fern unterscheiden sich denn das Maximus 4 Gene-Z zum Maximus Extreme Z?
Nur durch die verminderten Anschlüsse?
Überlege mir nämlich stark das Extreme Z zu kaufen! Gerade weil ich die Anschlüsse, besonders die USB3 brauche!
Will bis zum Ivy Bridge nen Sandy haben! Würde das Maximus 4 Extreme Z auch noch in nem halben Jahr (wenn Ivy raus kommt... evtl dauert es noch länger) gut abscheiden?
Ersteinmal ganz klar durch die Größe, den Platz muss man erstmal haben;
- GENE-Z Specifications/Asus µATX (24.4 cm x 24.4 cm) gegen
- Extreme-Z Specifications/Asus erweitertes (macro?) ATX (30.5 cm x 26.9 cm),
im Vergleich das alte Rampage Extreme LGA775 (30.5 cm x24.5 cm),
- die deutlich bessere Anzahl an Steckplätzen ( ich z.B. werde das brauchen..)
- sehr angenehme Abstände der PCI-E Slots (da passt jedes Multi-GPU SLI/ CF mit Zusatzkühlern)... leider nur nativex 8x Lanes ... wird wohl erst mitm LGA 2011 wirklich besser...
- aufgrund dessen gut unter Luft zu kühlen, bietet aber ebenso Platz zum Modden und WaKü basteln.
Ob es tatsächlich dem Kaufwert entspricht ist mir egal, zumal ich es einfach haben möchte.
Es passt vom Aufbau her optimal zum restlichen System+ LuKü, ist farblich mit der anderen hardware gut abgestimmt und sihet einfach gut aus.
... mehr fällt mir spontan nicht ein, da sich beides MB`s sonst recht ähneln.
@ mediajunkie
Wie sind denn die Abmessungen vom EVGA Kühler? Ich werde mir ja das Extreme-Z holen und dachte da an einen CPU Kühler mit den Ausmaßen eines Mugen 2.
Meinst du, dass da genug Luft sein wird? Ich denke nämlich nicht, dass das Gene-Z um den CPU Sockel herum soviel weniger Platz zur Verfügung hat.. denke mal die sind da recht baugleich. :grrr:
ich hab keine Ahnung. Denke aber auch, dass du damit keine Probleme haben wirst. Ich kann dir aber den Corsair H60 empfehlen. Hab den selbst schon verbaut und ich werde nur noch solche Kühler verbauen. Die Leistung ist super, dass Ding hörst du mit einem anderen Lüfter nimma, also auch Pumpe ist schön leise, und man hat diese Einfache und saubere Montage.
Kein Stress mehr mit RAMs tauschen oder Angst, die Graka passt nimma, oder Angst, dass Mainboard könnte beim Transport in Stücke reißen. Meiner Meinung haben die Towerkühler ausgedient.
aber: this are just my 2 cents ;)
KaerMorhen: Also deine Aufzaehlung passt nicht wirklich. Das Gene ist das kleine von den beiden. Und das andere hat doch nen nForce200 drauf.
Wow, laut dem Guide soll das kleine Board dem grösseren Bruder in Bezug auf Overclocking in keiner Weise nachstehen. Ich glaube datt Ding is meins !
Und Bestseller Computer gibt den 7.7. an.
Scheint wirklich ein Board ohne Macken zu sein, ein Traum.:love:
Na die Macken treten typischerweise auch erst auf wenn die Dinger tatsächlich beim Endkunden sind :fresse:
Danke für die Aufmerksamkeit, ich habe es natürlich geändert.
Naja ob der NF200 so den Unterschied ausmacht? Wenns um Benchen geht, dann ein klares JA, beim Spielen tut sich wohl nichts zum Gene z
Hmm.. 7.7 =/ Hatte gehofft das es vll. schon dieses We was mit der Bastelstunde gibt :-( Muss ich mich wohl noch mal was gedulden.
Ich habs damit ueberhaupt nicht eilig. Werde sogar noch die ein oder andere Woche abwarten, ob der Preis etwas sinkt. Hab ja schon ein gutes P67 Board drin. Das Gene wuerd nur ein paar 'Kleinigkeiten' verbessern.
Juhu...
falsch gedacht die hatten das schon vor über einem monat so drin das zählt immer bis zum voraussichtlichen verfügbarkeitsdatum bin gespannt ob sichs diesmal wieder verschiebt
War aber auch mit Vorbehalt der Termin. Ja aber wir müssen uns wohl alle Gedulden.
So wie es aussieht bekomm ich Samstag mein Board, spätestens Montag hab grad die Info bekommen :banana:
AUF LAGER bei FortKnox für 138,23 € / hab angerufen und auch schon bestellt!
Happy Fragging!!!
Hmm.. gefunden.
Angerufen. Geht niemand dran. Lieferbarkeit steht auf Gelb. Um Rückruf gebeten aber niemand meldet sich. Was geht ?
Vertrauenswürdiger Laden? Mal sehen ob die Extreme - z da auch haben.
