CAD PC
Wo sehe ich welche Revision ich habe?
Das möchte ich auch wissen.
Gibt es beim U2311H nicht eine ausklappbare Karte links bei den zwei USB-Ports wie beim Dell 2209WA?
"There's also a small card that extends from behind the USB ports on the left — this contains monitor info on the front, and various certifications on the back. This is handy if you have to get support for your monitor — all the details are now right in front of you, rather than having to turn the screen around. Incidentally, the info card listed our review sample as a first run revision, A00."
