Hier ensteht ein Sammelthread zum bis her günstigsten X58 Mainboard
im gegensatz zu anderen X58 Billig Mainboard bietet dieses hier eine Lizenz für SLI.
ab 133€
http://preisvergleich.hardwareluxx.de/deutschland/a442028.html
habe es mir bestellt testen kann ich vorausichtlich erst nächste Woche.
■Intel® Socket 1366 Core™ i7 Processor Extreme Edition / Core™ i7 Processor Supports Intel® Dynamic Speed Technology
■System Bus up to 6400 MT/s; Intel® QuickPath Interconnect
■ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
■Intel® X58 + ICH10R Chipsets
■Advanced V8 Power Phase Design
■Supports Triple Channel DDR3 2000(OC)/1866(OC)/1600(OC)/1333(OC)/1066 (6 x DIMM slots) non-ECC, un-buffered memory, Max. capacity up to 24GB
◦Supports DDR3 ECC, un-buffered memory with Intel® Workstation 1S Xeon® processors 3500 series
◦Supports Intel® Extreme Memory Profile (XMP)
◦3 x PCI Express 2.0 x16 slots (blue @ x16 mode, orange @ x4 mode) (Double-wide slot spacing between each PCI-E slot)
◦Supports ATI™ CrossFireX™, 3-Way CrossFireX™ and Quad CrossFireX™
◦Supports NVIDIA® SLI™ and Quad SLI™
◦PCIE Gigabit LAN 10/100/1000 Mb/s
◦6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, 1, RAID10, RAID 5 and Intel® Matrix Storage), NCQ, AHCI and Hot Plug functions
◦1 x Powered eSATAII/USB Connector
◦Supports 2 x IEEE1394 ports (one port on back panel, one header on board)
◦EuP Ready
◦Smart Switch
◦Dr. Debug
◦Supports ASRock Instant Boot, Instant Flash
◦Supports Smart BIOS, ASRock OC Tuner, Intelligent Energy Saver
◦7.1 CH Windows® Vista™ Premium Level HD Audio with Content Protection, supports DAC with 110dB dynamic range (ALC890 Audio Codec)
◦Windows® Vista™ Premium 2008 Logo Ready
◦Free Bundle: 1 x ASRock SLI_Bridge_2S Card
◦I/O Panel : 1 x Coaxial SPDIF Out Port, 1 x Optical SPDIF Out Port, 7 x Ready-to-Use USB 2.0 Ports, 1 x Powered eSATAII/USB Connector, 1 x RJ-45 LAN Port with LED, 1 x IEEE 1394 Port, 1 x Clear CMOS Switch
Product Specifications
General
CPU - Intel® Socket 1366 Core™ i7 Processor Extreme Edition / Core™ i7 Processor Supports Intel® Dynamic Speed Technology
- System Bus up to 6400 MT/s; Intel® QuickPath Interconnect
- Advanced V8 Power Phase Design
- Supports Hyper-Threading Technology
- Supports Untied Overclocking Technology
- Supports EM64T CPU
Chipset - Northbridge: Intel® X58
- Southbridge: Intel® ICH10R
Memory - Triple Channel DDR3 memory technology
- 6 x DDR3 DIMM slots
- Supports DDR3 2000(OC)/1866(OC)/1600(OC)/1333(OC)/1066 non-ECC, un-buffered memory
- Supports DDR3 ECC, un-buffered memory with Intel® Workstation 1S Xeon® processors 3500 series
- Max. capacity of system memory: 24GB*
- Supports Intel® Extreme Memory Profile (XMP)**
*Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® XP and Windows® Vista™. For Windows® XP 64-bit and Windows® Vista™ 64-bit with 64-bit CPU, there is no such limitation.
**Due to Intel® CPU spec definition, XMP DIMMs and DDR3 2000/1866/1600 are supported for one DIMM per channel only.
BIOS - 8Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- CPU, DRAM, NB, SB, VTT Voltage Multi-adjustment
- Supports I. O. T. (Intelligent Overclocking Technology)
- Supports Smart BIOS
Audio, Video and Networking
Graphics - n/a
Audio - 7.1 CH Windows® Vista™ Premium Level HD Audio with Content Protection
- DAC with 110dB dynamic range (ALC890 Audio Codec)
LAN - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111DL
- Supports Wake-On-LAN
Expansion / Connectivity
Slots - 3 x PCI Express 2.0 x16 slots (blue @ x16 mode, orange @ x4 mode) (Double-wide slot spacing between each PCI-E slot)
- 2 x PCI Express x1 slots
- 2 x PCI slots
- Supports ATI™ CrossFireX™, 3-Way CrossFireX™ and Quad CrossFireX™
- Supports NVIDIA® SLI™ and Quad SLI™
Connector - 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Matrix Storage), NCQ, AHCI and Hot Plug functions
- 1 x ATA133 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x COM port header
- 1 x HDMI_SPDIF header
- 1 x IEEE 1394 header
- 1 x TPM header
- CPU/Chassis/NB/Power FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- CD in header
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
Rear Panel I/O I/O Panel
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Coaxial SPDIF Out Port
- 1 x Optical SPDIF Out Port
- 7 x Ready-to-Use USB 2.0 Ports
- 1 x Powered eSATAII/USB Connector
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- 1 x IEEE 1394 Port
- 1 x Clear CMOS Switch
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Other Features / Miscellaneous
Unique Feature - ASRock OC Tuner
- Intelligent Energy Saver
- Instant Boot
- ASRock Instant Flash
- Hybrid Booster:
- CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
Smart Switch - 1 x Power Switch
- 1 x Reset Switch
Support CD - Drivers, Utilities, AntiVirus Software (Trial Version)
Accessories - 1 x ASRock SLI_Bridge_2S Card
- Quick Installation Guide, Support CD, I/O Shield
- Floppy/ATA 133 Cables
- 4 x SATA Data Cables (optional)
- 2 x SATA 1 to 1 Power Cables (optional)
Hardware Monitor - CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU/Chassis/NB/Power Fan Tachometer
- CPU Quiet Fan
- Voltage Monitoring: +12V, +5V, +3.3V, CPU Vcore
Form Factor - ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
- All Solid Capacitor design (100% Japan-made high-quality Conductive Polymer Capacitors)
OS - Microsoft® Windows® XP / XP 64-bit / Vista™ / Vista™ 64-bit compliant
Certifications - FCC, CE, WHQL
- EuP Ready (EuP ready power supply is required)
Reviews:
http://www.futurelooks.com/asrock-x58-extreme-motherboard-review/
http://www.tomshardware.com/reviews/cheap-x58-motherboard,2368.html
http://www.motherboards.org/reviews/motherboards/1923_1.html
http://www.ocworkbench.com/2009/asrock/X58-Extreme/g1.htm
http://www.anandtech.com/mb/showdoc.aspx?i=3593
Weitere Infos folgen!
Edit 19.01.2010:
Review www.tomshardware.com/de
http://www.tomshardware.com/de/x58-Mainboards,testberichte-240378-18.html
ab 133€
◦EuP Ready
◦Smart Switch
◦Dr. Debug
General
BIOS - 8Mb AMI BIOS
- AMI Legal BIOS
Graphics - n/a
- Realtek RTL8111DL
- 2 x PCI slots
- 1 x IR header
- 1 x TPM header
- CD in header
- Instant Boot
- Hybrid Booster:
- ASRock U-COP
- 1 x Reset Switch
- CPU Quiet Fan
Reviews:
Edit 19.01.2010:
und es gibt kaum mehr noch "Überlebende", die sich damit befassen wollen? ....
. Schraubenlänge
