[Sammelthread] Asus Rampage III Extreme R.o.G. (Intel X58)
Chrisch
Legende
Münsterland
[blockquote]
Spezifikationen Spezifikationen
CPU
  • Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor
  • Supports Intel® Dynamic Speed Technology
  • Supports 4.8GT/s & 6.4GT/s QuickPath Interconnection
Intel® chipset
  • Northbridge:
    - Intel® X58 Express chipset
  • Southbridge:
    - Intel® ICH10R
Memory
  • 6 x DIMM, Max. 24 GB, DDR3 2200(O.C.)/2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Non-ECC,Un-buffered Memory
    Triple channel memory architecture
    - Supports Intel® Extreme Memory Profile (XMP)
    - *Hyper DIMM support is subject to the physical characteristics of individual CPUs.
Expansion Slots
  • 4 x PCIe 2.0 x16 , support x16; x16/x16; x16/x8/x8 and x8/x8/x8/x8 configurations
  • 1 x PCIe x4
  • 1 x PCI 2.2
Multi-GPU Support
  • Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
    - * We recommend that you use full tower chassis for building a 3-Way SLI system.
Storage
  • Intel ICH10R controller
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
    - 1 xSATA 3.0 Gb/s port
  • Marvell® PCIe SATA 6Gb/s controller
    - 2 xSATA 6.0 Gb/s ports
Audio
  • 8-Channel High Definition Audio CODEC
    - Blu-ray audio layer Content Protection
    - Supports Jack-Detection, Multi-streaming, Front Panel Jack-Retasking
    - Supports 1 Optical S/PDIF out port at back I/O
LAN
  • Gigabit Intel® LAN
Internal I/O Connectors
  • 1 x IEEE 1394a connector
  • 1 x S/PDIF Out connector
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connectors
  • 1 x 24-pin ATX Power connector
  • 2 x 8-pin ATX 12V Power connectors
  • 1 x En/Dis-able Clr CMOS header
  • 1 x LN2 Mode Header
  • 1 x START (Power On) button
  • 1 x RESET button
  • 2 x EZ Plug connectors (4-pin Molex Power connectors)
  • 1 x OC Station header
  • 1 x RC Bluetooth header
  • 1 x Go Button
  • 1 x BIOS Switch button
  • 1 x ROG light connector
  • 1 x CD Audio in
  • 1 x Audio front panel
  • 1 x System panel connector
  • 1 x FAN1 Connector for optional fan-thermal module
Back Panel I/O Ports
  • 1 x PS/2 Keyboard port (purple)
  • 1 x Clr CMOS switch
  • 1 x Optical S/PDIF out port
  • 1 x External SATA port
  • 1 x LAN (RJ45) port
  • 1 x ROG Connect On/Off switch
  • 1 x RC Bluetooth switch
  • 2 x USB 3.0/2.0 ports (Blue)
  • 7 x USB 2.0/1.1 ports (1 port also for ROG Connect)
  • 8-channel Audio I/O
Special Features
  • CPU Level Up
  • MemOK!
  • Onboard Switches: Power / Reset / Clr CMOS (at rear)
  • ASUS MyLogo3
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • Q-Fan Plus
  • ROG BIOS Wallpaper
  • ASUS Q-Connector
  • ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
  • ASUS Q-Slot
  • ASUS Q-DIMM
Accessories
  • 1 x ROG Connect cable
  • 1 x ProbeIt cable set
  • 1 x 3-Way SLI Bridge
  • 1 x SLI Cable
  • 1 x CrossFire Cable
  • 1 x 2 in 1 ASUS Q-Connector Kit
  • 3 x 2-in-1 SATA signal cables
  • 1 x 2-in-1 SATA 6G cables
  • 1 x 2-port USB2.0 + ESATA module
  • 1 x I/O Shield
  • 1 x Thermal Sensor Cable Pack
  • 1 x Cable Ties Pack
  • 1 x ROG theme label
  • 1 x 12-in-1 ROG Cable Label
  • 1 x Optional Fan-Thermal Module
  • 1 x Bluetooth Module Accessory Card
    - Bluetooth V2.0/V2.1+EDR
    - RC Bluetooth On/Off Switch
BilderBilder
Das Mainboard
Die Verpackung und das Zubehör
(Quelle: AwardFabrik.de)
Das BiosDas Bios
DownloadsDownloads
Bios Downloads
  • Bios 0402
    - First release Bios
  • Bios 0531
    - RAM-Performance verbessert
    - Besseres OC-Verhalten unter Kälte
  • Bios 0602
    - FIX SATA 6G device may experience S3 resume failure when using Intel i7 965 CPU
  • Bios 0704
    - Added additional memory options (tRFC settings) to improve overclocking
    - Enable support for "Subzero Booster" for improved LN2 overclocking capabilities
    - Enabled additional CPU support for CPU Level Up functionality
    - Improved 3D performance at stock settings
Sonstige Downloads
[/blockquote]
Sehr schönes Board und mit viel Power. Freu mich auf erste Tests...
Na dann mal warten bis es bei den ersten Onlineshops eintrudelt. Bestellt ist es schon :-)
Bin wirklich gespannt, fand das RIIE schon spitze.
Endlich das passende Mainboard zum HD2 Handy :fresse:
Wirklich sehr nette Features,OC Station liegt hier schon und wartet darauf connectet zu werden.
Danke Chrisch für den Thread :)
War mir irgendwie klar, dass du den Thread machst :fresse:
wer einmal damit anfängt muss das auch Fortführen ;)
Was meint ihr? Passt der scythe mugen 2 da drauf :-)
Wo kauft ihr das Board?
Bei AN gibt es das Board momentan für 319 + Versand.
Darf ich das verlinken?
Jemand schon einen besseren Preis gefunden?
stehe auch gerade vor dem kauf einem neuen boards
entweder das RIII oder das Classified 760
was wäre da die bessere Wahl?
ach und hat das RIII wirklich nen Intel Lan Controller?
dann glaub ich ist meine Entscheidung schon gefallen :)
jo wird ja überall so ausgewiesen mit dem Intel Lancontroller.
Blöde Frage
Was ist den Intel LAN bzw. wo liegt der Unterschied zu LAN?
3x2 GB @1052 MHZ CL7 :bigok: Hatte auf dem RIIE immer so meine Probleme mit CL7, aber mit dem RIIIE macht das richtig Laune :d
Mehr Ergebnisse findet ihr hier ;)
Hi
bitte schön für was ein Asus Rampage III Extreme???
wegen dem neuen SATA und USB 3.0 kauf ich mir lieber die Asus U3S6 Karte und ich habe die neuen Schnittstellen auch.
ich wechsel erst wieder das board beim x68.
das board ist ein reiner Werbe tral lallalalal
Grüße
Rocci75
Wenn man keine Ahnung hat, dann..... ;)
Das Board ist für Extreme-OC gedacht und da macht es sich sehr gut. Das geht nicht nur um USB 3.0 etc. Schau dir mal die Links an, zu der Ergebnissen, die damit erreicht wurden. Dann sprechen wir uns wieder.
Und wenn du es Werbe-tralalala nennst, was sind dann das:
Gigabyte UD9
EVGA X58 SLI Classified 4-Way
MSI XPower
etc...
Sind alles Boards nach den selben Prinzip. :)
Ich würde lieber mal so sagen. Das wir erst beurteilen wenn das Board erhältlich ist.
Selbst du weist nicht wie das Board sich bei einem Privat User verhält
Doch, weiß ich. :)
Siehe Ergebnisse von SoF.
sorry, aber was soll das bitte für ein ergebnis sein?
diese werte in superpi erreiche ich auf meinem DFi mit weitaus weniger takt???
soll der screnn nur zeigen was an takt drin ist - oder hab ich da was falsch verstanden?
Testest du auch unter Win7? Ist kein SuperPi-Windows, ich hab da nur den maximalen RAM-Takt getestet, die Zeit war mir egal. Wenn ich auf Zeit gehe, dann sicher nicht mit Win7 :fresse:
Was erwartest du denn im 1m für Unterschiede??? 50MHZ sind maximal 50ms wenn überhaupt...da bist du mit 10.7X noch gute 400ms weg, das passt schon o_O
Hier ein Run mit CL7 und 4 GHZ...
