Jetzt jajetzt habe ich die zurückgeschickt und wollte von euch wissen ob man das sieht das es mein fehler war?
guten morgen zusammen,
habe jetzt auch seit 3 tage meine erste wakü und hätte gerne gewußt welche frequenz in der pumpe eingestellt werden muß ?
Where do you want to order? Where are you from?
The inlet and outlet adapters for the Aquastream XT are different. You need something like this: http://www.a-c-shop.de/Adaptersatz-fuer-1046-und-aquastream-auf-G1-4-ohne-Anschluesse-nur-Adapter
All G1/4" fittings should fit on these (or similar) adapters.
I wouldn't order the Ultra Pure Water. I would just use distilled water plus corrosion blocker.
The Heatkiller 3.0 (full copper, LT or LC) would be better than the NexXxoS.
Edit: Maybe Perfect Seal fittings and Danger Den 16/10mm tube are an option for you. Very good combination.
If you have friends, relatives etc. in Germany you can get a 10% discount at www.a-c-shop.de. The owner is getting married.
But back to your questions.
Imho the ultra pure water is expensive and not really necessary.
16/10 compression fittings are expensive and many/most use the perfect seal fittings and danger den 16/10 without hose clamps.
The reason why a lot of people like the 16/10 DD is, well just look at the pictures: http://www.dexgo.com/index.php?site=artikel/view.php&id=327&rubrik=Hardware&seite=5
But 13/10 and compression fittings are fine. A matter of taste.
On the HK 3.0 you can use fittings with a max. diameter of ~21mm afaik. They increased the spacing (around Januaray) because the 16/10 feser compression fittings didn't fit. So you shouldn't have any trouble with the 13/10 fittings.
If you like 13/10 and compression fittings, why not? Masterkleer 12,x/9,x (non UV) and the various feser tubes are fine.
for the quick reply.@Sniper1010: Why don't you place the whole order directly in a shop located in Holland like: http://www.highflow.nl/ I think, it's a good shop - it has lots of watercooling-stuff - and Freddy is very friendly.
kann ich das FLOW kabel vom aquaero (also fr den Durchfluss) mit nem normalen (!) Lüfterverlängerungskabel verlängern? oder gibt das irgendwie andere signale?
