Hier der stanni UD3P / R Test um die Güte der MCH zu checken... Sollte die Kiste so nicht laufen, ist die MCH von schlechter Güte
Nur so als Tip von mir...
GA EP45T-UD3P Bios F5
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................:
8
Fine CPU Clock Ratio...................: 0.0
CPU Frequency ............................: XXXX (
450 x 8,0)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control................: Enabled
CPU Host Frequency (Mhz) ...........:
450
PCI Express Frequency (Mhz) ........:
100
C.I.A. 2...........................................: Disabled
Advanced Clock Control
CPU Clock Drive...........................:
900mv
PCI Express Clock Drive................:
800mv
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)...................:
0ps
DRAM Performance Control
Performance Enhance......................:
Turbo
MCH Frequency Latch....................:
333
System Memory Multiplier ..............:
2.0B oder 2.4B (muss unter FSB 450 laufen mit max. 1.30VMCH)
Memory Frequency (Mhz) ..............: xxxxxxxxxxxxxxxx
DRAM Timing Selectable ...............: Manual
Standard Timing Control
CAS Latency Time.........................: 5
tRCD .............................................: 5
tRP............................................... ..: 5
tRAS.............................................. .: 15
Advanced Timing Control [Press enter]
tRRD.............................................. .: [Auto]
tWTR.............................................. : [Auto]
tWR............................................... .: [Auto]
tRFC.............................................. ..: [Auto}
tRTP.............................................. ...: [Auto]
Command Rate (CMD) ....................: 0 [Auto]
Channel A
Channel A Timings Settings
Static tRead Value..............................: Auto
DDR Write Training............................Auto
REST AUTO
Channel B
Channel B Timings Settings
DDR Write Training............................Disable
REST AUTO
Motherboard Voltage Control
Load-Line Calibration.........................:
Enabled halte ich für Ok, ab 1.40V werden die Spitzen sehr gefährlich...
CPU Vcore...............1.30000V..........:
musst du wissen!
CPU Termination.........1.200V............:
Auto wird später langsam gesenkt..
CPU PLL.................1.500V...............:
CPU Reference...........0.760V............: Auto
MCH/ICH
MCH Core................1.100V.............:
1.20V wenn der Rechner mit der Con. nicht Bootet bzw. nach dem Neustart wieder default Bootet, bitte versuche dann 1.30V MCH und Teiler 2.40B, sollte das nicht gehen ist deine MCH von sehr schlechter Güte und ich kann dir nur raten gebe das Board lieber zurück! Es muss 8x450 / 2.00B mit 1.20MCH booten, alles andere ist nicht geeignet und hat den MCH Bug was heisst das die MCH zwischen 1.20V und 1.40V nicht regelbar ist ohne Bootloop oder load des Backup-bios...
MCH Reference...........0.760V..........:
Auto
MCH/DRAM Reference......900........:
Auto oder Standard belassen!
ICH I/O.................1.500V...............: Normal
ICH Core................1.100V..............: Normal
DRAM
DRAM Voltage............1.500V..........:
was dein Ram halt braucht...
DRAM Termination........0.750V.......:
Auto
Channel A Address Vref..0.750V.......:
Auto
Channel B Address Vref..0,750V.......:
Auto
Advanced Settings
Limit CPUID Max. to 3...................: Disabled
No-Execute Memory Protect...........: Enabled
CPU Enhanced Halt (C1E)..............: Disabled
C2/C2E State Support....................: Disabled
x C4/C4E State Support.................: Disabled
CPU Thermal Monitor 2(TM..........: Enabled
CPU EIST Function......................... Disabled
Virtualization Technology.................: Disabled
Ich habe meine 24/7 settings jetzt...
