Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
Chipsatz
• 8M bit flash ROM
HyperTransport™
Memory
• DIMM slots: 4
• 1 x IR connector
• 1 x COM connector
Erweiterungs- Slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
• 1 x HDMI port
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
BIOS
Bundle Software
Besonderheiten
Links und Downloads
Passt nicht
Passt
mal schnell zu installieren und das so mit dem Flash durchziehen und dann kannste es ja wieder runterwerfen. Nen anderen Plan hätte ich jetzt auch nicht, leider.
