Foxconn DigitaLife ELA
Verfügbar ab: Sofort
Preis: ca. 250 Euro
	Wichtige Links:
Treiber:
Bios:
Manual:
FAQ:
Spezifikationen:
Prozessor:
Intel® Core™2 Quad
Core™2 Extreme
Core™2 Duo
Pentium® Dual-Core
Pentium® Dual-Core prozessors
Socket T (LGA775)
Chipsatz:
Eaglelake Intel® P45 + ICH10R
Front Side Bus:
1600(oc**) 1333/1066/800 MHz (FSB)
Memory:
Dual channel DDR2
1066(oc**)/800/667
4 DIMMs, Max. 8GB
Erweiterugns-Slots:
3* PCIe2.0 x16, 2* PCIe2.0 x1, 2* PCI
Serial ATA(SATA)/RAID:
6* SATAII + 2* eSATA w / RAID 0, 1, 10, 5
Audio:
7.1 channel HDA by Realtek® ALC888SDD, with DTS CONNECT™ and Dolby Digital Live™ certifications
Back Panel I/O Ports:
1 x PS/2 mouse port
1 x S/PDIF Coaxial Out port
1 x S/PDIF Fiber Out port
2 x IEEE1394a ports (with 1* mini IEEE1394a)
1 x Audio jack supports 6 jacks
2 x eSATA ports
6 x USB 2.0 ports
1 x RJ45 LAN port
Internal I/O Connectors:
1 x ATX 24-Pin power connector
1 x 8-pin ATX 12V power connector
1 x 4-pin ATX 12V power connector
2 x 4-pin CPU / System fan connectors
3 x 3-pin fan power connectors
3 x Onboard On/Off/CMOS Reset buttons
1 x Front Panel connector
1 x Floppy connector
1 x CD-in connector
1 x IrDA header
3 x USB 2.0 connectors support additional 6 ports
3 x SATAII connectors
1 x on-board power_LED
1 x IEEE1394a header
1 x Intrusion Alarm haeder
1 x S/PDIF Out header
1 x IDE connector
1 x Front Audio header
1 x Buzzer
BIOS Features:
8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Special Features: ** Achieved by overclocking
* 3* PCIe2.0 x16 with integrated IDT PCIe switch provides ATI CrossFireX™ support with 3 slots x8 bandwidth
* 8 phase Digital PWM provides more robust power delivery
* DTS CONNECT™ and Dolby Digital Live™ certified audio
* Dual Digital Audio function enables separation of 2 different sound sources from your PC, and also provides 2 digital audio outputs via S/PDIF Coaxial and Fiber
* 100% SOLID Capacitor design and Ferrite Choke power delivery ensure a stable basis for overclocking and increased reliability
Lieferumfang:
Im Lieferumfang findet man leider nur folgendes:
4 x SATA Kabel
4 x SATA Strom Kabel
1 x Bedienungsanleitung
1 x IDE Kabel
1 x Floppy Kabel
1 x RAID-Diskette
1 x Treiber CD
1 x USB-Slot Blende
Bei einem Mainboard für Rund 250 Euro könnte der Umfang ein klein wenig größer Ausfallen. So hätten sechs SATA Kabel sicherlich nicht geschadet. Der ein oder andere hätte sich bestimmt auch über einen kleinen Aufkleber gefreut.
Layout:
Das Board verfügt über ein schönes rotes PCB welches sich vor allem in Verbindung mit ATI Karten gut macht. Die Kühler der Southbridge und der des CrossfireX Chipsatzes werden passiv mit einem kleinen Kühlkörper auf Temperatur gehalten. Beide kühler sind flach genug um den großen Grafikkarten nicht im Weg zu stehen.
Die Northbridge wird mit einem etwas größeren Kühlkörper ebenfalls passiv gekühlt. Die Größe des Kühlers ist allerdings gerade noch ok um auch Kühler wie den Scythe Mugen bzw. Infintiy montieren zu können.
Zwischen dem ersten und zweiten PCI-E 16x Steckplatz sitzen zwei PCI-E 1x Steckplätze. Beim Einsatz von Dual-Slot Grafikkarten wird der obere dieser beiden Anschlüsse verdeckt.
Unter dem zweiten PCI-E Steckplatz befindet sich der erste PCI Slot auch dieser wird von einer Dual-Slot Karte verdeckt. Als nächstes kommt der dritte PCI-E Steckplatz unter dem sich noch mals ein PCI Steckplatz befindet. Wer Also Tripple-Crossfire mit drei Einzelkarten betreiben möchte, welche über eine Dual-Slot Kühllösung verfügen kann lediglich eine weitere Karte anschließen. Diese muss allerdings über einen PCI-E 1x Stecker verfügen.
Eine gute Idee von Foxconn – Aktive bzw. belegte Steckplätze werden mit einer blau leuchtenden LED dargestellt.
Alle zusätzlichen Stecker wie IDE, SATA usw. sitzen gewinkelt am äußersten Rand des Boards. So ist es ohne große Mühen möglich ein ordentliches Kabelmanagement einzuhalten.
BIOS:
Foxconn setzt beim ELA auf ein AMI Bios. Neben den bekannten Bios Einstellungen wie SATA und Co. bietet das Bios ein Gladiator Bios in dem die Overclocker zu hause sein werden. Hier einige Werte die eingestellt werden können:
Vcore:
Das besondere an der Vcore ist, dass sich diese aus zwei Werten berechnet. Einmal gibt es die Vaule Vcore und die Multiplikator Spannung.
Value – 1,2V – 1,6V -> 6,25mV pro Schritt – 65 Schritte möglich
Multi – 1,0V – 1,256 -> 38mV pro Schritt – 8 Schritte möglich
So erreicht man ein Maximum von 2,0V wie sich die Spannung optimal verhält werden wir noch klären müssen.
Ram: 1,6V – 2,99V -> 25 Schritte möglich
V-STR: 1,38V – 1,678V -> 37mV pro Schritt
V-MCH: 1,02V – 1,27V -> 28mV pro Schritt
V-FSB: 1,2V – 1,67V -> 80mV pro Schritt
CPU-Clock (FSB): 1MHz – 800MHz -> 1MHz pro Schritt
Ram-Teiler
800MHz CPU: 1/2.4 & 1/4.0
1066MHz CPU 1/2.4 & 1/3.0
1333MHz CPU 1/2.0 & 1/2.4
Bei einer verpatzen Einstellung muss man nicht gleich die Flinte ins Korn werfen. Foxconn hat auf dem Mainboard drei Taster angebracht, mit denen man das Board Ein- und Ausschalten kann bzw. einen CMOS Clear durchführen kann.
Bei den ersten Versuchen reichte es sogar einfach den Netzstecker zu ziehen, kurze Zeit zu warten um dann wieder loslegen zu können.
Des weitern gibt es zwei "7-Segement" Anzeigen auf dem Board welche immer den aktuellen Status wiedergeben. So ist zum Beispiel bei "AA" alles ok. Erscheint "F1" auf der Anzeige befindet sich ein Problem am Speicher.
Das Bios lässt sich mittels Software automatisch updaten.
Software:<a name="Software:"></a>
Auf der Mitgelieferten CD befinden sich folgende Programme und Treiber:
Treiber:
- Audio (Realtek) – Vista und XP
- Chipsatz (Intel) – Vista und XP
- LAN (Realtek) . Keine Version angegeben
- Raid Treiber (Zusätzlich auf Diskette vorhanden)
Software:
- Adobe Reader
- DirectX 9c
- FoxDMI
- FoxLogo
- Foxone
- LiveUpdate
- Norton
Mit FoxDMI lassen sich sämtliche Informationen über das Board und das System auslesen.
Mit FoxLogo lässt sich das Boot-Bild verändern, zum Test sind direkt fünf Test-Bilder im Programm vorhanden. Es können alle *.BMP und *.JPG Dateien eingebunden werden. Ist das Bild zu groß kann auch der Anzeige-Bereich gewählt werden.
Mit Foxone kann in der Windowsoberfläche übertaktet und angepasst werden ohne lästige Neustarts durchführen zu müssen. Stellt man einen zu hohen wert ein, stellt sich das System automatisch zurück und verhindert so einen "freeze". Getestet wurden die Einstellungen bei FSB, Spannung und RAM. Die gewählten Einstellungen werden nach kurzer Wartezeit alle gut übernommen.
Overclocking:
Coming Soon
  is jetzt im Startpost.
		 kann jemand testen ob es bei Crossfire volle (X16) anbindung hat? Lt. HP nicht , aber 2 reviews meinen das das Board bei 2 Karten dank " integrated IDT PCIe switch " volle Anbindung hat und bei 3 Karten X8
